Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Honda
Civic
> '96-'00 Civic |
View Full Version :
'96-'00 Civic
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
98 civic window ?/ whats the cables
just 6 questions
K20A Type 'iS' Long Block Questions
cancel key code
cancel key code
2000 Honda Civic CX pcv location
What motor mount fits my ek??
Turbo EX D16Y8 Questions
Suspension noise
97 Civic Cx H/B help question
98 civic power window broken
a/c works sometimes
98 civic dies while driving
'00 Civic MAF Location?
civic drop time
tire problem
Need Swap Advice Now Help!!!
Check engine light on but NO CODES!
cx or dx hatch?
help please
Please Help
radiator question
doing a mini me this week or next.
help!
99' 5 spd Civic Ex Won't Start~Help Me
98 civic lx high idle
99 Honda Si IDLE PROBLEM PLEASE HELP!
Have fun with this one
2000 civic hx cvt
cracked exhaust manifold/bad o2 sensor
Transmission Question
lowering car...question?
header+cat+o2=emissions?
98 civic light brake pedal
00 Civic EX Rear Disc Conversion
98 honda...parts?
cold startup noise fix
Floating Si Emblem
Help a Chick
98 lx civ sputter take off
mini swap help
97 HX Dual Mufflers
the D on drive is flashing
ls/vtec internals
weight of a 96 hx?
whats the HP for this car ?
96 Hatch; Electrical Problem
is this reparable?
back seats
97 civic ex w/SI motor ecu ?
noise
1996 Civic 4dr LX
Well, I bought a Civic (was DX, EX, and HX gas mileage)
1996 Honda Civic
00 Si Turbo Set-Up Help Needed and More Newbie Questions
'00 Civic won't start...please help
help please
D16Y8 swap to ?
tried google sorry still need help
WTF is this noise??? Please help me if you know
headers for a 1998 honda civic cx
ticket
help with wiring a new o2 sensor
I need help!!! Any guys that know anything about Honda Civic's PLEASE READ THIS!!
More than one Speedometer or Tach.
Cold start engine 'tapping' FIXED!
1997 honda civic ex swap
!997 honda civic ex grinding in nuatral
Comparison - Injen Short Ram PLUS Extension
OEM Honda tweeter kit for 96 Civic LX
EK seat swap 4-door
Choking at stop on D
pulsing lights
Some major problems.
How do you Remove a Stock head Unit?
Mugen, Spoon
Serious, Very Serious, Let's Talk About Rice
Help with Light Configuration wiring
5th or 6th gen
Last exhaust '?'
Cleaning the Throttle Body
Can you go without Heat shield?????
Oil/Air Problem
redline for a 1998 honda civic cx
type r motor
How to get better gas mileage
just bought a civic cx
Valve adjustment
Head question
2000 Si Turbo Questions
Where do I add brake fluid to 98 Civic LX?
Rough @ idle and drop rpm
Si front end conversion
DX and HX gas mileage, and general gas mileage questions
Brake System
NewBie's Questions
5th gen d15z1/ 6th gen d16y8 head swap?
little knocking
Smoke is coming out of my AC vent???
Losing gas mileage
How much does it cost to paint rims black?
Remote start on a 1997 DX Hatchback manual
97 HX what i need to do....
Park brake indicator on acceleration
'97 Honda Civic EX .... A VTEC?
cost to raise my car?
97 HX need help please
Yucky oil
Auto to manual
Civic Single Belt Pulley
fuses under the hood?
grinding noise
96 and 2000 coupe doors
how do i tell if its obd1 or obd2?
Motor getting wet ???
unstableness at high speeds
A/C problem when outside temp is cold.
SUV-Civic side impact!
Does a Civic SI exhaust fit HX??
what problems am i going to have with my hx?
Are 4 doors slower than 2 doors?
Weird Cold Weather Headlight Problem
Auto Transimission problem
civic dx
Civic Question
75000 miles
Changing Spark plug wires/Rotor/Distributor Cap
97 Civic Wiring Diagram
brake fluid for '96 civic
2000 si b16
will it fit?
Catalytic Converter location
A Cvic
d16y8 turbo times
side moldings
short shifter
hatch/coupe parts interchangable?
Changing Brake pad
motor mount question on 1996 civic
auto to man tranny swap
Squeaking belts
Carsmetic!
Few Questions
Civic headers please help!
Humidity issues??? normal??
96 Civic Ex Smog Problem
brake-shift interlock
install factory radio
2000 Civic LX Tires
Difference?
Replace the radio bezel on 98 civic
drivebelt noise
2000 Civic LX - No Instrument Lights
braking issue
98 Civic Ex Keyless Remote/valet Prob.
jerking
97 civic needs helps
speedometer does not work!!!!!!
someone help me
what is this part called?
Alarm problem on 99 civic turns xmas present into dud...santa's helper needed
brakes
Dumb question
Power antenna?
Code P0420 (update)
Stock Clutch Life
97 civic dx
96 DX No Start & Crank pulley bolt torque??
engine swap problems?
b16b
97 ex question-Idling at stop(pushing clutch in)
97 civic dx coupe???
headlights...
Heater Not Working
spedo acting up
Strangest Problem I've come across
headers and intake
Question dat needs a ANSwer ASAP
What do u guys think about this???
Wont Start
lower compression
gauges
i need help installing a BOMZ Cold Air Intake for Honda Civic 00
axle question 97 civic ex
Please HELP
vtec controllers
99 civic si problems
hydrolocked b16A2 replaced
b18
Engine question
no instrument lights???? wtf!
wiper motor fuse blows
Civic Problems?
valve cover
b16 question
timing belt
96 civic idle problems
1999 civic si
EK Swap-B18A1/B18B1-C1Head
quick questions
h22 motor mounts
Ram Air or Cold Air Intake?
door locks
Gas
won't start
newbie in need of help...
cat and header exhuast trouble shooting
97 ex possibally alternator
Is Nos Cheating??
disassembly of door
b16 or h22
Exhaust
Strut Compatability question
Cold Starts
99 Civic trans shudder
overheating 96 Civic
19" Rims Need HELP!!!
WINTER tires.. good deal or not..
CRVtec
b20/vtec?
help b18b into 2000 civic
02 Eliminator
97 EX Hood Won't Open
springs
1.6L SOHC potential?
Call it a dumb question
b16a to b18c swap?????
mini me, help!
prelude seats...
Cold weather problem
Ecu info
Driveshaft
help! wiring prob.?
99 Civic Winter rims
ZC swap into 97 civic EX
B16b Swap
is this normal
car fax help
Where is 97 Civic PVC?
Honda 1600 VTec Head Torque Settings
1998 Honda Civic LX engine swap
Just got my first Honda (97 Civiclx)
96 Civic Si
anyone selling?
starting problem
98 civic EX headlight bulb question...
Dohc
I need Honda Civic Si
98 EX jack points?
big road trip coming up, your inPUT needed..
Web
AF
