View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19
  1. Problems restarting after bad traffic
  2. New car, lots of little headaches.
  3. 1998 2.4l Auto cold acceleration problem
  4. ABS acting up
  5. Low Coolant - where is it going?
  6. Help 1997 Pontiac Sunfire...
  7. Please help with my '98 Sunfire
  8. Help!!!!!
  9. temperature guage stopped working
  10. clutch problem
  11. weird question
  12. CEL on... Need an O2 sensor
  13. an itty bitty problem. rough driving and power locks
  14. 97' Cavalier Help plz!
  15. 97' Cavalier Help plz!
  16. 97' Cavalier Help plz!
  17. 97' Cavalier Help plz!
  18. 2001 cavalier problems
  19. Help please -2000 caviler dies on highway
  20. 96 Cavalier overheating & wiring issues?!?!
  21. 2000 cav flickering problem need help
  22. low beams won't work...HELP
  23. Door Locks
  24. hard to start
  25. Noisey Fuel pump
  26. hard starting/anti theft the cause?
  27. Engine misfire?
  28. Aggravating car! I need help!
  29. chevrolet cavalier fuel pump problems
  30. Car starts...then stops..engine knocks..timing belt maybe?
  31. Replaced fuel pump but still no fuel?
  32. replacing 95 cav 2.2 l ohv water pump
  33. Coil Packs
  34. 89z24
  35. And the list continues....
  36. Car batteries Hydrometer went blank
  37. A/C comes on when heater turned to defrost
  38. strange grinding sound when starting!!!!
  39. Oil Burner
  40. starting cavalier
  41. crazy gauges
  42. CV Halfshaft
  43. Thump noise from front end
  44. 95 Cav Z24 stalling when hot
  45. 95 Cav Z24 stalling when hot
  46. 89 cavalier problem. help please :)
  47. Auto Tech 3.0
  48. HELP! Sunfire Rough idle/dies hard start
  49. How to replace alternator on 98 Z24?
  50. Two weeks later... ANOTHER mysterious problem!
  51. 1991 Chevy Calavier
  52. Electrical problem
  53. 2000 cavalier code B1001 - help please
  54. Idle problem after car was overheated
  55. 2.3 skipping problem
  56. Oil Filter for 2.2 L
  57. not starting
  58. instrument panel not working
  59. Oil cooler hose leak
  60. starting motor?...maybe?..click here and guess!!
  61. 02 Cav - radio stays on when door opens
  62. Gas leaking around fuel injector
  63. No spark from 1 plug wire
  64. Thank You...Thank You...Thank You...
  65. Lunchbox!
  66. Spark Plugs
  67. Bad Headlight Switch??
  68. Cv Joint
  69. Gas milage way too low
  70. changing a belt tensioner in a 94 chevy caviler
  71. Need new egr valve
  72. engine compatibility ???? HELP Blowen engine!!
  73. 96' Brake Problems also
  74. 1996 Cavalier Brakes
  75. 94 2.2 litre transmission problems
  76. 96 Cavalier will turn over but not start - HELP!
  77. How do I reset the engine computer?
  78. Slightly Low-High rpms and chaking. Please help
  79. 2000 z24 cavalier dim headlight
  80. 96 Cavalier no spark in #1 and 4 cyl!!!!!! 2.4L
  81. does my car TRULY need a fuel level sensor
  82. egr cleaning
  83. 98 sunfire wont start
  84. downshifting too late?
  85. crank shaft postioning sensor
  86. Engine Quit
  87. car takes long to start
  88. 2000 Pontiac Sunfire codes...
  89. Simple Vacuum question
  90. OverHeating
  91. airbag/seatbelt lights
  92. how many miles
  93. 97 Cavalier 2.2 Overheating
  94. alternator problems? or just a Screwed up car?
  95. 97 Sunfire wierd "knocking" sound???
  96. 97 pontiac clutch and shaking problems
  97. 97 Cavalier 2.2 - Rough Idle
  98. 99Sunfire 2.4L Automatic ~ Sounds like a Diesel
  99. 98 Sunfire Convertible Window switch
  100. Crank sensor location for a Cav. Z24 1995
  101. 01 Cavalier Z24 ABS
  102. bad clutch?
  103. '03 Cavalier headlight problem
  104. 96 Cavy VATS problem. TDM.
  105. 1989 Cavalier Z24 OVERHEATING LIKE MAD
  106. 2001 cavalier problem!
  107. Problem finding the proper brake line
  108. 2002 cav. anti lock break reset
  109. 01' Cavy will not start, please help!!!!!
  110. Big Problem
  111. 94 Trunk Release
  112. Small problem with a 99 Cavalier Z 24
  113. Radio and dash light issues
  114. 96 Cavalier Interior Light Problems
  115. Battery problem indicator keeps coming on
  116. 1993 Cavalier 2.2l No Start
  117. Annoying Engine Code..
  118. 97 Cavalier fuel lines
  119. 2000 Sunfire GT a/c
  120. 99 cavalier wont start
  121. Quick Questions about the Warning Lights
  122. extremely fast idle
  123. 2000 Sunfire Idle Problem
  124. transmission fluid check?
  125. Getting codes P0336..P0340...P0130
  126. power locks
  127. Temp Guage acting up.
  128. Where Do The Problems Lie With Cavaliers?
  129. in the process of finding the cause for my engine to be running on 3 cylinders.
