View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19
  1. 1997 Z24 Check Engine Light
  2. ignition or passkey
  3. Fuel problem
  4. my odometer/speedometer don't work
  5. 1995 Sunfire: Rough Idle & Makes a Popping Noise
  6. 03 Cavalier Won't Run!
  7. 2005 Chevy Cavalier Check Engine Light
  8. 2000 cavalier fan speeds`
  9. Where is Fuse Box 89 Cavy???
  10. Engine won't turover
  11. 1995 Cavalier air conditioning
  12. looking for part name
  13. 98 Cavalier Rattles
  14. under hood sensors
  15. 98 Cav, Rattle
  16. radio problems
  17. 2001 cav. Temperature problem HELP!
  18. Engine shudders when cruising/accelerating
  19. cavalier heats up slowly when stopped
  20. 03 cavalier died while running
  21. Stoopid Fuel Filter QD!?!?
  22. O2 Sensor question
  23. Gauge Cluster Help
  24. "01 Sunfire Trans. and Speedometer problems
  25. 2.0 stalling
  26. Cooling Fan 1 Issue
  27. Where is DRL relay on 99 Cavalier?
  28. Gauge reads over heating, but radiator is not hot
  29. fuel injector
  30. clearing pcm
  31. How to correct computer if smaller sidewall tires are put on?
  32. 97 cavalier cooling system?
  33. Tick.Tick.Tick. Where?
  34. '92 cav overheating... then won't start for a period of time
  35. stumped
  36. Back Brakes grinding and squeaking
  37. need help asap with 97 cavalier
  38. Bosch 440cc Green Tops injectors...will they work?
  39. 2003 Cavalier power window problem, help
  40. Sunfire 97 - stalling problem. Help!
  41. 99 caviler wiring problems
  42. Dog chewed up my air filter
  43. running on 3 sometines 2 cilinders
  44. How screwed am I?
  45. '94 cavalier, replaced ,rockers,springs,rods head, gasket, etc..
  46. 2001 Sunfire-no range on remote
  47. lossing freon
  48. AC soaking my carpet. Help!
  49. Squeaking/knocking sound in front end
  50. Head Gasket, Rings, & Mains?
  51. O2 sensor out, now car won't start..??
  52. O2 sensor out, now car won't start..??
  53. replacing bent rod
  54. Moisture in the Oil?
  55. 02 cavalier no gauges
  56. Cavalier Shuts Off While Driving
  57. Lots of Moisture in Halo Lights, whats wrong?
  58. 98 Cavalier knocking in driver front wheel
  59. 95 Sunfire PRNDL indicator not working
  60. Did I Blow It Up???
  61. cooling fan not working 97 cav 2.2
  62. Air/ Fuel problem
  63. projector headlight problem?
  64. 98 Cavalier Horn Location
  65. New Car With Just a Few Problems
  66. 99 Cav, no low beam headlights
  67. loss of power
  68. transaxle seals
  69. slow start
  70. 98 Sunfire Just Won't Start. HELP!!!
  71. engine coolant light!!! HELP!!
  72. 96 lier wont keep a charge.
  73. 92 Cavalier Radiator/Overheat Problems? Help!
  74. asap please
  75. 88 cavalier running rough on start up
  76. uhh explosion may occur??!!
  77. 02 Chevy Cavalier won't start
  78. 2.2 stopped engine will turn but wont start...
  79. 99 2.2 very hard to start
  80. 2003 Cavalier- engine stalling at idle
  81. Please Help
  82. Installed new aftermarket headlight bulbs, Lost DRLs
  83. Z24 drinking gas like alcohol?
  84. Code keeps coming up...
  85. 97 Cav Unknown Problem
  86. 2200 serp belt
  87. 98 z24 AC Compressor question
  88. Replacing O-Ring Seals on Compressor? Possible?
  89. Please Help power widow problem!!
  90. 2002 Cav Odometer reads "error"......
  91. ETS off light and flashing engine light
  92. '92 2.2L 3Speed starts then dies....
  93. 2003 Cavalier fuel problems
  94. check engine light on 94 cavalier
  95. 96 sunfire GT 2.4 L engine runs rough in hot, humid weather
  96. 97 Sunfire 2.4L A/C
  97. Need help on cooling fan
  98. Please help on cooling fan
  99. 2000 Pontiac Sunfire's brake lights
  100. '96 Sunfire GT 2.4L Engine doesnt like hot, hunid weather
  101. 98' sunfire 2.2 starts but dies--ECU problem?
  102. 2000 Pontiac Sunfire Won't crank!
  103. 20002 Cavilier guages not working
  104. I Hate Newer Cars !!! Help
  105. changing lock cyclinder, will passlock be an issue?
  106. 96 Cavalier starter-alternator
  107. 2.4 question
  108. 1995 Cavalier rough running condition
  109. 2001 cavalier 2.2
  110. brake sensitvity
  111. how to get codes
  112. 97 sunfire 2.2L
  113. Please help Sunfire owner
  114. Starting problem
  115. 94 Cavalier Ground Problems--please help
  116. Code P0113 Intake Air Temp Circuit Hi Input
  117. problem with 2002 cavalier
  118. Fan doesn't work on my '99 Cavalier
  119. 99 cavalier z24 odometer is all scrambled
  120. 95 cav 2.2 intermittent spark
  121. No Belt Tensioner 97 Cavy
  122. Sunfire 200 Dashboard and Shifter
  123. need to replace front brake pads on 2001 cavalier need help
  124. 03 cavalier gauge problems
  125. 97 AC Problems!! Need Some Help!!
