View Full Version : '96-'00 Civic
Pages : 1 2 3 4 5 [6] 7 8 9
  1. Questions about 97 honda HX
  2. 99-00 civic parts
  3. How to remove airbag to install aftermarket wheel
  4. 1998 Civic SiR with B16a engine ***HELP!!**
  5. how do you know if you need new rotors?
  6. Doors will not lock or open!!!!!!!!!!!
  7. My e-brake doesn't work (ok to remove completely???)
  8. Need Help Plz
  9. Messed up parking brake
  10. vtec malfunction question
  11. a car that run 12's??????????
  12. DOHC Engine Swap
  13. will 99 hood fit my 97
  14. p0131 code
  15. Sounds like a Turbo, But NO TURBO!
  16. Need A/C help...
  17. Speed Chip?
  18. slow acceleration
  19. general maintenance + manual
  20. Belt Replacment on 00 LX
  21. Buying a Steering Wheel?
  22. Models of Honda Civics
  23. Rate Your Exhaust
  24. any 1 herd the dragger muffler
  25. d16y7 compression
  26. Thinking of buying a Civic . . .
  27. k24 motor in a 1997 civic
  28. Engine Swap
  29. intake
  30. Help Me Plz!!!!!
  31. Selecting park
  32. Head Gasket Horror! I Need Help
  33. 99 civic power windows..help
  34. exhaust questions
  35. ECU for VTEC
  36. water & spark plugs, NOT GOOD MATCH; HELP!
  37. head lights
  38. Tach problem need help
  39. Civic 98 Alternator Replacment Walk Through
  40. No spark
  41. Keyless entry / Alarm - 98 Civic
  42. flowmaster exhaust ?
  43. Buying 96 H/B
  44. O2 sensors
  45. Squeaky Clutch
  46. guage cluster
  47. trans fluid leaking in clutch
  48. weird noise please help
  49. OEM vs aftermarket front bumper
  50. Almost stolen 99, now needs ignition. HELP.
  51. is the d15b a direct replacement for a 1997 civic dx
  52. N/A setup
  53. alternator drive belt help
  54. Tough decision, need lots of help here on purchase
  55. ecu or distributor
  56. 98 dx cat-back exhaust
  57. OEM keyless remote entry for 96 EX
  58. ? about the engine for a 1997 civic dx.read
  59. Catback vs. Axleback
  60. Exhaust for 4dr?
  61. compression ratio
  62. N/A or turbo
  63. Websites not to order parts from...
  64. car specs
  65. Knock sensor question
  66. whats the best sounding exhaust for a 1997 civic dx
  67. whats the best intake for a 1997 civic dx
  68. Free Rear Strut Bar for 99-00 Civic Si Coupe
  69. cold engine problem
  70. difference between drag and full coilovers?
  71. No power steering on my '99 DX?
  72. 98 ex
  73. Si or EX?
  74. Clutch click
  75. engine swaped parts
  76. watch this hilarious vid
  77. getting a 96 civic
  78. sponsership pros and cons, and availible ones
  79. 97 lx best engine swap for the price
  80. just curiouse. what would i get for a trade in for a new civic if i traded in a 1997
  81. whats the best place to get a engine for a 1997 civic dx
  82. Is my 2000 civic ex a vtec
  83. b18b swap
  84. getting a 96-00 civic soon
  85. K20a2 AC & Powersteering
  86. cat????
  87. BAD Head problems plz hlp
  88. getting a motror swap
  89. Vtec Head Swap Question
  90. how to install a muffler?
  91. gaughe swap
  92. timing belt help!!
  93. 00 civic----burning oil in no.2 cyl
  94. locking tuner lugs
  95. Civic SI - please read
  96. D16 series valve covers
  97. Turbo vs Supercharger in a B18C5 Type R
  98. Door Panel
  99. clock reset
  100. Cutting off Catyliac Convertor
  101. how can i redline higher?
  102. 2 questions...
  103. Need Help, 98 DX Hatch Intake System
  104. headlight bulb size?
  105. what in the hell is VP???
  106. Electric Supercharger?????????????
  107. Spring installation
  108. Need Wire Diagram for 97 d16y7 alternator
  109. 97 Civic Turbo D16y5 ..fuel pressure help.
  110. How many inches of piping should i go?
  111. are these good rims?
  112. PCV Valve location 2000 Honda Civic EX
  113. Side skirt length?
  114. Clutch adjustment???????
  115. CIVIC SI vs. CAVI Z24?
  116. 99-00 A/C Kit on my 1997 DX Civic?
  117. 97 civic hx
  118. does this seem like a decent setup?
  119. Got a new hatch
  120. is a 97 civic dx a good car?
