View Full Version : '96-'00 Civic
Pages :
1 2 3 4 [ 5]
6 7 8 9
- Car Fax!
- What do Civics feel like to drive? *Civic noob*
- Difference in doors?
- Civic 96
- installing a 93 civic engine on a 92 civic
- 96-98 2dr & 4dr fenders diff?
- LS, GSR, and Type R transmissions
- is this normal ?
- VTECH (also known as V-TEC)
- Replacing the Steering Wheel
- car wouldn't start this AM
- 97 Civic LX Radio Bezel
- B18B engine internals internet dealer?
- Removing 1996 Civic airbags...
- not like u
- is it hard to change a 5 speed transmission
- honda OEM parts
- Engine swap 97 honda civic for vtec
- civic hx
- difference between cx and dx?
- dead tranny
- Headlights
- 96 lx timing belt
- driver door lock?????
- civic lx exhaust manifold
- Honda Turboz
- EXTREMELY soft brakes
- Couple of questions about my civic.
- A few concerns...
- Fuel pump or???
- will 2000 rear bumper fit
- need exhaust gaskets
- engine question
- 96 Civic DX Engine Swap
- 96 civic ???2000 rear bumper???
- Factory spark plug Gap?
- can someone help me answer this........
- P0122 code Honda Civic 16Y5
- 99 Code P1362 & P1298?
- megan racing
- sohc non vtec just kicked in, yo.
- test pipe
- Best Swaybar for 98 Civic Ex
- Smooth ride?
- Looking for a d16y8 cylinder head mini me
- civic 98 radio bezel removal
- Rims For Sale
- cousins civic
- 96 Civic Camshaft Suggestions?
- Vtec
- D16y6
- Techno Racing Soundtrack
- 96 civic oem bumper lip??
- 96 Civic Dx Injectors?????
- 96 civic dx cam gear suggestions
- 96 CIVIC DX FUEL SYSTEM suggestions?
- CHECK engine light...p1337 Help.~
- HELP! Does this problem sound familiar?
- spark plugs
- Im building this car, please comment.
- Help! P0420 CODE
- engine light on
- 97 civic air bag removal - Help!
- Starter Issue
- exhaust/muffler?
- Awd Civic?
- What else should be replaced when doing timing belt
- Major Problems
- honda 96-98 engine #
- oh the mileage
- 97 Civic alarm or panic problem
- honda's
- CIVIC 97 - Air intake problem
- new
- will this work?
- caliper mounting bolt
- Ruined Head?
- rice vs. sleeper
- 2000 civic, new header new trouble codes
- Intake Troubles
- clutch pricing
- 97 civic dx stereo removal HELP!!!
- * Need Some Help Guys*
- 1996-2000 Civic's Any Chronic problems ?
- Accelerator Sticking
- obd2a/obd2b
- spoon sports EK9 pictures!
- CEL Code PO420
- Complete Manual Tranny for a Swap
- Cold Air...
- Auto to Manual Transmission Swap Photos?
- Vtec question...?
- 97' LX (four door) - Acceleration?
- 97 EX Guage Cluster Lens Cracked
- B18b
- 00 sunroof sunshade replacement???
- flywheel
- need help - crack in exhaust manifold
- Help! 96 Civic EX door panel removal
- manual tranny 96 civic
- How to replace fuel filter on 2000 Civic EX
- ha ha ha
- in dire need
- I finally got my SI...
- B16 Swap
- knocking noise...help!!
- 98' Civic HX transmission crapped out
- Radio Code
- 97 trim levels and specs?
- obd1 or obd2??
- 99 Civic D16Y8
- Cruise Control
- D18Y8 ignition timing.
- What do i do with it???
- Washer/wiper question
- intake cause low rpms
- lowering a civic
- replaceing starter 98 civic dx
- brake light problem
- megan racing lower control arms goood??
- some advice..please?
- 98 Civic wont start
- axle problems on my civic si
- Need advice/info on Air Bag control of Fuel Line
- Checkmate remote programing
- DTC P1298 at a roadblock..anyone help?
- catalytic converter
- 99 civic ex driver side glass fit my 96 civic hatch dx? does anyone know? help thanks
- starting civic cold
- intake and exhaust ?
