Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '96-'00 Civic |
View Full Version :
'96-'00 Civic
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
d16y8 swap to jdm d15b vtec ?s
Plasitc Runner on bottom of civic
99 DX header + test pipe
Best ideas to make power out of a D16 (turbo,NA,supercharger)
HELP!! Stripped bolt on fuel filter
'97 Civic project
99 LX is lowered - need instructions on how to raise it back to stock height
Emergency HELP HELP
Rice Rocket Potential?
Engine Ac problem
97 dx y7 to y8 swap
98 civic axle, balljoints, rotors
99 civic dx starts then stalls, keeps running only if i give gas
OBD2 conector on a 97 lx 4 door
Another N/A D16y8 Build. My 1st thou......
engine crank but won't start
wiper problem
99 civic lx cracked exhaust manifold by O2 sensor
Swap B16A1 INTO 1997 Civic Coupe
Honda civic parts swap
Civic drivers side power window issue
Owner's Manual
99 civic w/ slipping problems. related to intake?
SRS Reset instructions
96 civic ex with NOS???
should i tade 99 sierra for 97 civix hx mod
Advise on "Restoring" 2000 Civic EX SDN
auto trans?
blinking drive light
removal replacement of rusted alternator pivot bolt -1998 civic 1.6 cx
2000 Civic power door lock won't unlock.
Megan Racing Springs
98 civic coupe
Help with my 96 Hatch!
How to take out a rear side window from a 96 honda civic
99engine codes do i need 16 pin reader
1998 1.6 EL question
'00 Civic EX using oil
Engine Overheating Mystery
Motor Swap Help
trans fluid
'99 Honda Civic LX Stalls
'96 Check engine light no no power to code reader
98 Civci - Upper "ball Joint" problem
97 Civic chattering noise
honda civic 1999 miles
Trunk leaking....
98 Civic Engine Misfiring
Honda civic engine experts!!!!!!!! Must see!!
California Smog legal Header with Cat ?
99 civic lx power locks stoped working
vibration after cv replacement
Ipod connection in 98 civic without losing cd changer
Whats up I have a question about piston slap
2000 Civic DX-I need help interpretting OBD-2 code
Civic d15/16 head swaps
96 civic shaking on accel.
GSR headers on a jdm b16a?
What kind of car is a jdm b16a out of?
Need Help With Wiring of Side Mirror!!!!
96 Civic HX o2 Sensor Replacement....
98 cx speedo woes
Crack in the Catalytic Conconverter shield?
looking for a good drag car
99 LX accelerator mounting bracket(loose) moving all over even though nut is tight
help with my 96 civic
garrett turbo
Swap Interference Questions
Squeaking Wheel
98 Civic LX Squeaking
Engine noises
Need help diagnosising P1457 - EVAP (Canister area)
Just Bought a 97 Civic CX...base model
97 Civic idle surges
What's that noise?
1997 Honda Civic EX Overheating?????
changing front axles
help vtec stopped working
Lowering my Civic
98 LX Belt Replacement
Blower resistor problem
1998 1.6 EL bad ecu
Thumping sound when coasting
Header On Lx. What To Do With O2s?
98 Civic brakes shaking badly
gas mileage for 97HX
largest tire on stock 14" rim
1999 civic interior water issue
1996 Civic Vtec engine Squeal
96 tranny grinds in reverse
headlight switch help
need help with my D16A intake
parts
Wrecked
Need Help PLZ with my b16a2
wire diagram
96 civic sunroof keeps opening by itself
o2 sensor
2000 civic si
4th cylinder won't start.
Idle Seems To Rich
Idle Seems To Rich
Idle Seems To Rich
98 won't start
99 civic idle goes up and down
Jackson Racing Super Charger... Thoughts?
Help with blower motor?
transmission swap question
96 civic
Help Please
Wierd noise coming from my exhaust i think...
whats the best way to boost a b16a
1996 Civic Engine Info
98 CRV Just Quit
99 Civic Code p1457- Control Canister?
97 Civic AC Condensor Fan Fuse Blowing
swaping ecu's any problems?
wiring for cruise control
manual or automatic transmission
Oil Pan gasket, bolts
car shakes when break over 40 MPH, Any ideas???
