Chevrolet
Cavalier
> Cavalier Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
Air Conditioning Compressor Leak
89z24 tranny
Low coolant light and car overheated at idle
sure signs of HG failure
Dry Oil Filter.
02 Cavalier No power, rapid clicking when turning key
01 Sunfire starting problem
2003 Cavalier AC Problem
Possible Overheating
2000 z24 starting problems
97 Cavalier
transmission
Cavalier Pulls to the Right ?
problems with AC
Sputtering at low rpm's
98 Cvalier Stalling problem
Transmission fluid drained at stoplight.
overheating problem
Loss of power:Poor acceleration
Brakes Clicking
I need Starter motor help!
96 2.4l Ignition Problem
faulty wiring on headlights?
96 not starting...weird acting...
1996 cavalier starting problems
electrical problem, starter perhaps?
locked in park
won't shift out of park
Interior fan wont shut off
Theft system
my vent air smells like black and mild smoke.... wtf???
97 2.2 cavalier starts but shuts off when driving
coil pack to distributor?
air locked
mystery problem
Strange Smell
Can mufflers get clogged?
Vibration while braking
Trac Off Light
brakes
Idles Funny
Brake Problem
97 Cavalier Oil Leak
92, Changing a Fly-Wheel?
Dam curbs
1999 cavalier axle nut
97 Cavailer
1994 cavalier won't start
02 Cav. making weird noise
Air Vents not changing
So Very Confused
lopey idle, and somking on the inside
Help to maintenance or test Sunfire 2002 sensor's
98 cavy, abs/battery lights
running short on patience and money
Reset or Restart Computer to original values
Cold Air Intake = Check Engine Light
Passenger side mirror on 95 cavalier
Single Mom needs Help!!
AC Problem
2003 sunfire Fault codes
2003 Sunfire Need help with tranny problem
Recurring P0420 code on a good running Cavalier
97 Cav misfire
95 2.2 cavalier engine noise
Has anyone changed a window motor on a '96
Name That Noise ?
Hesitation, misfire when warm
03 cavy stall-HELP!
cooling fan
2001 Z24 tranny code
removing backseat
99 cav squeal
road noise
02'Sunfire
Help!!! 98 Cavalier Low Beams Not Working
89 2.8 idling problem
4th cylinder dies after engine warms up...
96 cavalier. How do you check tranny oil level
99 cavalier headlight problems
94 Cavalier 2.2L wont start
squealing steering wheel???
1991 Cav, no spark (DSI)
93 Taurus Head Gasket replacement
97 cavalier 2.4 liters engine keeps turnig over with out keys
96 cavalier probs
Squeal when making left (94 Cav)
Definite fix for stalling while braking?
Coolant Light/Leak
96 cavlier with the 3t40 tranny (3speed) problems!!! NEED HELP ASAP!
96 cav turns over but will not start... 70 miles from home!
97 Cavalier 2.2 Heat Gauge Problems??
emissions and drive cycle
97 sunfire power steering problem
1995 cavalier clutch problem.
help car heating up
help car heating up
93 Z24 3.1 sooty black p[lugs, runs rough
coil packs
Grinding noise under 35mph
more Cavalier Problems
Wierd Grinding/Buzzing noise
01 Cavalier Stalling when warm
1996 cavalier runs when key is off
01 Cavalier, problems starting.
Engine/Oil Flush?
Caviler 93 started and then stoped and not starting
1996 Sunfire won't start. Dash acting crazy
Extremely Jerky Idle
Clunking from wheels - turning or bumps
BUCKING Bronc (99 Cavalier)
e-brake lock up
battery light comes on when shifting
2nd Generation Trunk/window Leaks
HELP! 1993 Cavalier Stalling Problem
Whats with my tranny?
94 cav problem with running
'02 2.2 Cav starting isuue
cavalier fuel pump
98 Sunfire Transmission Converter surge problem
97 cavalier excessive road noise
Window down in rain and snow! HELP!
85 Cavilier EGR problem
95 cavalier auto trans issue
Replacing ignition switch...
