Our Community is 705,000 Strong. Join Us.
View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18
  1. 2001 Cavalier has a vibration/thunk from the rear ONLY while making right turns.
  2. Gauge Problems
  3. Cavalier Cluster! HELP
  4. Removing Catalitic Convertor 02 Cavalier
  5. 96 Cavalier 2.4L trans removal
  6. injector flush
  7. oIL LEAK
  8. 97 cavalier shifter cable
  9. car rpm continue to rise after shifting
  10. CV 'inner' Change out 2002 Sunfire
  11. 2002 Chevrolet Cavalier burning smell in car
  12. Radiator fan
  13. 96 cavailier timing issue
  14. Fuel fittings
  15. starts, runs for a few seconds
  16. 04 Cavalier problem
  17. fuse
  18. how do you remove the spring loaded belt tensioner
  19. Oil leak
  20. OBD II style connector on an OBD I vechile
  21. Replaced Spark Plugs and Wires
  22. front suspension help
  23. 96 Sunfire axle
  24. 1999 Cavalier back doors will not open, not power locks
  25. engine swap troble 97 into a 96 help plz help
  26. 95 2.2ohv stalling when eng warms up
  27. Operating temperature?
  28. Operating temperature?
  29. car shaking, wheel locks, car in neutral
  30. 2000 cavalier air bag problem
  31. 98 cavalier headlights
  32. 98 chevy cavalier won't start after accident
  33. Power Steering Return Hose
  34. 99 Grand AM steering problem
  35. 95 Pontiac 2.2 L OHV engine
  36. Need help/opinions on coolant flush
  37. 96 Sunfire no start when hot
  38. 90 2.2 tbi
  39. Help!!
  40. Keyless Remote Programing
  41. Need some advice about lots!
  42. auto transmission stuck in low
  43. 94 Chevy Cavalier Z24 3.1 Timing chain issues
  44. Starter won't disengage
  45. Car won't start
  46. Fuel Pump or Filter?
  47. rubbing sound at front wheel
  48. Smoking under the hood
  49. 2003 sunfire camshaft sensor
  50. Ignition Key Switch ?
  51. 99 CAVALIER starter
  52. No Power At The OBD-II Connector
  53. Check engine light and error code
  54. 1989 cav grrrrrr
  55. Help! Knocking noise
  56. Grinding noise
  57. hard starting/dies while in motion
  58. Dim Gauges
  59. Caliber Bolt won't turn
  60. troubleshooting rear defrost
  61. Engine Whirr
  62. 2004 Cavalier
  63. 1999 Chevy Cavalier Z24 2.4 DOHC A/C Issue
  64. 97 Pontiac sun fire 2.2L OHV will not start
  65. so confused please help
  66. problems reading codes on a 97 Z24
  67. Horn Quit on 2003 Cavalier
  68. Water pump
  69. Radiator fan plus AC?????
  70. 2004 cavalier wiper problem
  71. Running Extremely Lean
  72. Brake Problems
  73. No Dash ligts, tail lights or 'lights-on' bell
  74. 01' 2200/stick
  75. right rear turn signal out
  76. Is it the fuel filter or something else
  77. Desperate Sunfire help
  78. 2001 Cavalier Power Loss
  79. ***Squeakie Noise When Driving***
  80. Chevy Cavalier interior door lamp won't turn off.
  81. fuel pumps
  82. Air Bags sensor question
  83. security theft system problems
  84. Fuel pump fix
  85. Leaking coolent
  86. Rattling
  87. Brake Problems
  88. 93 Cavailer Fuel @ injectors, spark @ plug, won't start
  89. 93 Cavailer Fuel @ injectors, spark @ plug, won't start
  90. 2003 Standard Cavalier - Help
  91. brakes wont work please help
  92. need part numbers
  93. michael s.
  94. 96 cavalier
  95. '97 Cav. A/C prob's.
  96. caviler 2.4 liter need mega help
  97. Frequent headlight failure - 2000 Cavalier
  98. 1996 2.2L Noise from fuel tank
  99. Spark issues on 91 Z24 HELLLP!!!
  100. '99 Z24 alternator fried. Need helpful instructions on how to replace it.
  101. 94 Z24 auto trans issue HELP
  102. 98 cavalier-How do you change the manaul transmission oil?
  103. keyless remote issues
  104. 1992 Cavalier 2.2 ran intermittently then died, has spark and fuel pressure
  105. 97,cavalier wont start
  106. plug wires
  107. oil pan
  108. 1994 cavalier Z24 oil pressure
  109. my cav doesnt want to idle out
  110. 1996 Chevy Cav High RPM to shift
  111. 1999 Cavalier LS Won't Start - Maybe Alternator?
  112. Brake Drum
  113. 01 cavalier, No headlights, wipers and drivers door lock
  114. Fuel leak
  115. Engine tick
  116. I smell gasoline
  117. 1993 Cavalier, 2.2 L, 4 cylinder
  118. I Need Help!!!
  119. 1997 to 1998 engines
  120. 2001 Cavalier Headlight Issue
  121. 98 overheating at highway speeds only
  122. Chasing an Engine Misfire... any input
  123. Tcc
  124. A/C problem
  125. 99 Sunfire 2.2L doesnt like to start right away
  126. 2000 LS 2.2 - Died on road, won't start, still turns
  127. 3 questions
  128. Odd brake-problem sound
  129. 98 Z24 is idling rough
  130. 02 cav 2.2 sohc auto no start!!!
  131. 02 cav 2.2 sohc auto no start!!!
