View Full Version : '01-'05 Civic
Pages : [1] 2 3
  1. Problems with Acceleration and now Power Steering
  2. 01 Civic Automatic Transmission Shifts like...?
  3. Srs
  4. 01 civic power locks
  5. 03 swap question
  6. Soaked in the flood
  7. Engine Block swap B17A2 and B17A1
  8. 2004 Civic EX wont' start
  9. 2002 Honda Civic Si 1.7L
  10. What's that box BEFORE the Air Filter holder?
  11. What's that Box BEFORE the Air-filter?
  12. Blue Flashing LED on the left side of the dashboard
  13. 2nd gear pop-out issue
  14. Is this used 2002 Civic a good deal?
  15. 2001 Civic EX Advice
  16. 03 ex overheating issues
  17. cooling fans coming on only when A/C is turned on.
  18. 2003 civic si?????
  19. 01 ex
  20. 2002 civic hood latch won't release
  21. Consistent surging
  22. New Guy with a Civic
  23. Shock/Strut 2002 Civic
  24. The Best PM's for your Honda!
  25. belt squeal 2001 2 door civic
  26. 2002 Civic sedan wiring diagram
  27. 2003 civic maintenance light
  28. failed transmission survey HERE NOW!
  29. repairs times 01 Honda Civic 1.7 MFI auto
  30. common issues 01 Honda Civic 1.7 MFI auto
  31. 01 5-speed vs. 02 5-speed transmission
  32. Brake Job
  33. '04 civic ex shakes when shifting
  34. Possible Fuel pump/Filter
  35. Sound from brakes. My car is moaning.
  36. 01 civic power locks
  37. My 2001 Honda Civic EX is making me sick
  38. Headlight Issue!
  39. 01' LX Transmossion not shifting... P0730
  40. manual trans bulletin from honda
  41. 04 Civic Dx replacing dash lights ??
  42. 01 Manual Trans Bearing Noise
  43. 2002 Honda Civic creaking noise
  44. manual trans clutch removal instructions
  45. HX and EX difference
  46. 03 Civic - clicking sound from passenger side engine transmission area
  47. Repair manual?
  48. Blew out a shock on a pothole.
  49. transmission model
  50. 2003 Honda Civic
  51. 05 Civic disc brake pad removal problems
  52. '01 Honda Civic 1.7L Intake Manifold
  53. 01 honda, help a lady out?
  54. 02 won't move
  55. body kits for mk7 civic
  56. Honda Civic New vs. Used
  57. Figured out the problem, now I need the part
  58. 01 Civic LX 1000 RPM Drop at Highway Speeds
  59. Removing RS symbol on 01 grill
  60. 05 Civic Ex, Camshaft Position Sensor
  61. Need Help Finding Cps (camshaft Positioning Sensor)
  62. ANZO Projector Headlight Help (2004 Civic Si)
  63. installing a HOD or HHO system and need map sensor info
  64. droping rpm
  65. changing gear shift knob
  66. OBD II Codes
  67. Is it possible to overfill a gas tank??
  68. Planning to get '04 Civic
  69. honda civic 04 lx 2 door
  70. Fuel Air Metering
  71. 2005 Honda Civic Stock Stereo sound goes in and out
  72. 01 Civic with no Dash / instrument lights
  73. Transmission problems.. help
  74. Door won't open from the outside
  75. Thoughts On Car Bras
  76. how do i reset timing
  77. 03 Hybrid clunk
  78. p0301?
  79. Advice/Information on Tachometer/Guages
  80. 04' Hybrid Gas Milage
  81. 03 Hybrid
  82. Civic 4 Sale
  83. 01 Motor Mounts
  84. H22 in a EM2
  85. Manual shifter issues..
  86. New to civics...
  87. rear window shelf
  88. shutting off randomly? power steering also...
  89. pcv valve location
  90. smelly stuff in cabin
  91. Heating and A/C blower?
  92. Feel dumb but can't find my block heater
  93. 03 Honda Civic EX
  94. DRL relay noise.
  95. [URGENT] - '01 Civic lost and Axel Seal and now...
  96. new to imports
  97. When to replace brakepads
  98. Exhaust? Whats the diff between catback
  99. wits end with 2004 honda civic 1.7 4 dr
  100. 2001 Honda Civiv EX Engine stalls
  101. '03 Civic EX Coolant smell, Temp rising
  102. Jdmes1civic
  103. Civic autostart installation help
  104. parts
  105. SRS light reset
  106. Help! How to replace 01 Civic coupe window glass driver side
  107. Alternator/Battery/Gauge issues
  108. 2001 Honda Civic radiator fan motor
  109. Heating...very odd....
  110. AC/Blower Not Working =(
  111. Replacing the a/c compressor on a 03 Honda Civic SI?
  112. 01 civic lx p1362 missfire
  113. My old friends need help
  114. with these tires fit?
  115. HELP!! SRS light!!!
  116. 02 civic EX control arm
  117. Civic radio code
  118. 04 Civic SI A/C Condenser location.
  119. Help!!! How Do I install Halo Projector Lights on a 2001 Honda Civic?
  120. Cherry Bomb?
  121. Drums Won't Come Off
  122. Loud drive?
  123. Which is better
  124. Is this road trip a good idea
  125. 2001 Civic HX won't pass emissions
  126. Seeking Advice on "Recommendations" from the Dealer
  127. Release for Gas Cover not working
  128. Want your opinions
  129. AC compressor
  130. 05 Civic tranny not shifting...
