Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Still with the poping noise passenger side
89 Z24 rpm too high @60MPH
Hissing When Brake Applied
2000 sunfire won,t start
Sun roof trouble
Replaced fuel pump, still no fuel ??
1993 Chevy Cavalier Turn Signals Don't work.
sorta rev limiter
Engine overheated and wont start at all
Finding the elusive 'back-up switch' on a manual transmission
1999 2.2 5speed Starting Issue!!
Car is running really, really, really rich.
how to replace the wheelbearing on 2000 chevrolet cavalier
96 cavalier stalled, will only kind-of start
Poor gas mileage
03 Cavalier temp & Fuel Gauges Way out Of Wack
2000 chev z-24 blowing fuses
lost head light to a deer. Now i can not stop lights from lashing.
mid 90s ECU wiring diagram
96 ECU Conversion
95 Cavalier
cooling fan problems 98 cavalier
90 cavalier won't start
stalls in gear
1998 sunfire gt 2.4liter
Valve cover gasket
Light alarm
Factory Alarm
Oil change ecotec 2.2
97 cavalier misfire, engine lite blink
03 Cavalier oil in air intake
'98 cavy wouldn't start after dying battery
97 Sunfire stalled and won't start
99 Z24 power windows
trunk latch
Door Panels
2200 head gasket
2000 z24 odometer problem
Tranny Swaps for a 2000 Cavalier
Z-24 air conditioning problem
Quick EVAP question
97 Sunfire Coil Problem?
2000 Z24 check engine light
Engine probs, 92 cav
Ugh code P0108.
2001 Sunfire Won't start
93 Sputtering and backfiring
Sunfire stuck in first gear
2001 Z24 won't start in mornings.
windows and convertible problems
Coolant Leak
2000 z24 front left noise
Aftermarket wheel on, but how do I HORN?
03 Sunfire Rear defrost don't work
LED Indicator
Engine Running Problem 95 2.2L Coupe
Code P0440
Speed Sensor-'98 Sunfire GT
Radio not shutting off when I open my door
1997 Z24 Check Engine Light
ignition or passkey
Fuel problem
my odometer/speedometer don't work
1995 Sunfire: Rough Idle & Makes a Popping Noise
03 Cavalier Won't Run!
2005 Chevy Cavalier Check Engine Light
2000 cavalier fan speeds`
Where is Fuse Box 89 Cavy???
Engine won't turover
1995 Cavalier air conditioning
looking for part name
98 Cavalier Rattles
under hood sensors
98 Cav, Rattle
radio problems
2001 cav. Temperature problem HELP!
Engine shudders when cruising/accelerating
cavalier heats up slowly when stopped
03 cavalier died while running
Stoopid Fuel Filter QD!?!?
O2 Sensor question
Gauge Cluster Help
"01 Sunfire Trans. and Speedometer problems
2.0 stalling
Cooling Fan 1 Issue
Where is DRL relay on 99 Cavalier?
Gauge reads over heating, but radiator is not hot
fuel injector
clearing pcm
How to correct computer if smaller sidewall tires are put on?
97 cavalier cooling system?
Tick.Tick.Tick. Where?
'92 cav overheating... then won't start for a period of time
stumped
Back Brakes grinding and squeaking
need help asap with 97 cavalier
Bosch 440cc Green Tops injectors...will they work?
2003 Cavalier power window problem, help
Sunfire 97 - stalling problem. Help!
99 caviler wiring problems
Dog chewed up my air filter
running on 3 sometines 2 cilinders
How screwed am I?
'94 cavalier, replaced ,rockers,springs,rods head, gasket, etc..
2001 Sunfire-no range on remote
lossing freon
AC soaking my carpet. Help!
Squeaking/knocking sound in front end
Head Gasket, Rings, & Mains?
O2 sensor out, now car won't start..??
replacing bent rod
Moisture in the Oil?
02 cavalier no gauges
Cavalier Shuts Off While Driving
Lots of Moisture in Halo Lights, whats wrong?
98 Cavalier knocking in driver front wheel
95 Sunfire PRNDL indicator not working
Did I Blow It Up???
cooling fan not working 97 cav 2.2
Air/ Fuel problem
projector headlight problem?
98 Cavalier Horn Location
New Car With Just a Few Problems
99 Cav, no low beam headlights
loss of power
transaxle seals
slow start
98 Sunfire Just Won't Start. HELP!!!
engine coolant light!!! HELP!!
96 lier wont keep a charge.
92 Cavalier Radiator/Overheat Problems? Help!
asap please
88 cavalier running rough on start up
uhh explosion may occur??!!
