View Full Version : '96-'00 Civic
Pages :
[ 1]
2 3 4 5 6 7 8 9
- What is this?
- Advice on Selling 1999 LX for Parts
- size conversion
- Rack and Pinion Boots
- Starting system
- Not starting or turning over
- A/C doesn't work on low
- Need help identifying a part under my hood! please help!
- Need help to decide
- Starting help
- where has everyone gone?
- 97 civic hx cvt
- 98 Honda Civic window problem
- swap 96 accord vtec into 96 civic ex?
- Honda Civic-NEED HELP
- 96 Honda Civic power window problem
- 99 Civic LX Need Valve Train Help
- bad coil tested ok with ohmmeter
- EK3 98 No ABS , Break problem
- 98 Civic DX Testing Speedometer and VSS
- '96 Honda Civic VSS indentification
- 99 Honda Civic door actuator question
- 99 Civic Idle Air Control System
- 99 Civic LX check engine lite came on - engine is missing
- Torque Converter unlocked when cold.
- Overheating civic ex
- 1996 Civic ex 5 speed
- 96 civic no spark, no start
- 98 Civic hard to shift into reverse/ drive
- 96 Civic A4RA vs B4RA??
- Another Speedo issue.
- slippin trans, drive in 2nd then shift? good or bad
- clutch acting up
- 99 Civic- check engine light on - OBD 2 code > PO420 "Catalyst efficiency below threshold bank 1 question
- Need help please
- 1997 Civic Starter Install Assistance Needed!
- 99 Honda Civic DX stalls in hot weather - why?
- Power Windows don't work
- Air Condition Clutch won't engage properly
- 1st gear poor acceleration
- 97 EX "enrichment system" issue?
- 1997 Honda Civic Ex Fuel Guage Erratic acting
- re instaling 1998 honda civic engine
- Cooling problem
- Timing belt replacement
- D16Y8 replacement YouTube vid
- Sometimes I'm smart... others I'm not
- 1999 Honda Civic EX starting issues please help!
- 97 Civic heat shield rattling on exhaust
- HELP!!!! my civic is dying!!
- 1999 Honda Civic Help!
- Weird thing that happened
- can u convert a 96-98 lx sedan civic into a 99-00 lx sedan?
- 1999 honda civic
- speedometer issues
- Help!!! Hx swap going wrong!!!
- Civic 201000 miles runs perfect.. need advice
- 97 civic motor swap
- 99 honda civic erratic idle
- 1999 Honda Civic Will Not Start/Turn over.
- What years/models of the Honda Civics have VTEC?
- Jeep cherokee or honda civic si?
- honda tires allignment
- 96 Honda DX Idol/Gas Panel Problems
- Swapping engine ek1 civic
- replaced master cylinder... more issues
- H22a help
- Just got an oil change, now need new O2 sensor?!
- '99 Civic A/C troubleshoot
- Please Help! Camber Kit???
- rebulid 1997 ex motor
- parking brake vs. car in park...help!
- civic project
- potential transmission problem?
- Oil Issues
- window issues
- '00 civic codes p1399 and p0172
- stuck on my built
- Engine will not turn over or start...
- Bad alignment
- Whats with my oil?
- 97 civic hx hessitates on accel please help =(
- 99 Civic Dx Overheating!! HELP
- Car wont start
- Can anyone identify these rims????
- Wtb 97 civic parts
- Car has poor acceleration
- Which engine????
- speedometer reading jumping
- Oil Loss. No Smoke. No Leak?
- Inner Rim Grind
- Fitting seats?
- loss of power, no speedomiter, d4 blink?
- !999 Civic trans fluid
- Need p2e ecu pinout diagram please help
- EX Running Rich
- 2000 honda coup died twice on the road tonight
- New Thermostat & Engine OH???
- hmm caught me as kinda odd
- VIN report
- VTEC Soleniod Valve
- Need help with tires! Help a girl out!
- O2 & Knock Sensor Issues
- Transmission Filter on 99 civic
- Problems with my Civic Si 96
- Civic loses all electrical power-comes back later
- 98 Civic died while driving then started 10 min later
- MIL code 1336
- 2000 civic intake switch
- 96'4 dr rad support on 00' coupe
- 1990 Transmission swap
- 96 Civic d15 jdm
- Civic runs poor at times
- Iacv
- 00 civic lx surging idle
- transmission slipping
- 97 Civic LX - Transmision Turbine Replacement
- d16y8 swap to jdm d15b vtec ?s
- Plasitc Runner on bottom of civic
- 99 DX header + test pipe
- Best ideas to make power out of a D16 (turbo,NA,supercharger)
- HELP!! Stripped bolt on fuel filter
- '97 Civic project
- 99 LX is lowered - need instructions on how to raise it back to stock height
- Emergency HELP HELP
- Rice Rocket Potential?