  131. SES Light
  132. V-tech Controllers Help
  133. Keyless Help-'05 Civic
  134. Flushing power steering fluid
  135. '05 civic
  136. '99 Civic SI rims -- Same bolt pattern as '01 Civic EX?
  137. Door key wont turn
  138. 05-06 Civic Manual Vs 04 Impala Ls Auto
  139. 03 Civic Throttle Position Sensor
  140. Help me out please
  141. Help me out please
  142. Anyone tried the Nitrod Performance Meter....
  143. Intake Manifolds
  144. civic question
  145. Performance Chip
  146. CAI/air by-pass valve/throttle spacer
  147. i need to tune up my civic lx 2001
  148. 02 Civic Suspension
  149. 2003 Shift Light out
  150. Crazy Problem... Shifting problems!
  151. 70k service for 2002 Si
  152. 01 DX quetions
  153. Does anyone know of any good shops in Central Jersey?
  154. Installing a turbo kit...
  155. 03 A/C install
  156. full suspension swap DIY
  157. Couple more noob ?'s
  158. cold air intake
  159. Noob has question about VTEC
  160. Spark Plugs - Which Ones Do You Run/Like?
  161. Steering problem w/'02 Civic HB SI
  162. Please Help
  163. Is this a good deal ('02 Civic Si Hatchback)
  164. turbo, how many psi?
  165. 02 civic shop/mechanic problems
  166. new underdrive pulley, what belt?
  167. My Right Front Spring Squeaks When I Steer.
  168. Help! Engine won't start..
  169. installing an alarm 2003 civic hybrid disarm the factory keyless entry
  170. installing an alarm 2003 civic hybrid disarm the factory keyless entry
  171. installing an alarm 2003 civic hybrid disarm the factory keyless entry
  172. installing an alarm 2003 civic hybrid disarm the factory keyless entry
  173. installing an alarm 2003 civic hybrid disarm the factory keyless entry
  174. 2005 SI Gauge
  175. General Suspension Question
  176. 2002 Civic Si Clutch Paddle Squeaks.
  177. 01 radio static with rear defogger
  178. Ep3
  179. Mighty mice
  180. 04 civic ex dop kit help!
  181. 2002 Honda Civic Transmission Fluid change
  182. 2002 Civic No Start
  183. '04 DX Water Leak
  184. 2001 EX Speedo stuck - VSS or bad gauge?
  185. Driver's Side MiRROR removal
  186. Help-01 Civic HX parts
  187. 2002 Si Screams at 80 mph.
  188. Grinding Noise
  189. '03 dash removal
  190. Blow out
  191. Air Vents Registers Loose Hard to Direct Air
  192. Help! 2002 Civic Rear Door Panel Removal
  193. 01 civic 5spd DIFFICULT and SQUEAKY SHIFTING
  194. civic Si on my mind
  195. 2001 Cavalier Reverse Lights
  196. 01 Honda civic ex turbo ?
  197. engine light
  198. 05 Civic Si - Which Winter Tire
  199. Please .. 2001 Civic - camshaft off center ?!
  200. brakes?
  201. Official picture thread?
  202. Adjusting Brightness of Dash Lights
  203. airbags 02 civic
  204. Maintenance help?
  205. Jensen VM9311TS Help?
  206. How do i get more from my d15b motor?
  207. driver's side lock broken, kind of
  208. 01 gold civic
  209. 05 civic headlight problem
  210. 02 civic Ex vs 03 Camry LE
  211. 04 LX Questions
  212. 2001 DX coup speaker sizes?
  213. need help from dx/lx owners
  214. HELP! what are specs for 01-05 EX?!?!? =(
  215. Squeaking/Clanky sound from front right passenger side area
  216. Funny Prius hybrid animation
  217. 2002 Civic EX Radio help
  218. Finally broke my 1,000mile tank summer goal!
  219. problem installing head unit on my civic 01
  220. Help! Speed Gauge suddenly stopped working
  221. Vibration in driver side door (bass induced)
  222. more horsepower
  223. vibration 2003 Civic LX
  224. 2001 DX has no tachometer
  225. 2004 honda civic ecu replacement???
  226. Bottom 13's
  227. 2001 Civic EX - rear speaker removal, help
  228. Tach stopped working suddenly
  229. 02 Civic Ex Wont start!!
  230. SRS light-- does it disable the air bags?
  231. 02' driver side door lock
  232. help - 01 Civic driver seat rocks up n down
  233. 05 limited edition stereo, how to put in a sub
  234. ????Throttle body boring & porting by Maxbore.com????
  235. anyone ever install battery isolator?
  236. 03' Coupe Headlight Bulb
  237. DRL light flashing and clicking
  238. 01 civic ex big problem
  239. 03 EX 4dr, need short ram intake, any suggestions? PLEASE!
  240. Vtec?
  241. Honda Civic EX Traction Control
  242. 2003 civic hybrid speakers front and back
  243. Wheel Stud Removal for '01 Civic
  244. 02 EX Coupe - What are the trunk dimensions ?
  245. 2002 Civic cluster problems...
  246. 2002 civic A/C making some funny noises...
  247. 02 Civic - What are the sizes of the speakers ?
  248. TPS low voltage (code p0122)
  249. Getting wheels, what next?
  250. My 02 clicks, but from somewhere else
