View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19
  1. My car is a P.O.S!!
  2. '99 Cavalier intermittent misfire condition on cylinder 4
  3. help get my car to run
  4. need help
  5. 93 cavalier chugs and sputters
  6. head gasket question
  7. RPM question
  8. 2002 z24 running trouble
  9. gas pedal troubles
  10. 1995 Cavalier ABS problem
  11. 2003 Acting Up
  12. Advice with 1994 Cavalier RS Woes
  13. 95 sunfire dome light and heater control light problems
  14. Coolant change HELP
  15. oil & coolant leak. need help!
  16. 2000 cavalier shift knob removal?
  17. 97 tranny fluid
  18. coolant leak Cann't tell where
  19. oil light coming on erratically
  20. 2002 Cavalier starts, won't run...Help?
  21. 98 Sunfire shift cable problems...
  22. 92 sunbird flywheel
  23. Help Needed Asap!!! Car Died And Won't Start!
  24. 97 sunfire 2.2
  25. 96 cavalier
  26. Fan Speeds?
  27. 97 Cavalier wont start
  28. Starting Problem. Help!!!
  29. 95 Cavalier Serpentine belt diagram
  30. Radiator Flush
  31. 01 cavalier sputters...dies at red lights
  32. 01 Z24 rear brakes clunk and grab
  33. squeaking nosie
  34. Help Please .. No air comming out of vents
  35. Turn Signal Relay
  36. 97 Cavalier cut off when making a turn
  37. 88 Cav. Z24..Need Some Help Guys.
  38. brake lights
  39. quick help
  40. Camshaft and crankshaft......
  41. Auto trans slipping in 1st gear, 87 4 cyl
  42. Z24 wont start after reaching operating temp
  43. shifter loose
  44. Pin Hole Leak in Fuel Line
  45. it never ends!
  46. 2002 Z22 Odometer not working
  47. blinker shuts off headlights
  48. Heater blower won't run in 97 cavalier
  49. WONT START....ew;oefhghweroriei! !
  50. UH oh... Leaky clutch fluid '95 Cavalier
  51. Please help me..... Plzzzzz
  52. '92 Chevy Cavalier Oil Sensor Question
  53. '91 2.2L TBI No Start Problem
  54. 99 Cavalier ETS OFF light is on
  55. 2000 Cavalier that died on the road
  56. 1995 2.2l Manual tranny trouble with CO
  57. Heater Core
  58. Fixing a Fuel Pump
  59. help me
  60. 2000 Sunfire No DTRL
  61. Won't start-no fuel-HELP PLEASE!
  62. center terminal in 2002 cavalier headlight socket melting
  63. 96 Cavalier Ignition Problem...please help
  64. ABS light problem
  65. ECM Location
  66. fan problem
  67. Theft system light is flashing and car won't start.
  68. 1996 Z24 Rough Idling
  69. Overheating--weird chunks in radiator hose?
  70. sunfire won't start
  71. Stalling problems
  72. Water in Trunk of 2000 cavalier Z24
  73. 1990 cavilier to shim or not to shim
  74. 4.3 vortec #1 cyl ? bank an firing order
  75. Quick Tansmission help!!!!
  76. "Trac Off" and "Check Engine" light keeps coming on...
  77. rad fan
  78. 1991 Chevy Calavier - Shuts off at stops and shakes
  79. ABS light and Engine Ticking, Please Help
  80. please help possible head gaskets leak
  81. How to remove the turning combo Switch
  82. 98 Cavalier won't start sometimes
  83. timing chain aliment
  84. sunfire got hit in the rear and now will not start
  85. drum brakes lock
  86. 91 V6 Cav stalling and sputtering probs
  87. 1996 sunfire/2.4 twin cam
  88. Gurgaling sound from my heater core
  89. 98 cavalier 2.2L automatic
  90. Clunking from Steering column?!?
  91. 86 cav z24 what next?
  92. 98 sunfire stereo problem!
  93. MAJOR misfire problem back
  94. help with fan sencor location
  95. Cav won't start.
  96. 1995 cavalier stalling problem
  97. sunfire gt enige sputters
  98. 95 Cavalier 2.2 roller valve removal
  99. PCV valve 2002 ecotech
  100. cavalier does not shift
  101. 2003 cavalier...no fuel?
  102. 92 cav no spark, good crank sensor
  103. 97 z24 2.4 trouble - endless
  104. '74 chevy step-side truck for sale
  105. cavalier ECM/PCM
  106. Rear motor ABS circuit (RF)?
  107. ***Series of Problems.... Oh boy..****
  108. cavalier PCM and crank re-learn procedure
  109. 99 Cavalier needs help (shucking action & temp. gauge stuck on cold)
  110. name this noise?
  111. How to take ignition switch out
  112. '93 cav - rough idler
  113. starting
  114. trunk lid
  115. engine doesnt turn
  116. oil starvation (2.4L)
  117. help needed
  118. Locked ignition Switch
  119. intermittent rough run
  120. 87 sunbird rough idle still
  121. clicking noise in front brakes
  122. '97 cavalier overheating
  123. 2000 sun fire problem, please help??
