Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
oil light when idle
Help
is engine missing or something?
engine temp problem
Heater core question
Sunfire - Manual Shifter
I don't know what this light is.
Starting Problems
95 bogs down/hesitates....
electrical problem
Ignition problems -- 94 Cavalier
My Son Hit a Curb
wiper arm from steering colunm
Coolant smells??
oil light
2001 Backup Light Problem
crankshaft sensor
Battery running low?
Engine periodically getting too hot...possible problem?
Clutch, stuttering in 1st.
01 cavalier with a PO442, what is it?
Brakes
Crankshaft/Rod Bearings
temp sensor?
Camshaft Position Sensor
99 Sunfire burning oil
96 Cavy Revs high with little acceleration only while making a left turn
97 OHV -check engine lights when damp & runs crappy
2002 Sunfire 2.2 Shifting Problems
drop in gas mileage
Control Arm Install Woes
CV Joint?
96 and 97 2.2 engines compatible? No spark
96 Caviler bucking
fuel injectors
96 Cav - Trouble Codes PO420 & PO440. Please Help
1998 Sunfire CD player error 20
92 cavalier 2.2 ecm? please help
Header Help
2002 headlight problems
96 cavalier head specs
idle control problem
Strange Battery Drain / front spring problem
check engine light on
Slipping clutch on a 98 Z24?
Weird flasher/ABS problem
help!...lol this is bad
Headlight Issue. Electrical problem?
pro start CT3100 won't work
2003 cavalier rear defroster not working
2003 Cavalier High Beams Not Working
coolant going missing
throttle body sensor changing?
squeak when turning left on 03 cavy
wheel bearing
97 Cavalier High RPM Air control; HELP!!!
Spark Plug Question
looks like cooling problems are popular
89 cavalier heater problem
1995 cavalier dies, and doesnt pick up speed
Here is another coolant problem for everyone
Another Coolant Problem
Foglight Hell
ABS code 1261, what does this mean?
Leaking coolant resovor cap ?
97 Cavalier High Idle P0507
smokes like hell
my 90 z 3.1 wont idle when cold
problem idling when cold
1999 Cavalier Convertible - HELP!!!
96 cavalier
Crazy Electrical problems
1999 z24 cavalier head ligh chimes
Rough shifting
'99 Z24 Cavalier Convert. - blower motor resistor
'98 2.2 idling problem plz help
Electrical Problem
1990 Cavalier leaking coolant
96 Cav Convertible Z24
96 Z24 Auto Tranny Pulls
Engine cooling fan, problems?
Headlight problem, Need HELP!!
possessed 96' cavalier, 2.2 ltr. all lights flash and rough idle,die
2003 cavy idile is to low and jumps. Please help
OK I'M BACK and i need to know EVERYTHING about catalytic converters
cav. won`t start
2003 Cavalier Engine Light
Need help on ABS light is always ON!
Wierd Cooling Problem
97 Cav "Microprocessor Unit" ? ! ? !
Not Your Average Keyless Remote question
2000 cav wont start
92 cav z24 3.1L
Wtf!!!!!!!
Intermittent Light/power failure
Gear Shift problem
'98 2.4 problems
2.2 ECOTEC Idles but cuts out when gassed ???
Wheel Bearing
98 cavalier Cooling fan circuit P0480 DTC
Replaced Starter Now It Doesnt Start
Girl who's car won't start
putter
2002 Z24 - No Turn Signals or Hazards Lights
94 V6 3.1 Idle
Airbag light is on after installing remote start
Got Code 440 now what
Help Me Please
oil pump problem
'96 Bonneville engine cuts off
bad gas mileage?
Idels between 1100 and 1500 rpms
2000 sunfife rear brakes locking up when brakes applied
1996 Cavalier-What could be causing this strange sound?
sunfire clunk
Electrical problem??
Rear Brake Cylinder Replacement Problems
turn signal on 90
94 engine problem. help
2000 Cavalier Z24- electrical malfunction
Stalling
TC light, ABS light, Service light
Partial Loss of Power
P0441 Code and Stuck Idle??