  132. clacking sound at start
  133. Haynes or Autozone?
  134. quad4
  135. Ughh I need to install an evaporator for 97 cavalier
  136. 2002 Ecotec Cooling Fan Problem
  137. 97 won't start
  138. PowerLock Relay...location??
  139. 97 Cavi - dreaded P1336
  140. '99, automatic, 2.2, "grinding" noise in first
  141. 95 Cavalier Horn Problem
  142. 00 Z24 keeps stalling once warm!!
  143. Coolant Bypass Pipe Removal
  144. TPS problem?
  145. Power Lock Switch not working..help plz.
  146. A/C not blowing through front vents
  147. 2004 Cavalier Fuel Tank Removal
  148. Acceleration problem around 45-55
  149. wierd problem with chime and dome light
  150. 96 Cavalier won't start or even turn over
  151. fuel to throttle body but no fuel to start vehicle?
  152. fuel to throttle body but no fuel to start vehicle?
  153. Cavalier shifter cable problem
  154. 95ish Cavalier won't start
  155. 2004 Cavalier HVAC control lights
  156. '97 Cav - Passlock/PCM problem, won't start! =*(
  157. 200 cavalier dosen't turn over after wreck
  158. Vaccum leak?
  159. 98 z24
  160. check engine light
  161. Parking brake problem?
  162. 2001 Cavalier back up light problems
  163. Changing Fuel Pressure Regulator
  164. 02 cavalier rough shift into 2nd gear
  165. 1994 Chevy Cavilier transmission fluid change
  166. 1994 Chevy Cavilier reverse flush
  167. 1991 Cavalier RS Lower control arm broke
  168. Sunfire GT 2000 stucking idle
  169. 96 Sunfire Stalling
  170. Loud noise from front end 97 Cavilier Z24..CV Joints??
  171. Please Help :(:(
  172. 2000 ac problem
  173. 2002 2.2 engine in a 2000 Cavalier?
  174. Hard start
  175. 2003 Cavalier Headrest Removal, How Do You Do It, Its Drivin Me Nuts
  176. Battery?
  177. overheating...
  178. starting, window ,and guage problems
  179. 99 cavalier w/2.4L DOHC TDC P0300
  180. Can I Hotwire My Ignition?
  181. 2004 chevy cavellier -fan coming on
  182. No start after timing chain replacement
  183. Cavalier z24 2 door power windows help!!
  184. Tach/speedo problems on a 97 Z24
  185. Help Transmission Keeps Blowing Clstr Fuse
  186. Transmission & Temp sensor questions
  187. 97 sunfire low/rough idle
  188. 1994 3.1L idels and runs rough
  189. bulbs
  190. location of Cooling fan tempeture swith
  191. Burnt out odometer light bulb!
  192. 91 Cavalier Fuel Filter Location
  193. Overdrive on '97 Cavalier
  194. 1996 Cavalier Cooling Fan stopped working
  195. Backfire Thru IM
  196. fuel injectors or MAP?
  197. How to change my digital dash to a regular one?
  198. Driver's side power window not working.
  199. Toyota Brake light randomly quitting
  200. Shuddering...transmission problem?
  201. A/C is not working at all. Please Help
  202. sputters/ cuts in and out at highway speeds
  203. Omg..Shifting Problems!!
  204. Steering columm needs adjusting-How?
  205. Gauges start jumping, lose power steering, car won't start for 5-10 minutes
  206. Passlock Bypass
  207. 1999 Lockup torque converter problems
  208. Timing Chain Replacement
  209. 02 cai problems
  210. 92 Cavalier won't start unless wheel is cranked to RIGHT
  211. 96 cav 2.0 start/run problem
  212. How much fuel pressure does the return line have on a 96 cavalier?
  213. Shifting 1st to 2nd - 'Whoosh'
  214. Ignition Problems
  215. cluster removal in 98' z24?
  216. Stalls at idle ONLY when outside temperature gets HOT??
  217. Fan Motor not working on low and low/medium
  218. Wheel bearings
  219. 2002 Cavalier elec problem
  220. 1992 Chevrolet Cavalier VL 2.2 - TV Cable Issue
  221. Rear -02 sensor
  222. Newbie question about whinning sound from front-end
  223. '96 2.2l cav battery replacement issue
  224. car wont start
  225. 1990 Cavalier where is the cruise control module located
  226. Big transmission problem, or not a big deal?
  227. Pontiac engine problems
  228. door lock repair question
  229. please help 1999 chevy cav wont start
  230. My Cavalier Hates Me - MYSTERY PROBLEM!
  231. 2000 Cavalier hard starting after warm sometimes
  232. Won't pass emissions, high hydrocarbons
  233. 02 cav 2.2 hesitation or no start or just fine oil in airbox
  234. How do I disconnect Cav pkg light sockets?
  235. 96 Pontiac Sunfire GT 2.4L Twin Cam
  236. Brakes, only one wheel working!!
  237. Trans output seal help
  238. **Replacing Ignition**
  239. 00 2.4 cav idle problem 1500rpm to 3000rpm
  240. fill plug on
  241. 1999 Ignition coil problem
  242. Fuel pressure
  243. 97 sunfire overheats when idling
  244. 2004 Cavalier Overheating / Fan Replacement
  245. CV Joint/Ball Joint (?) 1996 Cavalier
  246. Head rest replacement
  247. Multiple issues after lightning strike
  248. overheating on my 96 cavalier
  249. 01 Cavalier 2.4
  250. 96 Cav Fuel Filter QD replacement