- Engine Ac problem
- 97 dx y7 to y8 swap
- 98 civic axle, balljoints, rotors
- 99 civic dx starts then stalls, keeps running only if i give gas
- OBD2 conector on a 97 lx 4 door
- Another N/A D16y8 Build. My 1st thou......
- engine crank but won't start
- wiper problem
- 99 civic lx cracked exhaust manifold by O2 sensor
- Swap B16A1 INTO 1997 Civic Coupe
- Honda civic parts swap
- Civic drivers side power window issue
- Owner's Manual
- 99 civic w/ slipping problems. related to intake?
- SRS Reset instructions
- 96 civic ex with NOS???
- should i tade 99 sierra for 97 civix hx mod
- Advise on "Restoring" 2000 Civic EX SDN
- auto trans?
- blinking drive light
- removal replacement of rusted alternator pivot bolt -1998 civic 1.6 cx
- 2000 Civic power door lock won't unlock.
- Megan Racing Springs
- 98 civic coupe
- Help with my 96 Hatch!
- How to take out a rear side window from a 96 honda civic
- 99engine codes do i need 16 pin reader
- 1998 1.6 EL question
- '00 Civic EX using oil
- Engine Overheating Mystery
- Motor Swap Help
- trans fluid
- '99 Honda Civic LX Stalls
- '96 Check engine light no no power to code reader
- 98 Civci - Upper "ball Joint" problem
- 97 Civic chattering noise
- honda civic 1999 miles
- Trunk leaking....
- 98 Civic Engine Misfiring
- Honda civic engine experts!!!!!!!! Must see!!
- California Smog legal Header with Cat ?
- 99 civic lx power locks stoped working
- vibration after cv replacement
- Ipod connection in 98 civic without losing cd changer
- Whats up I have a question about piston slap
- 2000 Civic DX-I need help interpretting OBD-2 code
- Civic d15/16 head swaps
- 96 civic shaking on accel.
- GSR headers on a jdm b16a?
- What kind of car is a jdm b16a out of?
- Need Help With Wiring of Side Mirror!!!!
- 96 Civic HX o2 Sensor Replacement....
- 98 cx speedo woes
- Crack in the Catalytic Conconverter shield?
- looking for a good drag car
- 99 LX accelerator mounting bracket(loose) moving all over even though nut is tight
- help with my 96 civic
- garrett turbo
- Swap Interference Questions
- Squeaking Wheel
- 98 Civic LX Squeaking
- Engine noises
- Need help diagnosising P1457 - EVAP (Canister area)
- Just Bought a 97 Civic CX...base model
- 97 Civic idle surges
- What's that noise?
- 1997 Honda Civic EX Overheating?????
- changing front axles
- help vtec stopped working
- Lowering my Civic
- 98 LX Belt Replacement
- Blower resistor problem
- 1998 1.6 EL bad ecu
- Thumping sound when coasting
- Header On Lx. What To Do With O2s?
- 98 Civic brakes shaking badly
- gas mileage for 97HX
- largest tire on stock 14" rim
- 1999 civic interior water issue
- 1996 Civic Vtec engine Squeal
- 96 tranny grinds in reverse
- headlight switch help
- need help with my D16A intake
- parts
- Wrecked
- Need Help PLZ with my b16a2
- wire diagram
- 96 civic sunroof keeps opening by itself
- o2 sensor
- 2000 civic si
- 4th cylinder won't start.
- Idle Seems To Rich
- 98 won't start
- 99 civic idle goes up and down
- Jackson Racing Super Charger... Thoughts?
- Help with blower motor?
- transmission swap question
- 96 civic
- Help Please
- Wierd noise coming from my exhaust i think...
- whats the best way to boost a b16a
- 1996 Civic Engine Info
- 98 CRV Just Quit
- 99 Civic Code p1457- Control Canister?
- 97 Civic AC Condensor Fan Fuse Blowing
- swaping ecu's any problems?
- wiring for cruise control
- manual or automatic transmission
- Oil Pan gasket, bolts
- car shakes when break over 40 MPH, Any ideas???
- 96 Civic DX 2DR Bosal Stock Exhaust
- HX Help
- help idle problem 99' si
- 98 hx header
- 97 Civic DX A/C Stopped Working After a Clunk
- Syn Oil???
- engine spewing coolant
Automotive Network, Inc., Copyright ©2021
