View Full Version : '96-'00 Civic
Pages :
1 2 [ 3]
4 5 6 7 8 9
- D16Y8 + D15B7 = Mini-Me
- Best motor for a civic swap
- The Project: Rebuild,swap or both?
- 96 civic with a b16a from japan needs help wiring :(
- tail lights..???
- battery question
- 99 civic hatch back ?
- b16b
- any 91 accord exr parts can be used ?
- bad axle? or what else?
- wastegate help
- stupid car?!
- 1999 Civic Hatchback minor prob
- Sounds of sloshing water.
- help on what what to upgrade?
- 96 Civic Axle Assembly
- Possible dying alternator?
- question about new clutch...
- 3.4 grand am vs 2000 civic Si vtec
- how much does a 2000 civic si cost???
- What Size Rims????
- Extremely shakie tires
- Intermittent Wippers not working
- fender question
- Tranny Conversion Questions
- Burning coolant! Need help!!
- Valve adjustment problem
- Engine code
- Rebuilding a '96 EX
- Need help installing a turbo on my 99 Si
- 98 Civic Hatch Back Seat Broken - HELP!!!
- where to order paint with a reasonable price? 99 civic
- Alignment problem?
- 96 Civic HX suddenly no heat
- some new pics (56k go mow your lawn)
- 97 Ex making a noise??????
- New Manual Honda Civic owner
- Confused As Hell
- high mounted brake light removal -- 99 hatchback
- Need Help
- 6th gear
- Yet another exhaust question
- Will aftermarket headers and high-flow converter cause the cel to pop up?
- Can a bad catalytic converter damage the sensors?
- '00 Civic EX timing belt/water pump replacement
- Are Bosch oxygen sensors any good?
- rad help pt.2
- OEM code AFTER new trans install!!
- Engine Help!!!
- b series mounts
- Exhaust Help!!!
- switch for 2000 civic
- Rad help
- '97 Civic HX keyless entry light flash?
- Thinking about buying, need advice....
- honda 1.8 vtec colant probs not head gasket helppppp
- Black Smoke
- need help in choseing an engine for a 99 civic
- front bumper ???????
- How to replace rear indicator bulb
- black dust on exaust pipe?
- should i trust the rice shop?
- lock problem
- aftermath of a fire
- my civic idles real low when i stop
- Dumb ? here
- Trunk bars (triangulation)
- 98 civic ex shutting off
- Knocking sound only when accelerating into turns
- 98 Civic Engine Help
- Camber Kit Problem, how screwed am I
- 98LX Sedan Coolant Flush/Front Brake Pads
- AC Question!
- 98 civic lowering options
- alarm won't shut off!!!
- First Time Honda Owner
- Rattling in exhaust pipe
- new engine help
- leaky rear air outlet?
- 1999 unstable revs help
- civic turbo kit, how many psi?
- underdrive pulley, what belt?
- seats for tall 2000 si owners?
- Civic mileage?
- 99' Civic 1.5l Oil mixing with coolant problem.
- 00' sir killing too much gas
- Intake port size?
- Auto to Manual parts
- h22a swap can ac stay?
- 98civic ex wont start
- with a bumper here and a bumper there...
- Charging System
- Water in headlight
- Got another civic lol
- 2000 factory speaker removel
- shaking wheel
- 5 speed shifter loose
- Steering- what's my problem??
- keyless entry/ radio 96'
- Weird Electrical Blip??
- Is this a fair price for a 2000 si
- for my 2000 civic ex knock sensor rplcmt
- help on 98 civic window seal
- Service Check Connector on 98 Civic
- Kumho Touring A/S 795 tire
- Transmission Fluid
- 96 Civic - Cold Weather
- problem with 98 civic
- Car starts w/out clutch
- rpm question
- 2000 honda civic 1.6
- Squeeking Sound When Pressing Clutch
- What is the best way to Swap a J-spec B18C1 into a 96 DX?
- b18c and d16y8 injectors
- My 98 Civic
- Are parts for Civics expensive in Australia?
- New Civic for me....
