Our Community is 705,000 Strong. Join Us.
Mitsubishi
Eclipse/Talon/Laser
> Eclipse Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
91 eagle talon, high idle, tranny stuck in 4'th
90 TSI AWD turns over no hit?
92 talon tsi awd, starts&dies horrible misfire
'96 Eclispe downshifting and dying
96 RS Consistant Problems, can't find the source
trouble starting on a cold start
Drivebelt won't stay on
1991 1.8 eclips no spark
Alternator upgrade?
95 gsx trouble starting
valves
bad hesitation turbo car
1990 Eclipse GSX help
1990 gsx that won fire.
1990 gsx o fie.
98 RS Start Issue
My Convertable top leaks
Oil in Boost Gauge Hose
Noise Filter
oil leak and low oil pressure at idle
slave bleeding problems
Please Help 92' Eagle TSi AWD
1990 eclipse fuel wiring problem
96 talon flywheel problem
'92 Eagle Talon TSi AWD Idle Problem
95 eclipse rs wont idle and hit rev limiter at 3500
96 Spyder starts then shuts off
93 eclipse wont start
96` no heat....
90 laser gst starts then dies. troubleshoot
injectors problems please help
96 Eclipse RS Start issue *Paniced*
Idle Bounces 0-1200
94 Eclipse no sparks
1996 Talon Cylinder Head
1995 ecpilse GS Crazy problem need help with
1990 gsx
Water Pump Problem (NOT SURE) EMERGENCY
Stuck Timing Belt????
Problem with gas gauge.
1996 Eclipse Blowing Engine Fuse
Oil Pressure Light
manual window to power window swap
92 Eagle Talon will not start HELP PLEASE!!!
replaced MAF but still getting code?
rear lights stay on
car runs bad
Car not running well
need a little advice
Jerking when accelerating slowly
Electrical fan problem?
White smoke and no spool up
Remote mirrors will not work
Popping in front end
light comes on while taking turns
2nd gen gsx
speed sensor a
The Push Starting Woes need help to fix problem
Car runs bad
Quick Wiring Question
Leaks
revs at idle
To High Fuel Pressure
running problems.
water pump
1993 eclipse 1.8 L no spark
Went on Road Trip, now feels sluggish at high rpms in 1st
Lock Jammed for convertible trunk release lever
problem with boost and tranny
Oil pressure
No power at all and a weird idle...
1995 Eclipse wont run
engine nock
1992 Eclipse non Turbo cranks and has spark but won't start
logger results help 1st thru 3rd gear pulls
Turbo about to take a crap?
Tach not working, Hard shifting, And oil in the plug wells
HELP: cant fix the CEL light
how to use afc controller
No power to the CAS on a 91 talon.
I know this does not belong here but HELP LOL 96 cavalier
Mitsubishi eclipse 97 stutters and shuts off help :(?
2g Coil Question????
1995 TAlon TSI: Stalls when warmed up
02 sensor location
vss
95 eclipse rs, ready to trash it..........
90 eclipse 1.8L: ecu fried need help
late start
Eclipse Gst Not Firing
eclipse acting wierd
94 Eclipse problems - engine light, rough idle & dies when A/C is on, loud rattling
Yay for electrical!
Clutch problem
oil leak when starting
Gaah friggin B-Joint
Running Hot
Slave Cylinder? possibly??
Preventing hydrolock
My car is sick some advice please
Smoke from exhaust while idling and Check Engine Light
Have to jump every start. Closer...
Issues Continue with my 1996 cirrus!! Open for answers!!
Hopefully my head isn't warped.
Sunroof STILL leaks
Hydrolock Aftermath?
95 Altima keeps stalling.
starting issues
Electrical Issue: Battery or Alternator or ...?
random stuttering at 3000 rpms
shifting and brake problems
Wtf???
Turboed my 88 Dodge Dakota, problems!!
Replacing O2 sensor... super fun!
Throttle position sensor
Do Eclipses break easily?
91 talon tsi no boost after findind heater hose sliced
Trouble Shooting my talon
I had no idea where to put this, 1996 chrysler cirrus help plz
timing job done: idle acting up!
