View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16
  1. 1985 Cavalier won't start after tune up
  2. '97 Cav 2.2 oil pan
  3. 94 cavalier z24
  4. 97 Cavalier DRL
  5. Red back lighting on odometer
  6. 2003 Sunfire foglights
  7. 1991 Cavalier Transmission Problem Please Help
  8. 98 cavalier electrical issues?
  9. 96 Cavalier instrument cluster issue.
  10. 95 Cavaliar reoccuring headgasket leak
  11. Help....My engine is crazy
  12. Need some guidance on ignition lock cylinder
  13. 2001 sunfire firing problems
  14. car cranks no spark
  15. ATF - motor oil
  16. Plug wires
  17. 91 Cav. had engine catch fire
  18. Please help engine caght fire
  19. bad lower control arm bushings?
  20. f**ked up ignition
  21. 96 cavalier z24
  22. pontiac sunfire gt 2001 bcm question?
  23. Transmission problem
  24. Lower Engine Mount
  25. 1996 Cavalier stalling at stops
  26. 93 cavalier strut bolt
  27. 97 cavalier not starting
  28. 97 clutch problems
  29. 97 clutch problems
  30. 2003 Cavalier Stalling out when stopping.
  31. 01 cavalier overheating
  32. disablling the theft system? can it be done ?
  33. theft system mess.
  34. 2001 Sunfire Gt 2.4l Engine Diagnosis Help
  35. cooling system troubles
  36. 2003 Cavalier Handbrake adjustment bolt?
  37. wheel bearing
  38. help me out please
  39. starting problem and light problems
  40. Plug wires arcing
  41. Horn and Dome light dont work
  42. 97 cavalier, valves clatter, power loss, engine chugging
  43. cavalier engine?!
  44. 04 CAVALIER Steering, pops when turning right
  45. brakes locking up
  46. need help on swaping a 2.8 into a 3.1
  47. brake problems
  48. help: 99' chevy won't start
  49. 2002 Cavilier AC clicking problems.
  50. '97 Cav running rough - stalling
  51. 98 cavalier cranks but wont start
  52. 1994 cavalier-key is stuck
  53. 1995 Cavalier ABS need some guidance
  54. Radiator fan won't kick in
  55. '89 Cavalier Starter
  56. Headlight Problems...Any Ideas?
  57. please help. im still learning about cars
  58. 96 Cavalier Passenger Side Headlamps Dim
  59. speedo gone crazy
  60. Air Charge Temprature Sensor
  61. head bolt set no washers???????
  62. 2001 cavalier
  63. 2002 Cavalier electrical problem
  64. i could really use some help.
  65. '97 sunfire sparking/rough idle/stalling
  66. A/C control not working/running rich
  67. 96 2.2 cavalier, alarm/remote start
  68. What causes a Crankshaft Sensor to go bad?
  69. Failed Emissions. Little help please
  70. 2001 Cavalier is there a Fan Relay switch?
  71. Anyone Clean The EGR Passages Before?
  72. Sunfire GT 98 2.4L jerking, need help !
  73. '96b sunfire GT
  74. oil light funky
  75. 99 Z24 Cavalier Probs...
  76. car running on it's on
  77. horn ignition
  78. i need help my 97 cav is running bad
  79. Damaged Exhaust Pipe
  80. Dim Headlights, Check Engine Light On
  81. 96 cavalier 2.2 weird no start problem
  82. 96 cavalier-no start/theft light still on?
  83. left headlight
  84. cav accelerates after releasing gas!
  85. damn cavis
  86. 2004 Cavalier Shaking
  87. 2004 Cavalier Doesn't Like Gas
  88. What The Hell?!!?!?!?
  89. 2003 Chevy Cavalier Error Codes
  90. Transmission problem
  91. odd stall out
  92. 96 Cavalier, problem with stalling, specific to warmer weather
  93. Help with oil leak please
  94. O2 sensor fix
  95. no power steering!!!
  96. 2000 Sunfire service engine light come on.
  97. Slight Auto-Transmission Leak
  98. ECM problem - need help
  99. Is it the gas
  100. help with p0118 and p0335
  101. Cavalier Transmission problem
  102. 2002 Chevrolet Cavalier Z24 oil leak
  103. Engine Swap
  104. Engine Swap
  105. dark spark plugs
  106. Re-doing headliner?
  107. whistleing sound or whining sounds
  108. engin knocking last night but now its not
  109. 98 Sunfire GT only has running lights!
  110. Mystery sound
  111. Noisy lifter?
  112. Cavalier Evaporator
  113. 2002 Suifire P0300 misfire
  114. 03 Cavalier passenger side cv shaft problems
  115. 2001 cavalier wont start
  116. '93 Cavalier with a sudden onset of running problems
  117. Need help for ETS off light on in dash
  118. Lower Control arm/Castle Nut Problem
  119. '97 sunfire crank but no start
  120. Diagram for fuse box on a 93 Cavalier
  121. Assistance Needed (Heating)
  122. 99 Cavailer shakes and idles rough
  123. Fogging Problem
  124. Problems In The Brakes..help!!
  125. 93 2.2 with some problems
  126. my pcm wiring harness got cut and corroded.
