Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
Turn signals
2000 Cavalier Z24 remote door lock problem
1993 cavalier transmission help
93 cav. wont run
96 Pontiac Acting Odd
93 cavalier wont start
'96 2.2 manual COOLING PROBLEM help asap
flashers not working
00 Cav temp gauge
1998 cavalier miss in motor-program ecm??
crossed wires, how bads the damage?
Please Help
91 Cavalier engine surging
messed up real good
98 2.2 starts for 2sec.then stops fuelpu. good
idle and oil pressure unison variations
92' Cavailer stalls when at a stop or slowing down??Please help.....
'89 Cavvy RS 2.0L vibrating?
Belt Tensioner Replacement 98 Cavalier
Tie Rods and 1 CV Axle (replacement)
92 cav stereo wire colours?
theft system problem
1997 Pontiac Sunfire Squeeling & knocking
problems with my 2.8L
power window failure!
Please Help!
1996 2.4l Sunfire terrible idle
1st and 2nd gears don't like to go in place when warm
Having problems starting, any ideas?
Clutch Adjustment
88 Cavalier not going into reverse?
89 Failed Vehicle Emissions Test Twice HELP
88 z24 digital dash tach
Transmission Problem?
driver's side headlight/signal light problem
Driver's Side Window Won't Go Up
Stalls
94 Cavalier 2.2L overheating
Power Window Help!!!!!
Harness
2.2 '92 Cavalier (Stalling)
no spark
Passenger Door
cavalier light indicator?
1995 Cav electrical problem??!!??
Cavalier 93 intermittent starting problem
Radiator Fan
Need Some Help Please
Loss of power to fuel pump
hearing a ticking noise thru the oil pan
Having A/C troubles
Erg Sensor
95 cavalier will not drive in any gear
1992 cavalier brake problems
2000 Cavalier Starting Problems
1991 cavalier
Loose Steering Column
valve cover gasket
P0335 and PO342 Codes Both and once
Cylinderhead Torque settings for Sunbird 2.0 1991
Can't locate directional flasher
98 Cavalier - Engine is remaining hot
anti theft system
small hole in gas filler tube
ignition problem
ignition problem
firing order 1991 Chevy Cavalier 2.2 litre
Power loss,rough idle
light under gearshift?
sputtering and popping
'96 won't fire
2001 Z24 - Rattling and Grinding Noises
98 Cavalier won't start, dashboard dead too
2 problems in 1: Unresolved coolant leak/ power steering fluid leak
intermittent dome light coming on
clicking noise in engine
97 z24 pass.window issue/interesting story
Starting Car
Wipers and Radio
99 Cavalier Dead
steering no assist - intermittent
94 Cavalier Brake Problem
low tranny fluid/ drive axel?
replaced water pump
alarm Question ?
Fuel Filter Location
2000 sunfire false reading on temp gauge
leaking fuel pressure
install RPM gauge
sunfire no start
crankshaft position sensor or timing
Car clicking when ac on and cruising
Headlights turn off while driving
1997 - No Start - Power comes and goes
97 Cavalier - Misfire
Possible Fuel Pump Problem
Radiator tube (not hose)....Where 2 find?
ac engine problems
98 cavalier ac just up and quit
Cavalier Engine removal HELP!!!
Changing ATF/FILTER O-RING HELP!
Replacing Air Bags
1998 Pontiac Montana engine problems??
98 Sunfire A/C Problem
2001 Sunfire having a few sudden problems
97 Cavalier won't start after radiator was damaged.
91 cavalier window problems
How to replace radiator 00' 2.4L
2003 cavalier died while driving wont start
Clickity-click noise is driving me nuts! Help?
91 cavalier runs then dies
do all cavaliers have electrical problems like mine???
Transmission wont shift into 3rd and 4th gear
engine noise
engine noise
battery light
steering rack/cv boot
Please help! only half my engine running
1995 sunfire wont start
Bad wheel bearing??
98 sunfire has no pickup... whats going on?
