View Full Version : '01-'05 Civic
- Help! Engine won't start..
- installing an alarm 2003 civic hybrid disarm the factory keyless entry
- 2005 SI Gauge
- General Suspension Question
- 2002 Civic Si Clutch Paddle Squeaks.
- 01 radio static with rear defogger
- Ep3
- Mighty mice
- 04 civic ex dop kit help!
- 2002 Honda Civic Transmission Fluid change
- 2002 Civic No Start
- '04 DX Water Leak
- 2001 EX Speedo stuck - VSS or bad gauge?
- Driver's Side MiRROR removal
- Help-01 Civic HX parts
- 2002 Si Screams at 80 mph.
- Grinding Noise
- '03 dash removal
- Blow out
- Air Vents Registers Loose Hard to Direct Air
- Help! 2002 Civic Rear Door Panel Removal
- 01 civic 5spd DIFFICULT and SQUEAKY SHIFTING
- civic Si on my mind
- 2001 Cavalier Reverse Lights
- 01 Honda civic ex turbo ?
- engine light
- 05 Civic Si - Which Winter Tire
- Please .. 2001 Civic - camshaft off center ?!
- brakes?
- Official picture thread?
- Adjusting Brightness of Dash Lights
- airbags 02 civic
- Maintenance help?
- Jensen VM9311TS Help?
- How do i get more from my d15b motor?
- driver's side lock broken, kind of
- 01 gold civic
- 05 civic headlight problem
- 02 civic Ex vs 03 Camry LE
- 04 LX Questions
- 2001 DX coup speaker sizes?
- need help from dx/lx owners
- HELP! what are specs for 01-05 EX?!?!? =(
- Squeaking/Clanky sound from front right passenger side area
- Funny Prius hybrid animation
- 2002 Civic EX Radio help
- Finally broke my 1,000mile tank summer goal!
- problem installing head unit on my civic 01
- Help! Speed Gauge suddenly stopped working
- Vibration in driver side door (bass induced)
- more horsepower
- vibration 2003 Civic LX
- 2001 DX has no tachometer
- 2004 honda civic ecu replacement???
- Bottom 13's
- 2001 Civic EX - rear speaker removal, help
- Tach stopped working suddenly
- 02 Civic Ex Wont start!!
- SRS light-- does it disable the air bags?
- 02' driver side door lock
- help - 01 Civic driver seat rocks up n down
- 05 limited edition stereo, how to put in a sub
- ????Throttle body boring & porting by Maxbore.com????
- anyone ever install battery isolator?
- 03' Coupe Headlight Bulb
- DRL light flashing and clicking
- 01 civic ex big problem
- 03 EX 4dr, need short ram intake, any suggestions? PLEASE!
- Vtec?
- Honda Civic EX Traction Control
- 2003 civic hybrid speakers front and back
- Wheel Stud Removal for '01 Civic
- 02 EX Coupe - What are the trunk dimensions ?
- 2002 Civic cluster problems...
- 2002 civic A/C making some funny noises...
- 02 Civic - What are the sizes of the speakers ?
- TPS low voltage (code p0122)
- Getting wheels, what next?
- My 02 clicks, but from somewhere else
- Grinding noise from the timing belt
- 04 ex and 04 si turbo kits
- Flushing 5spd tranny
- 04 civic problem
- Ok lets just say
- Thinking of buying an '03 Civic EX...
- 04 ex cam install ?
- HP in Civic '02 Si
- 2001 civic exhaust
- Windshield washer fluid light is on
- Cam gears ,, can someone help?
- someone please tell me the only real problem with 01 civics is tha f#$king ecu it has
- O1 civic D17 1.7
- 02 Civic EX Radio Removal...
- 2002 Civic Si, Veloz
- Stereo Codes
- Premium Fuel in the 06' SI????
- Lia Honda - Ripoff
- 2001 civic headlamp buzzer
- How to save fuel these days
- 2.4L swap into '03 sedan
- 2006 Civic si Availability?
- Help ASAP timing belt snapped
- stressin
- Engine Light...
- 02 Civic Headlight trouble
- ecu flash?
- Euro 2.2l diesel
- Service light blinking
- What do ya'll thank ?
- FOR SALE 2006 CIVIC EX Coupe
- 2006 Civic Have I been lied too?
- I have a Question about shocks 03 civic?
- Need Help!!!!!!! civic wont go over 80
- shop wants $116 to replace and "flush" Automatic tranny
- hey anyone know will a d16z6 transmission fit into a d17a2 vtec-e motor
- 2008 Civic Convertible
- 2001 civic Exhaust
- Is the 7th gen D still a D at heart?
