View Full Version : Cavalier Problem Diagnosis
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. overheating/loss of coolant
  2. 2001 cavalier temp gaugepegs no heat
  3. overheating
  4. 96 Cavalier won't start/stalls when boosted
  5. 2001 Cavalier Makes CLicking Noise When TRanny Is Put Into Reverse
  6. 00 cav 2.2 rich condition
  7. exhaust to downpipe
  8. Service Light ( wrench icon ) no codes??
  9. Temperature Gauge
  10. Charging Problem
  11. low voltage to tps and egr
  12. Can't Remove Heat Core Cover
  13. 999 Cavalier Will not start
  14. 92 cavalier instrument cluster burning out?
  15. 90 cav driver window
  16. egr pintle position
  17. 00 cav 2.2 p0300
  18. Problems with service light and blinkers ???
  19. 97 cavalier won't stay running
  20. 2003 Cavalier scraping/rubbing sound, please help!
  21. Lifter installation
  22. Alignment
  23. Odd front end feeling
  24. 94 cavalier heat actuator mounts
  25. 94 cavalier blown head gasket??????
  26. PS Box leaks at pully crankshaft?
  27. 96 Cavalier runs a bit rough after new fuel filter installed?
  28. Manual Transmission Fluid Dissapearing
  29. 1997 Cavalier computer issue
  30. 2000 Chevy Cavalier Battery Problem
  31. 05 sunfire gauge problems
  32. 1994 cavalier heater, wipers , radio
  33. 1992 cold start problem
  34. Trouble codes PO342, crank senors stuck
  35. 90 Cav drivers window
  36. 96 chevy z24
  37. 2002 chev cavalier radio code and procedure
  38. Power loss after hitting bump
  39. Service and ABS light Cavalier
  40. Temperature Gauge all the way to hot
  41. 99 Cavalier repair
  42. 97 cavailer cooling problem
  43. 1998 Sunfire engine codes
  44. Weird Electrical Problem
  45. 2002 highbeam indicator...
  46. 2,2 cav rod bearings
  47. How Hard Is It To Change The Heater Core On A 1999 Cavalier?!
  48. help.. wont start 96 sunfire
  49. 2002 2.2L idler pulley bolt
  50. Need to Push on Gas For my 2.4 to Start
  51. Slow turn signal
  52. transaxle noise
  53. highbeams not working... 2003 sunfire
  54. hard starting
  55. '00 sunfire 2dr cp, high pitch sound when driving
  56. 1996 sunfire excessive fuel usage/ running rich /lean
  57. 99 Cav Overheating?
  58. 1998 Cavalier - Clutch Going?
  59. 97 cavalier wiring harness
  60. Brakes!
  61. 97 2.2L timing confusion...help
  62. 98 Overheating Again
  63. Tire Question(s)
  64. Hearing a loud roar at all speeds. Until I touch the brake.
  65. Idling rough, power issues, stalling.
  66. 99 cav hard shifting
  67. 98 cavi with brake probs
  68. puzzling problem with my cavalier
  69. Could it really be the fuel pump??
  70. 99 sunfire fuel pump fuse blows intermittently
  71. non-AC serpentine
  72. 94 cavalier engine mounts and struts
  73. wheel bearings???
  74. anti-theft?????PLEASE HELP
  75. My 99 cavalier has a check engine and ets off light on and shifts hard and surges
  76. Rear main seal
  77. PASSLOCK Code, Car won't start
  78. mil code p0118
  79. Oil pan sealant
  80. Help! Failed Emmisions Test on NOx, Ignition Timing Advance to blame?
  81. 92 Chevy Cavalier no start
  82. 1998 door pins
  83. 1998 z24 door pins
  84. 03 cavalier electrical problem
  85. fuel line help
  86. 91 chevy cavi idles fine full throttle response till i put it in drive then it craps out.
  87. Finally Installed NewEngine, Error codes
  88. Please Post a picture of the Half Axle and Trans connection
  89. Passenger side Half Axle
  90. Best way to fill - purge cooling system
  91. Oil in the fuel line?
  92. A/C fan problem with 94 cavalier
  93. Installed Trans and engine, Now not shifting?
  94. Trouble re-installing front axles, Help
  95. Throttle Body and Air Cleaner Assembly
  96. How do you drain the trans fluid ?
  97. 94 Cavalier AC/Heat problem....
  98. What is this? It has a connector too
  99. Starter Connections
  100. Help. Snapped the bolt at the trans cooler line.
  101. Can't Find Connector
  102. HELP. Can't locate Connector
  103. Changed starter now no spark from one coil
  104. Theft light - Can't Start
  105. 93 chevy cavalier
  106. Fuel Injector , Missing spring clip
  107. Help Passlock 1 issue sunfire
  108. Rear Signal Lights, Brake Lights, and Backup Lights not working
  109. 99 Z24, IAC & IAT high voltage, bucking on upshifts, AC cuts out from this
  110. '05 Cavalier Stalling
  111. new idling problem
  112. Main cap bolt torque
  113. Gas tank
  114. 04 Clutch replacement
  115. 98 Cavalier: Starts, then dies?? All warning lights on...
  116. 98 Cavalier Starts... but dies? All warning lights on...
  117. '93 wiper problems
  118. 93 Cavalier no power to wheels
  119. 2.2 OHV fuel pressure reg ?
  120. fuel line check
  121. 93' Cavalier tired of spending more time coasting in neutral than running in drive!
  122. AC problem 2001 Cavalier
  123. speedo and odometer failer
  124. Gas related stalling issues?
  125. 99 cavalier no start
  126. '98 Cavalier (manual) Starting issue
  127. a/c problems on 98
  128. 1998 stalling problems
  129. 98 Cavalier z24 clutch issues
  130. 97 cavalier
  131. wont start
  132. 87 Cavalier IAT Sensor LOCATION?
