Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
clutch sticking kinda...
2002 LS Cavalier
2.3 vs. 3.1 V6
DEI 555L passlock
2001 Inertia switch location
Ebrake cable
96 Sunfire bad on gas, running rough
98 z havin a cat problem look an see what i mean
Could It Be A Bearing
shifting hesitation
HELP! '94 cav 2.2l Dies suddenly... Wont start back up
91 Cavalier V6 problems
Want to put 2.3 ltr. quad 4 in 95 cava help
Power Window Problem
timing chain noise!
2001 Cavalier Back End Noise
Front end vibration
99 Sunfire will not start on random occasion
Shake rattle and Groan
electrical problem
2001 cavalier safe engine?
Fuel Line Reset switch in 2000 Caviler?
fan problems
new gauges
Check Gauge light???
01 won't start 2.2L
Idle is jumping ... what can it be!
new timing chain....knocking noise
93 cav motor ...still starting probs....
94 cavalier ignition
'99 Sunfire Engine Shakes
97 sunfire GT 2.4L Ignition control module
01 Sunfire Shit at high RPM
Leaky Fuel Injector Advice Please! 94 Cav
Fuel smell low fuel light on
2.4L acceleration problems 2000 sunfire
anti-lock trouble?
Snow problem
dome light & seat belt light problem
car will not start
00 Clunk when steering
Throw Out Bearing
warning sound for 94 cavalier
Car will only start sometimes Please Help!!
93 cav motor...offers to start but won't
Help.. 97 2.2L... Wont Start
2001 accelerator quits working
Automatic Gearbox
93 cavalier drains power
Offers but won't start!
rear seat detached
Help! 92 Cavalier Stalls Out
humming noise in 96 cavalier
tubeless tires
93 Cavalier cyl. not firing Help!
97 Cavalier 2.4 rough acceleration at low rpms
Blow off in engine area when press gas
Altinator plug 2 small wires came from clip 2.2 96 cavalier
93' Fuse Panel
noise while starting
93' Cavalier Starting probs.
97 Cavalier valves ticking and oil grade?
Anoying noise while slowing down
00 cav not starting
Timing Belt
Help Idle problem
'95 Sunfire Daytime running light problems
What's the heck is going on with my daughters car?
'04 cav oil plug? and filter?
running hot
92 2.2 Cavalier not firing and fuel pump not running
A/C out..and summer coming
i got this 96 cavalier for sale
Destroying Batteries
1995 Cavalier Turn Signals
01 Cav will not start
1987 4cyl 2.0 Black smoke, poor mpg
96 sunfire very rough idle
headlight Wiring Short? bad Ground?
93 cavalier tranny problem??
broken hood latch
Alright guys, here is a tough one for you!
Overheating Help!!!
Power Steering
Multiple Problems in a 2000 Cavalier; Any advice greatly appreciated
94 cavy 2.2 wont start
click click click...vr-r-r-r-r- v-r-r-r-r-room
Light Problem
97 Sunfire Car Problem - PLEASE Help
Short Trip issues
what is din and half mean?
Car is chugging bad!
Location Coolant Temperature 2002 Pontiac Sunfire
1994 cavalier
timing chain again
Any One know a trick to install belt? 96 Cav
2002 serpentine belt replacement
how to install a 00 01 02 CHEVY CAVALIER REVERSE GLOW GAUGES GAUGES W/T
2003 Cavalier Starting Problem--PLEASE help. Please?
led issues, HELP!!
99 Cavalier z24
01 Cav passenger seat problems
how to get to oil sending unit? 96 cavalier 2.2L
Starting problem with 96 cavalier..iz it injector prob?..plzz help
Fuel Filter Location 96 Cavalier
94 z24 clutch problems assistance needed
O2 sensor on 93 Cavalier..where is it?
Fuel problem??
newb w/ questions
Replacing clutch on '96 cav. How difficult?
