Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
monte z34 overheating in one cylinder? perplexed
1994 chev.cav.electical problem
third time belt change >a week
car died---hard to re-start--code P0506
Where to mount clutch res. ????????
Fuel Filter Problems
97 Cav Z24 Dies Over And Over
92 calvalier 3.1 MFI
01 Cavalier..turns,but doesnt start...
Oil Light pops up when rough Idle and acceleration
check engine light is on and.......
1995 blazer 4x4 doint engage
2002 sunfire GT 2.4 no headlights
Sudden drop in Mileage
Cold weather idle
98 that's burning through gas extremely quickly
03 rear dash problem
95 cavalier, QDM Circuit problems.
99 Cavalier - Intermittent Rough Idle
89 that runs like crap
replacing 2003 sunfire backup lamps
I have NO idea what the problem is.
surging idle mysterious stall????92 cav
valve cover..
Blower Fan
Driver side head light on z24
99 Cav ABS Light
electrical problem!!!!! I think????
02 Cavalier Horn won't shut off airbag light is on
hard starting and theft light is on...
Cooling system nightmare
Temp sensor
Headlights are wacked...
my car will not start
92 Won't start?? Been searching......
98 Cav 5spd problem
Access to Front End
PCV Valve Location
no upshift
2003 Cavalier Thermostat
98 sunfire rear window defrost
Check engine light
odometer light
95 Sunfire sucking juice
IgnitionSwitch
2004 cavalier How to install Instrument cluster
Fuel Problems with 2001 Z24 Cavalier
ECM problem
uh oh again
97 Pontiac SunFire Ingition Switch
Air Mode Knob Broke?
96 cavalier no fire to blower motor???
Hit a curb, HELP
I think it maybe possessed
Igniton Problem
Pontiac Sunfire - NO HEAT
Thermostat
My car is a P.O.S!!
'99 Cavalier intermittent misfire condition on cylinder 4
help get my car to run
need help
93 cavalier chugs and sputters
head gasket question
RPM question
2002 z24 running trouble
gas pedal troubles
1995 Cavalier ABS problem
2003 Acting Up
Advice with 1994 Cavalier RS Woes
95 sunfire dome light and heater control light problems
Coolant change HELP
oil & coolant leak. need help!
2000 cavalier shift knob removal?
97 tranny fluid
coolant leak Cann't tell where
oil light coming on erratically
2002 Cavalier starts, won't run...Help?
98 Sunfire shift cable problems...
92 sunbird flywheel
Help Needed Asap!!! Car Died And Won't Start!
97 sunfire 2.2
96 cavalier
Fan Speeds?
97 Cavalier wont start
Starting Problem. Help!!!
95 Cavalier Serpentine belt diagram
Radiator Flush
01 cavalier sputters...dies at red lights
01 Z24 rear brakes clunk and grab
squeaking nosie
Help Please .. No air comming out of vents
Turn Signal Relay
97 Cavalier cut off when making a turn
88 Cav. Z24..Need Some Help Guys.
brake lights
quick help
Camshaft and crankshaft......
Auto trans slipping in 1st gear, 87 4 cyl
Z24 wont start after reaching operating temp
shifter loose
Pin Hole Leak in Fuel Line
it never ends!
2002 Z22 Odometer not working
blinker shuts off headlights
Heater blower won't run in 97 cavalier
WONT START....ew;oefhghweroriei! !
UH oh... Leaky clutch fluid '95 Cavalier
Please help me..... Plzzzzz
'92 Chevy Cavalier Oil Sensor Question
'91 2.2L TBI No Start Problem
99 Cavalier ETS OFF light is on
2000 Cavalier that died on the road
1995 2.2l Manual tranny trouble with CO
Heater Core
Fixing a Fuel Pump
help me
2000 Sunfire No DTRL
Won't start-no fuel-HELP PLEASE!
center terminal in 2002 cavalier headlight socket melting
96 Cavalier Ignition Problem...please help
ABS light problem
ECM Location
fan problem
Theft system light is flashing and car won't start.