'89 Cav Brake issues
Help! Lights came on, What does it mean?
1998 Sunfire: DRL, one dim headlight?
97 cav wont crank
pontiac sunfire 2003
rpm drop, almost stall when turning off ac
97 cav probs Please Help
01 Cavalier Cranks and Wont start
Still needing some help w/ ignition
98 cavalier RS running rough lost power, MPG
Gas Gage
97 Cavalier turn signal
Trans problem
1991 Cavalier Hesitation
95 2.3 idles REALLY rough and wont move.. mucho gas smell
Trunk Help!!!
Electrical Problem
'89 Z24 starter problems....help!!!
Wipers Won't turn off @ 60MPH ++
Squeak??
transmission fluid and hard shifting
1996 cavalier P0440 + cooling fan always runs
cruise control
01 chevy cavalier
Body Control Module
91 Cavalier, 4 Cyl just stopped, will not start
Sunfire doing wierd F*&^ up things
Knocking Noise
Car stalling, Need HELP!!
1996 - no tach, no temp & all dash lights light up
Installing Ignition in my 1992 Cavalier
Lights
98 z24 deceleration?
Remote Car Starter Problem
96 caviler starter
2000 Z24 IAC question
96 Sunfire GT M/T cant shift into 2, 4, or R
ABS problem
chronicles of my 89 cavalier
Problem starting - where to start?
Need help with front end!
trans issue???
2002 LS Cavalier
1996 pontiac sunfire overheating 2.2L
Kilometers wont show, but an error msg will!?!
89 4cyl cav.. TEMP Light Comes on, heat/air smell like antifreeze... new thermostat?
93 Cavalier stalls after reaching over 65 mph
96 cavalier lights only work on one side
over heating and overcooling
94 Cavalier RS Rough Idle
2000 cavalier ecu - trac off
sputter before warm
97 Cav keeps blowing Power Steering system O ring
rdm
rdm
pilot bushings?? going from auto to standard
Driving Light Problems
My Car will not crank to come alive
Side Mirror is very loose
'96 Sunfire - Power & Idle Issues
Stiff Shifter
oil sensor& tighet gas pedle cable
Steering Problem
95 tansmission
Anyone know
Anyone wanna try and help with this problem
oil light when idle
Help
is engine missing or something?
engine temp problem
Heater core question
Sunfire - Manual Shifter
I don't know what this light is.
Starting Problems
95 bogs down/hesitates....
electrical problem
Ignition problems -- 94 Cavalier
My Son Hit a Curb
wiper arm from steering colunm
Coolant smells??
oil light
2001 Backup Light Problem
crankshaft sensor
Battery running low?
Engine periodically getting too hot...possible problem?
Clutch, stuttering in 1st.
01 cavalier with a PO442, what is it?
Brakes
Crankshaft/Rod Bearings
temp sensor?
Camshaft Position Sensor
99 Sunfire burning oil
96 Cavy Revs high with little acceleration only while making a left turn
97 OHV -check engine lights when damp & runs crappy
2002 Sunfire 2.2 Shifting Problems
drop in gas mileage
Control Arm Install Woes
CV Joint?
96 and 97 2.2 engines compatible? No spark
96 Caviler bucking
fuel injectors
96 Cav - Trouble Codes PO420 & PO440. Please Help
1998 Sunfire CD player error 20
92 cavalier 2.2 ecm? please help
Header Help
2002 headlight problems
96 cavalier head specs
idle control problem
Strange Battery Drain / front spring problem
check engine light on
Slipping clutch on a 98 Z24?
Weird flasher/ABS problem
help!...lol this is bad
Headlight Issue. Electrical problem?
pro start CT3100 won't work
2003 cavalier rear defroster not working
2003 Cavalier High Beams Not Working
coolant going missing
throttle body sensor changing?
squeak when turning left on 03 cavy
wheel bearing
97 Cavalier High RPM Air control; HELP!!!
Spark Plug Question
looks like cooling problems are popular
Automotive Network, Inc., Copyright ©2019
