View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16
  1. Mis-Fire
  2. clock in radio stays on
  3. IAT sensor- clunk while shifting
  4. cavalier hub bearing
  5. starting problem
  6. 97 2.4L Bad idle Need enlightenment
  7. cooling
  8. steering wheel bearing
  9. 2002 Chevrolet Cavalier Headlamp Assembly bulb replacement
  10. 2002 Chevrolet Cavalier Headlamp Assembly bulb replacement
  11. 98 z24 my thermostat doesnt fit
  12. 2003 weird no start problem
  13. How do i pull trouble codes for '95 cavalier?
  14. 97 sunfire ac problem
  15. I have a 96 Chevy Cavalier that is overheating.
  16. please help this mechanic 2.2 p0300
  17. please help mechanic 97 2.2 p0300
  18. 2004 cav stick coupe
  19. HELP-DESPERATE - Used 1996 Cavalier
  20. 1997 Cavalier 2.2L P300 - random Multiple Cylinder misfire
  21. rad doesn't get warm
  22. Stupid Cavalier
  23. odometer not lighting up
  24. 1996 2.2 Cavalier How to set the gears back in time on the timing chain
  25. temp guage extreme right 2003 Cavalier Z24
  26. Help with Cavalier Transmission
  27. Help!!!
  28. How do you get a shift cable out?
  29. Wiper in Up Position
  30. Anyone needing to pull Cv Shafts ( check here)
  31. 03 cavalier won't start
  32. '97 Sunfire Stalling on accel (w/ fault codes)
  33. 2004 Cavalier P0455 code - engine revving
  34. 01 automatic transmission shifting problems
  35. 96' Cavalier A/c runs slow at stop but then speeds up when driving?
  36. Problem with Check Engine Light
  37. Spark Plugs?
  38. oil pressure is at 550
  39. headlights dim
  40. 92 cavilier problem
  41. no drl, no low beams, ticking noise fuse box
  42. Weird problem, need some help!
  43. cavalier please help
  44. 2000 2.4L problem!!!
  45. Please help ME!!!!!
  46. Help with '96 Cavalier DRL relay
  47. 96 z24 cavalier with no head lights
  48. Windshield Wiper Woes
  49. 97 Cavalier idle problem
  50. 94 cav won't start
  51. nuetral safety switch on a 92 cavy
  52. Whats wrong??
  53. coil packs
  54. New clutch won't engage
  55. 2003 engine reving.rpm/ sputtering problems
  56. Help with failed emissions
  57. Fuel gauge
  58. 98 Cavalier 2.2L overcooling
  59. 2004 Cavalier 2.2 OHC (EcoTec) Alternator
  60. 96 2.2 cavalier temp gauge
  61. Fog Lights, 2003 Pontiac Sunfire
  62. Battery Lite & ABS Lite Coming On & Problems....
  63. switching computer and BCM from a 99 to a 00
  64. 97 Cavalier 2.2 P0301 code
  65. Oil pressure light 2001 2.2
  66. Belt Squeeks!!!
  67. Rear defroster
  68. 98 Cavalier 2.2 Cooling system nightmare
  69. tork converter clutch
  70. heater fan
  71. Idle issue
  72. a little bit of white smoke from engine
  73. 2003 Cavalier Horn Problems
  74. Gauges, Stereo, Electrical, Error
  75. Power when off, no Power when on
  76. phantom gauges
  77. Help Tranny
  78. 1994 Cavalier - Did I bust a timing chain?
  79. 1989 Cavalier-Where is the flasher unit?
  80. Temp gauge
  81. very high idle
  82. extracting the tie rods 99' cav
  83. 94 z24 heat problem
  84. 1998 Cavalier Z24 Fluid leak at water neck?
  85. 97 Power Steering Problem
  86. no power until check eng.lite comes on
  87. 1990 Cavalier No Headlights
  88. Dome Light Not turning on
  89. blower motor resistor balogna
  90. Steering wheel off center? This bugs me
  91. 1996 Cavalier Clutch problem
  92. 1996 Cavalier Clutch problem
  93. 1995 sunfire stumped
  94. 97 Z24 - 157000 miles
  95. 98 Cavalier - Stalling, crank sensor, codes
  96. ugh...more problems...more headaches
  97. Intermittent Oil Light 96 2.2L
  98. 03 cavalier, getting shocked exiting the car
  99. 05 Cavalier Temp gauge
  100. 01 cavalier gas gage not working
  101. 1997 Cavalier Check Engine, ETS Off, Intermittant Start Problem
  102. cant figure out idle
  103. 1999 Cavalier stalls when running at low speed
  104. 1999 Cavalier stalls when running at low speed
  105. [ cig ] fuse blown.
  106. Cavalier low compression
  107. 96 Cavalier, new owner...old problems
  108. weird idle and stall and abs light
  109. 2002 Cavalier No Start Problem
  110. 96 Cavalier 3rd Alternator in 2yrs
  111. 02 Cavalier - Electrical Issues
  112. 2004 rubber muffler hanger
  113. Unintentional braking
  114. 'killing' 91 RS Cav
  115. 2000 Cavalier Trouble Code (C1232) LF ABS
  116. 96 Cavy..No Start
  117. Need some help
  118. 97 Sunfire GT noise help
  119. 02 Cav. Electrical Problems and thumping in the front tire
  120. 98 Z24 valve cover gasket
  121. 97 chevy made a pop and quit
  122. Installed used BCM- Won't start now
  123. Turbo/Blow Off Valve Question
  124. 91 sunbird 2.0 temp gauge
  125. Post 2002 Cavalier Serpentine Belt Change
  126. Brakes
  127. my clutch went to mush...
