Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Cavalier
> Cavalier Problem Diagnosis |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
98 cavalier brake problem
2003 Cavalier loses power Code P0171
1997 Sunfire gasoline smell any ideas?
'01 Cavalier growls
02 Sunfire problems w/ Int. Lamp
problems with ac in a sunfire 97
Abrupt new clicking noise
87 cav. timing troubles
97 2.2 gas coming out of exhaust!
exhaust too loud
'99 Cav Alternator Problem
2001 Cav 2.2 Engine
93 Cavalier stalls or hesitates
loud screeching noise???
charging system light coming on and off
96 Pontiac sunfire Brake problems
2000 Cavalier - Indicator light issue/error
Trying to replace tensioner pulley
Problem with interior vents on an 03 sunfire
ATTENTION---Read now before posting ANY MORE REPLIES
Engine temp between 195-220???
Pulls Right when Braking in rain.
ecotec clutch master cylinder diagram...
wont maintain speed after hard acceleration
97 Cavalier Z24 Starts but won't stay started.
In the market for 97 sunfire
weird noise
99 sunfire no start..
454cu Cooling Problems
Wheel Bearings
new thread for high idle
04 Cav theft Deterrent
'97 - Parking/Emergency Brake light comes on when..
problem with 2000 ford winstar stalling
rksport intake problem
Blower fuse blows after 3-5 minutes
Transmission Solenoid Location???Where
93 Chevy Cavaliar RS TCM Location?
Tranny problems (TCC solenoid or leaky valves)
high high high high idleing!!!!
Horn isnt working...
94 Cavalier Charging System
Clunky noise sifting from park or from Reverse to Forward ?
weird clicking noise then car dies...
Rear wheel hubs in 94 Cavalier?
91 fuel filter
radiator cooling fan not working
Car will no longer start
Humming Issue
Cavy Cd PLayer
2001 Sunfire ABS problem
98 Sunfire AC Problem
code 42, bubbles in radiator
91 cavalier overheating
adjustable fan switch
OBD I or OBD II, I'm confused, clarification needed.
100,000 miles, time for a tuneup...
cooling fan/toggle switch
Air Conditioning Compressor Leak
89z24 tranny
Low coolant light and car overheated at idle
sure signs of HG failure
Dry Oil Filter.
02 Cavalier No power, rapid clicking when turning key
01 Sunfire starting problem
2003 Cavalier AC Problem
Possible Overheating
2000 z24 starting problems
97 Cavalier
transmission
Cavalier Pulls to the Right ?
problems with AC
Sputtering at low rpm's
98 Cvalier Stalling problem
Transmission fluid drained at stoplight.
overheating problem
Loss of power:Poor acceleration
Brakes Clicking
I need Starter motor help!
96 2.4l Ignition Problem
faulty wiring on headlights?
96 not starting...weird acting...
1996 cavalier starting problems
electrical problem, starter perhaps?
locked in park
won't shift out of park
Interior fan wont shut off
Theft system
my vent air smells like black and mild smoke.... wtf???
97 2.2 cavalier starts but shuts off when driving
coil pack to distributor?
air locked
mystery problem
Strange Smell
Can mufflers get clogged?
Vibration while braking
Trac Off Light
brakes
Idles Funny
Brake Problem
97 Cavalier Oil Leak
92, Changing a Fly-Wheel?
Dam curbs
1999 cavalier axle nut
97 Cavailer
1994 cavalier won't start
02 Cav. making weird noise
Air Vents not changing
So Very Confused
lopey idle, and somking on the inside
Help to maintenance or test Sunfire 2002 sensor's
98 cavy, abs/battery lights
running short on patience and money
Reset or Restart Computer to original values
Cold Air Intake = Check Engine Light
Passenger side mirror on 95 cavalier
Single Mom needs Help!!
AC Problem
2003 sunfire Fault codes
2003 Sunfire Need help with tranny problem
Recurring P0420 code on a good running Cavalier
97 Cav misfire
95 2.2 cavalier engine noise
Has anyone changed a window motor on a '96
Name That Noise ?
