View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. 2001 chevrolet cavalier
  2. a little direction please!
  3. RPM's rev at contant speed?
  4. 96 z24 cavalier idle problem 2.4
  5. Passenger-side headlamp not fully lit
  6. car dies at stop lights
  7. spark plug not firing
  8. confused
  9. Question on replacing rotors on 96 cav
  10. '95 engines
  11. 1996 cavalier 2.2 starting
  12. Grinding Wheel, Not the bearings.
  13. 99 Cavalier over heat/no start
  14. 96 2.2 head gasket R&R
  15. Leaking freeze plug?
  16. Chevy cavalier power steering problem
  17. no start 95 cavalier 2.2
  18. 2001 Cavalier Battery Drain Problem - HELP
  19. cavalier fuel injector pops out after shut off engine
  20. 04 Tranny
  21. 97 2.4 cav sounds like a diesel engine
  22. 2001 Cavalier Stalling only when Cold.
  23. 2001 2.2 Shift Solenoid
  24. Installing a new gasket!
  25. Is it possible to replace connecting rod bearings on 2.4l w/out removing engine!?
  26. cooling issue
  27. automatic flywheel on a standard?
  28. 99 cav convertible quarter window help
  29. 99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights
  30. Trunk Remote Problem
  31. Cavalier is overheating
  32. 02 Code 0440
  33. My engine light came on today...
  34. 95 Cav 2.2 no start
  35. 2004 exhaust rattle
  36. 97 chevy cavalier won't start changed plugs ran fine two days
  37. possible coil pack problem?
  38. 2002 blower fan question
  39. 96 Cav 2.2 water pump R&R
  40. Cavalier Brake Master Cylinder
  41. Object found in engine,..can anyone ID this piece?
  42. 2001 Cavalier
  43. 98 sunfire gt 2.4
  44. 95 cavalier not firing
  45. Rythmic engine noise in '03 cavalier
  46. 90 cavalier engine running rough
  47. 97 sunfire ...clutch pedal to the floor to shift
  48. 2000 Cavalier Idle Surging High and Low
  49. 94 Cavalier, good battery, goes dead, clock stay on
  50. battery dead starts and will stay running till i let off the gas
  51. 2001 Cavalier start/run problem
  52. '97 Z24 Cavalier Losing Coolant/Overheating
  53. Help.!!
  54. 90 Cavailier auto transmission wont move in reverse
  55. 99 sunfire clicking during braking causing lights to flicker
  56. 04 Cav. AC Max in/outside air door actuator
  57. 99 cavalier need to press gas to start
  58. 96 Sunfire
  59. 98 cavalier
  60. 1996 Cavalier
  61. 1998 Cavalier stalls
  62. V8 Cavalier??? Say Wha?!
  63. Replacing CV Joint 1997
  64. 2001 z24 starts but will not run
  65. 95 parts on a 03
  66. How to remove Instrument Cluster on a 93
  67. 97 Cavalier.need to press gas to start
  68. Water temp. sending unit
  69. 1996 cavalier 2.2 head gasket
  70. Engine Vibration Noise Only During Acceleration
  71. Please Help Me
  72. 96, 2.2L sunfire
  73. 2000 Sunfire Turn Signal Problem
  74. '98 Sunfire GT stumbles on accleration!
  75. 95 Cavalier many symptoms Help!
  76. 96 Sunfire must press gas pedal for it to run.
  77. 01 Cavalier - Wipers don't stop, looking for help!
  78. 95 cavalier VSS terminals at PCM
  79. Brake Rotor Warp
  80. PO480- Cooling Fan Circuit 1
  81. overheating?
  82. Odd problem with speedometer
  83. where is the tcc ?
  84. 1998 Z24 knocking. Lifters?
  85. Sunfire starting problem
  86. running like crap when cold.
  87. How To: Check and refill Transmission fluid on 4T40E,4T45E
  88. auto tranny trouble
  89. 95 Cavalier no power whatsoever.
  90. 2002 Chev Cavalier Poor Gas Mileage ,,, Checked Everything??
  91. 2002 Cavalier LS Sport - 3 Problems
  92. 93 cavalier problem. No power, 8 DTC codes
  93. MANY problems - '98 Cav
  94. 96 z24 cavalier 2.4 no spark.
  95. 2000 cavalier clutch
  96. Having oil pressure problems.
  97. 93 Cavalier HELP! Its cold!!!
  98. Intermittent Loss of Spark to 2 Cylinders
  99. 01 Manual Shift Plate
  100. 98 cav parking break cable
  101. How do I know if my Starter is Going out?
  102. How to remove rear door mechanism ?
  103. Put a 99 2.4 in a 97
  104. Electrical Headache! please help.. 96 cav
  105. 2003 Cavalier
  106. 97 Cavalier Z24 / 2.4L Heat Problem!?!?
  107. 98 Cavalier cannot start cold
  108. 1999 2.4L Cavalier EGR?
  109. Help with 98 Cavalier
  110. 1997 cavi 2.4 RS Convertable power steering issue?!?!?
  111. engine knock
  112. 2003 Cavalier Problems
  113. 2000 2.4 misfire
  114. 1996 Cavalier 2.2 "check oil" light
  115. Need help with my sunfire, coolant leak
  116. Milky substance in intake
  117. 2000 Chevy Cavalier Starting Issue (Power/Electrical)
  118. error code is P0141 Bank1 Sensor2. came back on
  119. Running Code P0122
  120. Cavaliar start up on near empty gas level, died, added gas, then did not start
  121. 1996 sunfire..