- Civic Si Vortech (Need help)
- Something strong...
- swap questions
- Serious brake problem...please help!!!
- rim question
- Brake job - 2000 Honda Civic EX coupe
- curse me...i need help and hate to ask..
- goodbye civic
- 1996 hx
- Blox Catback
- fluctuating rpms, bang, tick & other woes -97 HX
- brake problem?
- 99 Civic-to buy or not to buy?
- Windshield weatherstripping R&R
- 1996 hood latch broken - help!
- How much "bucking" is normal?
- smoking vti
- help with 98 honda civic
- 2000 civic ex
- !stock hatch spoiler!
- Need advices.
- pics of my car a year later
- Ek Short Shifter
- Possible Wiring Problem???????
- losing power?
- frying smell
- NEED help! the order in which the spark plug wires GO?
- Just wondering...
- Speedometer & Odometer problems...
- 99 oil pan gasket replacement
- 99 Civic Front end squeak
- need help can't seem to adj valve springs
- my 99 civic wont start!!
- CV Joint Replacement
- Coolant problems!!
- Coolant Question
- Cylinders 1 & 2 misfiring
- 98 EX gauge swap
- Hondas for sponsors!
- timing belt and water pump
- help wanted: clutch install
- new engine?
- the yahoo commercial
- Bad Syncro?
- Fair price for balance and alignment?
- tubos / h.p.
- my car is making a weird noise
- d16y8
- What kind of Intake should i get
- Changing turn signal light?
- H22 swap in 97 ek info
- 97 honda EK problem
- A few tech. questions... anyone?
- 1997 Civic DX
- 2000 civic hatchback
- speedometer problems
- taillight issue
- ecu code?
- not starting??
- sad day for me
- 10k engine service
- flywheel lightened, questions about proper lightening procedure
- audio help please
- Makes me want to cry
- What's a good selling price???
- what could be wrong
- engine swap
- Helppp me someone!
- engines
- 97 CX No Spark, Any ideas?
- 97 civic idles funky when in drive and stopped
- How to Replace Headlamp Assembly in 1999 Honda Civic.
- cel after 60m/h?
- 1998 Civic D.i.y. Timing Belt ?
- Transmission Oil
- jdm 1600cc
- 98 Honda Civic Ex Power locks
- Help me fix this so I can boost my civic!
- 99 civic distributor
- Maintainance required light
- 1996 Civic DX
- power window switch
- A couple of questions
- Honda civic how to make more power
- 1997 civic EX - emissions warranty
- Honda Civic Starting Problem
- intake/exhaust
- No Wiring For Rear O2 Sensor
- cooloant
- How do i know when i need alignment?
- civic treadwear limit
- 98 Civic random misfire SES flashing
- SRS again!!!
- cap / rotor
- 2000 civic speakers?
- Wipers won't work in the rain ('00 SE)
- I need information about lightening my flywheel
- What car should I get a 96 civic or a 02 cavalier?
- Civic idle problems with air conditioning only
- fender bender question
- Door Locks-1998 Honda Civic EX
- 96 civic passenger power window wont go down
- What would be the better choice?
- belt squeaking when A/C is on! '00 Civic EX
- Check Engine Light, new headers
- 97 civic lx wont start...need info asap
- c-pillar bar
- 98 civic AC problem Help
- Stall problem
- Clutch
- hey help on my 00 civic
- civic for 15k?
- Wiring Diagram for a 1996 Civic EX Coupe 5 Spd
- 1997 Honda Civic LX door panel removal??
- Emergency help.
- 98 Civic HX - What are the dimensions of the trunk?
- Car Troubles
- I've got a problem
- PLEASE HELP ! changing spark plugs part fell inside!
- system too rich
- Wipers Dont Park
- 97 civic has no power and runs BADLY, need help!!!
- What intake should i buy for 98 civic???
- replacing brake bulb - 98 Civic EX
- odd rpm gauge question
- mini me swap
- 98 civic INTAKE HELP! PLease asap
- 1999 EK Civic lowered not looking level