Cavalier Brake problems '94'
Warped front rotor
Front Brake Bolt Size 2002
Cavalier Keyless Remote Problems
Random Dieing when Braking, Laggy/Stuttering Takeoff.
odometer out!
94 cavalier RS trans filter.
Wind noise 2002 cavalier LS
96' cavi won't start Please help
popping/clicking
oil light comes on
Trunk Leak 2nd Generation
oil leak
Chevy Cavalier starting battery alternator problem??
Alternator electrical probs weird noises
I have no idea what's going on.
power window?????
2001 cavalier
Oil Pressure Gauge drops to "0"...
97 Z24 Dome Light Stuck On
jerking motion?
cat. plugged or missing?
1998 cavalier 2.2 wont start
'93 Cav RS Strut / Knuckle Bolts
Loud Hummin Sound
Bright Lights don't work
96-98 cavs seem to have the same problems
Car wont start...
Best Cavalier Repair Manual?
Fuel Pump/Electrical system problem...
2002 pontiac sunfire..engine light on
1988 cavalier-new starter-good battery-won't start
98 z24 2.4 motor mount troubleshooting
1996 automatic cavalier ignition problem
Headlights Wont Come on Amymore
Which came first? And Why???
oil in throttle body and intake
oil in coolant fill bottle
drivers side windows fog up esaly
rear defroster switch buzzing
No Start
98 Cavalier hesitating/bucking
No high beam lights
98 Chevy cavelier acting like it's running out of gas
98 Chevy Cavelier acting like it's running out of gas
95 Cavalier Heater
1999 head gasket change
1997 Pontiac Sunfire airbag lights?
1993 Cavalier Trunk Problems
2000 z24 check engine light steady on
Abs+ets+svs 2
Abs+ets+svs
'94 Sunfire blown head gasket????
Won't start when wet
95 cavalier heater air flow
95 Cavalier 2.2L 5speed Trans problem
Women
1999 Caviler Alternator 2 small wires disconnected
03 Cavalier-Is the auto trans shifting right?
idle
Trans has only 2nd forward gear
Transmission Jumping When Changing Gears??
ECM Location
Pontiac Sunfire gas mileage
clutch problems...
rpm's fluxuating problem
Hellllllllllllllllp
Hellllllllllllllllp
1997 transport won't take fuel
pontic transport 3.8ltre 94
how do I purge my system
whats evap line???
Hesitation or miss under moderate acceleration
1997 Firebird heater problems
wipers and theft system
intermittent headlights 97 cavalier
loose BOLTS!!!!!
1992 Cavalier ABS light staying on
Reading computer codes
1997 Sunfire won't stay running HELP!
questions about new replacement radiator
Driver side power failure
1999 Cavalier ABS + BRAKE ! Light
Smoke coming from the steering column
dimming head lights??
newbie with questions!!
1991 Cavalier Check Gages Light
service light on not sure why
Gauge Cluster lights Help
98 cavalier transmision problems
Low idle problems
2000 Sufire misfiring
need an alternative to driver side airbag
buzzing noise from front speakers
95 cavalier overheating
dukeboy
Flywheel
car won't start, think its the ignition switch
2003 Check Engine Light on...
Check Engine light is on and i have the codes
stalls when making slow left turn
/ cooleant leak on top of resover?
96 Sunfire Overheating only in winter
2003 Sunfire Headlights
95 Cavalier Intermitent Starting problerms, and check engine light
Need Help With 91 Chevy Cavalier RS
99 Chevy cavalier problems im lost help!!!!
98 cav will not start
vapor comes out of the hood on my 91 Cavalier
Possible Blown Motor
no air flow
Weird electrical problems; Domelight not working HELP!!!!!
Radiator/Fan Problem '94 cav
Headlight indicator
Getting to the spark plug will on the coil pack 95 Cavalier
95 sunfire spark problems
Serious Problem
How to install RKsport FPR???
98 sunfire wont warm up -- confused!!!
2 WEIRD problems with 96 Cavalier!!
I crashed my 2000 cavalier and now need to remove airbags
Need some advice
98 cavalier stalls when ever it wants
Heater Problem
headlight Problems
Web
AF
