View Full Version : Del Sol
- 93 honda del sol door want open
- Knowledgeable Honda owner needs ignition help
- 95 del sol tranny problem help please
- Del sols with vtecDOHC engine
- 94 del sol starts runs for 1 min then shuts off and wont restart
- need a new car
- Parking lights/ brakes question
- ls engine in 95 delsol?
- '93 honda del sol door panel removal
- '96 Del Sol door latch problem
- Del Sol Insurance
- Bad A/C Issue...
- Need Help With Washer Fluid Issue
- Head light questions
- won't run please help!!
- ECU gone bad, help me find replacement PLEASE
- under-hood informational sticker
- Myterious Electrical Problem........
- 93 del sol skyline conversion
- Passenger Door Handle Problem
- SRS light stays on
- Aem Sr Intake On Delsol Vtec Help!!!!
- Sail Panels for the Del Sol?
- Eibach springs and suspension
- Right Hand Steering Conversion
- Need help with an obdo ls vtec swap into my obd1 del sol
- New Here
- 95 si head gasket replacement Qs
- B16 rebuild in 93 Del Sol
- Del Sol Modifications
- new car, belt, spark plugs, & turbo kit questions
- power window problems
- 1993 Honda Del Sol
- Del sol Taillights
- 3rd gear grinds only at high rev?????
- turboing 94 si
- cylinder id
- window sticker
- what is the average used Del sol's 0 to 60
- Question on adding AC to 94 VTECH
- Bought a 93 del Sol. Just found out it was used for street racing...
- oil temp sender
- Removable roof
- Free Delso
- Alpine Type X
- Fog Light Problems :s
- Rattle from the targa top
- another v tech ..
- new del sol driver..
- v tec engine....
- B@w/ot-2008
- FORUM RULES AND GUIDELINES, GROUND RULES and FAQ...EVERYONE MUST READ!!!
- Del Sol Power Window Help
- O2 sensor spoofing?
- Help!! deciding on a del sol
- 95 DelSol stalls when temperature nears operating temp
- radio and clock no power
- Headlight adjustment on Del Sol
- hot tall is to tall for a sol?
- 94 Del Sol
- Tach Fluctuates
- Do all Del sols have electric roof?
- delsol adjustable suspension
- Targa Top.....
- d16z6 question
- powers steering
- Del Sol door handle problem
- wierd happenings
- changing front lights two to one.
- $500 Del Sol?
- Problme with break lights HELP PLZ!
- Picky Clutch
- del sol question?
- Light bulbs in heater control
- Exhaust for Jap import
- New Honda owner...
- Just Getting Turbo KIT HELP PLEASE!!!
- Horn out
- Custom Mods to Delsol - Opinions & information
- SRS indicator light
- wierd wired?!?
- hood totaled
- 1993 del sol trunk problem
- What kind of sealant??
- Plug Wires
- speedometer calibration is off
- ECU swap
- 94 del Sol clutch, master cylinder, slave cylinder, battery problems
- Leaky Water Clips
- '96 Del Sol radio antenna
- Cruise Control not working
- Rear Speaker Brackets
- Tacometer Question
- I hear water/sloshing noises when I turn, what can I do?
- Oil Crud
- New Ride
- Mystery Indicator Lights
- 93 del sol brake rotor
- Aftermarket ebrake cable
- A/c
- Antenna
- d16y8
- Buyers guide
- Questions about a system?
- Keyless Entry?
- Bigger tires on rear?
- werid Sounds.....oh no
- Info on a front body kit
- missing link problem
- Seatbelts?
- need some pics for project prep.
- del sol question
- Racing Seat Trouble
- THE COMPLETE 93-97 Del Sol Engine Swap Guide!
- H22/D16/B18 Engine Swap Info?
- R-Series into del Sol?
- h23 in a del sol?
- rwd
- steering wheel?
- Does anyone know crash safety ratings for a 94 VTEC del sol?
- targa top
- type-r urethane front lip
- Air Bag disarment 96 Del Sol
- Window relay.