  124. Alternator / Battery Problems
  125. Weird noises when turning
  126. abs light
  127. Wipers
  128. Chevy Cav Brake light and blinkers don't work?
  129. Subwoofer problem...
  130. Turns off on turns
  131. no heat
  132. drivers side rear window replacement
  133. 2002 Sunfire trunk lid problems!!!
  134. Whats up with the suspension on these Cavs!
  135. torque converter lockout selenoid replacement
  136. Added gas mixed w/oil into my gas tank...what can I do?
  137. Gauge Trouble
  138. 96 cavy stalled and wont crank up
  139. 99 Cav won't start
  140. 1996 Pontiac Sunfire
  141. idles to fast
  142. '90 Cavalier -- turning over but not starting
  143. A few problems with my 01 Cav.
  144. poor mileage
  145. 91 Cavalier Bypass Hose
  146. fuel problems
  147. whats wrong with my car?
  148. 93 cavalier clutch bleeding
  149. 94 Cavalier RS Will not start/ turn over
  150. mystery sound
  151. Running very sluggish at times
  152. Cavalier Will Not Start in Hot Weather
  153. PaceSetter Header
  154. rapping sound in engine
  155. Alternator or Battery?
  156. 88 cav cranks wont start
  157. what's that?
  158. headgasket torque specs
  159. no power
  160. Air Conditioner on Z24
  161. 98 sunfire - alternator problem!!!! HELP!!!
  162. Glass Pack Muffler Exhaust system
  163. know power
  164. coolant
  165. 01 cavalier weird burning smell
  166. tranny sounds/awkward
  167. best memory/turn-on wire?
  168. Selector cable replacement
  169. Trany... HELP!
  170. abs whirring, can't stop
  171. brake caliper bolt
  172. running out of gas question???
  173. running out of gas question???
  174. 02 Cavalier Radio Went Dead
  175. 2003 Cavalier issue
  176. 98 Cavalier Help!!!
  177. headlight update
  178. 1994 cavalier tranny problem?
  179. Head lights wont come on
  180. 1999 Cav trans issue
  181. Please Help, 3rd time asking power steering Q
  182. Time set?
  183. ABS/TC Light Problems
  184. Help
  185. 98 Cavilier temp guage problem
  186. added keyless entry to a 2000 cavalier from a wrecked 2004
  187. '94 Cav. overheating.. but no heat.
  188. replacing brakes
  189. Chugging / Bucking Cavalier
  190. Rear Brake Shoe Screech in Reverse
  191. Location of Coolent Sensor on 98 sunfire
  192. ? clutch release on 94 Z24 3.1L 5 speed
  193. Turn signals
  194. 2000 Cavalier Z24 remote door lock problem
  195. 1993 cavalier transmission help
  196. 93 cav. wont run
  197. 96 Pontiac Acting Odd
  198. 93 cavalier wont start
  199. '96 2.2 manual COOLING PROBLEM help asap
  200. flashers not working
  201. 00 Cav temp gauge
  202. 1998 cavalier miss in motor-program ecm??
  203. crossed wires, how bads the damage?
  204. Please Help
  205. 91 Cavalier engine surging
  206. messed up real good
  207. 98 2.2 starts for 2sec.then stops fuelpu. good
  208. idle and oil pressure unison variations
  209. 92' Cavailer stalls when at a stop or slowing down??Please help.....
  210. '89 Cavvy RS 2.0L vibrating?
  211. Belt Tensioner Replacement 98 Cavalier
  212. Tie Rods and 1 CV Axle (replacement)
  213. 92 cav stereo wire colours?
  214. theft system problem
  215. 1997 Pontiac Sunfire Squeeling & knocking
  216. problems with my 2.8L
  217. power window failure!
  218. Please Help!
  219. 1996 2.4l Sunfire terrible idle
  220. 1st and 2nd gears don't like to go in place when warm
  221. Having problems starting, any ideas?
  222. Clutch Adjustment
  223. 88 Cavalier not going into reverse?
  224. 89 Failed Vehicle Emissions Test Twice HELP
  225. 88 z24 digital dash tach
  226. Transmission Problem?
  227. driver's side headlight/signal light problem
  228. Driver's Side Window Won't Go Up
  229. Stalls
  230. 94 Cavalier 2.2L overheating
  231. Power Window Help!!!!!
  232. Harness
  233. 2.2 '92 Cavalier (Stalling)
  234. no spark
  235. Passenger Door
  236. cavalier light indicator?
  237. 1995 Cav electrical problem??!!??
  238. Cavalier 93 intermittent starting problem
  239. Radiator Fan
  240. Need Some Help Please
  241. Loss of power to fuel pump
  242. hearing a ticking noise thru the oil pan
  243. Having A/C troubles
  244. Erg Sensor
  245. 95 cavalier will not drive in any gear
  246. 1992 cavalier brake problems
  247. 2000 Cavalier Starting Problems
  248. 1991 cavalier
  249. Loose Steering Column
  250. valve cover gasket
