Our Community is 705,000 Strong. Join Us.
View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. 1996 Chevy Caviler Smokes, missfires, and has oil in air intake box.
  2. 99 Cavalier ABS Light on
  3. 99 Sunfire GT 2.4L Twin Cam Auto--CLICKING NOISES FROM ENGINE BLOCK
  4. 98 cavalier stalls
  5. 93 chevy cavalier
  6. 2.2 oil pan gasket
  7. ok heres one for ya I NEED HELP!!!!
  8. 96 2.2L crank/no start...keep reading
  9. Help with Air Conditioning Compressor
  10. obd codes 96 cavalier
  11. '98 repeating electrical problem (fuel line)
  12. ac in 98 cavalier
  13. 2004 overheating
  14. 97 CAVALIER blinks really fast
  15. 03 cavalier help -> W. VIDEO
  16. Accelerating/turning noise
  17. sounds like it wants to back fire
  18. 2003 cavalier growling noise
  19. 1996 z24
  20. ECM QUESTION for a 1994 Cavalier
  21. e brake
  22. 01 Cavalier, Fuel Line Schrader Valve Location?
  23. Good Site to get Codes, OBD2
  24. 2003 Cavalier fuel gauge problem
  25. 2004 chevy cavilier
  26. 95 Cavalier shimmy at Highway speed
  27. '91 Cav, 140000km, hesitates on acceleration up to 30km/hr
  28. 2003 cavalier HID help.
  29. 2003 cavalier help. Cluster gauges.
  30. 02 cavalier 2.2 ecotec HELP
  31. 2001 sputtering in drive
  32. AC issues
  33. 97 cav tranny issues
  34. help 2000 Z24 acting stupid
  35. Check Engine Light- Code 25
  36. cav. sutting off while driving
  37. Max AC Clicking/Tach Problem
  38. Wet floors-2002 4 door Cavalier
  39. Fuel Gage
  40. '03 Cavalier with slight ticking (Lifter? Timing? Tensioner?)
  41. Strange Radiator Fan Problem? Help?
  42. Air Conditioning Problems
  43. Horrible sound
  44. code P0325
  45. 96 cavy wont start
  46. timing & head Q's
  47. "97 Cavalier 2.2 slow start, & code 440 issues
  48. 99 Sunfire - Need help - 2 Problems....
  49. 1998 Pontiac Sunfire - No dash lights
  50. 99 Cav - Switch from non cruise to cruise?
  51. cavalier 99 cooling fan
  52. 94 problems
  53. 04 Cavalier Troubleshooting
  54. drl (daytime running lights)
  55. engine light comes on
  56. Engine and Transmission Compatibility Issues
  57. 97 sunfire clutch leak
  58. 94 cavalier stalls
  59. Decided to rebuild my engine
  60. 97 sunfire (2.4lt twin cam) serpentine route
  61. adding a/c
  62. Changed brake pads now trac off light and brake warning light stay on
  63. 1996 cavalier 2.2 shocks
  64. 2002 Cavalier - Oil in Air Intake
  65. 92 cav crankshaft sensor
  66. 1998 Sunfire 2.2 troubles
  67. 2000 Cavalier just died. Won't stay running
  68. P0440 Evap system problem
  69. Engine dies while going down the road
  70. 1992 Z24 3.1 Can't get the timing set back right....(MY FAULT)
  71. 2004 cavalier, only cranks and code reader wont read?
  72. What do you think about the Mitchell1 Website for manuals?
  73. What's next?
  74. Premature brake wear?
  75. Wheel Bearings
  76. 2.3 Tapping loud
  77. My 2002 Cavalier LS 4 Door Coupe
  78. stalls when put in gear
  79. 1998 2.2 L Sunfire overheats
  80. 99 cavalier 2.2 guage cluster goin crazy
  81. I don't want to spend a ton
  82. Stalls and studders
  83. Bad parts at Auto Zone??
  84. 2000 Cavalier Vent Flow Problem
  85. Aftermarket cd problems
  86. 2002 chevy cav err message on radio?
  87. Transmission Problem?
  88. Tips for starter modification
  89. Any other way to read the engine codes?
  90. Sounds like a LAwnmower, Help!
  91. 96 Sunfire 2.2L Misfire after new Batt. & Alternaotr
  92. Overheating and surging idle 99 z24
  93. no cooling fan
  94. power window limit switch
  95. check engine light
  96. 2002 Z24 Cavalier - won't start...sometimes...
  97. Electrical or just a pain?
  98. '97 cav 2.2 stalling
  99. horn button
  100. 1998 2.2L quit running
  101. 2002 Cavalier A/C and Radiator Fan Not Functioning
  102. 2000 Z24 dome light will not go out
  103. 93 cav 2.2 emissions control??
  104. noise in driver's side front
  105. 99 z24- nightmare stereo installation
  106. 2003 Cavalier parasitic current
  107. 99 cavalier z24 5sp stnd. (shifter Problem)
  108. 2002 Cav ABS harness
  109. Hit Large Chuckhole
  110. Front Brake replacement.
  111. radiator
  112. Cavalier 2.2 ecotech RPM's bounce around, sometimes dies, runs normal rest of time
  113. 91 Cavalier RS 3.1 Wont stay running
  114. 97 Cavalier 3T40 transaxle drain, fill plugs
  115. 1996 2.2 heater
  116. 1997 Cavalier wipers park in middle on delay
  117. Starting problem
  118. Code 445
  119. cooling fan always on
  120. 2002 Chevy Cavalier A/C compressor oil leak
  121. 2.2 head gasket replacement tips
  122. 1998 chevy calvalier
  123. 2003 Cavalier quick question...
