View Full Version : '96-'00 Civic
Pages : 1 2 3 4 5 6 [7] 8 9
  1. Spraypaint question
  2. 96 civic power windows quit working
  3. rpms bounce from 1k to 2k constant
  4. Just bought '00 EX Coupe...Suggestions?
  5. a/c controls
  6. Window tinting
  7. Brands
  8. gas octane question
  9. 2000 Honda Civic Si Beats 450hp Viper Video
  10. civic hx fuel mileage
  11. Ac bracket
  12. Wheels?
  13. cant decide on exhaust
  14. regardin civics and power window's..
  15. gauges? is it really that simple PLuG n PlaY? let me know...
  16. 98 civic lx worth it?
  17. Vertical Doors Inc Vs. "Immitators"
  18. !HELP! water in my engine
  19. suggestions for my 97 civic
  20. 45k Engine coolent & brake fluid change
  21. factory chips?
  22. LAMBO DOOR advice? who to get them from?
  23. 98 LX Swap Sugestions please
  24. Vafc
  25. replaced my d16y8 wont start up?
  26. Good Body Shops?????
  27. 97 ex brakelight/horn fuse keeps blowing
  28. 2000 Honda Civic SOHC to DOHC swap
  29. 1998 civic
  30. 96 Civic Headlight removal question
  31. Bov Problem ....help!!!!!!!!!!!!
  32. Emergency
  33. 98 Civic EX D16Y8 replacement
  34. 96 civic Vtec Indicator Light
  35. Who knows there Side mirrors???
  36. your opinion on my dx
  37. distributor cap 99 civic lx
  38. 99 Civic FCC Id Number
  39. Grinding Noise in 97 HONDA Civic
  40. Automatic Transmission Shifts Hard
  41. 98 civic timing question
  42. replacing shocks/struts
  43. spark plug gapping
  44. shaky steering while breaking
  45. CEL light, system too rich, hesitation, and awful gas mileage
  46. motor is blown!
  47. B-series turbo
  48. Greddy Evo not sounding right...
  49. 00 Civic exhaust help!
  50. Engine Rebuild!!!
  51. automatic transmission problem
  52. 02 problem
  53. so what's it all for?
  54. regarding mileage on gauge clusters...
  55. 100% New!!!
  56. d16y7 ecu help!
  57. Best turbo kit
  58. Headers for civic question
  59. 96 civic turbo. help out please:)
  60. 96 turbo? help me out please.
  61. Prevent a blown head gasket
  62. y7 headers
  63. Help with b16a
  64. !!! Need Help !!!
  65. 00 Civic EX/ Exhaust help
  66. what is the best turbo?
  67. Question Regarding Headlights
  68. Anyone thats knows about swaps in sOcal come. Help
  69. CYP Sensor
  70. buying a 96 civic?
  71. 96 Honda Civc DX start porblem.
  72. getting pistons next
  73. I Need Help Here!!! Does Anyone Know This!!!
  74. just got new head...opinions
  75. radiator replacement
  76. (% civix EX coupe squeaking noise
  77. CKP sensor???
  78. Monster Electrical Issues...continued pt.II
  79. installing projection headlights?
  80. Keyless entry with Flashing lights
  81. jet vforce control module
  82. o2 sensor problem
  83. Stripped Distributor Rotor screw
  84. noisy valves
  85. 98 honda civic wiper motor
  86. A/C Pulley Growl TSB?
  87. lets be real (swap)
  88. brakes whine while slowing down from reverse
  89. cluster Q?
  90. top speed
  91. thermal R&D?
  92. Wiring up Vtec... help me out a little
  93. RPM gauge for civic hatchback DX please help!!!!
  94. 00 Civic EX / Exhaust help!
  95. Exhaust help
  96. Swapping a 95 civic si head into a 97 honda civic non vtec help please!!!!!
  97. 98ex/00dx head switch
  98. zex cams and flywheel
  99. blinker problems
  100. swapping heads
  101. head pins
  102. Civic Hood Dampers Struts Shocks
  103. 99 SI AEM V2 Problems/Complaints
  104. EG, EK, EL What's It Mean!?!?!
  105. Evap system code P1457
  106. 1997 Civic EX oil pan
  107. Resistors for LED rings
  108. 96 Civic HELP PLEASE!!!!!!!!!!
  109. Another newbie thread
  110. suspention problems help me please
  111. where to go from here?
  112. engine management
  113. Does my 97 lx have keyless entry?
  114. 99 Si Help
  115. 97 hx intercooler piping
  116. Leaky hatch
  117. what do i need for a five lug conversion on a 200 civic si
  118. any one know where to buy FULL replacement clusters?...
