Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
2000 LS 2.2 - Died on road, won't start, still turns
3 questions
Odd brake-problem sound
98 Z24 is idling rough
02 cav 2.2 sohc auto no start!!!
clacking sound at start
Haynes or Autozone?
quad4
Ughh I need to install an evaporator for 97 cavalier
2002 Ecotec Cooling Fan Problem
97 won't start
PowerLock Relay...location??
97 Cavi - dreaded P1336
'99, automatic, 2.2, "grinding" noise in first
95 Cavalier Horn Problem
00 Z24 keeps stalling once warm!!
Coolant Bypass Pipe Removal
TPS problem?
Power Lock Switch not working..help plz.
A/C not blowing through front vents
2004 Cavalier Fuel Tank Removal
Acceleration problem around 45-55
wierd problem with chime and dome light
96 Cavalier won't start or even turn over
fuel to throttle body but no fuel to start vehicle?
Cavalier shifter cable problem
95ish Cavalier won't start
2004 Cavalier HVAC control lights
'97 Cav - Passlock/PCM problem, won't start! =*(
200 cavalier dosen't turn over after wreck
Vaccum leak?
98 z24
check engine light
Parking brake problem?
2001 Cavalier back up light problems
Changing Fuel Pressure Regulator
02 cavalier rough shift into 2nd gear
1994 Chevy Cavilier transmission fluid change
1994 Chevy Cavilier reverse flush
1991 Cavalier RS Lower control arm broke
Sunfire GT 2000 stucking idle
96 Sunfire Stalling
Loud noise from front end 97 Cavilier Z24..CV Joints??
Please Help :(:(
2000 ac problem
2002 2.2 engine in a 2000 Cavalier?
Hard start
2003 Cavalier Headrest Removal, How Do You Do It, Its Drivin Me Nuts
Battery?
overheating...
starting, window ,and guage problems
99 cavalier w/2.4L DOHC TDC P0300
Can I Hotwire My Ignition?
2004 chevy cavellier -fan coming on
No start after timing chain replacement
Cavalier z24 2 door power windows help!!
Tach/speedo problems on a 97 Z24
Help Transmission Keeps Blowing Clstr Fuse
Transmission & Temp sensor questions
97 sunfire low/rough idle
1994 3.1L idels and runs rough
bulbs
location of Cooling fan tempeture swith
Burnt out odometer light bulb!
91 Cavalier Fuel Filter Location
Overdrive on '97 Cavalier
1996 Cavalier Cooling Fan stopped working
Backfire Thru IM
fuel injectors or MAP?
How to change my digital dash to a regular one?
Driver's side power window not working.
Toyota Brake light randomly quitting
Shuddering...transmission problem?
A/C is not working at all. Please Help
sputters/ cuts in and out at highway speeds
Omg..Shifting Problems!!
Steering columm needs adjusting-How?
Gauges start jumping, lose power steering, car won't start for 5-10 minutes
Passlock Bypass
1999 Lockup torque converter problems
Timing Chain Replacement
02 cai problems
92 Cavalier won't start unless wheel is cranked to RIGHT
96 cav 2.0 start/run problem
How much fuel pressure does the return line have on a 96 cavalier?
Shifting 1st to 2nd - 'Whoosh'
Ignition Problems
cluster removal in 98' z24?
Stalls at idle ONLY when outside temperature gets HOT??
Fan Motor not working on low and low/medium
Wheel bearings
2002 Cavalier elec problem
1992 Chevrolet Cavalier VL 2.2 - TV Cable Issue
Rear -02 sensor
Newbie question about whinning sound from front-end
'96 2.2l cav battery replacement issue
car wont start
1990 Cavalier where is the cruise control module located
Big transmission problem, or not a big deal?
Pontiac engine problems
door lock repair question
please help 1999 chevy cav wont start
My Cavalier Hates Me - MYSTERY PROBLEM!
2000 Cavalier hard starting after warm sometimes
Won't pass emissions, high hydrocarbons
02 cav 2.2 hesitation or no start or just fine oil in airbox
How do I disconnect Cav pkg light sockets?
96 Pontiac Sunfire GT 2.4L Twin Cam
Brakes, only one wheel working!!
