Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
04 Cavalier rubbing noise
no air
air filter question
Need help with daytime running light on 2000 sunfire
1998 cavalier engine code P0742
!998 Engine Code P0742
Belt or Chain?
96 cav 2.2 W/ac cooling fan problem
2001 cav electrical issues
Opinions on Front End Noise
1999 Cavalier Fuel Pump Electrical issue?
97 z24 clutch slips
93 cavalier can't restart after warm.
trip odometer weirdness
A/C Compressor problem
Exhaust (mount)?
remote starter help
tps or ecu?
2000 Driver DRL Issue
gas line on a 91 cavilier
01 sunfire a/c not running right
Getrag F23 rebuild
'00 cavalier, odd noise and oil in air intake/throttle body
98 cavalier
92 cav crankcase vacuum
Strange Electrical problem
91' 2.2 cavalier making vibrating grinding noise from gear shifter?
ABS and Brake light on
201.4mm rear break drums??
engine rebuild
stalling / surging idle
2000 Pontiac Sunfire GT Randomly Loses Power
90 cav tach wire
Replacing a Fuel pump in 99 Z24 convertible
97 Cavalier Tranny Change Bearings Suspect
HELP~PLZ! Need advice on TimChain etc.
2004 cavalier - Please Help
2000 sunfire overheating
93 Cavalier 2.2L (2quick questions)
1998 Sunfire with Temp Guage issue.
1996 Sunfire GT - engine stalls out when warm
Cooling Fan Relay
Tranny mounts
95 Cavalier Heater Core
Stock 94 Cavalier power locks are sticky
2000 Sunfire, Starter snaps then no power.
'03 sunfire headlight wiring issue.
96 cavalier 2.2 clutch pedal not returning???
97 cavalier wont start with key
2004 cavalier 2.2 service lights
91' Cavalier losing power up hills and pop noise and cuts in and out
Name that part
Starter won't stop
94 cavalier elec
low end knocking. serious? easy fix?
Need help with 96 cavalier trans
Just replaced timing chain, bacfires through throttle body and exhaust!
How to remove spark plug wires
2000 cavalier radio loc code
2004 Cavalier hood release problem
2001 chevrolet cavalier
a little direction please!
RPM's rev at contant speed?
96 z24 cavalier idle problem 2.4
Passenger-side headlamp not fully lit
car dies at stop lights
spark plug not firing
confused
Question on replacing rotors on 96 cav
'95 engines
1996 cavalier 2.2 starting
Grinding Wheel, Not the bearings.
99 Cavalier over heat/no start
96 2.2 head gasket R&R
Leaking freeze plug?
Chevy cavalier power steering problem
no start 95 cavalier 2.2
2001 Cavalier Battery Drain Problem - HELP
cavalier fuel injector pops out after shut off engine
04 Tranny
97 2.4 cav sounds like a diesel engine
2001 Cavalier Stalling only when Cold.
2001 2.2 Shift Solenoid
Installing a new gasket!
Is it possible to replace connecting rod bearings on 2.4l w/out removing engine!?
cooling issue
automatic flywheel on a standard?
99 cav convertible quarter window help
99 Sunfire Dash Light & Radio Lights turn off when you turn on head lights
Trunk Remote Problem
Cavalier is overheating
02 Code 0440
My engine light came on today...
95 Cav 2.2 no start
2004 exhaust rattle
97 chevy cavalier won't start changed plugs ran fine two days
possible coil pack problem?
2002 blower fan question
96 Cav 2.2 water pump R&R
Cavalier Brake Master Cylinder
Object found in engine,..can anyone ID this piece?
2001 Cavalier
98 sunfire gt 2.4
95 cavalier not firing
Rythmic engine noise in '03 cavalier
90 cavalier engine running rough
97 sunfire ...clutch pedal to the floor to shift
2000 Cavalier Idle Surging High and Low
94 Cavalier, good battery, goes dead, clock stay on
battery dead starts and will stay running till i let off the gas
2001 Cavalier start/run problem
'97 Z24 Cavalier Losing Coolant/Overheating
Help.!!
90 Cavailier auto transmission wont move in reverse
99 sunfire clicking during braking causing lights to flicker
04 Cav. AC Max in/outside air door actuator
99 cavalier need to press gas to start
96 Sunfire
98 cavalier
1996 Cavalier
1998 Cavalier stalls
V8 Cavalier??? Say Wha?!
Replacing CV Joint 1997
2001 z24 starts but will not run
95 parts on a 03
How to remove Instrument Cluster on a 93
97 Cavalier.need to press gas to start
Water temp. sending unit
1996 cavalier 2.2 head gasket
Engine Vibration Noise Only During Acceleration
Please Help Me
96, 2.2L sunfire
2000 Sunfire Turn Signal Problem
'98 Sunfire GT stumbles on accleration!