- D16Y8 Intake manifold cost?
- MAJOR engine problem
- Hedlights wont turn on but ambers wont turn off??!!!!!!!!!!!!!!!!!!!!
- Exhaust Leak???
- help me out please
- brake knocking
- 99 civic engine
- how to remove radio from honda civic lx 2000
- 99 Civic Oil Loss
- A/C Pipe
- Looking for seat belts
- service connector for ignition timing
- Code 65.
- so do I need the heat shields on my 00 civic ex?
- Cold Start Engine knock/tick (NEW ENGINE THOUGH)
- 98 coupe(EX) build the D-motor & Turbo
- Help, cant find something.
- how to wire aftermarket headlights?
- 2000 civic ex questions
- Getting better gas mileage
- 96 semi-stock civic lost speedo,A/F light show,etc.
- 99 civic si
- dead battery possibly? your input needed..
- Looking for Advice !!!
- turbo kit for 92 to 00 civic
- I need inside door panels for 1997 honda Civic
- D16??
- Headlight Setup
- Timeing Belts
- Newbie looking for advice.....
- swamp problem
- universal O2 sensor
- 99 civic hesitates
- Throttle stuck...?
- 96 Civic EX Overheating
- engine swap for 98 civic coupe
- Fuel mileage?
- 98 Civic High Pitched transmission noise
- any ever dynoed stock b16a sir
- B18C1 hatch with problems...
- auto ignition switch in my 5 speed????
- f22b1 in a 97 civic ex
- faulty power door lock
- B18C GSR or B18C Type R
- Automatic door locks break fuse
- 98 hx problems, but whats new
- Suggestion on Early Mods
- whats really good?
- Idle question
- More Power
- 98 honda civic speedometer brocken
- worry about overheating
- Headers, Exhaust
- brakes
- Idle cintrol solenoid location
- Radiator support&Syncros
- CF diffuser?
- air intake questions
- 00 civic burns oil
- Car 'floats' at 60mph and above
- 5TH GEAR PROBLEM: VERY HIGH RPMs AT 65MPH
- 5th gear problem
- obd2b b18b into 00 civic hatch help!!
- Why are EX's so slow?
- looking for gearheads near akron ohio
- Fuel Specs
- 17's
- power windows!
- 1999 SI Question
- Code 67 Help!
- motor help????
- fer problems with my 96 civic
- Manifold too restricting?
- Driver Seat Mysterious Wire
- PCV Valve location 97 Civic LX Manual
- Tire width?
- turbocharging a fully built B20v
- Am I getting a Good Deal?
- 96 civic with a/c problems
- Main Pulley
- will 96 civic rims fit a 95 civic
- temp switch location
- Build your own turbo kit?
- Inhale and exhale
- Intake not sucking up air like it should?CEL error Fuel too rich
- Wheel weight?
- I cant get power to my left door panel speaker??????!!!!!!!
- How to install tweeters?????????!!!!!!!!!!!
- does a 98 civic hatch have abs
- 98 Keyless entry
- Help installing subwoofers!!!!!!!! to 1997 Civic
- 97 Civic DX Cpe - Need help!
- CIA bypass question
- 96 civic with no engine
- Hose came loose from AEM CAI and don't know where it goes...
- Cross Reference for AEM CAI filter
- 97lx TRUNK PROBLEMS...
- tires?
- Need Directions/instructions On Changing Timing Belt
- How do I adjust my e-brake?
- full AC install 98 Civic
- 1997 Honda Civic CX Hatchback Turbo Question
- h22 hatch owners
- '00 Civic Won't Start w/ key, only remote start.
- 97 CIVIC EX 1.6 L4 D16Y8 FI SOHC; VTEC Won't start
- 68mm Throttle Body/CAI
- is there detailed pics of bottom of civics online?
- What years can swap the engine with the 99 127hp?
- help changing spark plugs pleeze
- where is the air intake hose?
- Shift Light mod
- shocks and springs
- fog lights
- What body kit looks best on 96'-00' Civic?!
- quick question regarding the lift points on civics..
- Sony CDX-F5500 MP3 (Memory problem)
- got problems
- Oil Filter 4T22
- tires, what do you ride on?
