View Full Version : Eclipse Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12
  1. Damn check engine light
  2. power loss
  3. Oil filter housing problem
  4. what do i need to turbo?
  5. 18 mpg black smoke out exhaust
  6. What's my problem?
  7. tail light problem
  8. Tail Lights Dont Work
  9. Possible Broken Rod
  10. no cold start
  11. TPS code. What should I do?
  12. 92 Eclipse GS broken?
  13. 91 TSI AWD Problems
  14. 91 GS-T Misfiring
  15. Problem Under Hood Please Help
  16. greddy type s bov
  17. p1294 target no reached
  18. Problems with my 94 talon sohc
  19. Car wont start. Got gas but no spark
  20. question for 97 eclipse
  21. SRS Light is on
  22. wiring harnes = bitch made!
  23. cold weather with more problems to come (rubbing sound)
  24. throttle positioning sensor
  25. Help Ticking
  26. I'm ready to push my rs off a cliff..
  27. Speedometer
  28. spark plug wires
  29. strange noise when i move the steering wheel
  30. Having problems with a speed sensor that works!!! What great Luck!
  31. Speed-related noise...not engine?
  32. Oil Leak
  33. Oil Pressure
  34. car started bucking violently at 85mph
  35. eclipse gsx i need help bad please
  36. i need help bad
  37. My engine does not pass 4,000 RPM
  38. TSI AWD CV-Axle problem....
  39. Fuel Filter
  40. what can it be
  41. 420 help
  42. just a few concerned questions
  43. Won't start, any ideas?
  44. No Fire To Plugs
  45. No Fire To Plugs
  46. why my engine dont pass 3.500rpm 4g63
  47. turn signal malfunction
  48. replacing up ball joint...
  49. Grinding Gears
  50. (IAC) Idle air control motor.
  51. not idleing!! cant figure it out!
  52. Eclipse alarm or something else
  53. passenger front wheel knocking???
  54. What wld make a battery crank but not start?
  55. sluggish performance and tranny issues everything wrong
  56. chassis ecletrical
  57. 92 1.8 Eclipse-No start
  58. 97 Eagle Talon Check Engine and FM Radio
  59. Idle problem
  60. Interior Lighting
  61. ecu
  62. electrical problem?
  63. Timing belt trigger Check Engine light?
  64. Crazy electrical problem
  65. altenator replacementfor a 97
  66. '95 Eclipse bucks and sputters under load.
  67. Replacing alternator and dreading it
  68. turbo detonating
  69. Possible water pump problem?
  70. 93 Mustang Coil Problem
  71. recently got cold weird engine noise need help
  72. O2 sensor bypass problems...
  73. major oil leak!!!!
  74. Final touches
  75. any1 got a Thremo Valve for sell
  76. burning oil... bad turbo?
  77. Shifting Problems Good God!
  78. Instruction
  79. Eclipse Vibration
  80. Shaking eclipse
  81. Noises at start up
  82. 94 Eagle Talon TSI 2WD
  83. 94 Eagle Tal Non Turbo 2.0 No Spark
  84. Electrical Problem
  85. Stiff brake pedal
  86. rear brakes
  87. Transaxle Control Modules
  88. rattling noise?!?!
  89. MBC problems.
  90. Good/Best Code Reader
  91. Advice, installing spindle and control arm!
  92. What is draining my battery? & 1 other question
  93. What in the heck happened?!?!
  94. dodge neon to 98 eclipse 420A transmission conversion
  95. 1995 Eclipse fwd auto transmission problems
  96. Clutch squeaks in 97 eclipse
  97. CW question
  98. Fuse Box Diagram
  99. Want to buy a 97 Eclipse RS! GOOD DEAL??
  100. spyder 2.4 GS misfiring
  101. HELP!Coolant light problems....
  102. over heating HELP?!?!
  103. Electrical Problem?
  104. Check Engine Light turns on and off?
  105. My Car Is Goin Through Ecu's
  106. How reliable is AutoZone?
  107. #2 cylinder misfiring 2.0L
  108. computer problems
  109. Need Serious Help
  110. how to put on a front body kit?
  111. Major electrical problem
  112. yeah yaaaa finally fix my car
  113. Going 75(mph) and the car shuts off HELP!
  114. steering / wheel problem?
  115. Trans don't engage when cold after engine swap.
  116. 1995 Mitsubishi Eclipse Wiring Harness
  117. 1990 plymouth laser
  118. I'm all about the 4G63 w/tailight issues
  119. Ahhh!!!!!! Accident Need Opinions...
  120. idle problem
  121. clutch problem
  122. Ongoing problem with loss of power (NW Illinois)
  123. Need help tightening tilt steering
  124. car smokes to much please help
  125. cam senser
  126. Scratching sound when disengaging clutch
  127. '98 Eclipse RS Tranny problems
  128. New Engine
  129. I can('t) believe I'm having another problem.
  130. transmission problems
  131. Info about ECU's
  132. Galant Horn
  133. Interior lights come on while driving
  134. 92 automatic tranny replacement?