  124. Cav heating up due to fan not running
  125. 04 Cavalier rubbing noise
  126. no air
  127. air filter question
  128. Need help with daytime running light on 2000 sunfire
  129. 1998 cavalier engine code P0742
  130. !998 Engine Code P0742
  131. Belt or Chain?
  132. 96 cav 2.2 W/ac cooling fan problem
  133. 2001 cav electrical issues
  134. Opinions on Front End Noise
  135. 1999 Cavalier Fuel Pump Electrical issue?
  136. 97 z24 clutch slips
  137. 93 cavalier can't restart after warm.
  138. trip odometer weirdness
  139. A/C Compressor problem
  140. Exhaust (mount)?
  141. remote starter help
  142. tps or ecu?
  143. 2000 Driver DRL Issue
  144. gas line on a 91 cavilier
  145. 01 sunfire a/c not running right
  146. Getrag F23 rebuild
  147. '00 cavalier, odd noise and oil in air intake/throttle body
  148. 98 cavalier
  149. 92 cav crankcase vacuum
  150. Strange Electrical problem
  151. 91' 2.2 cavalier making vibrating grinding noise from gear shifter?
  152. ABS and Brake light on
  153. 201.4mm rear break drums??
  154. engine rebuild
  155. stalling / surging idle
  156. 2000 Pontiac Sunfire GT Randomly Loses Power
  157. 90 cav tach wire
  158. Replacing a Fuel pump in 99 Z24 convertible
  159. 97 Cavalier Tranny Change Bearings Suspect
  160. HELP~PLZ! Need advice on TimChain etc.
  161. 2004 cavalier - Please Help
  162. 2000 sunfire overheating
  163. 93 Cavalier 2.2L (2quick questions)
  164. 1998 Sunfire with Temp Guage issue.
  165. 1996 Sunfire GT - engine stalls out when warm
  166. Cooling Fan Relay
  167. Tranny mounts
  168. 95 Cavalier Heater Core
  169. Stock 94 Cavalier power locks are sticky
  170. 2000 Sunfire, Starter snaps then no power.
  171. '03 sunfire headlight wiring issue.
  172. 96 cavalier 2.2 clutch pedal not returning???
  173. 97 cavalier wont start with key
  174. 2004 cavalier 2.2 service lights
  175. 91' Cavalier losing power up hills and pop noise and cuts in and out
  176. Name that part
  177. Starter won't stop
  178. 94 cavalier elec
  179. low end knocking. serious? easy fix?
  180. Need help with 96 cavalier trans
  181. Just replaced timing chain, bacfires through throttle body and exhaust!
  182. How to remove spark plug wires
  183. 2000 cavalier radio loc code
  184. 2004 Cavalier hood release problem
  185. 2001 chevrolet cavalier
  186. a little direction please!
  187. RPM's rev at contant speed?
  188. 96 z24 cavalier idle problem 2.4
  189. Passenger-side headlamp not fully lit
  190. car dies at stop lights
  191. spark plug not firing
  192. confused
  193. Question on replacing rotors on 96 cav
  194. '95 engines
  195. 1996 cavalier 2.2 starting
  196. Grinding Wheel, Not the bearings.
  197. 99 Cavalier over heat/no start
  198. 96 2.2 head gasket R&R
  199. Leaking freeze plug?
  200. Chevy cavalier power steering problem
  201. no start 95 cavalier 2.2
  202. 2001 Cavalier Battery Drain Problem - HELP
  203. cavalier fuel injector pops out after shut off engine
  204. 04 Tranny
  205. 97 2.4 cav sounds like a diesel engine
  206. 2001 Cavalier Stalling only when Cold.
  207. 2001 2.2 Shift Solenoid
  208. Installing a new gasket!
  209. Is it possible to replace connecting rod bearings on 2.4l w/out removing engine!?
  210. cooling issue
  211. automatic flywheel on a standard?
  212. 99 cav convertible quarter window help
  213. 99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights
  214. Trunk Remote Problem
  215. Cavalier is overheating
  216. 02 Code 0440
  217. My engine light came on today...
  218. 95 Cav 2.2 no start
  219. 2004 exhaust rattle
  220. 97 chevy cavalier won't start changed plugs ran fine two days
  221. possible coil pack problem?
  222. 2002 blower fan question
  223. 96 Cav 2.2 water pump R&R
  224. Cavalier Brake Master Cylinder
  225. Object found in engine,..can anyone ID this piece?
  226. 2001 Cavalier
  227. 98 sunfire gt 2.4
  228. 95 cavalier not firing
  229. Rythmic engine noise in '03 cavalier
  230. 90 cavalier engine running rough
  231. 97 sunfire ...clutch pedal to the floor to shift
  232. 2000 Cavalier Idle Surging High and Low
  233. 94 Cavalier, good battery, goes dead, clock stay on
  234. battery dead starts and will stay running till i let off the gas
  235. 2001 Cavalier start/run problem
  236. '97 Z24 Cavalier Losing Coolant/Overheating
  237. Help.!!
  238. 90 Cavailier auto transmission wont move in reverse
  239. 99 sunfire clicking during braking causing lights to flicker
  240. 04 Cav. AC Max in/outside air door actuator
  241. 99 cavalier need to press gas to start
  242. 96 Sunfire
  243. 98 cavalier
  244. 1996 Cavalier
  245. 1998 Cavalier stalls
  246. V8 Cavalier??? Say Wha?!
  247. Replacing CV Joint 1997
  248. 2001 z24 starts but will not run
  249. 95 parts on a 03
  250. How to remove Instrument Cluster on a 93