  122. PASSLOCK Override - 1996 Cavalier Demo. Derby Car
  123. 1996 pontiac sunfire overheated
  124. Clunk In Front End Under Acceleartion
  125. Ramdom driving problem
  126. Noise from air intake
  127. 99 cavalier electrical problems
  128. Another Power Window Thread, I did a search, please hear me out
  129. airbag light on
  130. no brake lights, signal lights, ABS, defrost and power locks
  131. 95 Cavalier Transmission engage problems
  132. After collision tranny problem
  133. 1996 pontiac sunfire problems
  134. Trunk wont stay open
  135. coldrunning moter
  136. Rear Lights
  137. Brake issue???
  138. Headlight help please
  139. 97 Cavalier Rotten Egg Smell
  140. Loud vibration from front of car
  141. Heater Door Noise
  142. Check Engine Light Anomoly!!
  143. 99 cavalier cooling problems
  144. 2004 Clutch Actuator Cylinder Meltdown
  145. Help with a check engine light...
  146. problem removing + battery terminal
  147. 98 Cavalier replacing clutch?
  148. 1990 Cavalier runs very rough and stalls when driven
  149. 96 Cavalier Nothing When I turn The Key
  150. New belt but MUCH Noise!
  151. The Oh so Common "No start"
  152. Parasitic Draw?
  153. 98 cavalier alternator wiring need color code for plug
  154. 95 cavalier barely starts/ shuts off after moving
  155. 2005 Ecotec 2.2L burning out ignitoin modules
  156. 95 Cavalier Barely Starts/Shuts Off When Driven
  157. 03 Sunfire randomly died - won't start
  158. 2000 Cav when heater is on....
  159. How to remove rear door lock?
  160. Reclining problem with driver side...Need Help..Plz.
  161. My 1994 z24 has a problem staying started.
  162. 03 Cavalier no start, no communication
  163. Brake/tail light explodes
  164. Help!! my radiator fan keeps running!!
  165. All Lights Flickering
  166. Problem with my 98 Cavalier
  167. ABS+Brake warning light is on
  168. bleeding the cooling system
  169. Have a coolant leak. Need to know the part name.
  170. Rear defogger Relay
  171. Idler Pulley Noise
  172. 1994 chev cavalier headlight switch
  173. 2002 2.2 OHV Cavalier Stalls but starts back up
  174. '91 Cavalier RS won't start
  175. 97 Cavalier wont start after freeze
  176. 96 Chevy Cavalier ( my car is a pain)
  177. 1999 chevy cavalier 2. starter or flywheel?
  178. Huge Wiper Problem!
  179. ABS Brake problems
  180. 95 cavalier engine noise
  181. Cavalier Heater no working
  182. 97 Cavalier Alternator problem?
  183. 96 cavalier water pump
  184. 02 Cavalier trunk wont close/open
  185. 2002 Cav. 80/100km starts shaking a bit
  186. 2001 Electrical Issue
  187. 89 Cav 2.0 Hesitation Problem Help!!!
  188. My Caviler is possesed
  189. 96 Cavalier windshield washer reservoir removal
  190. The back brake locks up but only in cold wheather
  191. no power
  192. Clutch or Slave/Master? Help, Please!
  193. 1997 Cavalier Coolant Leak Z24 2.4 help please
  194. 2001 Cavalier LS - Any warnings?
  195. noise in the back
  196. Starting Issues
  197. 2002 Chevy Cavalier - Check engine light - Error Code P0742
  198. 2004 Cavalier Speedometer Problem
  199. 1996 pontiac sunfire hard to start
  200. 1996 z24 cavalier problem
  201. ETS Off Check Engine
  202. Need Help With noise comin from front wheel
  203. 02 Cavalier wiper arm issue
  204. 01 Cavalier intermittent start hesitation
  205. Possible Hydrolocked Engine?
  206. 2004 Chevy Cavalier misfiring
  207. Battery light issue
  208. 1997 Cavalier CV Joint need help
  209. Heating
  210. Groaning in front end
  211. need help with head lights
  212. 05 Cav power window shorting
  213. 2002 Cavalier - Dim Odometer
  214. Signal Mayhem - sunfire.
  215. What Type of Plastic Was Used on 1986 RS Cavalier Bumpers
  216. I Think She's Dying
  217. sway bar and struts
  218. 04 Cavalier Sway Bar Questions
  219. brake booster removal question
  220. How to replace '03 Getrag F23 transmission
  221. 2001 Cavalier No Start No Guages
  222. Rhythmic knocking/pumping? noise from back of 05 cavalier
  223. 97 z 24 high idle & harsh shifting at high rpm
  224. 2000 Cavalier Check Engine Light Extinguisher?
  225. 97 z 24 idles high and shifts late. happened overnight?
  226. 01 Sunfire Won't Start
  227. Headlight Wiring '95 Cavalier
  228. Popping sound in front in.
  229. Service Engine Soon warning light
  230. power windows 99 z24
  231. Motor swap from a 97 to a 96 not getting spark.
  232. hard to start when cold
  233. 03 cavalier occasional starting trouble
  234. 2003 cavalier: cooling fans wont stop running
  235. serpatine belt
  236. Please Help! Only car I have!
  237. 92 Cavalier head removal
  238. Tell me what's going on here(clutch related?)
  239. Air in the Power Steering line 2020 cavalier
  240. Random Misfiring on Multiple Cylinders
  241. Shaky Situation.. Please Help!
  242. Tail light problem
  243. cav clunk
  244. 04 sunfire 2.2 low idle problem with knock
  245. Driver Side Door Lock
  246. Fuel pressure specs. for 1994 cav. 2.2 L
  247. 98 Cav Parking brake
  248. Please help...
  249. Windshield Wiper Problem
  250. Help Low oil pressure only at warm up!
