View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19
  1. 1987 4cyl 2.0 Black smoke, poor mpg
  2. 96 sunfire very rough idle
  3. headlight Wiring Short? bad Ground?
  4. 93 cavalier tranny problem??
  5. broken hood latch
  6. Alright guys, here is a tough one for you!
  7. Overheating Help!!!
  8. Power Steering
  9. Multiple Problems in a 2000 Cavalier; Any advice greatly appreciated
  10. 94 cavy 2.2 wont start
  11. click click click...vr-r-r-r-r- v-r-r-r-r-room
  12. Light Problem
  13. 97 Sunfire Car Problem - PLEASE Help
  14. Short Trip issues
  15. what is din and half mean?
  16. Car is chugging bad!
  17. Location Coolant Temperature 2002 Pontiac Sunfire
  18. 1994 cavalier
  19. timing chain again
  20. Any One know a trick to install belt? 96 Cav
  21. 2002 serpentine belt replacement
  22. how to install a 00 01 02 CHEVY CAVALIER REVERSE GLOW GAUGES GAUGES W/T
  23. 2003 Cavalier Starting Problem--PLEASE help. Please?
  24. led issues, HELP!!
  25. 99 Cavalier z24
  26. 01 Cav passenger seat problems
  27. how to get to oil sending unit? 96 cavalier 2.2L
  28. Starting problem with 96 cavalier..iz it injector prob?..plzz help
  29. Fuel Filter Location 96 Cavalier
  30. 94 z24 clutch problems assistance needed
  31. O2 sensor on 93 Cavalier..where is it?
  32. Fuel problem??
  33. newb w/ questions
  34. Replacing clutch on '96 cav. How difficult?
  35. Im so pissed
  36. Valve knock/slap... blah.
  37. problem with my cars fuel system (i think)
  38. '94 Cavalier - Stalling and ABS light
  39. 02 Cavy shifting problem
  40. Shocks...literally...........ouch
  41. Cavalier Door Handle Problems
  42. '96 Cavalier odometer miles wrong
  43. Abs
  44. dashboard says check gages problem
  45. 01 cav wont start
  46. 96 Cavalier Headlight/DRL out
  47. Heat died HELP
  48. 95 Cavalier wont start, Help Please
  49. '94 Cavalier flashers
  50. 93 cav. dumping to much fuel?
  51. Another Passtime
  52. Sunfire Problem!
  53. 98 Cavalier stalling/poor idle
  54. 89 Cav stalls when stopped at red light
  55. valves ticking?
  56. Everything Locked Up
  57. gas smell in pontiac sunfire
  58. 99 cavalier 2.4l fuel problem
  59. winshield smear
  60. 91 sunbird wont start?
  61. 93 Chevy stalls after highway driving
  62. Wrecked Cavalier won't start
  63. 89 cavalier
  64. Clunking noise in Front end?
  65. Bad exterior paint job
  66. alternator battery problems
  67. 1999 sunfire transmission dipstick.
  68. Heater Core
  69. 96 pontiac sunfire jerks..
  70. 02 Ecotec w/ "special" oil filter??? HELP!
  71. overheating?
  72. Stereo/Dome Light/Glovebox Light
  73. 1996 cavalier headlight switch removal help... Please
  74. Gas Leak at Injectors!
  75. Repairing Fuel Lines
  76. '02 Cav Clutch Noise
  77. 95 cavalier no power
  78. 94 Z24 cav wont start
  79. 1998 Cavalier won't pass smog!!!
  80. Turn Signals not working
  81. wiring diagram for a 02 cavalier...im gonna bypass that class 2 data thingy
  82. Trac off light
  83. Help Please!
  84. 97 cavalier manual tranny probs
  85. 94 Cavalier won't start in high humidity
  86. My car is a whinner!
  87. Fan Motor
  88. Engine temp
  89. 2000 pontiac sunfire gt 2.4 sfi
  90. This is my first car. POS!!!
  91. stereo problems
  92. 89 Cavalier 4 Cylinder won't start when cold
  93. Hesitation while accelerating.
  94. Chevy Cavalier
  95. 1997 stalls when idling
  96. Pls help, heater fan problem
  97. 1990 Cavy Battery problem
  98. Abs
  99. Can't shift in freezing weather
  100. brake warning light
  101. hoist lip problem
  102. need help
  103. 2002 Chevy cavalier shifter light
  104. 91 Cavalier No Start Condition (Hot)..Help
  105. 2004 cava with CEL
  106. 2nd gear anyone??
  107. '95 Sunfire Blinker
  108. 2000 Cavalier Coupe manual windows slip
  109. Wipers
  110. Power Window Motor 2002 Cavalier
  111. Am I getting ripped off?
  112. engine stops! help plz
  113. Repair Manual
  114. Check Oil Light
  115. 97 Sunfire 2.2l rouge idle when cold
  116. battery
  117. wires
  118. 99 Z24 Manual Trans Help
  119. Girl who needs help!
  120. Numerous problems - Would like to avoid being ripped off at a shop...
  121. Engine problem
  122. 2001 2.2 over heating.