  121. 97 Civic HX Catalytic Convertor
  122. engine problem?!!
  123. radio code
  124. Need help with Trouble codes
  125. exhaust/catalytic converter
  126. help with 1999 civic ex motor swap
  127. Need help deciding new struts
  128. help need a 98 lx exhaust manifold will anything else work
  129. radiator help, please
  130. please tell me my wheel bearings arent gone
  131. shift knob
  132. d16y8 rebuild question
  133. P1259 vtec system malfunction
  134. Best plugs and wires?
  135. 1.5 auto...with mods = fast?
  136. power locks not working
  137. 96 EX Oil Pan and Exhaust
  138. Needa new clutch
  139. location of service connector for ignition timing
  140. Air conditioning
  141. bad gas mileage
  142. Voltage Stabilizer?
  143. 98 civic natural gas fuel injector problem
  144. Preparing To Boost 96 Ex
  145. suspension help PLEASE!!!!!!
  146. Please Help!
  147. removing rear seats
  148. Lambo door kit
  149. Fuel Filter - boy i feel really dumb
  150. head swap question
  151. Lights dim a bit when using interior window switches
  152. Few Questions
  153. Steering wheel play and noise
  154. LX Cluster
  155. Idle Problem
  156. Door stuck
  157. driver side halo question
  158. good deal??
  159. Adding a passenger side mirror.
  160. Leak
  161. Woot
  162. Civic Sites
  163. OMG indiglo's help
  164. top secret paint
  165. Rear Disc Brake Conversion
  166. Civic Console
  167. Eibach Spring problem HELP!!!!
  168. GSR rear disc, will the stock 13's clear em?
  169. Cabin Air Filter
  170. Si Rim Needed
  171. Help a novice out?
  172. Silver Civic
  173. Radio Removal
  174. 97 Civic HX - Bad Alternator
  175. power steering removel
  176. 97 Civic, Tachometer jumps up
  177. Struts & brake question
  178. Advice on buying a '96 Civic?
  179. how to disable daytime running lights.
  180. CIVIC CX Vibration @65mph and over
  181. remote start
  182. SCC issue hunt...
  183. $8000- what should i get??
  184. 00 Civic EX highflow cat
  185. 96-00 Civic Shaved Doors Help
  186. rear reinforcement bar
  187. Bought, 96 Civic with B16a2, Air coming from oil filler
  188. difference between EX and SI
  189. headlights wont turn on
  190. Feel really stupid...(e-brake handle install)
  191. D16Y6 into D16Y7 head swap. Help Please!!!
  192. D16Y6 into D16Y8 head swap. help please!!
  193. alarms
  194. front reinforcement bar
  195. 98 ex cold air intake
  196. d16y8 what yeartrans will bolt up
  197. 99 DX Turbo/Supercharger
  198. need your input on tires and new muffler?
  199. Engine cleaning
  200. B16a2 - Help
  201. '99 DX audio info needed
  202. Electrical Issue
  203. what is vtec?
  204. 99 civic speedo intermitant/stuck ??????
  205. Window Problems
  206. Idle problems just swapped
  207. cam gear adjustment
  208. hondata???
  209. axles for five lug conversion
  210. Catalytic converter question
  211. Used Wheels for 99 Civic Please
  212. What are my wheel options?
  213. I need to Program my 97 Civic Keyless Entry! help!
  214. f**king bimmers
  215. 1997 Civic MIL light on P0441
  216. quick question?
  217. insurance...
  218. buzzing sound at initial drive? Help..
  219. adjusting headlight level
  220. Suspension problem!!! HELP
  221. swap question
  222. Adding a Resonator
  223. Where is the CAT located?
  224. Droppin my civ...rear strut problems
  225. Drag Radials?
  226. Radio Help
  227. What manual do I need most?
  228. engine help needed
  229. my black 97 civic lx 4d plans (wheel help)
  230. Turbonator?
  231. Ticking noise
  232. when does vtec kick in?
  233. tail light removal help
  234. Civic Wide Body Kit Installation Mounting
  235. NEED HELP..1997 hond civic won't start.
  236. No power windows?!
  237. inatke manifold
  238. 97 Civic DX ECU mod
  239. muffler recomendation
  240. help me outttt
  241. RIP civic
  242. '98 civic ex project
  243. aem engine management system
  244. Civic PICS WITH 16" RIMS LOWERED PLEASE!!!
  245. H22a in 96 CX???
  246. 97 Civic acceleration feels lazy
  247. Axel joint??? rubber thing broke.....
  248. rims for 00 civic lx
  249. to all the gauge cluster SPECIALISTS!
  250. Tornado- Increased Gas Mileage???