Im so pissed
Valve knock/slap... blah.
problem with my cars fuel system (i think)
'94 Cavalier - Stalling and ABS light
02 Cavy shifting problem
Shocks...literally...........ouch
Cavalier Door Handle Problems
'96 Cavalier odometer miles wrong
Abs
dashboard says check gages problem
01 cav wont start
96 Cavalier Headlight/DRL out
Heat died HELP
95 Cavalier wont start, Help Please
'94 Cavalier flashers
93 cav. dumping to much fuel?
Another Passtime
Sunfire Problem!
98 Cavalier stalling/poor idle
89 Cav stalls when stopped at red light
valves ticking?
Everything Locked Up
gas smell in pontiac sunfire
99 cavalier 2.4l fuel problem
winshield smear
91 sunbird wont start?
93 Chevy stalls after highway driving
Wrecked Cavalier won't start
89 cavalier
Clunking noise in Front end?
Bad exterior paint job
alternator battery problems
1999 sunfire transmission dipstick.
Heater Core
96 pontiac sunfire jerks..
02 Ecotec w/ "special" oil filter??? HELP!
overheating?
Stereo/Dome Light/Glovebox Light
1996 cavalier headlight switch removal help... Please
Gas Leak at Injectors!
Repairing Fuel Lines
'02 Cav Clutch Noise
95 cavalier no power
94 Z24 cav wont start
1998 Cavalier won't pass smog!!!
Turn Signals not working
Trac off light
Help Please!
97 cavalier manual tranny probs
94 Cavalier won't start in high humidity
My car is a whinner!
Fan Motor
Engine temp
2000 pontiac sunfire gt 2.4 sfi
This is my first car. POS!!!
stereo problems
89 Cavalier 4 Cylinder won't start when cold
Hesitation while accelerating.
Chevy Cavalier
1997 stalls when idling
Pls help, heater fan problem
1990 Cavy Battery problem
Abs
Can't shift in freezing weather
brake warning light
hoist lip problem
need help
2002 Chevy cavalier shifter light
91 Cavalier No Start Condition (Hot)..Help
2004 cava with CEL
2nd gear anyone??
'95 Sunfire Blinker
2000 Cavalier Coupe manual windows slip
Wipers
Power Window Motor 2002 Cavalier
Am I getting ripped off?
engine stops! help plz
Repair Manual
Check Oil Light
97 Sunfire 2.2l rouge idle when cold
battery
wires
99 Z24 Manual Trans Help
Girl who needs help!
Numerous problems - Would like to avoid being ripped off at a shop...
Engine problem
2001 2.2 over heating.
blower works on one side
1996 auto trans won't shift
climate controls not working
common cavalier stalling problem
no power/battery
2003 cavalier won't start
97 Silverado CD Player Problem
105k Miles should i change Transmission Oil
Odd intermitant behavior 99 2.4L Cavvy LS
2002 Cavalier Trans Prob
car shakes at 45 mph
97 sunfire 2.2 slight miss sometimes and really bad fuel mileage
warning light
Fuel pump relay
Reverse lights out and Transaxle Case
1999 Cavalier Z24 Intermittent engine knock under Hard Acceleration
strange noise when starting up
02 Cav. making bad noises!
2001 Sunfire Headlight problem
Overheating
96 Sunfire running cold, bad fuel economy, Fan always on
temp drop
2000 Sunfire No Start
2001 pontiac sunfire just died going to work will turn over but wont start
94 Cavalier Blinkers not working????
serpentine belt
Windshield washer probs
Cold Start Problems
95 Cav - New Thermostat - Now Check Engine Light
cd player problems
Multiple Cavalier problems-estimate of cost??
Parts Help
98 Z24 Strange Problem
96 cavalier Air Bag/Seat Belt Light stays on
96 Cavalier air/heat problem
91 cavalier losing power
how do i replace my spark plugs on my sunfire gt
Fuel Filter Stuck
'00 Sunfire, no elec.
Shifting problem
Engine Noise and Shifting Problem.
Starter Issues?
Air Selector Knob 1995 Cav
misfire
VSS Problem??
high beam not workin
99 pontiac sunfire
frost problem
Heater not working
Blown fuse when in defrost mode
belt tensioner
2003 heat/air selector
Web
AF
