View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16
  1. Clutch or Slave/Master? Help, Please!
  2. 1997 Cavalier Coolant Leak Z24 2.4 help please
  3. 2001 Cavalier LS - Any warnings?
  4. noise in the back
  5. Starting Issues
  6. 2002 Chevy Cavalier - Check engine light - Error Code P0742
  7. 2004 Cavalier Speedometer Problem
  8. 1996 pontiac sunfire hard to start
  9. 1996 z24 cavalier problem
  10. ETS Off Check Engine
  11. Need Help With noise comin from front wheel
  12. 02 Cavalier wiper arm issue
  13. 01 Cavalier intermittent start hesitation
  14. Possible Hydrolocked Engine?
  15. 2004 Chevy Cavalier misfiring
  16. Battery light issue
  17. 1997 Cavalier CV Joint need help
  18. Heating
  19. Groaning in front end
  20. need help with head lights
  21. 05 Cav power window shorting
  22. 2002 Cavalier - Dim Odometer
  23. Signal Mayhem - sunfire.
  24. What Type of Plastic Was Used on 1986 RS Cavalier Bumpers
  25. I Think She's Dying
  26. sway bar and struts
  27. 04 Cavalier Sway Bar Questions
  28. brake booster removal question
  29. How to replace '03 Getrag F23 transmission
  30. 2001 Cavalier No Start No Guages
  31. Rhythmic knocking/pumping? noise from back of 05 cavalier
  32. 97 z 24 high idle & harsh shifting at high rpm
  33. 2000 Cavalier Check Engine Light Extinguisher?
  34. 97 z 24 idles high and shifts late. happened overnight?
  35. 01 Sunfire Won't Start
  36. Headlight Wiring '95 Cavalier
  37. Popping sound in front in.
  38. Service Engine Soon warning light
  39. power windows 99 z24
  40. Motor swap from a 97 to a 96 not getting spark.
  41. hard to start when cold
  42. 03 cavalier occasional starting trouble
  43. 2003 cavalier: cooling fans wont stop running
  44. serpatine belt
  45. Please Help! Only car I have!
  46. 92 Cavalier head removal
  47. Tell me what's going on here(clutch related?)
  48. Air in the Power Steering line 2020 cavalier
  49. Random Misfiring on Multiple Cylinders
  50. Shaky Situation.. Please Help!
  51. Tail light problem
  52. cav clunk
  53. 04 sunfire 2.2 low idle problem with knock
  54. Driver Side Door Lock
  55. Fuel pressure specs. for 1994 cav. 2.2 L
  56. 98 Cav Parking brake
  57. Please help...
  58. Windshield Wiper Problem
  59. Help Low oil pressure only at warm up!
  60. '96 - ABS, Brake, *AND* Oil Lights?
  61. '02 Sunfire - How do you change the oil filter?
  62. overdrive sensor
  63. over drive sensor 1993
  64. 96 Cavi Gas Gauge
  65. Guages on 04 sunfire not working right
  66. 96 quad-4
  67. Half shaft bearing
  68. Brake Line replacement
  69. center console light
  70. 1997 Cavalier stalls at Temperature
  71. 05 Cavalier 5-speed shifter...loose?
  72. after accident issues
  73. Headlight wiring diagram
  74. how to stop water leak 93 z24 interior
  75. 2003 Cavalier Clicking Noise when de-accelerating
  76. Losing Spark
  77. Calliper locking up
  78. Help would be appreciated
  79. 96 Cav timing out to lunch
  80. idle speed increase
  81. Dies when shifted into drive
  82. 03 Manual Shift linkage adjustment?
  83. 99 Sunfire Conv Remote Starter DIY install glitch
  84. wet drivers side floor
  85. need help on cavalier
  86. Issue with overheating
  87. 96 sunfire 2.2 fuel filter
  88. squel from belt area when idling?
  89. 2000 Pontiac Sunfire - randomly won't start
  90. 2002 Sunfire
  91. 95 cavalier tie rod
  92. Cooling Problems 2001 sunfire 2.2
  93. Cooling Problems
  94. front brake caliper bolts
  95. Odd problem - no chimes, no radio
  96. cranks and runs fine but wont restart
  97. belt tensioer came loose and unsprung. Please help
  98. car stops running after a while
  99. crank shaft sensor?
  100. Strange CD problem
  101. coolant leak water outlet
  102. 03 Cavalier: Car idiot questions - breaks, static, general maintenance?
  103. 03 Cavalier: Car idiot questions - brakes, static, general maintenance?
  104. Wipers
  105. My 2000 Sunfire Gt has a miss HELP!!
  106. Hum and a Grind?
  107. Strange CD problem
  108. Water pump pipe
  109. squelling
  110. 1999 Cavalier flashing dash lights problem...
  111. 1990 cavalier problem help!!
  112. 02 Cavlier Shudder 40 - 60 mph
  113. Temperature Gauge Acting up
  114. 1996 Chevy Cavalier clutch problem
  115. crud....
  116. Mass Air Flow Sensor
  117. '97 Z-24 Rough Idle When Started
  118. 2001 cav - high rpm idle - IAC Valve location?
  119. 93 cavalier starter removal
  120. 91 cavalier 3.1 interferace engine????