- del sol motors
- this is dumb but hear me out
- lower control arms
- mini swap
- Si = VTECH ?
- Vegas Invasion 7 - May 18-20, 2007
- taillight conversion
- body kit bumper
- Wierd problem!
- DEL SOL IGNITION PROBLEM! help asap
- newbie here need a bit of sum help
- Steering wheel
- 4-point racing harness
- Idle rpm rate issue
- d15b motor swap
- JDM Aux Switch
- 95 Del Sol....Noisy engine? That ok?
- Engine Mounts?
- 94 Del sol (KY,IN)
- WTB: Del Sol Hood
- What to do with a leaky trunk
- Should I do it or not? Pics...
- Have any of you actually seen my car?
- I dont think... is this normal?
- suspension
- NY Sol Meet
- looking for a small lip spooiler
- rod pistons and crank combo's
- Intermittent starting problem
- 93 del sol Check engine light
- Baffled! What the heck is going on?
- SiR on its way to ME :D
- del sol stock exhaust help
- '93 Del sol will not start at all now
- front bumper reinforcement
- rim weight
- Gauges
- got a GReddy turbo kit, but a intercooler kit?
- engine...?
- In need of help!
- need info on b18b1 into 94 del sol s
- Need some SOL LOVIN'!!!
- Help with low gas mileage
- driver side door
- Gear Box
- Great power loss...............
- how to check and change the manual Transmission Fluid?
- f22a4 in a 94 del sol s?
- e-brake light
- question on intake/nos
- New - East Coat Meet Location Moved!
- my sol got problem again...................
- VTEC A/C bracket
- weird problem with delSol 93 Si / starting it
- I was going 2 get some rims need some help
- Del Sol No Start
- if i have connected two batteries on my del sol...........
- Help with suspension?
- Problems....
- Suggest/Recommend Site to Sell My Babie'94DOHC/VTEC
- Ooooh.... Your friendly neighborhood mod got upgraded!
- honda delsol 93 car not starting cuz of gas
- how do i take off my delsol steering wheel
- transmission?
- Alloys
- 93 si check engine light issue
- question after The sunroof problem & stud pattern
- del sol no spark help!!!!
- short throw shifter
- Ugent~PRoblem with my Transtop (sun roof)
- Integra rear discs into 94 sol?
- B18A1 into 94 del sol?
- She is gone for good
- Brake problem
- cracked exhaust manifold
- transtop ecu
- del sol suspension??
- b20 sol
- Weather Stripping
- How do you lift top in trunk
- Del Sol Distributor bearing - worn out!
- del sol-like convertible conversion on cavalier?
- Replacement dials for my Del Sol
- problem with stereo/heater not turning off...PELASE HELP!!
- 93 Del Sol Rear Speaker Installation
- starting problems
- 93 del sol starting prob
- Change at heart. Got a new Sol!
- Hit a tire, blew airbags
- need help instalking led winshield washers
- A HEMI ate my SOL!
- why a del sol?
- Some pics of my Sol.
- MUGEN Front Bumper CR-X Del Sol EG2
- CRX but Del Sol wiring.... =(
- Huge del sol meet, Albany NY
- Not so good with Japanese
- Any way of telling how many del sols are still around?
- fuel pressure regulator
- HELP with exhaust...
- Change My ECU???
- Need to sell Del Sol
- ligal tint?
- Need HELP with door handles
- k&n or aem CAI ?
- 93 syncro problem
- interior trim problem
- b16a or b18c, and stay n/a
- Who's got subs?
- centerforce clutch
- Just got my 93 vtec sol, Got Questions 4u
- JDM Trunk..
- Side mirror help
- Help! Need ideas to get into my trunk
- Squeaky Noise In My Engine
- Tri-State Sols Meet (MI. IN. OH.)
- front end conversions
- turbo kits on ebay
- ?'s about my 94 del sol vtec.
- winter gas mileage lower?
- interior noises
- Anyone got a Del Sol with a 1.8?
- del sol rear window help
- Guages
- Clutch Kit Conundrum
- New Parts
