View Full Version : '96-'00 Civic
Pages : 1 2 [3] 4 5 6 7 8 9
  1. b18c and d16y8 injectors
  2. My 98 Civic
  3. Are parts for Civics expensive in Australia?
  4. New Civic for me....
  5. Civic Si Vortech (Need help)
  6. Something strong...
  7. swap questions
  8. Serious brake problem...please help!!!
  9. rim question
  10. Brake job - 2000 Honda Civic EX coupe
  11. curse me...i need help and hate to ask..
  12. goodbye civic
  13. 1996 hx
  14. Blox Catback
  15. fluctuating rpms, bang, tick & other woes -97 HX
  16. brake problem?
  17. 99 Civic-to buy or not to buy?
  18. Windshield weatherstripping R&R
  19. 1996 hood latch broken - help!
  20. How much "bucking" is normal?
  21. smoking vti
  22. help with 98 honda civic
  23. 2000 civic ex
  24. !stock hatch spoiler!
  25. Need advices.
  26. pics of my car a year later
  27. Ek Short Shifter
  28. Possible Wiring Problem???????
  29. losing power?
  30. frying smell
  31. NEED help! the order in which the spark plug wires GO?
  32. Just wondering...
  33. Speedometer & Odometer problems...
  34. 99 oil pan gasket replacement
  35. 99 Civic Front end squeak
  36. need help can't seem to adj valve springs
  37. my 99 civic wont start!!
  38. CV Joint Replacement
  39. Coolant problems!!
  40. Coolant Question
  41. Cylinders 1 & 2 misfiring
  42. 98 EX gauge swap
  43. Hondas for sponsors!
  44. timing belt and water pump
  45. help wanted: clutch install
  46. new engine?
  47. the yahoo commercial
  48. Bad Syncro?
  49. Fair price for balance and alignment?
  50. tubos / h.p.
  51. my car is making a weird noise
  52. d16y8
  53. What kind of Intake should i get
  54. Changing turn signal light?
  55. H22 swap in 97 ek info
  56. 97 honda EK problem
  57. A few tech. questions... anyone?
  58. 1997 Civic DX
  59. 2000 civic hatchback
  60. speedometer problems
  61. taillight issue
  62. ecu code?
  63. not starting??
  64. sad day for me
  65. 10k engine service
  66. flywheel lightened, questions about proper lightening procedure
  67. audio help please
  68. Makes me want to cry
  69. What's a good selling price???
  70. what could be wrong
  71. engine swap
  72. Helppp me someone!
  73. engines
  74. 97 CX No Spark, Any ideas?
  75. 97 civic idles funky when in drive and stopped
  76. How to Replace Headlamp Assembly in 1999 Honda Civic.
  77. cel after 60m/h?
  78. 1998 Civic D.i.y. Timing Belt ?
  79. Transmission Oil
  80. jdm 1600cc
  81. 98 Honda Civic Ex Power locks
  82. Help me fix this so I can boost my civic!
  83. 99 civic distributor
  84. Maintainance required light
  85. 1996 Civic DX
  86. power window switch
  87. A couple of questions
  88. Honda civic how to make more power
  89. 1997 civic EX - emissions warranty
  90. Honda Civic Starting Problem
  91. intake/exhaust
  92. No Wiring For Rear O2 Sensor
  93. cooloant
  94. How do i know when i need alignment?
  95. civic treadwear limit
  96. 98 Civic random misfire SES flashing
  97. SRS again!!!
  98. cap / rotor
  99. 2000 civic speakers?
  100. Wipers won't work in the rain ('00 SE)
  101. I need information about lightening my flywheel
  102. What car should I get a 96 civic or a 02 cavalier?
  103. Civic idle problems with air conditioning only
  104. fender bender question
  105. Door Locks-1998 Honda Civic EX
  106. 96 civic passenger power window wont go down
  107. What would be the better choice?
  108. belt squeaking when A/C is on! '00 Civic EX
  109. Check Engine Light, new headers
  110. 97 civic lx wont start...need info asap
  111. c-pillar bar
  112. 98 civic AC problem Help
  113. Stall problem
  114. Clutch
  115. hey help on my 00 civic
  116. civic for 15k?
  117. Wiring Diagram for a 1996 Civic EX Coupe 5 Spd
  118. 1997 Honda Civic LX door panel removal??
  119. Emergency help.
  120. 98 Civic HX - What are the dimensions of the trunk?
  121. Car Troubles
  122. I've got a problem
  123. PLEASE HELP ! changing spark plugs part fell inside!
  124. system too rich
  125. Wipers Dont Park
  126. 97 civic has no power and runs BADLY, need help!!!
