Our Community is 705,000 Strong. Join Us.
View Full Version : Eclipse Problem Diagnosis
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12
  1. 1G talon gauge cluster, not working. HELP
  2. car cuts with boost
  3. Need some help with my chrysler cirrus PLEASE!!!
  4. Idle problems after tune-up.
  5. reverse lights and horn help PLEASE !!!
  6. Problems....:(
  7. quick starter question
  8. smoke problem?
  9. New To DSM's
  10. Electrical - Rear and interior lights.
  11. 96 talon esi coil pack connector????
  12. DSMLINK problems!! HELP PLEASE!
  13. Back up lights help!!!
  14. Got new outer tie rods...
  15. I'm f'n starting to hate my logger!!! "no rev" error??
  16. Transmission kicking... not moving
  17. Help identify this sensor
  18. What else could it be?
  19. 2000 rpm idle?
  20. one quick question need answer before I go out.
  21. Still with my problem. Moisture?
  22. egt gauge problems
  23. Check engine light, smoke, worse gas miles, bad o2 sensor ?
  24. vibration problem
  25. Transmission Bolts?!?
  26. Brake Problem.
  27. The Wh***
  28. Piston ring and head gasket size
  29. ignition coil help
  30. Emergency timing problem
  31. Fuel leak
  32. 1993 eclipse bumps while hitting 10mph mark slowing down...?
  33. Possible Wastegate Issue/Boost Leak
  34. grey smoke from talon esi??
  35. What should I do?
  36. And is dead
  37. idle problem
  38. My friend car, dont event tell me to go honda forum.
  39. Car Shuts Off While Driving?!!!
  40. my very last tranny question.... hopefully
  41. Spark Plug Wire Diagram 1994 Mitsubishi Eclipse 1.8
  42. Is this a good TB and TB stuff?
  43. oil leak!!
  44. running issues
  45. spider transmission
  46. profec b help
  47. ran out of oil PART 2
  48. throttle cable adjustment
  49. i got a problem with my code. can anyone help?
  50. ran out of oil
  51. talon turns off once warm????
  52. starter relay
  53. Idle problem
  54. Vacuum?
  55. Blue smoke after boost
  56. Aftermarket fuel lines
  57. Got a couple of things.
  58. idle that stays the same when shifting
  59. Odd Clutch Master Cylinder Problem, Please Help!
  60. how do i fix this
  61. Burning Oil
  62. Won't start :(
  63. Stutter when acclerating hard.
  64. Weird idle.
  65. $1,000,000 if you help me spool!
  66. Mass AIR Sensor problems
  67. crank sensor problems!!
  68. my 95 talon won't turn over and start
  69. tps
  70. Clutch master cylinder blown.
  71. Lame tranny question.
  72. cold nature
  73. '95 tsi awd 6 bolt swap. Need Help with a no start.
  74. If it isnt one thing its another
  75. DP rubbing on oil pan
  76. Installed FMIC GOT PROBLEM
  77. Speedometer not working
  78. turbo timer acting up
  79. CV axle issues.
  80. turbo problems
  81. really low rpm's
  82. removing o2 sensor
  83. Bad Outer Tie Rod
  84. Removal and installation of 1G driver side lower ball joint.
  85. P1105 DTC Dual upper alternator fault
  86. Weird electrical problem
  87. my 16g keeps blowing vacuum lines?
  88. Problem Installing Fuel Filter
  89. spark plugs
  90. spark plug problem
  91. Stroker fudged up !!!
  92. I need Help!!!!!
  93. Auto Transmission Ques: code: p0734 gear 4 incorrect
  94. turn signals and dash lights
  95. 1994 Talon tranny stuck in "limp mode"
  96. loss of power
  97. tranny problems
  98. Wiring
  99. !Help! please, snap/or/pop noise when turning???
  100. 1999 gst lights all blinking
  101. The Engine on my eclipse shut off and wont start back....help plz
  102. click noise ?
  103. Engine bolt specs.
  104. What is this belt ?
  105. Oil all over the road! HELP!
  106. What happent if you strip the valve cover threat ?
  107. I"m back.help with ISC & Speed sensor
  108. 97 Eclipse RPM Gauge
  109. Black Oil.
  110. Where I can buy this cable ?
  111. Downshifting into First
  112. I need help with my Talon!
  113. bad alternator or voltage regulator??????