- What are some good engines that will fit in a 05 Civic
- HELP 2001 civic tail lights!!
- 05 Civic LX Help
- 05 Civic LX Sedan Engine/Tranny Swap
- 2002-2004 Civic body parts swap
- Serious problems with 06 Civic
- Need VSS wire!
- What does everyone think about the digital dash on the new Civic?
- 2001 honda civic power door lock issue
- civic block
- 1999 - 2000 - 2001 Honda Civic
- 03 Civic Pedal Pads
- 2005 Honda Civic EX Moldy Smell
- Help Anyone..
- OMG! Civic Si SEDAN?!
- 02 civic EX transmission help
- d17
- 01+ Civic "Manufacturer" Steering DEFECT
- 2001 honda civic HL
- What do you think?
- MIL codes
- honest advice on honda
- Tach iin 2002 civic
- 02 civic strut bearing on 01
- Where to Run Tach Wire
- Setting Time on Clock
- weird cat problem 02 dx
- Installing a tach in 2002 civic
- maintence light won't go away
- power door lock conversion
- Check this out.
- ?'s about new Civic Si
- gear shifting problem
- K24 in 7th Gen?
- 05 Civic Water Leak
- 2005 Civic Speedo not working.
- 2001 si engine swap and sir time
- 01 civic swap and sir time
- quater mile time
- HELP:problems with SRS, check engine and battery lights!
- 01 civic Halo Projector
- Instrument panel lights are out 01 civic
- 01 civic rear speaker
- check engine light / feels like its going to stall
- the 06 si
- overheating
- Any one selling parts for Civic
- help doing car up right
- Stereo Installation Help
- carbon fiber mirrors
- 01 civic rev limit increase
- Maintenance Indicator
- 2001 mustang gt vs 2004 civic ex turbo
- Piston Rings for 01 civic
- dash board
- Boring the cylinders
- ??? In Your Opinion What Is The Most Affordable Racing Car ???
- Any suggestions on how to buy a 2006 Civic EX Sedan?
- Cv Shaft and transmission
- 02 Si keyless entry problems
- hey need help on tune up wit my 06 Civic EX
- stupid but fun...racing in an economy car
- Changing Oil to a synthetic in 2006 Civic
- tricking the air sensor
- window frame
- Rallye Red 06 Civic
- Alarm System in Civic SI '05
- Method of buying Japanese cars and parts cheap!
- Honda Hybrid
- Si Sedan...
- 2002 Honda Civic Hybrid
- 2001 civic dx
- 2006 civic recall
- 06 civic si turbo'd question
- lowering
- 10K scheduled maintenance at dealers
- SI seats for sale
- Civic HX owners!!!
- D17A1-A2 Engine Dimensions?
- now what can i do with this baby?
- 2006 civic lx coupe price
- 03 civic si CEL
- new si civic vs 04 str-4
- 2003 Honda Civic Making Clicking Noise
- Exhaust 01 Civic
- 2006 Civic EX.....still a tuner?
- Honda TURBOZ!!!!1!!
- 2006 civic engine compression ratio...
- Air Filter on 2002 Civic
- AEM EMS engine management system
- 2001 Civic headlight install
- dealership maintenance, worth it???
- 01 CIVIC remove catalytic converter
- Need Buying Advice from A Dealer Associate 2006 Civic EX Sedan.
- Best Exhaust for Civic SI
- 05 Civic VP cruise control?
- 02 Civic Tire/Rim Noise?
- 01 civic trouble
- auto mileage
- 2006 SI Stats mistake?
- 01 going non v-tech
- Modding the EX civic: Fact or Fiction?
- Look what i saw today! (56k maybe)
- 04-05 conversion on 01-03
- what engine?
- Blown head gasket - warranty?
- 01 Civic rear brakes
- Help Help with SRS light
- '02 Civic EX engine (?) acceleration/deceleration problem
- '06 Civic Si
- More hp for my 01.
- sponsorship
- need new motor 02 coupe
- 03 hybrid transmission problem
- Burning Smell
- I think I have a break problem
- "2001" civic horspower?
- Is dome light wire 12v ?
- NEED 2003 Honda Civic driver side mirror
- FYI 04-05 Civic lip
- 02 Civic Clicking
- Body Shop near Boulder, CO for Civic
- DFL Warning Light
- 2006 Civic instrument cluster
- 2006 Civic Si Pics
- Dome Light Help
- Which Exhaust??
