Mitsubishi
Eclipse/Talon/Laser
> Eclipse Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Ecu Probsss
squealing noise
wheel bearings (FWD)
Hose size ??
Water Logging...
Transmission
Dumb electrical int. lights problem
GSX missfires?
So the problems begin...
Need to tighten Handbrake
What is this noise,listen see if you can hear it
Stereo problems...
Will New RCA's Remove Alternator Noise?
I need a vacum diagram for my 95GSX
loose rpm when i hit the gas.any idea
Oil pressure
95 talon overheating
Cracked head????
Crank Walk symptoms? Do the 1.8's do it?
What kind of motor is this?
I need a tourque sequence
exaust leak or loose clamp
Having problems with my 1996 Eclipse RS
Clutch Slip
Need help port polish??
car smoke after boost leak test ?
STALLING eclipse 2.0 the answer
95 eclipse wont start wont run
95 eclipse wont start / run
turbo not spooling!!
plugs keep turning red
Loss of power/ car sounds like a suby
Mystery part in engine
Im about ready to get rid of my car!!! I hate this money pit
Transmission Problem PLEASE HELP!!
I really need help with a 4G63 no spark!!
Need some serious help with no spark!!
car sputters
having a wee bit of a problem.
Sound driving me crazyyyyyyy
tsp/ PCM
Door triggers
Possible power steering/hose problems? I dont know :|
Engine Rebuild not working
a/f ratio gauge help!!!
98 Eclipse Cruise Control
Exhaust manifold gasket
My 95 , talon.
Boost controller install problem/question
Dont know whats going on
Oil Pressure Problem
420a bottom pully
engine hits wall around 6k rpm, not sure why?
Some quick ??? about the GSX
Heater, Air Conditioning Fan won't run
If u love Dsm you will read an help
Temporary Headgasket fix...
New clutch, problem???
Is satan is only place to trust for timing belt change ?
Does this mean blown turbo seals or what? I just cannot figure it out!
stalling out please help
Tick Tick Tick
engine problem
in line fuel filter???
SAFC tuning
coils packs for 1gs and 2g's
car throttles high rpm when I let off gas
Rb Clip?
overheating
Fuel Pressure
crank sensor
Alternator Wiring Harness
ignition moduel
Radio Power No sound???
Bad Alignment?
Is there something more to this problem than what the seller says?
Valve cover and Oil (2G)
Check Enine Light
air conditioner problem, leaking water inside
no spark
Tranny problem, where's reverse?
cooling fans
1.8L Lifter Noise
Please help Car Stalls
Backfire... lots of smoke
Clutch problem. no pressure, wastes fluid!
Exhaust Stud Problem
'97 Eclipse RS, "Belt Shredder"
crappy idle and diagnosis..
help ASAP, melted fans :)
Charging system problem
92 Eagle Talon 2.0 No Spark
W-t-f......oil Leak
oh boy- i messed up big time
Weird TPS and IAC and TB problem
Isc/iac '97 Rs?!?
Another thread white smoke !!!
Engine wont start
Boost test + vid Still a problem though???
Just bought 92 laser
ECU problem?
check engine light
crazy problems
Oil pressure, oil pump ?
ticking
white smoke
Car runs perfect for 5 minutes then dies?
backfiring or shooting fire?
Haynes manual for awd
Lower timing belt cover
Cleaning the head with springs and valves on
a intercooling pipe problem maybe?
LOW RPM AT IDLE After Timing Belt Change
idles good until it warms up
clutch making weir sound ?
92 gs n/t
Bov
ECU Differences from 90-94, the thread!
More Input on third gear please
Turbo boosting problem. WEIRD!
Resistance of plug wires?
A bit rough in at idle when in gear
Lose power for 1 second...
Car died, started later, died again
Egr Valve
problem starting 97' gst
They say I threw a rod
how you do boost leak test again ?
Found the MARKS!!!
Turbo Timer
Im feel that I loose alot hp
Timing Marks
Turbo timer keep turn off ??
3rd gear
Oil Light
i have asked before but cant find out how to do it.
A/C Belt
1 and 2g interactive engine parts location
My dealer is fix my transfer case, help choose gear oil.
one of my lights is one help!!
Bad Problems
Squeaky Brakes
funny sound (cooling fans?)
bad electrical problem, help
Bad Electrical Problems
Engine revs high
It simply won't run right...
New to DSM, need advice :( input shaft sleave?
Rattling under 1200 RPM
No boost, No leaks? Lost! All vacum
Bad news right before college....
Need to buy online
Greddy turbo timer install.
self AC recharge kits
Its ok ? ( wheel fitting )
Alternator
Poor Performance/ killer Gas Consumption
Oil Leak
orange light comes on at high rpm
Cranking no Starting
No Plugs for talons
1994 talon tranny problems
Alternator Belt
electrical problem....
96' Talon Tsi AWD Backfire
No Spark
Car Stalling and idle problems
Boost leak test result......
slow start 1990 eagle talon
instaled FMIC today.
Gettin sick of this
EVAP Canister
Need help asap with boost leak tester
poor idle
Oil leak from manifold
Loud ticking or grinding from tranny
WTF!? DSMs are sooo wierd.
Need Help!!!!
Belt too tight??? smoking, low idle, and CEL???
Lose wheel studs?
bad Mass?
Big timing issue
high idle
URGENT HELP !!! soooooooo close
Vibrations from underneath
o2 sensor
cruise control help
99 Eclipse Rag Top leaks
Knock Sensor
2003 Spyder GTS
Need an oil press. sending unit
Have results from compression test..sound pretty good.
Need help with Compression Test and Boost Leak Test
I need help with this damn front o2 sensor!!
Broken bolt in block
Boost problem
02 sensor housing and 2.5" exhaust
98 GST Engine Grinding Noise
lifter problem
lifter problem
Blinker Light..
Loose windows
Power Steering problem - not pump :(
EGR Vaccuum lines...
Starter Question
I Can't seem to locate the fuel filter
Rod Knocking... mmmm fun
What is this for??
bov question
1995 Mitsubishi Eclipse dies on Interstate at 75MPH
How to stop vibrating
possible to swap a 1991 auto 2.0 for a 1994 5 speed 1.8????? please help!!!
Well the car is in...and their are some problems.
Talon wouldnt start, Ecu possibly?
Halo Projector Lights
External Oil cooler elimination?
The parts are here!
transmission
car Won't start
IAC and TPS..should i change both of them???
Compression test results...
changing crankshaft bearings?
Running water sound
1g 4g63t head
So she runs, now for the problems.
95 Eclipse NT no spark/no fuel FIXED!
what the hell is this noise
To all the DSM wizards
Question about Power Steering Line
eco/wiring harness?
Balance shaft spacer?
Damn whistle in TB... STILL!!
The overheated thread
my type s bov sound like crap, its broken ?
Pinched lower radiator hose
420a Smoking
GSX driving me crazy
Seafoam 4g63 T
Balance shaft removal tomorrow
Over heating problem
Symptoms of Worn Piston rings?
Unplug clutch swith
Anyone good with electrical wiring?
6 bolt TPS swap...
valve cover bolts
help install triple gauge pod .
Coolant
I cannot figure out where this plug goes!!!
Transfer case recall !!
I think my ISC ( IAC ) busted,
