Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
2000 Z24 ignition housing reinstall
96 cavalier stays in park mode until dr is selected
Electrical Problem
96 cavalier running cold at highway speed
abs indicator on 99 cavalier malfunctioning
how to repair/replace cigarette lighter in 2004 cavalier??
Fuel Pump
rer rer rer dead
1991 cavalier will not start
CRJ is stumped for once....
ABS/HZD fuse blowing
94 cavalier rear defrost
engine shaking and smells. help?
05 cav radio problem
93 cav heater blower
viper alarm system
O2 sensor bad?
NO REAR Defrost need major help
he Mystery of The Dissapearing Gasoline
Temp Gauge
no horn or cig lighter?? i need help
ONE signal light won't blink
91 cavalier runs lean after warms up
New car disaster!
Couldn't shift gears when cold.
1994 sunbird "check engine" light
gas in my oil?
messed up computer I think
Lost Female
Where is the Air Bag sensor for the 2003 Cav LS model
Car bogs down when I accelerate !!!
96 Cavalier hard to start (Sometimes)
Trunk not opening with key
Z24 Won't Start
Dome Light Won't Go Off
Need Help; new CD Player, car stopped running!
front defrost not working
whining noise and speaker buzzing
Turn Signals
Remote starter help on 98 sunfire...
Starts but won't stay running
'99 Sunfire GT/2.4L Starter/ Alternator Problem
Jacking Locations For A 87 Cavalier
Fan replacement
whoops, moved this to the right place I think...
Help! Is my car possessed??
Head Gasket or Cooling system?
key won't turn forward to start, any tricks
Fuel Pump?
Help! 2001 Cavalier...trac off light came on when it died!
1995 Sunfire wiper problems
What is this called?
92 cavalier fuse panel
need help with a 94 sunbird
97 sunfire trouble! HELP
Low oil pressure?
z24 Tranny
Heater and A/C not blowing strong
Rotten Egg Smell
car keeps dieing losing power?please help
WiCkEd noise in the back tires
96 sunfire n 96 cavalier brake problems?
temp sensor
temperature sensor location
please help, noise from serpentine belt
Car cranks but won't start
Clunch noise in rear brakes
overheating like MADD
Help!
'96 Sunfire Auto Trans Problems
swaping trans
Problems....yikes
Anyone else have problems with front strut mounts.
Coolant Leaking Out!
94 2.2L no electrical power
Where is a good place to get a Shop Manual?
Clutch..?
cruise control not working
'97 2.4L crankshaft position sensor (wet ecm?)
Car won't start
new cd player
2000 sunfire bright light problem
heater works on 2 speed
93 Cav Z24 Loosing Acceleration Speed
hesitation/stalling
01 Z24 vibrating really bad @ 2200 rpm+
2000 Cavalier - Headlights out, clicking sound from dash fuse panel
Does a 2000 Sunfire have a Timing Belt?
STALLING Problems.....89 Z-24
Pull My Finger (Gas Smell)
2000 sunfire heating problem
1991 Cavalier 2.2L - Rough idle, unresponsive accel. starting from full stop.
92 4-door carpet is SOAKED!!!
Wiring or bad ground?
HOW TO: Change your serpentine belt on a 95-02 2.2L
1997 conv.2.4 LS part Number needed
"CHECK ENGINE LIGHT"
How to replace front wheel bearing?
cavalier vibrates when i stop
Low beam headlamps do not work....
1996 Cavalier wiper issue
1999 Z24 Pcv Valve Help!!!!!!!!
abs light in 93 cavalier
2000 Cavalier...engine stalling/fuel pump?
Headrest Removal..
97 cavalier keyless entry
Web
AF
