View Full Version : '96-'00 Civic
Pages :
1 [ 2]
3 4 5 6 7 8 9
- '96 honda civic gas gauge stuck on full????
- Intake swap from another Civic?
- jerks upon acceleration
- Alternator caused speedometer to fail...?
- parts needed for auto to manual trans swap for 2000 Civic Si???
- rear disk brakes
- converting 97 civic to 99-00?selling velside bodykit
- Clutch Help
- replacing inner tie rod 97th pw steering
- excessive inner wear, rear tire
- Fixing power window on '00 civic
- help!!! coupe or sedan?
- help asap please!
- Fidanza Flywheel Help
- swap in ek
- 1998 Civic Dx Hatchback
- Turbo Automatic civic
- Help with 2000 Civic
- my civic....
- civic vtec
- '96 Civic Engine Issues
- jdm d15b into a 96 dx??
- 1997 Civic EX clutch engages starter
- 98 Civic Keyless Entry - pwr locks problem
- Need help......
- Hand Break is realy loose
- Hey Need Info Asap!!
- overheat when got stuck
- 98 civic lx CEL headers exhaust
- supercharger on a civic
- Idle air problem, 99 civic
- HELP!! Stereo/dash lights/alarm HELP
- Obd1?!obd2?!
- Getting a B18A1
- Power window kits.
- 2000 cvic dx
- valves
- 2000 Civic Lx a/c problems!!
- Help with '97 Remote
- Bizarre Soft Brake Pedal
- programming keyless fob
- overheating civic ???
- how do you know if vtec is kicking in?
- Newb from ohio
- Testing waters..how much?
- How to install Front Oxygen Sensor for 1998 Honda Civic EX coupe
- connecting CD player in civic '96
- air conditioner whistling
- '00 Civic Possible Swap.
- 00 civic ex help remove side view mirror and wiring diagram
- 99 Civic LX - Low RPM Problem
- Radiator support
- 97 civic hx afc neo install?
- swap question
- fiixing an aluminum rim? getting rid of dime size rust spot? help!
- 97 Civic A/C Problems
- 2000 EX help please! AHHHHH!
- Door restraints grinding on 98 Civic
- Stereo problem
- 97 EX (d16ya) Valve Adjustment Help
- H23A1 Swap into my 98 civic EX?
- Wrecked civic
- wtb 99-00 civic front end
- Rear brakes squeal / squeak
- whistling sound
- how to replace ac thermostat on 96 civic
- need opinions
- Manifold & throttle question
- What other years could I take a hood/bumpers from to fit my 97 civic cx hatch?
- checking the timing on a 97 civic
- Neon bulbs in defrost switch
- Color Code
- Engine miss/backfire '97 Civic EX
- HIDs with angel eyes from ebay
- 1997 civic LX problems with somethin!
- The Conversion
- ex to vx
- Old Rusty.
- Timing Belt
- Third Brake Light on Spoiler....
- vibration on civic 99 LXi manual when AC compressor on
- Interior Question????
- My clutch won't come back up!!!
- iacv
- vtec controller
- SI vs. PRELUDE OPINIONS!! PZL HELP!!
- installing throttle body?
- clutch problems
- throttle
- Mystery Cooling System Problem
- 02 sensors
- idle prblem
- z1 fenders
- Intake Tube Lengh/Filter Cone Length
- Tach, speedometer, fuel, temp gauges
- Center console
- Sponsors
- AEM CAI = bad throttle body???
- Rear Disc Brake Caliper Piston Retraction
- What engines can be put in a 2000 Civic EX Coupe
- d16
- what do i need to hit vtec?
- cv boot
- buying a civic
- enigine swap exaust compatability D16-B18B1
- Paint!
- 2000 Honda Civic EX Rust
- muffler/exhaust installation help
- reprogram a Honda remote to arm/disarm antitheft system
- no vtec
- How much tranny fluid in a 98 civic hatch?
- A/T cooler-safe to drive without?
- help! pops when turned
- Belt noise when using accessories
- Civic 1.6i ES - Alarm/beeps goes off
- HELP! Error codes P0420 and P1457
- gauge light not working
- Warning Light Code
- Throttle body?