Trans output seal help
**Replacing Ignition**
00 2.4 cav idle problem 1500rpm to 3000rpm
fill plug on
1999 Ignition coil problem
Fuel pressure
97 sunfire overheats when idling
2004 Cavalier Overheating / Fan Replacement
CV Joint/Ball Joint (?) 1996 Cavalier
Head rest replacement
Multiple issues after lightning strike
overheating on my 96 cavalier
01 Cavalier 2.4
96 Cav Fuel Filter QD replacement
how to rebuild 88 cavalier Z24 tranmission
97 Z24 Issues Again, Ffs...........................
ABS light
Gas tank pressure buildup
P0440: EVAP small leak/no flow condition
2.3 Quad Four in 95 ragtop engine racket.
89 with 2.8 and auto trans
Grinding noise when i turn right only
Door Lock Problem
Lowering a 97 cavalier Z24 with Tokico struts & springs - Need Help for strut mounts
RPMs lower than normal; car dying.
Popped Serpentine caught code P0420 2.4L DOHC 98
95 Chevy cavalier
check eng / lost 4th gear on highway?
93 cavalier z24 wont start
96 Cavalier, what's behind the front passenger side bumper?
1998 2.2 Can not find the second coolant bleeder screw?
01 Chevy Cavalier 2.2 that bucks
fuel pump issues
04 Cavalier Daylight Running Lights
Arggghhhh!!
93 2.2 ignition control module questions
99 Sunfire GT...hard shifting
Lost need help
car broke down. need some help. puhlease
99 oil pump ????
Missing and no power on accelleration
egr valve problem
airbag light help?
98 cvalier rear brakes SHUDDER!!!!
Low Speed Vibration
2002 brakes need attention every three weeks?
Headlight, windshield wiper and door lock problem - 2001 sunfire GT
Won't start for exactly ten minutes
Driver door shakes at highway speeds.
knocking noise in the lower end of a 2.2 l
O2 Sensor Help
warning chime
2001 2.2l #1 cylinder plug is melted down! Please help! Timing?!?
Idle air control
Crismas Headlights....
Overheating No Matter What I Do!
Is my engine on the way out?
01 Cavalier window problems
NO HEADLIGHTS....on a 98 Cav
Sunroof problems
is my clutch messed up?
Po 507
Drl And Park Lights Only Working!!
2004 Cavalier Intermittent Airbag Light
98 Chevy Cavalier that surges
96 cavalier no power when accelerating
Replace Cruise Control Module 2002 Cavalier
1994 cavalier shakes
96 cavalier ignition problem
Starter Motor Bolt Torque
Natural Gas
Abs
Shaking Omg Why, Sick Of It!!!!!!!!
Engine Jumping HARD etc.
99 Cavalier- no brake lights, no turn signals
89 cavalier
97 z24 whine in 1st and 2nd
p1870 code for check engine
'97 2.2 stalling
Tach wont work??
Cavalier Z24 Engine Cuestions...
'96 A/C issue
Got a brand new 2.2 motor, need some answers!
What kind of fluid is this?
Engine Trouble
2003 Cavalier code P0420
2003 Cavalier Check Engine Light
Trunk wont stay closed
93 Cavalier RS fast idle
HID Lighting problems ><
02 Cavalier Trac Off light then died
'97 Cav computer reset
02' Sunfire high rpm's in neutral??
no spark no matter what
Warning Lights Keep Goin On and off
no power
gas shooting from cylinders on 95 cavalier
02 Cavalier
fan not coming on
no low beam
'99 Key won't turn to start position
Manual transmission stuck in 3rd gear
96 cavalier brakes - HELP
window motor ..
1998 Sunfire has a knocking sound in the tire
'93 RS Problem
spark plug location...
97 Cav P0440
New Problem
2001 back seat removal help NEEDED
Spark Plug Wires
Cylinder flooding
Help 1992 2.2 Cavalier
Cavalier Plastic Bumper?
95 cav tcc solenoid
Help...98 Cav Turn signals/dome light/RR Defogger all working/not working..??
Driver Window rolls down (powered), stuck.
1985 Cavalier won't start after tune up
'97 Cav 2.2 oil pan
94 cavalier z24
97 Cavalier DRL
Red back lighting on odometer
2003 Sunfire foglights
1991 Cavalier Transmission Problem Please Help
98 cavalier electrical issues?
96 Cavalier instrument cluster issue.
95 Cavaliar reoccuring headgasket leak
Help....My engine is crazy
Need some guidance on ignition lock cylinder
2001 sunfire firing problems
car cranks no spark
ATF - motor oil
Plug wires
91 Cav. had engine catch fire
Please help engine caght fire
bad lower control arm bushings?
f**ked up ignition
96 cavalier z24
pontiac sunfire gt 2001 bcm question?
Web
AF