96 Cavalier - barely starts/idles, no power
91 z24 3.1 randomly will not start
Rough Idle, Rich mixture
A/C problems
Oil Pan removal from 2004 Cavalier
'92 Cav Riding Rough Help please?!?!
Slipping Transmission
My 97 has a number of problems. HELP!
Where would I find the Turn Signal Flasher
Electrical ? Problem...need help badly
Jerky Idling on 96 cavalier
ghost in the courtesy light...drivin me nuts!!Please help!!
HELP! Already tried many things on 95 Cavalier
Radiator wont release colant
Battery lght issue
1997 Z-24 - Electrical Issues!!!
2000 Cavalier ABS Problem
Fuel Pump
Another (unique) starting problem on 95 Sunfire
Very stiff turning right at slow speeds
overheating
need to know if gas tank can be drained easily using the elect. fuel pump?
Reverse Lights Inop
Random Missfire Problem!!
Power Windo Woes
removing fuel filter
Auto trany stuck on drive
1999 Sunfire Buzzing Noise Behind Dash
Check engine light stays on after car is turned off?
Big Problem
Volume Problem w/ JVC unit 1998 sunfire
Tachometer
2000 Cavalier a/c -ok going- cuts off stop
2005 Pontiac Sunfire cd install,help!!!
Strarting Problem
Brakes
02 starting problems
All Kinds Of Bad!!!
Electrical Problems
rattle in the left fron
Heat problem
02 cavalier coil-on-plug ????
98 Sunfire Overheating and fan will not kick on
No Start Condition
engine fan switch?
Stalling
91 Z24 Issues Starting, motors, fuses
Timing chain and a noise problem??
what can i do to remove a broken srew?
Tail Lights
Power Windows stuck open
Studdering at start
Fuel Filter Help!
Blown Headlight
Check Engine / ETS Light..
AC Blows Warm Air
Clunking Noise
coolent light on...
94 z24 ecu error?
check engine - ETS off indicators
Atf!
2.2l timing question
please help
Engine Noise
97 Chevy Cavalier
91 Z24 sputtering bad
Motor Mounts
i f up....
1998 chevy cavalier z24_need motor mounts?
Need Help
this ABS is driving me crazy!
89 cavalier 2.0 litre bogs on hard acceleration
Strange problem..
Intermittent FUEL PUMP
coolant light
cluster panel light
Fuel System Cleaner
97 Cavalier EHT light and ABS light stay on
2004 2 Door Cavalier with Issues
Extra Transmission cooler needed?
Starter slipping on flywheel easy fix?
2000 gauge overlay wiring
fuel smell
Installed new intake, check engine light on and trac off light on
daughter's cavilier
Engine Fan Won't Start
1997 Pontiac Sunfire computer replacement help
Disable theft system??
water injestion
00 Z24 Fuel Pump doesn't always work-HELP PLEASE!!!
95 Cavilier Stuck In Reverse
A/C Problem
Shock or Strut? (1991)
Has anyone had their dashboard crack from the sun?
ebrake / abs light
01 Cavalier Jerking when braking, any ideas?
91 Cavalier no belt tensioner ???
1994 Cavalier 2.2 exhaust black
noise in the engine???
Crank Sensor
1998 chevy cavalier Z24-problems with clutch???
1997 cavalier vent problem
97 Chevy Cavalier running rough
Junk Sunfire deck lid
HELP no fuel. not the pump
Keyless entry programmer
1998 sunfire no start.
OBDII Codes --1800 / MFR
vats system
98 sunfire Vehicle Speed Sensor
Car bogging in rain
HVAC only off and high
Temp Gauge with a Mind of its Own
ABS, TRAC OFF, SERVICE ligth on simultaneouly
core is out
93 cavalier sprocket timing mark
help please starter not turning over
heater core hoses
00 Cav overheating
Here's a question for the Tech's
AC/Alternator Problem
Melted battery terminal
92 Cav 3.1 fuel pump relay
plenum help please?
turn signal when installing body kit???
Won't Start
1999 A/c Problem
Web
AF