  128. Mystery noise?
  129. 91 z24 engine problems
  130. 96 cavalier cranks but doesn't start
  131. 96 2.4L manual transmission problem
  132. oil pump 2.4L
  133. car sounds like a tractor
  134. '02 Sunfire SE (2.2) Dead, and I mean Dead. Help!!!
  135. '02 Sunfire SE (2.2) Dead, and I mean Dead. Help!!!
  136. Manual Transmisson Problem!
  137. Manual Transmisson Problem!
  138. 96 cavalier clutch problem
  139. 2000 Chevy Cavalier..Coolant Overflow
  140. PGR Valve...
  141. 2002 cavalier wont start HELP!!!!!!
  142. Window Alignment
  143. Trouble Code (P0118)
  144. Service light on
  145. 96 cavalier rattling at front passenger side
  146. Transmission won't shift into any gear
  147. P0758 Boys, not lookin' good...
  148. Weird A/C issue
  149. 03 Cavalier Transmission Question
  150. Wheel bearing & "tire noise"?
  151. 02 Cavalier headlight assembly
  152. tranny slip? Misfire?
  153. Injector problems??
  154. Random/Multiple Cylinder Misfire
  155. HELP.. Need help 96 Cavalier Auto Can drive forward but no reverse
  156. swap sunfire 2.4 junk for reliable 2.2 with getrg
  157. 2003 Cavalier...BCM Problems??
  158. 02 Cavalier no start
  159. engine missing and i am stumped
  160. minor clunk
  161. Plz help me in my 96 Cavalier ...
  162. Tensior pulley assembly
  163. 95 & 98 2.2 vacuum line help
  164. wiper problem
  165. HELP!!! 99 cavalier 5spd 2.2 stalling
  166. 2500 rpm idle when getting off highway.
  167. UHM...HELP! 01 Sunfire shifting problems!
  168. Halfshaft question
  169. 01 Cav no start
  170. 2003 Sunfire Bogs down in 2nd and 3rd Gear
  171. 1999 Auto Cavy shift prob
  172. both daytime running lamps don't work
  173. 96 2.2l cavalier starts, then dies
  174. 1992 2.2 Cavalier only fires on 1&4 cylinders
  175. 96 sunfire misfire
  176. How do you adjust 1-piece halos......?
  177. 03 cavalier engine surge, high idle when getting off highway.
  178. lower ball joint
  179. 99 cavalier
  180. 2000 Sunfire Possible Alternator Problem
  181. Signal Light Replaced But Still Not Working
  182. p0440 error
  183. 92 Cavalier rear brake keep tighting up
  184. 2001 Cavalier won't start & the BCM/RFA clicks
  185. Help! 2001 Cavalier won't start...
  186. 98 cavalier overheating. please help
  187. 96 Exhaust Manafold
  188. 91 cavalier...dies after getting warm
  189. Brake Pads
  190. 1999 Cavalier Brake fault indicator
  191. 1999 Sunfire problem
  192. Unlock a BCM?
  193. I Need Sunroof Help!!!
  194. 00 Cavalier Died and Won't Restart
  195. tranny slipping.....bad!
  196. 95 chev cav speedo goes up in reverse new vss
  197. 94 Cavalier signals won't flash.
  198. Battery problems
  199. Help me!!! Needed a boost now keyless remote not working
  200. 96 Pontiac Misfire... I mean, Sunfire
  201. Trouble with 5th or Reverse
  202. 1998 Cavalier Clutch Problems
  203. oxygen sensor after the catalytic converter
  204. Brake problem
  205. 1995 Cavalier NOT CHARGING!
  206. 2002 Sunfire Transmission Cable
  207. Sunfire 96 hesitate/jerks problem ?
  208. manual trans shifting issue
  209. The wobbly shifter
  210. Airbag related issues in removing steering wheel?
  211. 97 Cavalier LEAKING COOLENT.
  212. Problem with 2000 Z24 water outlet going bad.
  213. Brakes Squeal Just Before Stop
  214. 1998 Chevy Cavalier Clutch Issues
  215. Are there tricks or traps in replacing Cavalier starter?
  216. Crankshaft Position Sensor
  217. how to drop 96 fuel tank
  218. 95 Cavalier Won't Start 2.2l
  219. 2003 Pontiac Sunfire won't start
  220. rough idle...help!!!
  221. power window problem
  222. 95 cav wont start sometimes
  223. Steering wheel yanking 97 sunfire
  224. Cavalier 2002 4 dr sedan engine repair light on? and problem when starting
  225. Air Conditioning
  226. dying car and dummy lights
  227. Oil Gauge Acting Weird
  228. Battery posts & radio...
  229. Rear Defogger Not Working Chev Cavalier 2003
  230. Transmission Noise?
  231. 98 cavaliar loud nose from rear end..
  232. Cat converter problem please help
  233. :::1996 Pontiac Sunfire Overheating:::
  234. high engine temp? and no oil pressure
  235. 96 Z24 engine problem
  236. not sparking properly
  237. more wiring problems YAY
  238. steering wheel removal
  239. Struts and Spring
  240. 96 Cavi 2.2 Crankshaft Sensor
  241. ETS is a pain in the ass.
  242. Help!!!!!!!
  243. 98 Z24 interior lights and power mirrors
  244. cavalier
  245. '96 Cavalier stalling at stops!!!!!!!!!!!!!!!!!
  246. Oil in Coolant on 2.2 L. 95 Cavalier
  247. 94 Z24 Problems
  248. cavalier fuel filter
  249. Timing on a 1998 2.4 L
  250. 98 Cavilier won't start