  119. h22a in 98 civic
  120. 98 civic door panel help
  121. 99 Honda Civic Oil Leak
  122. Engine Stall
  123. Starter problem?
  124. cost of oil pan replacement on 98 civic?
  125. does anyone know why?
  126. How hard to replace window regulator?
  127. '98 HX w/ cracked exhaust header
  128. pulleys/exhaust/CAI
  129. Loud noise coming from motor when turned on
  130. Headlight Blub replacement 96 Civic?
  131. 98 civic trim question
  132. i am lost ,confused
  133. regarding a new gauge cluster...
  134. CC/header questions..
  135. knocking/thumping noise
  136. security / keyless entry problem
  137. Greddy exh. vs. Apexi exh.
  138. Cyl' Head Temp' Sender into D16 ?
  139. Noob question about stock bumbers
  140. CD Player installation
  141. will 4th gen shocks and springs fit a 6th gen
  142. vtec or not
  143. 2000 acura 1.6 power lock motor
  144. After-market AC install in Civic?
  145. help 1st piston is out
  146. Poor mans scan tool
  147. clutch
  148. Clutch install
  149. speakers
  150. many NooB questions, please help....
  151. Ring compressor
  152. 00 civic pic's
  153. After gauge install...
  154. how would i piece together a turbo kit
  155. just got a 98 civic
  156. Poor acceleration/hesitation HELP PLEASE
  157. Gotta Go Jdm Big Diff. Ecu Help?
  158. Heat/Defrost '96 Civic EX
  159. Header/cat
  160. SRS light on.
  161. help on engine swap
  162. Sponsorships
  163. Car will turn over, but no fuel help!
  164. Drive conversions...
  165. Cheap horsepower...
  166. ecu tuning?
  167. !!! WTF is "V-Tec 20"
  168. Which Exhaust?
  169. Question about engine wear, shifting, and the throttle body
  170. I have a 00 civic dx hlp cnt find!!!!
  171. Fuel Consumption in Civic RTi
  172. B20 in a 99 Civic DX
  173. B18c1 In Cixic Lx
  174. EXACT specs required
  175. trans. shuddering
  176. correct tire profile
  177. she got some balls or what?
  178. Washer Fuild Light???
  179. switching teams
  180. converting my d16
  181. LBS. of torque?
  182. shift improver for honda
  183. what do you think
  184. Gas help
  185. what to do with a b16a2
  186. Yellowing euro taillights???HELP!!
  187. help!!!!!!
  188. How to change Fuel Filter
  189. license plate led
  190. Hood release cable
  191. i have read nonsense before
  192. 98 ex still having idle problems
  193. Air Conditioning Problems w/ 00 Civic
  194. 97 ex with sohc v-tech zc won't run
  195. Ex Trasmission on Civic Dx
  196. 99-00 SI Brake Question
  197. Slight knocking sound for first few minutes driving
  198. Tailight Modification Question
  199. Climate control/radio bezel electrical
  200. my clutch problem
  201. vibrations...mounts?
  202. Stupid Questions...
  203. b16a2 how much boost?
  204. 99 civic accel. problems...
  205. JDM motor in my 97
  206. Intake manifold for d16y7
  207. 99 civic rear discs
  208. 99 civic lx header..
  209. 98 civic ex vs 97 accord ex
  210. Pulleys
  211. 99 civic ?
  212. Guess what?
  213. crazy idle problem
  214. 6th Gen Photos
  215. moderators... can i ask a favor?
  216. Got an extra $1750?? Acura RSX anyone?
  217. Front Speakers wire color
  218. Which engine?
  219. magnaflow vs apexi 1?
  220. Looking Good, but What to do now?? (lots of pics)
  221. Code P0135
  222. distrubitor
  223. Need some help with boost options.
  224. SRS Airbag Light on
  225. damage after throttle body cleaned?
  226. 98 EX stalling intermittently
  227. civic coupe and hatchback
  228. Oem
  229. Putting a Grant steering wheel on a 99
  230. another misfire detected?
  231. designing exhaust...muffler inlet size
  232. 2000 Civic SE noise when disengaging clutch
  233. engine knocking sound at cold start
  234. Heat
  235. 99 civic completly dead
  236. h22 help
  237. Quick question about honda performance?
  238. New CV boots...
  239. Question about throwout bearings...
  240. Check Engine light after header swap...
  241. 98 Honda Civic HX - check engine light
  242. Auto to Manual Swap: Cost, Parts needed
  243. What is an EK, EK3 , EG etc.....
  244. RPM drop badly when aircon is on
  245. b16 alt.
  246. fender wheel molding...
  247. window won't go up all the way
  248. what mods should i do . just got 99civic
  249. Looking for some 00 Civic Floormats
  250. CAT Question....