  135. fast dsm horrible gas mileage
  136. Plymouth Laser Turbo, will not start
  137. 97 Talon ESi drivability issues
  138. cylinder order??? 90 montero
  139. My TOP won't go down. or up.
  140. BIG eletrical/alternator problem PLEASE HELP
  141. A Few Questions...
  142. Do you know how too....
  143. TPS adjustment
  144. Engine/Idle problems
  145. i had it with my eclipse
  146. Noise when clutch pedal is push in...
  147. 95 GST Problems
  148. car wont start
  149. P000
  150. what the hell is wrong with my car
  151. Car wont start
  152. Dash Light Problem Found!!!!
  153. TSI Troubles
  154. 2 problems in new car
  155. My eclipse tranny is stuck in 2nd gear plz help.
  156. Accident! Any suggestions!?
  157. What does a bad ecu look like?
  158. ? No spark 91 laser
  159. MY car is an oil-holic
  160. Wierd engine/acceleration problem
  161. car starts sometimes, other times, not
  162. CEL flashes 1, 2, 5, 5????????????????
  163. Trouble with turbo at high boost
  164. fuel injection control relay
  165. HELP!!!My baby is goin crazy!!!!
  166. Lights flicker at high rpms.
  167. dash lights!!!
  168. Check Engine...
  169. My car seems possessed!
  170. dead car
  171. help...black smoke problem
  172. timing my 2g
  173. right blinker always on
  174. I am desperate for help!!!!
  175. Possible Vacuum Leak
  176. Car making tapping noise
  177. Need Help: White'ish Smoke
  178. This eagle not flying very far
  179. big handling problem in the rain
  180. injectors problems
  181. Dash Lights and Console not responding
  182. Will a torn motor mount cause my car engine to shake at low idle rpms?
  183. a/c problem
  184. ecu question
  185. shifter Question
  186. PROBLEM: Driving (25mph) and engine shuts off - will NOT restart!!!
  187. I have a pretty good-sized problem.
  188. won't start
  189. CEL help
  190. Im new and my car just freaked out...
  191. Weird Transmission Problem
  192. seal to throttle body
  193. 91 awd talon HIGH IDLE SURGE
  194. burned wires,some advise please
  195. ticking
  196. Eclipse can't swim
  197. Rules and Regulations: Follow Them
  198. 98 Eclipse door locks backward
  199. Check Engine Light
  200. blower motor
  201. oil and spark plugs dont mix
  202. Car is starting again but still a problem...
  203. air sensor needed???
  204. Problem with gears since new turbo
  205. Won't start and 2 plugs smell like gas.
  206. Just what i need right now
  207. Knocking noise, spark plug well oil puddle.
  208. loud pop from axle
  209. 97 eclipse with misfire and CEL on!!!
  210. Hard to start when Hot.
  211. Auto Transmission ?
  212. E-Brake light
  213. found the boost leak
  214. what causes Valve seal to fail....
  215. starter question...
  216. P0300 In a 420a, Starting Problem, Related?
  217. starts up with low rpm and oil light comes on when it hits low rpm,wont rev pass 2000
  218. 98 Eclipse GST missfire problems
  219. no oil pressure now car wont start
  220. 95 RS suddenly not starting
  221. 95 eclipse fuel and fire but no start
  222. Check engine light - code P0125
  223. NT 2.0 Smoking after warmed up
  224. Turn Signals & Hazards not working - Please Help!
  225. Motor Mount problems
  226. 99 eclipse gs.. no power
  227. still got intake problem ....please help
  228. Engine revs, but no acceleration
  229. Intake Problem
  230. Drivers Side Door Lock Problems HELP!!!!
  231. gauge cluster issue, help...
  232. no compression
  233. Need help BAD!!!!!
  234. Speedomoter not working
  235. Leak in Sunroof like a Waterfall..
  236. Leak in Sunroof like a Waterfall..
  237. correct cylinder compression?
  238. clutch??
  239. Knocking!! AHHHHHH!!!!
  240. 91 Talon AWD Turbo, Auto, won't shift down
  241. a few problems
  242. Ecu????
  243. Running too rich..
  244. Car overheating....help!
  245. Bad ECU
  246. DTC Codes PO731 and PO700
  247. 92 Laser starts/idles at 500rpm/stalls????
  248. HELP need wire harness
  249. rear main seal
  250. Clicking sound