Hesitation, misfire when warm
03 cavy stall-HELP!
cooling fan
2001 Z24 tranny code
removing backseat
99 cav squeal
road noise
02'Sunfire
Help!!! 98 Cavalier Low Beams Not Working
89 2.8 idling problem
4th cylinder dies after engine warms up...
96 cavalier. How do you check tranny oil level
99 cavalier headlight problems
94 Cavalier 2.2L wont start
squealing steering wheel???
1991 Cav, no spark (DSI)
93 Taurus Head Gasket replacement
97 cavalier 2.4 liters engine keeps turnig over with out keys
96 cavalier probs
Squeal when making left (94 Cav)
Definite fix for stalling while braking?
Coolant Light/Leak
96 cavlier with the 3t40 tranny (3speed) problems!!! NEED HELP ASAP!
96 cav turns over but will not start... 70 miles from home!
97 Cavalier 2.2 Heat Gauge Problems??
emissions and drive cycle
97 sunfire power steering problem
1995 cavalier clutch problem.
help car heating up
help car heating up
93 Z24 3.1 sooty black p[lugs, runs rough
coil packs
Grinding noise under 35mph
more Cavalier Problems
Wierd Grinding/Buzzing noise
01 Cavalier Stalling when warm
1996 cavalier runs when key is off
01 Cavalier, problems starting.
Engine/Oil Flush?
Caviler 93 started and then stoped and not starting
1996 Sunfire won't start. Dash acting crazy
Extremely Jerky Idle
Clunking from wheels - turning or bumps
BUCKING Bronc (99 Cavalier)
e-brake lock up
battery light comes on when shifting
2nd Generation Trunk/window Leaks
HELP! 1993 Cavalier Stalling Problem
Whats with my tranny?
94 cav problem with running
'02 2.2 Cav starting isuue
cavalier fuel pump
98 Sunfire Transmission Converter surge problem
97 cavalier excessive road noise
Window down in rain and snow! HELP!
85 Cavilier EGR problem
95 cavalier auto trans issue
Replacing ignition switch...
'89 Cav Brake issues
Help! Lights came on, What does it mean?
1998 Sunfire: DRL, one dim headlight?
97 cav wont crank
pontiac sunfire 2003
rpm drop, almost stall when turning off ac
97 cav probs Please Help
01 Cavalier Cranks and Wont start
Still needing some help w/ ignition
98 cavalier RS running rough lost power, MPG
Gas Gage
97 Cavalier turn signal
Trans problem
1991 Cavalier Hesitation
95 2.3 idles REALLY rough and wont move.. mucho gas smell
Trunk Help!!!
Electrical Problem
'89 Z24 starter problems....help!!!
Wipers Won't turn off @ 60MPH ++
Squeak??
transmission fluid and hard shifting
1996 cavalier P0440 + cooling fan always runs
cruise control
01 chevy cavalier
Body Control Module
91 Cavalier, 4 Cyl just stopped, will not start
Sunfire doing wierd F*&^ up things
Knocking Noise
Car stalling, Need HELP!!
1996 - no tach, no temp & all dash lights light up
Lights
98 z24 deceleration?
Remote Car Starter Problem
96 caviler starter
2000 Z24 IAC question
96 Sunfire GT M/T cant shift into 2, 4, or R
ABS problem
chronicles of my 89 cavalier
Problem starting - where to start?
Need help with front end!
trans issue???
2002 LS Cavalier
1996 pontiac sunfire overheating 2.2L
Kilometers wont show, but an error msg will!?!
89 4cyl cav.. TEMP Light Comes on, heat/air smell like antifreeze... new thermostat?
93 Cavalier stalls after reaching over 65 mph
96 cavalier lights only work on one side
over heating and overcooling
94 Cavalier RS Rough Idle
2000 cavalier ecu - trac off
sputter before warm
97 Cav keeps blowing Power Steering system O ring
rdm
rdm
pilot bushings?? going from auto to standard
Driving Light Problems
My Car will not crank to come alive
Side Mirror is very loose
'96 Sunfire - Power & Idle Issues
Stiff Shifter
oil sensor& tighet gas pedle cable
Steering Problem
95 tansmission
Anyone know
Anyone wanna try and help with this problem
Web
AF