- 98 civic brake rotors
- 2000 civic turn signals wont work
- How to keep the exhaust quiet
- loose tranny dipstick '00 Civic EX
- Civic leaking connecting pipe, help!
- Help! civic won't start
- New Horn
- messed up firing order leading to engine not starting...
- Shag's Ex Photoshoot (56k, oh my)
- Interested in purchasing a 97 or 98 civic..
- oxygen sensor simulator
- D16Y8 + D15B7 = Mini-Me
- Best motor for a civic swap
- The Project: Rebuild,swap or both?
- 96 civic with a b16a from japan needs help wiring :(
- tail lights..???
- battery question
- 99 civic hatch back ?
- b16b
- any 91 accord exr parts can be used ?
- bad axle? or what else?
- wastegate help
- stupid car?!
- 1999 Civic Hatchback minor prob
- Sounds of sloshing water.
- help on what what to upgrade?
- 96 Civic Axle Assembly
- Possible dying alternator?
- question about new clutch...
- 3.4 grand am vs 2000 civic Si vtec
- how much does a 2000 civic si cost???
- What Size Rims????
- Extremely shakie tires
- Intermittent Wippers not working
- fender question
- Tranny Conversion Questions
- Burning coolant! Need help!!
- Valve adjustment problem
- Engine code
- Rebuilding a '96 EX
- Need help installing a turbo on my 99 Si
- 98 Civic Hatch Back Seat Broken - HELP!!!
- where to order paint with a reasonable price? 99 civic
- Alignment problem?
- 96 Civic HX suddenly no heat
- some new pics (56k go mow your lawn)
- 97 Ex making a noise??????
- New Manual Honda Civic owner
- Confused As Hell
- high mounted brake light removal -- 99 hatchback
- Need Help
- 6th gear
- Yet another exhaust question
- Will aftermarket headers and high-flow converter cause the cel to pop up?
- Can a bad catalytic converter damage the sensors?
- '00 Civic EX timing belt/water pump replacement
- Are Bosch oxygen sensors any good?
- rad help pt.2
- OEM code AFTER new trans install!!
- Engine Help!!!
- b series mounts
- Exhaust Help!!!
- switch for 2000 civic
- Rad help
- '97 Civic HX keyless entry light flash?
- Thinking about buying, need advice....
- honda 1.8 vtec colant probs not head gasket helppppp
- Black Smoke
- need help in choseing an engine for a 99 civic
- front bumper ???????
- How to replace rear indicator bulb
- black dust on exaust pipe?
- should i trust the rice shop?
- lock problem
- aftermath of a fire
- my civic idles real low when i stop
- Dumb ? here
- Trunk bars (triangulation)
- 98 civic ex shutting off
- Knocking sound only when accelerating into turns
- 98 Civic Engine Help
- Camber Kit Problem, how screwed am I
- 98LX Sedan Coolant Flush/Front Brake Pads
- AC Question!
- 98 civic lowering options
- alarm won't shut off!!!
- First Time Honda Owner
- Rattling in exhaust pipe
- new engine help
- leaky rear air outlet?
- 1999 unstable revs help
- civic turbo kit, how many psi?
- underdrive pulley, what belt?
- seats for tall 2000 si owners?
- Civic mileage?
- 99' Civic 1.5l Oil mixing with coolant problem.
- 00' sir killing too much gas
- Intake port size?
- Auto to Manual parts
- h22a swap can ac stay?
- 98civic ex wont start
- with a bumper here and a bumper there...
- Charging System
- Water in headlight
- Got another civic lol
- 2000 factory speaker removel
- shaking wheel
- 5 speed shifter loose
- Steering- what's my problem??
- keyless entry/ radio 96'
- Weird Electrical Blip??
- Is this a fair price for a 2000 si
- for my 2000 civic ex knock sensor rplcmt
- help on 98 civic window seal
- Service Check Connector on 98 Civic
- Kumho Touring A/S 795 tire
- Transmission Fluid
- 96 Civic - Cold Weather
- problem with 98 civic
- Car starts w/out clutch
- rpm question
- 2000 honda civic 1.6
- Squeeking Sound When Pressing Clutch
- What is the best way to Swap a J-spec B18C1 into a 96 DX?
- b18c and d16y8 injectors
- My 98 Civic