Tranny sticking & wont idle
Check engine!!!?!?
wheel bearing
Bad case of clutch slip - 97 Eclipse
20 psi??
clicking coming from engine!
Still running very rich.
Throttle body repair help
Car Repaired - Now Makes New Noice, They Claim Not From Them
Need help identifying these oil leaks
chewing up belts!
Broke ball joint, Then this
Wont Start help!!!!!
rubber fuel hoses?
cylinder misfire? HELP IM LOST!
90 eclipse 2.0 turbo 5sp rebuild problem
too much fuel in talon turbo
boost leak or something worse?
4th gear stutter
95 eclipse
94 eclipse
Bolt sizes?
Auto Tranny acting weird
Eclipse Starts 1st time not second time.
Installing a new Head. Any tips?
all kinds of problems
95 eclipse sputtering
Uhhh?
o2 sensor/engine problem
sputtering
Turbo problems <STOCK>91 eagle talon TSI
Help!
Timing
eagle problem
Alternator Woes?
just 4 fun
what light is this coming on? 91 talon tsi
Battery dying in winter... update
car keeps fouling out spark plugs timing belt making clickiing noise
How do I set cruise control on a '91 eclipse?
Clatter From The Hood - Tales Of A Serpent!
minor progress!!!!
My Lemon: Exception or Rule?
Idling issues
rewirin a fuel pump
drive belt pulley bracket
91 talon,AWD,TURBO 0 boost,weird idle,help?
Coolant leak?
Weird sound from motor
sputters after 10min of driving only on Hwy
My clutch pedal has no resistance
Blowing intake hose off post-turbo '98 GS-T
Relays????
1993 Mitsubishi Eclipse
High beams won't stay on
Radiator hoses leaking
99eclipse gst problem
heel toe problem
new to this.91 talon?
door wont open
wont start!!!
1998 Eclipse alternator
swap from diverter valve to true into the atmosphere, BOV
grind with fast shift in only 2nd gear??!!
car hesitates when floored,but only at higher rpms
charging Queston for car genius's
lights not working???
Will not start with key only when roll started whats wrong?
Can't fix throttle and Short ram intake question.
95 Talon Rear Rotors
weird pop noise when accelerating hard.
headlights and parking lights, interior lights wont turn on
Idle Concern, Not Problem.
91 2.0L Turbo fuel cut question
Weird EGR Solution
Blown up turbo...pics inside
91 eclipse gs automatic throttle problem
95 Talon - Headlights don't turn off
Boost Problem
95 talon will not start
Can you help me install this?
1991 Laser ECU Question
Everytime I go to work on it I find another block
it would be nice to have spark
Jumped and ran like a champ...
91 Laser no start
420a cranks up WOT, no idle
Electrical problem
1990 Eagle Talon and hard starting
car won't fire
Throw Out Bearing
only getting spark on two cylinders?!? wtf
Transfer case??....HELP
Help, lights on horn comes on lights off and all stays on???
igniton timing
Help me with the 420A!
Blown turbo rebuild....Piston order help.....
98 eclipse clicking noise from rear driver side
4g63 Help!!
1.8 not firing....help!
Heater only works on high... WTF
What is it called?
Eclipse shuts off randomly
Alarm goes of randomly
cutting out.
help plse
Please Help!!!!!!!!!!!!!
I have a Question
Can't find where this wire connects to?
1993 eagle talon ES FWD Non turbo
Stuttering turbo
a dumb head problem.
96 headlight help
Starter not engaging (1992 laser)
help with rear suspension knocking noise
Video Post of my Problem..
starts. then idles rough and almost dies
Won't start without starting fluid?
Another "Cold" Question
Well.....
Rough idle
my 95 talon esi with a automatic. stuck in second gear
Battery Dies When Cold Out
No Start Problem Need Help, 91 Eclipse
replacing timing belt
92 Eagle Talon Problem
trouble starting in winter
p1495 evap code,where is the pump?
No start problem, not easy
No reverse on 5spd.
Automotive Network, Inc., Copyright ©2013