02 Chevy Cavalier won't start
2.2 stopped engine will turn but wont start...
99 2.2 very hard to start
2003 Cavalier- engine stalling at idle
Please Help
Installed new aftermarket headlight bulbs, Lost DRLs
Z24 drinking gas like alcohol?
Code keeps coming up...
97 Cav Unknown Problem
2200 serp belt
98 z24 AC Compressor question
Replacing O-Ring Seals on Compressor? Possible?
Please Help power widow problem!!
2002 Cav Odometer reads "error"......
ETS off light and flashing engine light
'92 2.2L 3Speed starts then dies....
2003 Cavalier fuel problems
check engine light on 94 cavalier
96 sunfire GT 2.4 L engine runs rough in hot, humid weather
97 Sunfire 2.4L A/C
Need help on cooling fan
Please help on cooling fan
2000 Pontiac Sunfire's brake lights
'96 Sunfire GT 2.4L Engine doesnt like hot, hunid weather
98' sunfire 2.2 starts but dies--ECU problem?
2000 Pontiac Sunfire Won't crank!
20002 Cavilier guages not working
I Hate Newer Cars !!! Help
changing lock cyclinder, will passlock be an issue?
96 Cavalier starter-alternator
2.4 question
1995 Cavalier rough running condition
2001 cavalier 2.2
brake sensitvity
how to get codes
97 sunfire 2.2L
Please help Sunfire owner
Starting problem
94 Cavalier Ground Problems--please help
Code P0113 Intake Air Temp Circuit Hi Input
problem with 2002 cavalier
Fan doesn't work on my '99 Cavalier
99 cavalier z24 odometer is all scrambled
95 cav 2.2 intermittent spark
No Belt Tensioner 97 Cavy
Sunfire 200 Dashboard and Shifter
need to replace front brake pads on 2001 cavalier need help
03 cavalier gauge problems
97 AC Problems!! Need Some Help!!
2001 cavalier radiator fan fuse blows
engine cuts out while cruzing
89 cavalier runs rough when hot
2005 Pontiac Sunfire
WTF Rear View Mirror???
97 cavalier choking up while accelerating
Sunfire Runs For 2-3 Minutes, Then Dies.
Brakes problem sunfire /96 needs help !
01 Cavalier - Both Hi-Beam Headlights out
2001 Chevy Cavalier Z24 with 2.4 liter engine-Can't check codes!
Check Engine Light-01 Z24 Cavalier-Can't read codes!
cooling fan problem
being blamed need help
ECM fuse blown on 1992 Cavalier Z-24
easy spark
why would this keep happening?
New Cavalier owner-1st problem within a week
Vibrations
Changing the Fuel Filter?
Brake lights not working.
rrrrrrrrrr on my cavy lol.
98 Z24 Cavalier won't shift out of 1st! HELP
How do I change my a\c relay switch on my 2000 cavalier?
where is the horn wire at????
96 Sunfire Won't Start & Dash Buzzing
Grinding sound on 91 cavalier
Bench Testing Starter/Solenoid Assembly
2.2L timing cover. Good gawd.
96 with possible electrical problems
'89 Z24 Stalls Out
Caliper mounting bolts don't go all the way back in?
Humming sound from under car at certain speed only
97 cavalier 5 error code(s)
missing...
My 95 Sunfire's lights stay on and raadio shuts off while driving
trouble code B 1013
97 with 2.2 stalling and rough idle
Compressor problem
Fuel system issues??
Anyone know where is the oil filter in a 2005 Pontiac Sunfire?
Rear table bushing... squeak..
my 02 gagt just cuts off
New guy with lots of probs..
Z24 Starting Problem
Wierd Metallic Popping Noise
Cooling Fan
99SunfireStarter
Cavalier problem: hard start & hesitation
MISFIRE with new plugs and wires
2001 Cavalier Z24 Knock Sensor Location?
97 Z24 cav help please
A Weird Ticking sound From front end
98 Sunfire GT water pump is out
Fast idle problem with 2000 Z24
2000 Cavelier Coolant Overflow
02 Cavalier jerks/stutters between 40 and 60 mph
'97 Cavalier strut prob?
96 Cavalier Oil Pan Sensor
02 cav brake problem
My..z24 Engine Is Going Need In Fo Please
90 z24 jerks sometimes
Big problem, long story. Please read.
Smell gas
cluster and needles issues
1996 Pontiac Sunfire Gt 2.4 Crankshaft Position Sensor
Web
AF
