Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
93 cavalier can't find horn to replace it
changing rear drum brakes
00 Cav Intermitant Starting/Stalling issue.
97 Sunfire 2.2OHV Has Fuel, Spark, Starter & Won't Start
Radio Code for 99 Cavalier
suspecsion
2.2 sunfire oil change
low coolant light
OIL FILTER! Help ASAP.
low mpg
"90 Cav. Occasional bucking & a code 24
Low Oil Pressure
1996 Cavalier Overheating
93 cavalier wiper problems
need help
Stalls when reversing
2001 sunfire won't start 2.4L
'98 Cavalier Z24 Wiring Diagram
Air Conditioner
96 cavalier passlock problem
has this happened to anyone esle....
Help, this Cavalier is driving me nutz!!!!
oil pan
Sunbird 2000 fuse "blo" underhood -- what does that one fuse?
HELP! Going out of my mind!
'89 Cavalier Z24 likes to shudder
Check Engine Light On. Help Please...
91 Cavalier won't start
'98 2.2 having issues w/engine cooling
Replaced Radiator, ran great, now will not start
PCV valve?
What next!?
Gas petal sticks with warm engine
heat problem???
problems when car changes gears
How do I bleed the cooling system?
'95 sunfire dies. ECU? fuel pump?
Problem Fixed
thump,click when turning
No charge getting to battery!
2001 Cavalier falls flat on its face
Vibrating Coming from front end
2000 Sunfire GT O2 Sensor
Cooling fan problem
Sunfire Rough Idle
how can i take the Thermostat out on a 96 2.2 cavalier...
01 2.2 cavalier won't start
Changing a Belt Tensioner
Licence plate neon
95 Cavalier A/C problem??????
1996 cav. wiring trailer lights
Check Gauges light on Fuel Gauge Falls..HELP!!
1988 Chevy Cavalier ....NEED HELP!!!
problem! car wont start
2003 Cavalier Clutch Issue
ETS Off Light On (No others)
97 cavalier no spark
92 Cavalier Need some help
Idle Air Control Valve
Flashing Numbers???
Check Engine Light????
Will a trunk lid from a 4 door fit a 2 door?
Changed Drl Relay,wont Start..
trying to find where the pcv valve is damnit help..?
blown
Electrical problem on 2004 cavalier
Where are the coil packs?
Ultra Expensive Waterpump what do you think?
Help Car Has trouble running
Coil Pack on 95 cavalier
Won't start, Just keeps turning over.
What are the symptoms of a bad EGR valve?
AEM intake + engine temp
Leaking trunk
91 cav Huge prob need help PLEASE!!!any help would be amazing
97 sunfire, clutch = funny noise, crankshaft bearings??
1995 Sunfire -motor Conks Out
Engine Temp + AC
stalling/sputtering.....again
Not wheel bearings..what then?????
1996 to 1997 Motor Swap No Spark
Headlight
95 sunfire AC TROUBLE
1995 Chevy Cavalier Horn Help!
Driving 3rd Gear Issue
2001 Cavalier questions
Changed fuel injector, car won't start
96 Sunfire- CRAZY problem
89 Pontiac Sunfire Tranny Problems???
92 Cavalier 2.2
Green Quick Connect Clip
Help!
horn stoped working....
shrader valve
Octane
Coolant Temperature Sending Unit Question
89 chevy cavalier won't start
Problems with Theft-Lock
CD player
ABS Problem on '97 Cavalier
99 cav z-24 ets light on
2000 Cavalier occasionally doesn't start
speakers buzz when cassette plays
Daylight running lights relay
90 Cavalier Z24 stalling problems
Car do not start
Free Ipod!
Trouble removing left front axle
Car Has Problems Starting (Not Getting Spark)
99 Z24 signal lights not working
Pcv
Fuel Filter
Won't pass DEQ
96 2.4L not starting
transmission
Atf
hissing sound....
valve cover bolt torque spec
95 Sunfire GT exterior plastic panels (removal).
Mpg
update on "possible lemon"
identifying a vacuum leak...
cav w/intermittent stall out
Will not start not check engine light.