96 Civic DX 2DR Bosal Stock Exhaust
HX Help
help idle problem 99' si
98 hx header
97 Civic DX A/C Stopped Working After a Clunk
Syn Oil???
engine spewing coolant
Where to buy a brake caliper?
Weird noise during tighter turns
Civic 2000 LX: Manual vs. Automatic (fuel efficiency)
d16y5 swap for b series
98 hx civic engine swaps
1997 Civic Intermittent A/C
99 civic paint is peeling on roof
2000 Civic sohc engine noise
99 Honda Civic EX coil spring problems
99 Honda Civic EX windows rolling up/down problems
Need help getting faceplate off
I need to settle a argument
wet trunk
Civic Ex overheating HELP! 140K
Civic Ex overheating 140K
Shifter problems 99 Si
Sloppy Shifter feel
96 civic not running as good as usual
what motors wil bolt right up
honda civic sir ????????
1997 Civic been sitting 2 years
Aftermarket or dealer
Engine popping when accelerating
A/C Problems
Can't get ignition advance set correctly
Crank no start
Recall?
96 Civic Coupe, outer door handle removal, HELP ASAP!!
A/C Compressor Belt Change
what to do to my civic
its spring again time for new pics of the car
Sunroof won't close
Questions on my 98 civic ex
civic si muffler
now we've changed the wires too...
after replacement of distributer car wont start
Body parts
96 Civic Transmission Issue
looking for 98 ex coupe specs
engine poor acceleration help!!!
Location of Vtec Solenoid Valve/oil pressure switch on 98 civic
Aftermarket car alarm problems?
Expansion Valve location? '97 Civic
98 Civic Alternator Step by Step
bent valves on a 97 honda civic lx........Help
99 civic cx
Intermittent misfires on cold start/acceleration only
valve timing on 96 civic...
need hepl!
ls vtec?
speedometer stuck
V-tecTrouble Code P1259 But no V-tec engine!
Car not starting
99 civic si window is stuck please help!!!
halo install help on 96 civic
1998 Civic LX Transmission has started to slip
Wanting to build honda motor
camber kits
98 Civic wont start/no power at all
98 Civic DX antenna replacement problems
Honda HX with EX tranny?
Car shaking on highway
Help My car won't start!!!
200 cx front plate screw
98 ex starting problems
1997 Honda Civic DX Problems.
Help Installing Type R Lips front and rear
what did you pay for your timing belt change?
Radiator problem
99 Civic intermittently runs rough
99 civic cat converter operating below threshold
Problem getting rear seat (passenger side) to fold down
Civic DX 98
Rear door lock problem
Gas Gauge adjustment
9.3mm spark plug wires
Buying a 98 Civic Ex
Your opinion?
99 EM1 rear brake pads
need help diagnosing codes on my honda
Honda Civic 99
98 civic rough idle/ check engine light
Honda Civic
purchasing a salvaged honda civic 98 ex?(PICS)
'99 EX (D16Y8) burning oil?
Motor oil Vs Transmission Fluid Question
vtech valve and speed sensor ?
lights surging
07 SI seats
air bags
honda civic air bag help
Swap Information Help please......
window regulator/motor
99' Civic Transmission swap questions
Swap questions EK series (Y7 to B16A2)
HELP!!!! 97 honda civic
exhaust question
11" slotted rotors with 4x100 bolt pattern.
automatic
1/4 mile stats
99 Civic DX fuse panel diagram
help!!!! turbo auto civic??
lca's
help with possible buy
96 EX civic heat control problems....
Dangerous or no effect?
Code- P0420
antenna
suspension
aghh someone help me!!
Replacing Antenna
HELP: Clutch pedal on EK
2000 honda civic AC compressor
exhaust research
98 Civic SI wipers won't stop
B16a2 (automatic) swap help!!
Web
AF