  133. wont stay started
  134. 92/94 Transmission: Stops shifting until key-off, key-on...
  135. 92/94 Transmission stop shifting until shutoff, restart...
  136. 01z24 holding 2500rpm idle help
  137. 2000 Cavalier stalling
  138. 2002 Cavalier a/c problems
  139. 98 sunfire wheel cylinder
  140. 98 sunfire clutch pedal stuck to the floor
  141. 95 Cavalier Master Cyl/ABS problems
  142. 95 Cavalier Master Cyl/ABS problems
  143. 95 Cavalier Master Cyl/ABS problems
  144. lights on dash.
  145. 1995 2.2l 5spd
  146. idles funny, when it idles
  147. 2000 Cavalier 2.2 slips when shifting
  148. 95 Sunfire throttle sticking ....
  149. 2001 Cav 2.2L engine problem
  150. Engine Coolant Overflow
  151. '98 2.2 Could old fuel filter cause this?
  152. High Idle - '01 z24 - TPS to blame?
  153. z24 won't run - need advice
  154. No Brake Lights or Turn Signals w/ ABS Light On
  155. Entire Headlight (front end) Re-Wire on 2.4L 1996
  156. Starting problem. Please help
  157. 1998 Cavalier LS 2.4L Water Pump
  158. 1998 Cavalier LS 2.4L Trans Fluid? Cat Converter
  159. 2002 eco tec timing issues.please help
  160. 1996 cavalier 2.2 alignment
  161. PCV VALVE on a '01 2.4 L?
  162. 200 headlight issues
  163. 03 Cavalier radiator fan, operational but noisy
  164. 1992 Power lock problem
  165. 92 power lock problem
  166. High Idle 1990 3.1
  167. Hesitation under 2k
  168. changed plugs/wires now won't start
  169. Single disabled mom needs help;
  170. clutch or tranny?
  171. ICV Idle Control Valve not working
  172. Releasing Fuel Pressure
  173. Problems With Stalling
  174. 04 2.2 ecotec removing dash problems to get to the radio
  175. DLR Relay Issue
  176. 95 Cav Cooling fan not kicking on
  177. Turning the key on a 1995 Cav does nada
  178. 2001 cavaler no start
  179. New CV half-shaft doesn't fit?
  180. 00 Cav Sluggish with Both AC and Heat
  181. Hesitation on Acceleration / Occasional loss of power & stalling
  182. P1133 96 Cavalier
  183. Knocking sound, please help!!!!
  184. Power loss, maybe transmission
  185. 04 2.2 ecotec dash board going nuts
  186. service light on but no code
  187. 94 2.2L Lifter stuck in bore
  188. Cavalier Engine Swap Help!!!!
  189. 2002 Cavalier Trans/Electrical Issue?
  190. problem with 01 cavalier overheating and started making high pitch squeal
  191. 1996 sunfire 2.2 computer problem
  192. 2002 Cavalier Trans/Electrical Issue?
  193. wierd idle???
  194. collision reset
  195. Possible Passlock 2 issue?
  196. r/t light came on
  197. HELP PLEASE 89 Sunbird won't stay running.
  198. HELP! replace water pump on 2001 cavalier z24 2.4L
  199. Brake Light Problem
  200. Cavalier Idles at 2500 RPM after it warms up
  201. 2004 Pontiac Sunfire Alternating RPM Problem 0o
  202. 1997 Pontiac Sunfire 2.2 Automatic 136K Oil Light Issue
  203. Anti-Lock Brake Light
  204. 2002 Cavalier cooling fan not working
  205. will run great on cold days but when warm outstalls
  206. 2002 Cavalier cooling fan not working
  207. 2002 Cavalier cooling fan not working
  208. z24 2002 sunroof...
  209. Exhaust Smell When Idling
  210. 94 cavalier no green light when ac pushed
  211. 87 Cavalier doesn't want to start.
  212. engine temperture sensor
  213. engine temperture sensor
  214. 01 Cavalier won't turn over - will start (run)
  215. 1998 2.2 cavalier help
  216. 2002 Cavalier cranks but won't start
  217. 98 Sunfire Transmission
  218. Auto transmission shifting hard
  219. 2001 Ignition switch/tumbler removal
  220. serpentine belt help...please
  221. Interesting Problem
  222. Front turn signal replace
  223. Won't crank.
  224. Water in gas tank causing problems?
  225. 1997 cavalier, need help
  226. 03 cavalier stuck in reverse
  227. 2000 Cavalier - ABS light problem
  228. Starts then stalls
  229. gm/pontiac tech/expert help with BCM
  230. need help
  231. 1998 sunfire , need to change door latch! Help!
  232. Lifter adjustment
  233. 2004 Pontiac Sunfire 2.2 engine miss
  234. passlock
  235. won't start-no power to injector
  236. Trac-Off, Check Engine, & now Air Bag lights are lit
  237. 98 cavalier engine missing
  238. Struts mount kit alignment and torque mount
  239. LFT RGT Signal Reverse light fuse blows MINi 10
  240. 04 Manual Transmission Problem Needing Help
  241. 98 cavalier engine surge
  242. 97 Pontiac Sunfire keyless entry remote problems
  243. Head gasket
  244. 99 Cavalier Transmission Problem
  245. I am so frustrated with this car please help!
  246. 97 Pontiac Sunfire 2.4L...Bogging down
  247. I need some help please!
  248. No Spark - Replaced all sensors
  249. 98 Cav Rad Inlet Pipe
  250. Engine interchange