  130. Chokes after use of accelorator
  131. High pitched engine noise
  132. Instrument Panel Probs--- long
  133. Low-Coolant Light on 2000 Cavalier when I shift from 3rd to 4th Gear only.
  134. rear defrost on 02 cavalier
  135. Problem With My Z24...acts Like Its About To Stall
  136. Lights dim, deck cuts out
  137. No Power to Starter
  138. 03 Cavalier 3rd Brake Light Out!
  139. 91 chevy cavalier rs loses power
  140. 2003 2.2L ecotech service light, ets, stall
  141. 2000 Sunfire not accelerating
  142. Cooling fan not working in 95 sunfire
  143. 2003 Sunfire headlight issue
  144. Problems in a 96 SunFire
  145. computer reprogram neccessary?
  146. 2001 New to me Cavalier
  147. Anit theft light is on
  148. loud noise HELP
  149. proper brake bleeding tech. for cavalier
  150. 2000 Sunfire No Brake Lights
  151. major brake problem
  152. 02'Sunfire
  153. 96 sunfire oil pan removal HELP!!!
  154. 96 cavalier starter/ignition
  155. please help 96 cavalier wont start
  156. 91 Cav 2.2 TBI, Serious Issues
  157. Help Please
  158. ETS check engine light on
  159. I Need Help
  160. 2002 Cavalier horn clicking??
  161. cavalier/sunfire won't start- fixed
  162. hell with it.
  163. Fuel Pressure Regulator
  164. Speedometer stopped working check light on?
  165. No light on my Odometer
  166. wierd popping noise
  167. need help please
  168. Blower Motor Works Intermittently
  169. 96 Sunfire - Engine Replacement?
  170. idles high rpm, smell gas, bad mpg = ???
  171. uggghh....brake issues
  172. New gas tank, new problem. 1996 2.2L Sunfire
  173. 98 sunfire stalling
  174. Fault code
  175. 97 2.4L Sunfire starting problems
  176. A/C clutch Sounds HELP!
  177. '94 Cavalier turn signal problem. Help!!
  178. Clutch Slave Cylinder
  179. 03 no start
  180. 96 Cavalier Charging Problem
  181. Sunroof problems....
  182. theft codes on 97 Sunfire
  183. 98 Sunfire - No Dim lights
  184. bypassing the ignition
  185. 98 z24 acceleration problem
  186. Idle and driving really rough.
  187. Rear Defroster not working
  188. "Theft System" light on
  189. 97' sunfire engine misfire
  190. How to Replace Radiator Cooling Fan
  191. 98 cavalier brake problem
  192. 2003 Cavalier loses power Code P0171
  193. 1997 Sunfire gasoline smell any ideas?
  194. '01 Cavalier growls
  195. 02 Sunfire problems w/ Int. Lamp
  196. problems with ac in a sunfire 97
  197. Abrupt new clicking noise
  198. 87 cav. timing troubles
  199. 97 2.2 gasoline running out of exhaust?
  200. 97 2.2 gas coming out of exhaust!
  201. exhaust too loud
  202. '99 Cav Alternator Problem
  203. 2001 Cav 2.2 Engine
  204. 93 Cavalier stalls or hesitates
  205. loud screeching noise???
  206. charging system light coming on and off
  207. 96 Pontiac sunfire Brake problems
  208. 2000 Cavalier - Indicator light issue/error
  209. Trying to replace tensioner pulley
  210. Problem with interior vents on an 03 sunfire
  211. ATTENTION---Read now before posting ANY MORE REPLIES
  212. Engine temp between 195-220???
  213. Pulls Right when Braking in rain.
  214. ecotec clutch master cylinder diagram...
  215. wont maintain speed after hard acceleration
  216. 97 Cavalier Z24 Starts but won't stay started.
  217. In the market for 97 sunfire
  218. In the market for 97 sunfire
  219. weird noise
  220. 99 sunfire no start..
  221. 454cu Cooling Problems
  222. Wheel Bearings
  223. new thread for high idle
  224. 04 Cav theft Deterrent
  225. '97 - Parking/Emergency Brake light comes on when..
  226. problem with 2000 ford winstar stalling
  227. rksport intake problem
  228. Blower fuse blows after 3-5 minutes
  229. Transmission Solenoid Location???Where
  230. 93 Chevy Cavaliar RS TCM Location?
  231. Tranny problems (TCC solenoid or leaky valves)
  232. high high high high idleing!!!!
  233. Horn isnt working...
  234. 94 Cavalier Charging System
  235. Clunky noise sifting from park or from Reverse to Forward ?
  236. weird clicking noise then car dies...
  237. Rear wheel hubs in 94 Cavalier?
  238. 91 fuel filter
  239. radiator cooling fan not working
  240. Car will no longer start
  241. Humming Issue
  242. Cavy Cd PLayer
  243. 2001 Sunfire ABS problem
  244. 98 Sunfire AC Problem
  245. code 42, bubbles in radiator
  246. 91 cavalier overheating
  247. adjustable fan switch
  248. OBD I or OBD II, I'm confused, clarification needed.
  249. 100,000 miles, time for a tuneup...
  250. cooling fan/toggle switch