  121. Speedometer spikes, then car stalls...
  122. HELP!! car won't stop overheating
  123. 1997 Cavalier 2.4L bogs
  124. Fuel line
  125. Car stalls out after leaving a stop.
  126. 2001 Cavalier has a vibration/thunk from the rear ONLY while making right turns.
  127. Gauge Problems
  128. Cavalier Cluster! HELP
  129. Removing Catalitic Convertor 02 Cavalier
  130. 96 Cavalier 2.4L trans removal
  131. injector flush
  132. oIL LEAK
  133. 97 cavalier shifter cable
  134. car rpm continue to rise after shifting
  135. CV 'inner' Change out 2002 Sunfire
  136. 2002 Chevrolet Cavalier burning smell in car
  137. Radiator fan
  138. 96 cavailier timing issue
  139. Fuel fittings
  140. starts, runs for a few seconds
  141. 04 Cavalier problem
  142. fuse
  143. how do you remove the spring loaded belt tensioner
  144. Oil leak
  145. OBD II style connector on an OBD I vechile
  146. Replaced Spark Plugs and Wires
  147. front suspension help
  148. 96 Sunfire axle
  149. 1999 Cavalier back doors will not open, not power locks
  150. engine swap troble 97 into a 96 help plz help
  151. 95 2.2ohv stalling when eng warms up
  152. Operating temperature?
  153. Operating temperature?
  154. car shaking, wheel locks, car in neutral
  155. 2000 cavalier air bag problem
  156. 98 cavalier headlights
  157. 98 chevy cavalier won't start after accident
  158. Power Steering Return Hose
  159. 99 Grand AM steering problem
  160. 95 Pontiac 2.2 L OHV engine
  161. Need help/opinions on coolant flush
  162. 96 Sunfire no start when hot
  163. 90 2.2 tbi
  164. Help!!
  165. Keyless Remote Programing
  166. Need some advice about lots!
  167. auto transmission stuck in low
  168. 94 Chevy Cavalier Z24 3.1 Timing chain issues
  169. Starter won't disengage
  170. Car won't start
  171. Fuel Pump or Filter?
  172. rubbing sound at front wheel
  173. Smoking under the hood
  174. 2003 sunfire camshaft sensor
  175. Ignition Key Switch ?
  176. 99 CAVALIER starter
  177. No Power At The OBD-II Connector
  178. Check engine light and error code
  179. 1989 cav grrrrrr
  180. Help! Knocking noise
  181. Grinding noise
  182. hard starting/dies while in motion
  183. Dim Gauges
  184. Caliber Bolt won't turn
  185. troubleshooting rear defrost
  186. Engine Whirr
  187. 2004 Cavalier
  188. 1999 Chevy Cavalier Z24 2.4 DOHC A/C Issue
  189. 97 Pontiac sun fire 2.2L OHV will not start
  190. so confused please help
  191. problems reading codes on a 97 Z24
  192. Horn Quit on 2003 Cavalier
  193. Water pump
  194. Radiator fan plus AC?????
  195. 2004 cavalier wiper problem
  196. Running Extremely Lean
  197. Brake Problems
  198. No Dash ligts, tail lights or 'lights-on' bell
  199. 01' 2200/stick
  200. right rear turn signal out
  201. Is it the fuel filter or something else
  202. Desperate Sunfire help
  203. 2001 Cavalier Power Loss
  204. ***Squeakie Noise When Driving***
  205. Chevy Cavalier interior door lamp won't turn off.
  206. fuel pumps
  207. Air Bags sensor question
  208. security theft system problems
  209. Fuel pump fix
  210. Leaking coolent
  211. Rattling
  212. Brake Problems
  213. 93 Cavailer Fuel @ injectors, spark @ plug, won't start
  214. 93 Cavailer Fuel @ injectors, spark @ plug, won't start
  215. 2003 Standard Cavalier - Help
  216. brakes wont work please help
  217. need part numbers
  218. michael s.
  219. 96 cavalier
  220. '97 Cav. A/C prob's.
  221. caviler 2.4 liter need mega help
  222. Frequent headlight failure - 2000 Cavalier
  223. 1996 2.2L Noise from fuel tank
  224. Spark issues on 91 Z24 HELLLP!!!
  225. '99 Z24 alternator fried. Need helpful instructions on how to replace it.
  226. 94 Z24 auto trans issue HELP
  227. 98 cavalier-How do you change the manaul transmission oil?
  228. keyless remote issues
  229. 1992 Cavalier 2.2 ran intermittently then died, has spark and fuel pressure
  230. 97,cavalier wont start
  231. plug wires
  232. oil pan
  233. 1994 cavalier Z24 oil pressure
  234. my cav doesnt want to idle out
  235. 1996 Chevy Cav High RPM to shift
  236. 1999 Cavalier LS Won't Start - Maybe Alternator?
  237. Brake Drum
  238. 01 cavalier, No headlights, wipers and drivers door lock
  239. Fuel leak
  240. Engine tick
  241. I smell gasoline
  242. 1993 Cavalier, 2.2 L, 4 cylinder
  243. I Need Help!!!
  244. 1997 to 1998 engines
  245. 2001 Cavalier Headlight Issue
  246. 98 overheating at highway speeds only
  247. Chasing an Engine Misfire... any input
  248. Tcc
  249. A/C problem
  250. 99 Sunfire 2.2L doesnt like to start right away
