Our Community is 705,000 Strong. Join Us.
Mitsubishi
Eclipse/Talon/Laser
> Eclipse Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
Clutch Pops
Car stalls randomly, please help!
DSMLINK won't be recognized
Thinkin I got a boost leak.
idle surge
Potential Boost or Fuel problem
1990 TSI AWD no headlights no horn
clutch master cylinder bleeding
No headlights, No Tach?!
Slight overheating...Possibly FMIC
D.o.a
Someone hlep me please... Car running very poor.
1996 avenger power steering Belt
Alright! IM BACK! :(
Valves, not seating?
Car starts and dies after 5 seconds
Dead time
P0505 & P1698
battery?
Does the AC Compressor require Freon to turn on?
need help fast !!!!!
Cranks, No spark, has fuel.
Hesitation; such an aggrevation
click clack
95 RS fuel/air problem
IAC Location
Alternater or battery?
Tranny Problem?
clutch problems?
Oil disappearing
P1294 and starting issues
P1294 and starting problems.
Power Steering Question
91 Eagle Talon AC Retro Kit?
idle problem
Restored Power?? Getting Hairy!
The Conlcusion
electrical problem?
92 Eclipse Dies whenever it wants ?
1997 Gs-T Help
no spark, no fuel
JB Weld to fix cracked turbo
95 Eagle Talon Esi A/t Has No Spark
water cooled oil cooler
definatly getting a new engine
Clutch / trans nightmear
When it sits, It wont start???
Car shut off while driving, starter not engaging.
need parts
Speedometer isnt Working
Idle Control Valve?
synchro
major oil leak???seals or what?
Door handle just broke up :-(
EGT probe problems
Autometer Gauges off, big time!!!
transmission problem
extremely low boost
electrical problems....please help
idles bad with a/c on
1997 Eclipse RS oil leak
96 Eclipse Randomly Stopped Running PLZ HELP
vibrations
My door lock is broken
Fuse keeps blowing...HELP
pulling the ECU
Gonna port my 02 who's gonna help me
91 GSX serious electrical issue! Please help!
HELP!! 95 gst stumble problem after warming up
Wobble in steering
clutch
Real Bad Idle And Runs Like Crap
battery or electrical problem? -_-;;
lower control arm balljoint
please help, drivetrain issues
Power Doors Problem
Really Bad Idle
need help with P0443 Engine code
no boost after evo 3 install
lock up, now bad noises
EGTs are too high!
1994 Mitsubishi Eclipse Horn Problem
i need sooo much help!
boost too low
|Where did you run the re-wire wires :)
Evap System
so im ready to get flammed.....
Car troubles
Electrical Problems
new car finnally question?? HELP!!
finnaly got the car!!!
popped turbo return oil line
acceleration sucks
carbon build up
Eclipse Stalling While Driving
will these neon parts fit/work on my talon
problem with engine cutting out
car cuts out at higher rpm/speed NEED HELP!
Vibration in steering wheel
starting issues
93' Eclipse Turn Signals Wont Work?
98 Eclipse Fuel Pump won't run
Fuel System Question
96 eclipse rs backfire when gave gas
GSX Squeaks in reverse NOT THE BOV HELLLLPPPP
96 eclipse rs 2.0 auto non turbo
Just a quick question....
piece of shit
Auto Transmission Lower engine to transaxle bolt
Need some wire harness help PLEASE!!
what sensor or switch is this?
Oil Cooler
air conditioner (92 tsi awd)
Not The Update I was hoping to Have
Boost leak, quick response please
car goin crazy
idle surge...
Tranny question, IDK what it is...
Hesitation at low RPM's
Bogging down
No heat
93 laser 2.0 nt tranny
Lower control arm...HELP!
coil question
squeeky suspension components
I have no idea what the problem is.
brake lights on all the time
ok got the no start thing......
95 Talon Turbo- Low oil pressure
Back window light
Car Doesn't Start In Cold. Changed Alot Of Sensors
Compression Problem
clutch grinding...
real quick question
95 GS-T weird spark prob....
can't seem to figure this out????
ECU problem??
Tranny Problem help before i buy
Need help with BUMPSTOPS/shocks asap
Again the Car wont start....
Power steering question...
is this normal?
OBD2 conversion.
is Low control arm balljoint recall ?
oil leak
1992 mitsubishi eclipse 1.8 L HELP PLEASE!!
Oil fouling estimate
Car shut off because I blow the BOV pipe ?
rs turbo
clutch -.-
air/fuel signal?
mileage meter
Camshafts
stage 2 clutch?
Car runs with no key
please I really need help fixing this problem
98 gsx squeek when downshift
Alternator Electrical Harness Plug
talon transmission help
Can You Help Me With Some Idle Problems?
94 talon es
Gauge light fuse keep burning ?
95 Eclipse Wont start!!!
Camshaft Problems
Eagle Talon 93 headlight issue
motor
Help 95 eclipse head on a 97 gst
Well, the datalogger doesn't even work.
91 Headlight mounts stuck open
Is this NORMAL?
02 sensor question
1g bov gasket ?
so many problems -.-
Coolant getting pushed out of system
jerking
Where is the Cap?
plugs + wires?
battery lite comes on and oil leaking
97 eclipse turns over but wont start!
while everyone has the clutch on the brain...
Trany wont go into over drive
Need help ~ 92 1.8 (distrubutor)
a couple of problemss...
Could 2.4 Engine Suffer from Lifter Tick?
Car running like crap (possible vacume leak) PLZ HELP!
are the problems ever gonna stop?
speedometer
iat sensor
1992 Eagle Talon getting no fuel
Does anybody have a clue with this check engine light code?
95 talon idle problems
grounding biss
Serious problems? or just being a bit paranoid?
420a won't start
cooling fan rewire problem
96 tsi tranny Question....plz help...
Drum Brakes - Cannot remove rotor
Oil Pressure
car cuts out when it starts to build boost.
whats my options
Another problem
Odd Problem.. runs good; rpms inconsistant; cuts off
ok so i have no sprak
My clutch can't decide if it's slipping, or if it's okay.
Recent Rough Idle and Low RPM problem
transmission swaps
reverse lights
code 3 on eagle talon (don't understand)PLz help
It wont start at all!
Clutch... DAMN IT!
problems starting cold
Problem Need help quick
gvr4 smoke and idle problem
gst feels like hits rev limiter at 4500-5000
Power Steering Porblem...
Check Engine light, 3 code
Fuel Cut
How to bench bleed brake master cylinder?
Oil leaking from PCV hose
trans/throttle problem?
1999 gst
My 96 eclipse wont start
turbo leaks.
95 Talon TSI Lean issues
4k rpm rev limit on hot days?
Will not start, no signal to injectors
Weird Suspension Problem
wiper problem
tps check engine light
'96 Talon oil dipstick
No spark?
timing belt replacement
No heat in bro's Ford bronco?
talon esi runs rough, light spark on 3-4 cylinder??
HELP ASAP! Missing balancer belt!!!!!!!!!
I need help
I Need Help!
Clutch/trans question
97 GS headlight bulb
My Problem... yes that's right... again
Trans. no reverse or neutral....
Possible overheating?
boost is low.. so i think..
Running Extremely Rich
Car died while running now it wont' start?
New DSM, some boost leak and other problems
Car wont start help!!! ECU problem
Vacuum and Starting...
1G talon gauge cluster, not working. HELP
Automotive Network, Inc., Copyright ©2013