  126. 2001 cavalier radiator fan fuse blows
  127. engine cuts out while cruzing
  128. 89 cavalier runs rough when hot
  129. 2005 Pontiac Sunfire
  130. WTF Rear View Mirror???
  131. 97 cavalier choking up while accelerating
  132. Sunfire Runs For 2-3 Minutes, Then Dies.
  133. Brakes problem sunfire /96 needs help !
  134. 01 Cavalier - Both Hi-Beam Headlights out
  135. 2001 Chevy Cavalier Z24 with 2.4 liter engine-Can't check codes!
  136. Check Engine Light-01 Z24 Cavalier-Can't read codes!
  137. cooling fan problem
  138. being blamed need help
  139. ECM fuse blown on 1992 Cavalier Z-24
  140. easy spark
  141. why would this keep happening?
  142. New Cavalier owner-1st problem within a week
  143. Vibrations
  144. Changing the Fuel Filter?
  145. Brake lights not working.
  146. rrrrrrrrrr on my cavy lol.
  147. 98 Z24 Cavalier won't shift out of 1st! HELP
  148. How do I change my a\c relay switch on my 2000 cavalier?
  149. where is the horn wire at????
  150. 96 Sunfire Won't Start & Dash Buzzing
  151. Grinding sound on 91 cavalier
  152. Bench Testing Starter/Solenoid Assembly
  153. 2.2L timing cover. Good gawd.
  154. 96 with possible electrical problems
  155. '89 Z24 Stalls Out
  156. Caliper mounting bolts don't go all the way back in?
  157. Humming sound from under car at certain speed only
  158. 97 cavalier 5 error code(s)
  159. missing...
  160. My 95 Sunfire's lights stay on and raadio shuts off while driving
  161. trouble code B 1013
  162. 97 with 2.2 stalling and rough idle
  163. Compressor problem
  164. Fuel system issues??
  165. Anyone know where is the oil filter in a 2005 Pontiac Sunfire?
  166. Rear table bushing... squeak..
  167. my 02 gagt just cuts off
  168. New guy with lots of probs..
  169. Z24 Starting Problem
  170. Z24 Starting Problem
  171. Wierd Metallic Popping Noise
  172. Cooling Fan
  173. 99SunfireStarter
  174. Cavalier problem: hard start & hesitation
  175. MISFIRE with new plugs and wires
  176. 2001 Cavalier Z24 Knock Sensor Location?
  177. 97 Z24 cav help please
  178. A Weird Ticking sound From front end
  179. 98 Sunfire GT water pump is out
  180. Fast idle problem with 2000 Z24
  181. 2000 Cavelier Coolant Overflow
  182. 02 Cavalier jerks/stutters between 40 and 60 mph
  183. '97 Cavalier strut prob?
  184. 96 Cavalier Oil Pan Sensor
  185. 02 cav brake problem
  186. My..z24 Engine Is Going Need In Fo Please
  187. 90 z24 jerks sometimes
  188. Big problem, long story. Please read.
  189. Smell gas
  190. cluster and needles issues
  191. 1996 Pontiac Sunfire Gt 2.4 Crankshaft Position Sensor
  192. 98 Cavalier Z24 no start/ VATS problem
  193. exhaust problem
  194. ecm or not
  195. 99 Sunfire --Flashers/Turn Signals, Brake Lights, a......
  196. Big Electrical Problem
  197. Idle RPM'S?
  198. No Vacuum
  199. 2004 Cavalier Check Engine Problems
  200. 1995 Cavalier 2.2L No start when damp or wet
  201. Depressed
  202. Car keeps stalling after installing sub and amp..
  203. 99 sunfire starting problems
  204. chevy cavalier 95 not starting
  205. Trouble Code P1133
  206. 98 Cavalier died on me!
  207. 98 Cavalier died on me!
  208. Fuel Problem
  209. 95 cavalier runs hard from start
  210. 98 Cavalier NO-START, please help!!!
  211. 98 Cav with awful gas mileage
  212. 98 Cavalier with awful gas mileage
  213. RE: 96 Cavalier issues with randomly not starting and stalling for the last 6 months
  214. Check Engine Light.... no code??
  215. Ignition Lock Cylinder
  216. cpu/sensor??
  217. Help
  218. 97 Cavi Will Not Start.. im stumped
  219. 2002 Z24 Check engine light
  220. GM techs, HELP!! stubborn crank position sensor.
  221. Fuel Problems on '96 Cav
  222. speedometer drive gear
  223. 2005 Sunfire Power Window Problem
  224. Odd Problems 97 2.2
  225. 1989 Cavalier Transmision shift
  226. engine problem
  227. firebird wont start
  228. climate control lights????
  229. Stick is actin kinda funny
  230. Demobilizer (i think) issue
  231. 98 Cavalier replace ac evaporator HELP!!
  232. Bah, i knew at 220k something would go wrong
  233. 95 chevy cavalier quad driver codes (i need help)
  234. odb 2 code p0480
  235. 1997 Chevrolet Cavalier 2.2 alternator
  236. 2.2 question
  237. 96 Cavalier takes average 50 seconds to start
  238. Dumpin Fuel, Won't Accelerate ??
  239. Dumpin Fuel, Won't Accelerate ??
  240. '02 Cavalier- car idle surging w/AC on and trans in drive
  241. '02 Cavalier- car idle surging w/AC on and trans in drive
  242. 97 Cavlier IAT Sensor Problem
  243. Rear wheel bearing
  244. 97' Z24 cyl 2 and 3 missfire???
  245. gas gage problem
  246. 94 cavalier dies while in drive and reverse
  247. Changed my coolant
  248. 91 Cav has trouble starting/running
  249. fuel pump
  250. 03 Cavalier Check Engine Emisiions Warning?