  127. 96 cavalier no start/theft light on
  128. 97 chevy cavalier transmission
  129. Cavalier 2002 how to access headlamp socket?
  130. Front end wobble
  131. Helicoil failure
  132. 2004 Sunfire stumbles while throttling
  133. Dash Cluster-Instrument panel -Guages
  134. 96 cavalier wiper issues...can't drive while squeegeeing..thanks
  135. help adding subs to a monsoon system
  136. 2004 Cavalier Clicking from under dash
  137. 2002 Cavalier No Start/Run
  138. Hard start stumble at idle
  139. coolant leak
  140. Cpmputer replacement.
  141. Radio Swap
  142. 97 cavalier 2.2L tranny fluid leak
  143. Removing the Catalytic Converter...
  144. 2004 Cavalier Fuel and RPM Gauges problem
  145. Bad Altenator? NEED HELP!!!!
  146. Theft System,can't get key out.
  147. rear defrost problem
  148. rpm and speed on dash not working
  149. 96 cav 2.4
  150. HELP! with ABS
  151. 92 cavalier died
  152. 98 2.2 crank sensor wire (s)
  153. 2001 Cavalier - left front headlight problem/running light problem
  154. Chevy blazer 2000
  155. 1994 cavalier wont start
  156. SDM 2005 Cavalier
  157. Daytime Running Lamps
  158. 91 chevy cavalier - engine siezed
  159. Automatic Transmission-Couple Questions
  160. burnt heat
  161. 95 Sunfire Parking Brake Light ..
  162. 04 cavalier driver side dim headlight
  163. 96 sunfire problems
  164. 96 sunfire problems
  165. ~HELP!!! 2000 2.2 cavalier oil pan removal????
  166. Help!!!!!!!! Overheating 99 Cavalier!!!
  167. Theft System Problem, new Radio 98 Sunfire
  168. no heat and its freezing!
  169. 96 Sunfire Engine Light Is ON Will Drive but sometimes just stops!
  170. hard braking
  171. 96 cav wont start
  172. Need Help Asap
  173. Need Help Asap
  174. 1996 -3t40 wire question
  175. Rough Idle, ETC
  176. 2003 cavalier oil leak Helpppppppppp
  177. 98 sunfire evaporator core
  178. Check Engine Light with code P1870
  179. I need some help... Please everyone
  180. Headlight Dimmed.
  181. 95 Cavalier DRL (Daytime Running Light) problem
  182. ERLS Fuse Blowing - Caused by sound system?
  183. My 97 baby is dying. Whats wrong with her?
  184. Weird Strut Noise?
  185. 2.2L stumbles after warmup
  186. 2001 Pontiac sunfire body control module help
  187. Washer Fluid Hose Size?
  188. where's my horn located
  189. 2001 sunfire tranny troubles
  190. Sound System...car being funky
  191. 91 Cav power steering hoses
  192. 99 Cavalier hesitating
  193. How to replace ECM ?
  194. 2003 Cavalier, keyless entry problem
  195. Electrical Problems Galore
  196. Aftermarket radio
  197. 1998 Cavalier blower motor,A/C ,Rear Def. not working anymore.Help.
  198. Service Light?
  199. 94 cavy idles rough when cold
  200. p1133 code for a cavalier
  201. 96 cavalier wipers and radio wont work
  202. 97 cavalier z24- heater fan?
  203. loss of power brakes and abs????
  204. 97 cavalier overheated and won't start
  205. 97 cav motor mounts
  206. Bent A frame
  207. replacing fuel injector in 1997 cavalier
  208. 1999 Cavalier 2.2l Power Steering Bypass?
  209. Sunfire cranks no start
  210. Thermostat Cavalier 2004
  211. New tires, now a bad wobble in front end
  212. no oil pressure
  213. I need some help with my 98 Cavalier...
  214. Power loss
  215. Changing spark plug wires
  216. Low beam out on driver's side
  217. Cool Air Blows Out When I Idle
  218. 97 Cavalier, will not start. PLEASE HELP!
  219. 97 Cav 2.2 stumble - rough idle
  220. Have No Dash Lights! Please Help.
  221. 99 cav. can't get the dash board off
  222. oil pump balance shaft
  223. Stalling again!!!
  224. 99 Cavalier, 2.2 Valve Cover Gasket
  225. 97 Sunfire, Will NOT move!
  226. gas tank/ door problem
  227. 2000 cavalier - A/C seized
  228. 04 cavalier grinding on pass front
  229. Coil pack
  230. 2000 Cavalier dash prob
  231. engine hesitation
  232. '03 Sunfire Headlight Problem Solution
  233. 1997 Sunfire 2.2L OHV starting problems
  234. Trac Off Light
  235. 1996cav/2000sunfire
  236. 90 Cavalier Dies when warm Please read
  237. Please help! problem connecting to obd2 port on 1995 cavalier
  238. 99 Cavalier, broken Fuel filter Quck-Disconnect
  239. Please Help. Ets Off Problem No One Can Fix!!
  240. wiper problem
  241. Problem with my car..Pls Help
  242. 98 Intake Removal
  243. Looking for help with trunk (and another Q)
  244. 94 cavalier problem help me
  245. 97 Cavalier Speed Sensor
  246. misfire question
  247. Running Lean?
  248. 2002 Chevrolet Cavalier drivers side headlight bulb problem
  249. Unknown Dash light
  250. Ahhhh!! Wind Noise! So Annoying!