  114. 98 Eclipse GST - smoke
  115. Bypassing knock sensor
  116. Trouble Codes
  117. My Transmission Problem
  118. CHECK ENGINE LIGHT - Fuel Trim Malf.
  119. Need Help!!!!!!please!!!
  120. Help indentify which is right way to install TBS !!
  121. Couple question please answer !!
  122. turbo balance
  123. How can my 700 mile pcv shit the bed that early ?
  124. Trouble starting
  125. Dead Transmission
  126. 1g ecu question
  127. Help, I just bought my first DSM
  128. bolts for exhaust manifold to turbo
  129. Problem
  130. no fuel comming out of injectors
  131. What to use to clean the valve cover ?
  132. Clutch fitment
  133. bolt problems
  134. Cold start problems
  135. '92 Talon - No Tail/Dash Lights
  136. Got money to fix one thing, what is it tho?
  137. Fuel Filter need
  138. What is knock and how do you know if you have it?
  139. Really crappy acceleration/power on 98 eclipse
  140. Bleading a clutch
  141. Serious Car Problem
  142. Clutch assembly or transmission?
  143. Minor Problems...Maybe...
  144. Crank Pulley
  145. 95' intermittent idle
  146. Something missing?!?
  147. Need Help ASAP... Something went Terribly Wrong...
  148. Oil filter keeps comming off...
  149. What is these cable are for ?
  150. Really need some help on this one!!
  151. Little update on coolant and heating...
  152. Power window stopped working...where's the fuse?
  153. Fuseable link
  154. car wont start
  155. Oil comeing out of lower ICP
  156. white smoke comming out...Do you no why
  157. heating and overheating problem?
  158. Planning on getting an eclipse
  159. Car start then die ?
  160. Back tires are rubbing up against the fender! HELP
  161. question about bov
  162. clutch not catching
  163. ticking 92 eclipse gs 2.0
  164. Heat, or lack of...
  165. Lug nut stud broken. HELP
  166. turn signal issue
  167. Help with throttle response plz!
  168. Confused about motor
  169. SRS light
  170. Help with my 95 talon please
  171. Engine Temp Problem
  172. Couple questions about 97 GST
  173. Replacing a T-25 what do I need?
  174. Car Stutters after switching gears
  175. Coolant problem!!!
  176. Need help working kinks out of the GSX
  177. Eclipse Gst-
  178. Transmission fill plug problem
  179. confused....
  180. i really need some help...please
  181. Engine swap problem
  182. 91 talon engine problems
  183. Need help with new tranny.
  184. Turbo install help
  185. Tune-Up
  186. intake manifold leak
  187. catylitic convertor = engine problem??
  188. just a few questions on crankwalk
  189. Help!! Need your expert advice!!
  190. Help!! Please go to this post ASAP!!
  191. talon blues
  192. engine is out now some questions.
  193. NEED HELP FAST! Leaking Fuel Filter
  194. problems with my friends car help !!!!
  195. Turbo Problems
  196. Kinda wrecked my car. Need some help.
  197. car running ruff willing to give away
  198. car running ruff
  199. 98 GST Spyder is boggin...help!
  200. I Found It (idle Problem)
  201. can fuel cut mess my internals?
  202. Car problems
  203. Swapping ECU's
  204. Black smoke = annoying
  205. Black smoke = annoying
  206. arlam problem
  207. Power steering loss !!!
  208. Help??? anyone...?
  209. boosting problems
  210. AFC Settings
  211. Haveing some probelms with a 1996 eagle talon PLEASE HELP!!!
  212. Throttle body nipples
  213. 95 trans sport transmission help
  214. Driveshaft Bearing
  215. Water in Coolant Resivior
  216. anti-theft
  217. wire hanging down
  218. Very confused!!! Need some help!!!
  219. Transmission on a 93 non turbo 2.0 eclipse, very confusing
  220. My BOV thread is strip
  221. 96 Talon
  222. timing belt
  223. Whistling from aftermarket intake
  224. throttle response...?
  225. Oil pressure problems
  226. Tranny Problem
  227. lots of codes after rebuild
  228. Eco/power switch...WtF?
  229. Cant get axles on transmission
  230. Big Problem
  231. Dipstick and oil leak
  232. How Do I Install Covertible Top??
  233. Starter problems
  234. Ecu Probsss
  235. squealing noise
  236. wheel bearings (FWD)
  237. Hose size ??
  238. Water Logging...
  239. Transmission
  240. Dumb electrical int. lights problem
  241. GSX missfires?
  242. So the problems begin...
  243. Need to tighten Handbrake
  244. What is this noise,listen see if you can hear it
  245. Stereo problems...
  246. Will New RCA's Remove Alternator Noise?
  247. I need a vacum diagram for my 95GSX
  248. loose rpm when i hit the gas.any idea
  249. Oil pressure
  250. 95 talon overheating
