Our Community is 705,000 Strong. Join Us.
Chevrolet
Cavalier
> Cavalier Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
how to rebuild 88 cavalier Z24 tranmission
97 Z24 Issues Again, Ffs...........................
ABS light
Gas tank pressure buildup
P0440: EVAP small leak/no flow condition
2.3 Quad Four in 95 ragtop engine racket.
89 with 2.8 and auto trans
Grinding noise when i turn right only
Door Lock Problem
Lowering a 97 cavalier Z24 with Tokico struts & springs - Need Help for strut mounts
RPMs lower than normal; car dying.
Popped Serpentine caught code P0420 2.4L DOHC 98
95 Chevy cavalier
check eng / lost 4th gear on highway?
93 cavalier z24 wont start
96 Cavalier, what's behind the front passenger side bumper?
1998 2.2 Can not find the second coolant bleeder screw?
01 Chevy Cavalier 2.2 that bucks
fuel pump issues
04 Cavalier Daylight Running Lights
Arggghhhh!!
93 2.2 ignition control module questions
99 Sunfire GT...hard shifting
Lost need help
car broke down. need some help. puhlease
99 oil pump ????
Missing and no power on accelleration
egr valve problem
airbag light help?
98 cvalier rear brakes SHUDDER!!!!
Low Speed Vibration
2002 brakes need attention every three weeks?
Headlight, windshield wiper and door lock problem - 2001 sunfire GT
Won't start for exactly ten minutes
Driver door shakes at highway speeds.
knocking noise in the lower end of a 2.2 l
O2 Sensor Help
warning chime
2001 2.2l #1 cylinder plug is melted down! Please help! Timing?!?
Idle air control
Crismas Headlights....
Overheating No Matter What I Do!
Is my engine on the way out?
01 Cavalier window problems
NO HEADLIGHTS....on a 98 Cav
Sunroof problems
is my clutch messed up?
Po 507
Drl And Park Lights Only Working!!
2004 Cavalier Intermittent Airbag Light
98 Chevy Cavalier that surges
96 cavalier no power when accelerating
Replace Cruise Control Module 2002 Cavalier
1994 cavalier shakes
96 cavalier ignition problem
Starter Motor Bolt Torque
Natural Gas
Abs
Shaking Omg Why, Sick Of It!!!!!!!!
Engine Jumping HARD etc.
99 Cavalier- no brake lights, no turn signals
89 cavalier
97 z24 whine in 1st and 2nd
p1870 code for check engine
'97 2.2 stalling
Tach wont work??
Cavalier Z24 Engine Cuestions...
'96 A/C issue
Got a brand new 2.2 motor, need some answers!
What kind of fluid is this?
Engine Trouble
2003 Cavalier code P0420
2003 Cavalier Check Engine Light
Trunk wont stay closed
93 Cavalier RS fast idle
HID Lighting problems ><
02 Cavalier Trac Off light then died
'97 Cav computer reset
02' Sunfire high rpm's in neutral??
no spark no matter what
Warning Lights Keep Goin On and off
no power
gas shooting from cylinders on 95 cavalier
02 Cavalier
fan not coming on
no low beam
'99 Key won't turn to start position
Manual transmission stuck in 3rd gear
96 cavalier brakes - HELP
window motor ..
1998 Sunfire has a knocking sound in the tire
'93 RS Problem
spark plug location...
97 Cav P0440
New Problem
2001 back seat removal help NEEDED
Spark Plug Wires
Cylinder flooding
Help 1992 2.2 Cavalier
Cavalier Plastic Bumper?
95 cav tcc solenoid
Help...98 Cav Turn signals/dome light/RR Defogger all working/not working..??
Driver Window rolls down (powered), stuck.
1985 Cavalier won't start after tune up
'97 Cav 2.2 oil pan
94 cavalier z24
97 Cavalier DRL
Red back lighting on odometer
2003 Sunfire foglights
1991 Cavalier Transmission Problem Please Help
98 cavalier electrical issues?
96 Cavalier instrument cluster issue.
95 Cavaliar reoccuring headgasket leak
Help....My engine is crazy
Need some guidance on ignition lock cylinder
2001 sunfire firing problems
car cranks no spark
ATF - motor oil
Plug wires
91 Cav. had engine catch fire
Please help engine caght fire
bad lower control arm bushings?
f**ked up ignition
96 cavalier z24
pontiac sunfire gt 2001 bcm question?