1996 Z24 Rough Idling
Overheating--weird chunks in radiator hose?
sunfire won't start
Stalling problems
Water in Trunk of 2000 cavalier Z24
1990 cavilier to shim or not to shim
4.3 vortec #1 cyl ? bank an firing order
Quick Tansmission help!!!!
"Trac Off" and "Check Engine" light keeps coming on...
rad fan
1991 Chevy Calavier - Shuts off at stops and shakes
ABS light and Engine Ticking, Please Help
please help possible head gaskets leak
How to remove the turning combo Switch
98 Cavalier won't start sometimes
timing chain aliment
sunfire got hit in the rear and now will not start
drum brakes lock
91 V6 Cav stalling and sputtering probs
1996 sunfire/2.4 twin cam
Gurgaling sound from my heater core
98 cavalier 2.2L automatic
Clunking from Steering column?!?
86 cav z24 what next?
98 sunfire stereo problem!
MAJOR misfire problem back
help with fan sencor location
Cav won't start.
1995 cavalier stalling problem
sunfire gt enige sputters
95 Cavalier 2.2 roller valve removal
PCV valve 2002 ecotech
cavalier does not shift
2003 cavalier...no fuel?
92 cav no spark, good crank sensor
97 z24 2.4 trouble - endless
'74 chevy step-side truck for sale
cavalier ECM/PCM
Rear motor ABS circuit (RF)?
***Series of Problems.... Oh boy..****
cavalier PCM and crank re-learn procedure
99 Cavalier needs help (shucking action & temp. gauge stuck on cold)
name this noise?
How to take ignition switch out
'93 cav - rough idler
starting
trunk lid
engine doesnt turn
oil starvation (2.4L)
help needed
Locked ignition Switch
intermittent rough run
87 sunbird rough idle still
clicking noise in front brakes
'97 cavalier overheating
2000 sun fire problem, please help??
Alternator / Battery Problems
Weird noises when turning
abs light
Wipers
Chevy Cav Brake light and blinkers don't work?
Subwoofer problem...
Turns off on turns
no heat
drivers side rear window replacement
2002 Sunfire trunk lid problems!!!
Whats up with the suspension on these Cavs!
torque converter lockout selenoid replacement
Added gas mixed w/oil into my gas tank...what can I do?
Gauge Trouble
96 cavy stalled and wont crank up
99 Cav won't start
1996 Pontiac Sunfire
idles to fast
'90 Cavalier -- turning over but not starting
A few problems with my 01 Cav.
poor mileage
91 Cavalier Bypass Hose
fuel problems
whats wrong with my car?
93 cavalier clutch bleeding
94 Cavalier RS Will not start/ turn over
mystery sound
Running very sluggish at times
Cavalier Will Not Start in Hot Weather
PaceSetter Header
rapping sound in engine
Alternator or Battery?
88 cav cranks wont start
what's that?
headgasket torque specs
no power
Air Conditioner on Z24
98 sunfire - alternator problem!!!! HELP!!!
Glass Pack Muffler Exhaust system
know power
coolant
01 cavalier weird burning smell
tranny sounds/awkward
best memory/turn-on wire?
Selector cable replacement
Trany... HELP!
abs whirring, can't stop
brake caliper bolt
running out of gas question???
02 Cavalier Radio Went Dead
2003 Cavalier issue
98 Cavalier Help!!!
headlight update
1994 cavalier tranny problem?
Head lights wont come on
1999 Cav trans issue
Please Help, 3rd time asking power steering Q
Time set?
ABS/TC Light Problems
Help
98 Cavilier temp guage problem
added keyless entry to a 2000 cavalier from a wrecked 2004
'94 Cav. overheating.. but no heat.
replacing brakes
Chugging / Bucking Cavalier
Rear Brake Shoe Screech in Reverse
Location of Coolent Sensor on 98 sunfire
? clutch release on 94 Z24 3.1L 5 speed
Web
AF