95 Cavalier many symptoms Help!
96 Sunfire must press gas pedal for it to run.
01 Cavalier - Wipers don't stop, looking for help!
95 cavalier VSS terminals at PCM
Brake Rotor Warp
PO480- Cooling Fan Circuit 1
overheating?
Odd problem with speedometer
where is the tcc ?
1998 Z24 knocking. Lifters?
Sunfire starting problem
running like crap when cold.
How To: Check and refill Transmission fluid on 4T40E,4T45E
auto tranny trouble
95 Cavalier no power whatsoever.
2002 Chev Cavalier Poor Gas Mileage ,,, Checked Everything??
2002 Cavalier LS Sport - 3 Problems
93 cavalier problem. No power, 8 DTC codes
MANY problems - '98 Cav
96 z24 cavalier 2.4 no spark.
2000 cavalier clutch
Having oil pressure problems.
93 Cavalier HELP! Its cold!!!
Intermittent Loss of Spark to 2 Cylinders
01 Manual Shift Plate
98 cav parking break cable
How do I know if my Starter is Going out?
How to remove rear door mechanism ?
Put a 99 2.4 in a 97
Electrical Headache! please help.. 96 cav
2003 Cavalier
97 Cavalier Z24 / 2.4L Heat Problem!?!?
98 Cavalier cannot start cold
1999 2.4L Cavalier EGR?
Help with 98 Cavalier
1997 cavi 2.4 RS Convertable power steering issue?!?!?
engine knock
2003 Cavalier Problems
2000 2.4 misfire
1996 Cavalier 2.2 "check oil" light
Need help with my sunfire, coolant leak
Milky substance in intake
2000 Chevy Cavalier Starting Issue (Power/Electrical)
error code is P0141 Bank1 Sensor2. came back on
Running Code P0122
Cavaliar start up on near empty gas level, died, added gas, then did not start
1996 sunfire..
PASSLOCK Override - 1996 Cavalier Demo. Derby Car
1996 pontiac sunfire overheated
Clunk In Front End Under Acceleartion
Ramdom driving problem
Noise from air intake
99 cavalier electrical problems
Another Power Window Thread, I did a search, please hear me out
airbag light on
no brake lights, signal lights, ABS, defrost and power locks
95 Cavalier Transmission engage problems
After collision tranny problem
1996 pontiac sunfire problems
Trunk wont stay open
coldrunning moter
Rear Lights
Brake issue???
Headlight help please
97 Cavalier Rotten Egg Smell
Loud vibration from front of car
Heater Door Noise
Check Engine Light Anomoly!!
99 cavalier cooling problems
2004 Clutch Actuator Cylinder Meltdown
Help with a check engine light...
problem removing + battery terminal
98 Cavalier replacing clutch?
1990 Cavalier runs very rough and stalls when driven
96 Cavalier Nothing When I turn The Key
New belt but MUCH Noise!
The Oh so Common "No start"
Parasitic Draw?
98 cavalier alternator wiring need color code for plug
95 cavalier barely starts/ shuts off after moving
2005 Ecotec 2.2L burning out ignitoin modules
95 Cavalier Barely Starts/Shuts Off When Driven
03 Sunfire randomly died - won't start
2000 Cav when heater is on....
How to remove rear door lock?
Reclining problem with driver side...Need Help..Plz.
My 1994 z24 has a problem staying started.
03 Cavalier no start, no communication
Brake/tail light explodes
Help!! my radiator fan keeps running!!
All Lights Flickering
Problem with my 98 Cavalier
ABS+Brake warning light is on
bleeding the cooling system
Have a coolant leak. Need to know the part name.
Rear defogger Relay
Idler Pulley Noise
1994 chev cavalier headlight switch
2002 2.2 OHV Cavalier Stalls but starts back up
'91 Cavalier RS won't start
97 Cavalier wont start after freeze
96 Chevy Cavalier ( my car is a pain)
1999 chevy cavalier 2. starter or flywheel?
Huge Wiper Problem!
ABS Brake problems
95 cavalier engine noise
Cavalier Heater no working
97 Cavalier Alternator problem?
96 cavalier water pump
02 Cavalier trunk wont close/open
2002 Cav. 80/100km starts shaking a bit
2001 Electrical Issue
89 Cav 2.0 Hesitation Problem Help!!!
My Caviler is possesed
96 Cavalier windshield washer reservoir removal
The back brake locks up but only in cold wheather
Web
AF