  123. blower works on one side
  124. 1996 auto trans won't shift
  125. climate controls not working
  126. common cavalier stalling problem
  127. no power/battery
  128. 2003 cavalier won't start
  129. 97 Silverado CD Player Problem
  130. 105k Miles should i change Transmission Oil
  131. Odd intermitant behavior 99 2.4L Cavvy LS
  132. 2002 Cavalier Trans Prob
  133. car shakes at 45 mph
  134. 97 sunfire 2.2 slight miss sometimes and really bad fuel mileage
  135. warning light
  136. Fuel pump relay
  137. Reverse lights out and Transaxle Case
  138. 1999 Cavalier Z24 Intermittent engine knock under Hard Acceleration
  139. strange noise when starting up
  140. 02 Cav. making bad noises!
  141. 2001 Sunfire Headlight problem
  142. Overheating
  143. 96 Sunfire running cold, bad fuel economy, Fan always on
  144. temp drop
  145. 2000 Sunfire No Start
  146. 2001 pontiac sunfire just died going to work will turn over but wont start
  147. 94 Cavalier Blinkers not working????
  148. serpentine belt
  149. Windshield washer probs
  150. Cold Start Problems
  151. 95 Cav - New Thermostat - Now Check Engine Light
  152. cd player problems
  153. Multiple Cavalier problems-estimate of cost??
  154. Parts Help
  155. 98 Z24 Strange Problem
  156. 96 cavalier Air Bag/Seat Belt Light stays on
  157. 96 Cavalier air/heat problem
  158. 91 cavalier losing power
  159. how do i replace my spark plugs on my sunfire gt
  160. Fuel Filter Stuck
  161. '00 Sunfire, no elec.
  162. Shifting problem
  163. Engine Noise and Shifting Problem.
  164. Starter Issues?
  165. Air Selector Knob 1995 Cav
  166. misfire
  167. VSS Problem??
  168. high beam not workin
  169. 99 pontiac sunfire
  170. frost problem
  171. Heater not working
  172. Blown fuse when in defrost mode
  173. belt tensioner
  174. 2003 heat/air selector
  175. 2000 Z24 ignition housing reinstall
  176. 96 cavalier stays in park mode until dr is selected
  177. Electrical Problem
  178. 96 cavalier running cold at highway speed
  179. abs indicator on 99 cavalier malfunctioning
  180. how to repair/replace cigarette lighter in 2004 cavalier??
  181. Fuel Pump
  182. rer rer rer dead
  183. 1991 cavalier will not start
  184. CRJ is stumped for once....
  185. ABS/HZD fuse blowing
  186. 94 cavalier rear defrost
  187. engine shaking and smells. help?
  188. 05 cav radio problem
  189. 93 cav heater blower
  190. viper alarm system
  191. O2 sensor bad?
  192. NO REAR Defrost need major help
  193. he Mystery of The Dissapearing Gasoline
  194. Temp Gauge
  195. no horn or cig lighter?? i need help
  196. ONE signal light won't blink
  197. 91 cavalier runs lean after warms up
  198. New car disaster!
  199. Couldn't shift gears when cold.
  200. 1994 sunbird "check engine" light
  201. gas in my oil?
  202. messed up computer I think
  203. Lost Female
  204. Where is the Air Bag sensor for the 2003 Cav LS model
  205. Car bogs down when I accelerate !!!
  206. 96 Cavalier hard to start (Sometimes)
  207. Trunk not opening with key
  208. Z24 Won't Start
  209. Dome Light Won't Go Off
  210. Need Help; new CD Player, car stopped running!
  211. front defrost not working
  212. whining noise and speaker buzzing
  213. Turn Signals
  214. Remote starter help on 98 sunfire...
  215. Starts but won't stay running
  216. '99 Sunfire GT/2.4L Starter/ Alternator Problem
  217. Jacking Locations For A 87 Cavalier
  218. Fan replacement
  219. whoops, moved this to the right place I think...
  220. Help! Is my car possessed??
  221. Head Gasket or Cooling system?
  222. key won't turn forward to start, any tricks
  223. Fuel Pump?
  224. Help! 2001 Cavalier...trac off light came on when it died!
  225. 1995 Sunfire wiper problems
  226. What is this called?
  227. 92 cavalier fuse panel
  228. need help with a 94 sunbird
  229. 97 sunfire trouble! HELP
  230. Low oil pressure?
  231. z24 Tranny
  232. Heater and A/C not blowing strong
  233. Rotten Egg Smell
  234. car keeps dieing losing power?please help
  235. WiCkEd noise in the back tires
  236. 96 sunfire n 96 cavalier brake problems?
  237. temp sensor
  238. temperature sensor location
  239. please help, noise from serpentine belt
  240. Car cranks but won't start
  241. Clunch noise in rear brakes
  242. overheating like MADD
  243. Help!
  244. '96 Sunfire Auto Trans Problems
  245. swaping trans
  246. Problems....yikes
  247. Anyone else have problems with front strut mounts.
  248. Coolant Leaking Out!
  249. 94 2.2L no electrical power
  250. Where is a good place to get a Shop Manual?