Transmission problem
Lower Engine Mount
1996 Cavalier stalling at stops
93 cavalier strut bolt
97 cavalier not starting
97 clutch problems
97 clutch problems
2003 Cavalier Stalling out when stopping.
01 cavalier overheating
disablling the theft system? can it be done ?
theft system mess.
2001 Sunfire Gt 2.4l Engine Diagnosis Help
cooling system troubles
2003 Cavalier Handbrake adjustment bolt?
wheel bearing
help me out please
starting problem and light problems
Plug wires arcing
Horn and Dome light dont work
97 cavalier, valves clatter, power loss, engine chugging
cavalier engine?!
04 CAVALIER Steering, pops when turning right
brakes locking up
need help on swaping a 2.8 into a 3.1
brake problems
help: 99' chevy won't start
2002 Cavilier AC clicking problems.
'97 Cav running rough - stalling
98 cavalier cranks but wont start
1994 cavalier-key is stuck
1995 Cavalier ABS need some guidance
Radiator fan won't kick in
'89 Cavalier Starter
Headlight Problems...Any Ideas?
please help. im still learning about cars
96 Cavalier Passenger Side Headlamps Dim
speedo gone crazy
Air Charge Temprature Sensor
head bolt set no washers???????
2001 cavalier
2002 Cavalier electrical problem
i could really use some help.
'97 sunfire sparking/rough idle/stalling
A/C control not working/running rich
96 2.2 cavalier, alarm/remote start
What causes a Crankshaft Sensor to go bad?
Failed Emissions. Little help please
2001 Cavalier is there a Fan Relay switch?
Anyone Clean The EGR Passages Before?
Sunfire GT 98 2.4L jerking, need help !
'96b sunfire GT
oil light funky
99 Z24 Cavalier Probs...
car running on it's on
horn ignition
i need help my 97 cav is running bad
Damaged Exhaust Pipe
Dim Headlights, Check Engine Light On
96 cavalier 2.2 weird no start problem
96 cavalier-no start/theft light still on?
left headlight
cav accelerates after releasing gas!
damn cavis
2004 Cavalier Shaking
2004 Cavalier Doesn't Like Gas
What The Hell?!!?!?!?
2003 Chevy Cavalier Error Codes
odd stall out
96 Cavalier, problem with stalling, specific to warmer weather
Help with oil leak please
O2 sensor fix
no power steering!!!
2000 Sunfire service engine light come on.
Slight Auto-Transmission Leak
ECM problem - need help
Is it the gas
help with p0118 and p0335
Cavalier Transmission problem
2002 Chevrolet Cavalier Z24 oil leak
Engine Swap
Engine Swap
dark spark plugs
Re-doing headliner?
whistleing sound or whining sounds
engin knocking last night but now its not
98 Sunfire GT only has running lights!
Mystery sound
Noisy lifter?
Cavalier Evaporator
2002 Suifire P0300 misfire
03 Cavalier passenger side cv shaft problems
2001 cavalier wont start
'93 Cavalier with a sudden onset of running problems
Need help for ETS off light on in dash
Lower Control arm/Castle Nut Problem
'97 sunfire crank but no start
Diagram for fuse box on a 93 Cavalier
Assistance Needed (Heating)
99 Cavailer shakes and idles rough
Fogging Problem
Problems In The Brakes..help!!
93 2.2 with some problems
my pcm wiring harness got cut and corroded.
96 cavalier no start/theft light on
97 chevy cavalier transmission
Cavalier 2002 how to access headlamp socket?
Front end wobble
Helicoil failure
2004 Sunfire stumbles while throttling
Dash Cluster-Instrument panel -Guages
96 cavalier wiper issues...can't drive while squeegeeing..thanks
help adding subs to a monsoon system
2004 Cavalier Clicking from under dash
2002 Cavalier No Start/Run
Hard start stumble at idle
coolant leak
Cpmputer replacement.
Radio Swap
97 cavalier 2.2L tranny fluid leak
Removing the Catalytic Converter...
2004 Cavalier Fuel and RPM Gauges problem
Bad Altenator? NEED HELP!!!!
Theft System,can't get key out.
rear defrost problem
Automotive Network, Inc., Copyright ©2013