Gages read bad after oil change
No Data from connector
2002 Cavalier auto tranny problems
Help with License plate lights
Question about fuel gauge and economy...
Odometer/Tripmeter STUCK!!
98 Sunfire wont start
Car is really startin to peeve me off
Problem with radio
Fan Motor?
sellin the car
Lube
possible short?
relay burnt wont start????please help!!!
What are the symptoms of a bad coil?
94 Cavalier Problems (95 Engine)
93 Caviler 2.2 Timing??
1998 z24 sputtering.... help
Engine Stopped On Highway
HOT AC on 1998 Cavalier
steering problem with 97 cavalier
Stereo problems
Signal Light Problems
Part Nomenclature
fuel prob
how to program remote for 96 sunfire?
01' starting problems!!
water in transmission
throttle position sensor
1997 Sunfire GT fan, lights please help
Coil Pack and Crank Sensor Question
93 Acceleration Problem
smokin out the neighbourhood
one thing after another...lemon maybe?
2001 Cavalier-Car Overheating
check engine light on....P0130 circuit question...
damn you, Alternator! How I loathe thee!
96 Cavalier Z24 front driver side noise
Normal or not???
2000 Sunfire GT Sunroof Problem!
Abs
poping coil packs on my 95 2.2
expecting the Worse, Need help please
please need advice on 2001 sunfire gt
2003 Sunfire squeaking
Check Engine Light Keeps coming on
Signal Light Out, Bulb Replacement Doesn't Fix
No start, electical?
1997 Cavalier Stalling Intermittently-PLEASE Help?!
check light stays on,01 sunfire, ASAP
Cavalier pouring oil??
AC Fuses Keep Blowing???
98 cavalier stalling
1996 Cavalier gas gauge gone screwy
Slipping Transmission: Temporary Solution
need help
Just bought a used 2000 Cavalier and it has issues......
1990 3.1 V-6 over heating
95 cav 2.2
Rattle when AC is switched on...pls help!
The CRJ is stumped!! F'n eh!
Transmission problem or not?
02 cavalier wound start
90 Cavalier Z24 will not start
Cavalier wont start
91 headlights are out
Head Gasket
96 sunfire only starts sometimes
1990 Z24 Headlights
Instrument Cluster Problem
ABS Code and hub bearing
00 Cav Engine Turns Over, Shuts off after 10 seconds
clutch sticks
1995 Cavalier Fuel Pump
No Spark
Couple easy questions?
99 cavalier 2.4L cylinder 1 misfire
2002 Sunfire Loud Knocking/Tapping Noise
94 Cav Z24 3.1L, unsure why engine quitting
Air Conditioning Problems
95 Sunfire Jerking/Bucking
95 Sunfire alternator help.
98 Cavalier Electrical Problem
Something Green
2004 Cavalier Shifter
2004 Cavalier Fan Problems
Mode box (air/heat)
'96 Sunfire horn location
99 Z-24 problems, help needed please
ETS OFF Light
'97 cavalier Wont even turn over- PLS HELP!!
Jensen XA4200 amp problem
Wiring Diagrams Desperately Needed!!!
Engine Swap Problems
clutch
99 cavalier stopper running and no longer starts
Winshield replacement
1992 HELP sunbird unusual stalling
driver side window off track
89 z24 problems
girl in trouble
1998 Cavalier 2.2L A/C Problem
ABS/ Brake Question
grindin noise
ABS Light
Try Figure this out
clutch sticking kinda...
2002 LS Cavalier
2.3 vs. 3.1 V6
DEI 555L passlock
2001 Inertia switch location
Ebrake cable
96 Sunfire bad on gas, running rough
98 z havin a cat problem look an see what i mean
Could It Be A Bearing
shifting hesitation
HELP! '94 cav 2.2l Dies suddenly... Wont start back up
91 Cavalier V6 problems
Want to put 2.3 ltr. quad 4 in 95 cava help
Power Window Problem
timing chain noise!
2001 Cavalier Back End Noise
Front end vibration
99 Sunfire will not start on random occasion
Shake rattle and Groan
electrical problem
Web
AF