  127. What intake should i buy for 98 civic???
  128. replacing brake bulb - 98 Civic EX
  129. odd rpm gauge question
  130. mini me swap
  131. 98 civic INTAKE HELP! PLease asap
  132. 1999 EK Civic lowered not looking level
  133. oscillating revs
  134. 2000 civic need help w/ dash lights
  135. A/C troubleshooting help....
  136. Dizzy A/C
  137. tool question
  138. 2000 civic 1.6 ID/PCM ?
  139. SRS light on my 98 Civic
  140. WTB stock springs for 1996 civic
  141. ECU Wiring harness
  142. Different Intake Systems..
  143. help my 96 wont start
  144. Wiring Harness 4 Sale!
  145. best type of headers 4 a N.A. single cam
  146. Splicing wires for wire harness
  147. Parts in Arizona?
  148. A/C Idle Up Not Working
  149. squeeling belt on 96 civic
  150. Engine light with rough idle
  151. loud sound when driving my car ? help please!
  152. tire psi for 17inchers
  153. srs
  154. 96 Civics Installing new radio
  155. 96 Civic Ex
  156. help Civic Ex 95'
  157. 99 lx stock exaust manifold
  158. Window Regulator Down for the Count
  159. help with spark plug torque spec
  160. Need MAJOR advice- hydrolocked my d16y7 and now ready to swap on a budget
  161. 98 Honda Civic - SRS Light
  162. transmission swap
  163. air conditioning noise
  164. 1.6 Vtec To 1.6 Non Vtec Swap
  165. gas milage
  166. need to know about engine mounts
  167. can't accelerate sometimes past 4000 RPM
  168. VSS Help
  169. leaking water from rear of engine compartment?
  170. hi guys i have a question that i want to ask!!
  171. 97 civic has p1298 fuel air mixture code
  172. new car
  173. obd 2 smog check problems
  174. where could i find the ecu fuse to see if it's blown?
  175. Any Civic owners in PA ??
  176. SRS light
  177. d17 question
  178. what halo lights are best?
  179. i have a 1997 honda civic
  180. will this work/ doors
  181. Help with 96 Civic EX
  182. 97 rear lower control arm bushing...
  183. Speedo Problems
  184. APC Seat install
  185. rebuilt title
  186. 96 Civic dash cluster swap
  187. mil/check engine light test failure? smog check experts?
  188. sometimes the turn signal buzzes and doesn't work
  189. 2000 si 2 problems
  190. selling 96 civic in south florida
  191. what do you think?
  192. 98 civic lx transmission dipstick loose?
  193. Sounds like a Lawn Mower...
  194. Direct Replacement Cat for '99 EX
  195. Interior Colour
  196. exhaust
  197. header
  198. '00 Civic EX Check Engine Light
  199. Civic hatchback DX power doors
  200. MexSiR Pictures (99 Si Ebp)
  201. 99 Civic LX 4 Door "REAR DOORS WILL NOT UNLOCK" HELP!!!!!!!!
  202. 1997 Honda Civic DX
  203. Bulbs for JDM Type-R headlights
  204. help please on a swap problem
  205. Help!
  206. 97 Civic EX SRS light on
  207. 2000 Civic EX Caliper Issue
  208. 96 civic - 00 si front end conversion
  209. Engine rev fluctuates
  210. wireing
  211. MAP sensor question...
  212. High Flow Cat Question
  213. 99 Civic Si HELP!!!
  214. lowering civic hatchback
  215. so confused?!?!?!?1
  216. 97 Civic EX Idleing High (Idle Screw Question)
  217. eyebrow and headlights
  218. need help asap, what's wrong with my idle?
  219. 96 civic hatchback rear brake conversion
  220. To Rice or Not to Rice
  221. So im new
  222. CD Player always starts at track 1
  223. 97 Civic HX Dual Exahst
  224. fuse box layout
  225. engine code 0420 in 96 civic dx
  226. What Blow Off Valve?
  227. 97 hx electrical malfunction...
  228. The Final word on keyless remote
  229. Mudflap differences
  230. 98 civic hx cvt transmission problem surges when cold
  231. 00 Si Bumper Fit 96 Civic EX???
  232. Is $2k good for B18C1 Full Swap?
  233. 97' Civic EX - Engine Quit
  234. 97 Civic Cx (Type R)B18C5
  235. Buying a new car - wut should i get?
  236. piston help!!!
  237. 95 acura integra gs-r motor swap into a 2000 honda civic coupe
  238. Civic SI lip and jdm Civic type R difference?
  239. Ehlp
  240. 97 civic black smoke?
  241. XM radio on 97 civic anyone?
  242. 00 civic low idle
  243. New MexSiR (PICS)
  244. 96 civic DX hatchback Power Steering
  245. Short Ram intake with odd problem
  246. new alarm installed but doesn't activate when door opens!!!
  247. Rear main seal leak on 2000 DX with 77K.
  248. 96 Civic Cluster
  249. OIL PRESSURE ON STOCK civic 98
  250. 96 civic suspension problems
