Our Community is 705,000 Strong. Join Us.
Mitsubishi
Eclipse/Talon/Laser
> Eclipse Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
window problem
i need some help asap! it ends in like 5 hours!!
Solution to the MR-FPR here maybe
92 eclipse low compression help...
AWD popping under acceleration
We have spark, fuel, and runable compression but it wont start. HELP!
e-brake light
Idle problem won't go off.
Stock wheel offset
Radio will not turn back on?
Radiator Flush
94 eclipse 1.8 single over head
tranny fuild overfill?
420a automatic transmission fluid?
haha over heating
t-25 die...14b now...need tips
Car Wont Start? EGR ?
WTF is this noise now :banghead:
Bubbleling noise from inside the engine.
Need some help with this plug for the balance shaft removal
taking off my headlight
Steering,front axle,rotors...What is it?!?!
Smoke from oil cap???
doest 94 eclipse have power steering
Power Steering Belt
What turbo is this?
Low RPM problem/stalling
grinding noise
turbo just died?
Header problem
Bleeding clutch and adjusting linkage HELP
Any connection with anything?
powerlock noise
Gauge install problems
Heavy hesitation problem/ power loss
timing
has anyone had this problem?
Car only starts when jumped
idling at a higher rpm help
Just got it & third gear grinds can u guys help???
Speedo screwed
how to check and change 5 speed tranny fluid ?
Problem here...
I need a CAS and I'm confused
hard starting
anyone from PA? im having tranny probs
automatic transmission fluid leak(bad)
idle problems
Knocking From Axle
2g window problems
vertical door kit
2g convertible top
420a motor has rattling noise from engine
Sub Thumps when I turn radio On/OFF
Problems with running rich
Timing Problem
timing
fuel issue
headlamp bulb replacement
Wont Start Half The Time Please Help
you gotta be kidding me...please help
heres what happened, whatcha think?
Problem with friends 97 sphyder gs-t
output shaft seal?
Leaking Coolant like crazy
fuel problem?
early 90's eagle talon
Transmission fluid
need advise
91 tsi talon no start
Anyone had this code before?
Timing Problem
gas door malfunction help!
Electrical issuses
93 eclipse - No heat - It's 0 degrees out!
Need help transmission questions
axle help please
very high idle after clean up TB !!
I keep blowing the turbo!!
Update: Can't start when cold
Gauge lighting problem
how do i change front bumpers?
talon spark plugs
Starter noises
Power Antenna
Fuckign Head Bolts
need help with gas pedal cable
cant get alternator out from behind engine 96 eclipse!
92 Talon Problems Help
AC Compressor
shallow/deep clutch
wastegate help
ODB code 33 and code 44
Anti theft alarm stuck - please help me
Power Steering Leak--HELP!!!!
Compression low?
steering problem
Car won't start? because of new head unit?
Could it be timing?
coolant,brake, and battery
95 Talon Timing Issue!!! Need Help!!!
hollow sound
Rear Clicking Noise
need help! ASAP
Starting problem
auto and man redlines
95 eclipse blew heater hose, now will not start
retorking head bolts,
Automatic transmision Problems
starting problem
Fried computer?
93 Eagle talon problems!!! PLEASE HELP!!
sick '92 Eclipse help please!
Gas gauge is dead?
Problem going into any gear
Oil pump sprocket is hard to turn?!?!
tach issues
rear strut?
Did I Fart?? I Smell Gas......
4G63 with no power/slow rev
93 talon engine problems
Not as fast as i thought
Problem relieving fuel pressure
how many bolts??
High idle all of a sudden?
Charging system problem
Check Engine Light....How to Diagnose???
No Brakes!?!?
cant get window down
some issues
another problem
stalling problem solved, Thanks!
Cranks cranks cranks cranks... no start, then starts 92 talon non turb0
cars anti theft problem
1990 Mitsubishi Eclipse....Engine Sputters Under Load...DSM woes
1990 Mitsubishi Eclipse....Sputters under load
im thinking
hhhhheeeeeeeeeellllllllllllllllpppppppppp me please
big ass problems with my 95
4g63 the ignition timing
SParkin Problems
Interior Lighting Problem
EGR Problem. Threw a CEL
4g63 eclispe
hey
idel adjustment problem 2000 eclipse
causes for SRS light
Idle Adjustment 2000 eclipse
engine swap
Timing Problem
weird humming/rubbing noise
Bad News... Again
1997 Eclipse Spyder Headlights
oil temp gauge dont move
clutch
post tps replacement problem
Fuse blown?? Please help
No spark....plz help
Please Need To Sell Car And Now Car Wont Start!!!!!!
Getting the abs code?
swapping parts help
Blinkers...
maybe someone can help me with weird problem with steering
no compression no spark
battery dies every morning
Burning rubber makes my car jump...
Recirculation Problem. PICS!
ecu
oil pressure wires?
Srs Light Wont Go Away
pop then brake problem?
Car wont fire
93 eclipse gs question=
Gutless over 4500rpm
Serious ignition problem 95 eclipse NT
tsi wont start
No Spark No Fuel No Start
Tire Rubbing
is it some type of throtal problem?
Warning lights..
please help with timing belt
oil loss - engine seized
Trouble Starting
low idle, check engine light, choking
I Need Help!
cant drive with any boost
2.4L question
What the heck went wrong with my car.
Flashing Ebrake AND Battery Light
Changing the Timing Belt/Waterpump
Eclipse GT multi center display dead...
2003 Kia Sedona Battery Problems
99 eclispe
stumbles on acceleration
91 turbo eclipse wont start
car wont start
eagle talon - no idle, car stalls at stop - please help!
engine problem
wtf car DIED on me New eclipse owner
92 Talon ES auto won't turnover
1992 Mitsubishi Eclipse
Can someone answer this
damn emissions problems
Car Belt Squeels
Broken harmonic balancer
is this a good fuel pump test?
Blitz Boost controller settings for DSM?
1st to 2nd gear!!!
Security System Problem?
Identify this part
2G ABS computer Wiring Schematics
1999 Eclipse Spyder Convertible - Top Won't Drop
Wtf???
Check Engine Light!!
white face guages install problem!!
40 or 60 liter (10.5 or 15.8 gal) tank?
Tranny Prob
engine
electrical
Syncros?
92 eclipse gs-wont start, got spark
To fix it or blow it up?
ugh more radio trouble
boost leak??
problem boosting??
Throttle Positioning Sensor...bottom screw!!?? help!
alternator/power output boost?
Car starts and idles for 5 sec. then shuts off????
rough idle help!?
Warning Lights ? ? ? ? ?
multiple problems with my at the same time
Damn check engine light
power loss
Oil filter housing problem
what do i need to turbo?
18 mpg black smoke out exhaust
What's my problem?
tail light problem
Tail Lights Dont Work
Possible Broken Rod
no cold start
TPS code. What should I do?
92 Eclipse GS broken?
91 TSI AWD Problems
91 GS-T Misfiring
Problem Under Hood Please Help
greddy type s bov
p1294 target no reached
Problems with my 94 talon sohc
Automotive Network, Inc., Copyright ©2013
