Our Community is 705,000 Strong. Join Us.
Mitsubishi
Eclipse/Talon/Laser
> Eclipse Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
96 talon esi auto wont start... help please.
96 rs with start and idle problem
just picked up a 1992 talon...wont start
sqeullingwhen i start and stalls when downshift or stop timing belt?
Going to fix drop-to-idle Problem
Check engine light on? Here are the codes
Black Smoke from Exhaust
97 mitsu eclipse gst P1105
squeeling problem
automatic transmission probelm.. =(
Running really rich!!!!!
DSMLink problems!
How many drive belts are on a '93 Talon
how do i adjust a 95 talon shift linkage
well shifting into second it sometimes slipps and pops out
Yet another tranny problem thread...
tranny issue...
My GF's tranny problem
Heater not working
Need some help with ECU
Tranny probablem
Fuel Flooding problem???? Help!!!
95 eclipse non turbo wont start..only runs on #4 cylinder!
Idle issues again
Help! ignition coil!
clutch -_-
Powersteering Pump Fittings
PLEASE HELP! 1997 eclipse no spark after engine swap
Rack & Pinion Steering Hard?
my new car is jacked up
More probablem please help
P0420
No cam sensor in head???
Ugh...CEL - P1487
No Spark?
hmm..Bad idle and sputters to a cut off when I stop.
what pound injectors do i have?
Low oil pressure and clumps in oil
Radiator
PVC Pipe Moisture
Cam Angle Sensor?????
My Car Died???????
1g head 2g block wont start no oil flow
What you think starting problems...
2g to 1g head swap, won't start any ideas??
98 GS-T Blown Engine?
Check engine And car useing up alot of gass
93 Talon DL Transmission Problem! :(
Vlave Cover Gasket
The problems never end
I Broke something at the track
Plug wires flashing?
Ran into a few problems while tuning
replaced knock sensor code 31 still pops up
98 GS-T Spyder top problem?
no start, no spark help!!
Ram Intake
speedo problems!
Karma?
93 Eclipse no spark
gear box question...... F5M22 galant
clutch pedals goes to the floor?
Brake light fades in..
Want to die...
No Light!
AWD Help
need a beter starter for my eclipse
1.8L Oil DRIP
car will not start
Service Engine Soon light
car wont turn over
non-turbo2.0 to turbo 2.0 swap..NEED HELP
lots off problems whit my eclipse
98 GS-T misfire/backfire
o2 data help please!
Window rattling thread?
96 talon automatic trans problem
Alternator Belt, 98 RS
Will start but will not run
Wont start, no spark
Is this a broken tranny ?
Where is the signal turning flasher unit??
fog lights
Please Help!!! Turning signal doesn't work!
Connection Missing
1995 talon TSI over heating
when will it stop
clutch is acting up
this is messed up
What the heck is supposed to be there?
Help Please
Car wont start, help!
Fried my car battery while giving boost
Strange Rpm drop
Car dies after getting on it???
Engine stalls when clutch is engaged
Another WTF moment
EGR block plate HELP
Last Problem on Purchase
Tach Sorta Responsive
always push start
Glow Guage Backrounds
N/T block Knock sensor location?
headlight adjustment
1996 Eclipse down shift problem
Crank shaft pully
Tach Issues...
None Beaded Pipes
help please
Another stupid question about 96 rs
Is my powersteering out??
2G Transmission problem 5sp AWD
bov constantly blowing off
please help, boost problems
(pulling My Hair Out)
Weird problem, need some expert advise
AC Knocking?
gears
Blue Smoke From Muffler
oil pump problem
96 TALON ESI Idleing problem please help
power steering pump pulley problem
idk wat it is!
Crazy Rad. Fan
open atmosphere
Boost Test
help pls! T.T
No power
95 Eclipse RPM cycles during idle hot
Cooling Fans
Question about my laser
Rear brakes making noise
Car alarm goes off whenever door opens--started today
Weird idle Probablem
Eclipse 97 gs AT
won't start
bypass thingy?
Valve clearance question
93 talon making a clicking noise when i start it
j pipe problems
Help no oil pressure
Please help!!!
Boost question
TPS Code/hesitation/power loss/boosts good
Help Another probablem
biss valve
Axle nut removal...HELP!!!! THIS IS HELL!
Tech help with main fuel line
p0700
messed up 95 eclipse gsx
possible blown head gasket
Boost doing funny things... boost spike?
will not run after start
ECU the problem?
clutch dropped to the floor
Fuel cut off
A big problem
Car loves to run HOTT
Need help rewiring after motor swap
1st and 2nd gear problems
need help with gsx lots of ecu codes coming up from scanner
93' Eclipse GS MFI Fuel Relay Keeps Shorting Out.
95 talon turbo awd are crank walks hard to install
My car Stutters, hesitates, has a bad Idle,wont boost, or is just acting funny!
Keeps popping out of 1st gear
92' Talon Randomly Dies...
poor performance 2500 - 3500 rpm
95 Eclipse Lopes At Idle
my fog light buton is pushed in
vacuum problems??????????
holding new cone filter in-place
flex pipe leak need an easy fix
horrible idling problem
my convertible top button wont work!!?
How to do it yourself?
getting the coilovers off my shocks...please HELP
I'm baffled, problem running right off the bat but it runs great afterward... help!
Coil replacement in distributor
car starts then dies 2 seconds later clicking noise under dash
No Spark????
blinking light
95 Eclipse no spark how to check coil??
dont know
idle speed control
smoking badly
3sp auto W/od stuck in 2nd
vacuum leak
problems
possible valve adjustment issue...
Window Problem
Cluster lights don't work. '98 RS
??Engine Code??WTF??
help?!!??!?!
Turn Signal
completely stumped
1995 Eclipse OBD II Compliant?
i cant get my trany out!!!
Check Engine Light Flash Code Translation
rear "brake backing plate"
96 Eclipse
95 Gs-T keeps blowing 30 amp ignition fuse
Question
headlight wont work
first time changing alternator
i dont even knowww!?!?!
Throw out bearing?
Turbo eclipse 420a vacuum lines
Shifting Problems...
Need Help to change the Starter
Calculated load?
Wastegate issues
My 1994 Eclipse Will Not Start!!!!!!
No dash lights?
Convertable top?
WTF? Code P1400?
transmission problems
MPI fuse Keeps Blowing
MPI fuse
quick tranny question
Why does my alarm keep going off?
not exactly sure as to what problem is...
oiled head
All my lights are flickering
Help!!! Muffler and mirror questions
Transfer case leak....
Rattling from Cat
no clutch pedal !!
Checking SAFC?!?
need a 420a engine
Talon ecu trouble
1995 talon tsi trouble
electrical problem?
97 GS-T Studders/hesitates While Boosting
How to make 1g or 2g oil return line fit?
Rear motor mount feels too loose!
don't know where this hose goes
Slave/master cylinder problem?
runs rough
look im havin problems...
Running Problem:( Please Help!!!!!
93 Talon DL Cooling Hose/Line? Help!
Same problem, different day.
Electrical problem? Sensors, ECU?
Back brakes locking up
HELP! Positive terminal and wires are VERY HOT!
Engine Turns, Has Spark And Gas Wont Crank!! Please Someone Help!
Rough Idle / Hard Start / Can't find Fuel Regulator
Big 16g oil return line
Vacuum question
Automotive Network, Inc., Copyright ©2013
