Our Community is 705,000 Strong. Join Us.
View Full Version : Eclipse Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12
  1. 1g Timing
  2. trans problem
  3. Battery draw
  4. piston ring
  5. 96 RS no spark to the ignition coil...?
  6. new guy with transmission problem
  7. RULES & REGULATIONS On This Forum!!!
  8. misfires, no CEL, no codes
  9. 2.0 Talon What do all y'all think happened?
  10. Need Help 92 Eagle Talon 1.8 check engine
  11. Well Blownheadgasket Turns BAD
  12. engine surge timing ?
  13. trans not going into 3rd
  14. Steering Wheel Problems
  15. oil loss????
  16. How do I raise/lower psi on stock 2g...
  17. What is the best & loudest BOV???
  18. Instrument panel warning light
  19. sudden loss of power
  20. all power cuts off
  21. Surging RPMs
  22. Broke Turbo Talon
  23. Clicking sound in engine bay
  24. Stalling when clutch pushed in
  25. Electrical connectors???
  26. gs to gsx
  27. wont start?
  28. grinding in transmission
  29. CA emissions and my 2GNT
  30. crazy idling
  31. tappin sound through certain rpms?
  32. messed up my bro's car
  33. 95 talon problem
  34. Relay prob.
  35. found out what my squeek is...
  36. Great another Prob!!! (water Pump)
  37. Clutch Problem
  38. Auto Tranny Problems
  39. Weird starting problem
  40. Time for a new clutch?
  41. Turbine Body/Housing YELLOW/WHITE/BURNT why?
  42. A little help needed here
  43. Blower Motor Out
  44. Head Gasket
  45. Cold Air Intake/Service Engine Light
  46. wierd knocking sound?
  47. Problem at 13-14 psi?
  48. Disabling automatic AC with windshield defogger vent in 97 DSM
  49. Car screeching
  50. Big Clutch Problem
  51. exhaust flow interrupted?
  52. Power steeering problems
  53. guage lighting??
  54. fuel filter/injector??
  55. 95 eclipse fault code
  56. jacking points
  57. Help car turning off
  58. Fuel Problem please help me
  59. clutch...
  60. left blinker does not work
  61. heater ducts?
  62. Clutch stuck to the floor!!! help.
  63. Left blinker does not work.
  64. 93 Talon door warning light stays on
  65. 97 eclipse
  66. 92 eclipse gs wont start
  67. check engine light. BCS warning, cyl. # 4 misfire
  68. electrical problems
  69. Creaking noise at passenger window - Eclipse spyder convertible top
  70. MIVEC Problem?
  71. 1g in 2g swap misfiring!!!
  72. NO spartk
  73. check engine code p1494 O2 sensor?
  74. Starting problems when car is warm...
  75. Starting problems.
  76. Too much BoOst...HELP!!!
  77. Weld hole in oil return pipe?
  78. engin cuts out!
  79. Help me diagnose the problem!! (valve seals?)
  80. heat problems
  81. hard starting
  82. auto to 5 speed
  83. coolant light
  84. idk even know wut happened
  85. Idle valve failure on a 93 eclipse
  86. 1996 eclipse GST wont stay on
  87. Boost isn't getting any higher....help
  88. car jurks to the right when going in 2nd?
  89. ticking in dash
  90. anti lock light on dash
  91. EVERYONE READ NOW! change time!
  92. Car shuts off and turns back on
  93. will my 1.8 head fit on a 2.0 engine block
  94. GST stalls in nutrual!! help help help!!! pleeeease
  95. Auto Transmission Problems
  96. eclipse 95 gs OBD II CODE U0E3F
  97. Help Needed Please!!! Please Help!!!!
  98. Autotrans problem
  99. clutch problems!!!
  100. gauge problem
  101. Throwing itself out of 5th
  102. check engine light?
  103. Buying a modded Talon?
  104. wont start
  105. it wont stay running
  106. Engine Stalling at idle
  107. In need of some good help!!!
  108. 4g37 to a clot g37b
  109. 93 eclipse gsx. engine cuts out
  110. eclipse will not start
  111. 95 Eagle Talon ESI high beam turns off my radio
  112. misfiring
  113. alternator problem??
  114. intake manifold noise?
  115. Lock/Keyless Entry Problem
  116. oil leak
  117. trouble with anoying dash warning light!
  118. Does Anyone Has Greddy Turbo Timer On Their Car?
  119. Tachometer don't work !!!
  120. Leaking valve seals
  121. Question about Valve cover gasket
  122. no boost?
  123. violent shaking when accelerating
  124. 95 eclipse(non) does not turn over
  125. Friends car diesels!!!
  126. Oil leak....NEED help!!!
  127. still running lean?
  128. cmp sensor problem/hard starting
  129. Idle Problems....still.
  130. Some high end misfiring problem
  131. i dont know wats wrong
  132. boosting problems
  133. Loose Rockers???
  134. Airbag
  135. Blown Head Gasket
  136. Cooling Fan
  137. Annoying screech
  138. Noise "cricket chirp"
  139. exhaust rattle.
  140. Electrical Nightmare
  141. 96 Eclipse ECU Question/Swap
  142. My Eclipse Wont Start
  143. Turbo Is Puttering Pls Help!!!
  144. Running lean
  145. quick question
  146. camshaft sensor wiring on 91 tsi
  147. mechanic evaluation
  148. 420a cutting out and missing
  149. 90 non-turbo 1.8L
  150. guage lights help!!
  151. Help, Car real sluggish
  152. Transmission
  153. wastegate
  154. '97 eclipse "squeaks"
  155. can you help
  156. Valve cover gasket
  157. 93 Talon starts and dies
  158. 93 talon knocking/oil gauge bug
  159. housing imperfections
  160. engine looping at 1500rpm
  161. power steering
  162. 93 talon engine swap
  163. clutch proablems
  164. can anyone meet up with me and help me
  165. Can Anyone Help?
  166. White smoke or something?
  167. Oil leaking from where the exaust valve connects to the head!!
  168. 95/96 Eclipse Engine Swap = Problems, wont start ...
  169. 1990 eclipse rough idle and blowing black smoke
  170. missing prob, seems like everyone has it.
  171. uh oh, bolt broken...
  172. Starting Problems?
  173. turbo trouble
  174. convertable top motors for spyder
  175. dont know how to get engin code
  176. check engine light comes and goes as i drive, turbo psi fluctuate
  177. weird clicking sound when i push the gas
  178. I just bout 91 GSX having major prob Tranny and Boost
  179. Help!
  180. Droppin to say "hey" and ask some Q:
  181. oil in my spark plug hole
  182. Suspension problems
  183. heatercore -overheating?
  184. NO START..... need help
  185. Airflow sensor
  186. wont run unless jump started
  187. Exhaust
  188. dropped tranny...rear end...
  189. Evap system leak
  190. Problems, Problems, Problems......
  191. From idle, shifter refuses to go into 1st gear. Must do 2nd, then 1st.
  192. Uhoh, Not Piston Rings, Please!?
  193. Trouble
  194. Stalls out
  195. boost controller
  196. valve cover bolt seals
  197. stinky headers?
  198. idle surges and sputtering
  199. Tranny noise!!
  200. what are splines?
  201. need help asap
  202. Clutch Problems
  203. Still having problems
  204. loud POP! not a backfire wtf
  205. Engine Code 1494
  206. Clicking belt
  207. How do I tell which engine this is
  208. 1995 tsi Talon
  209. possible blown head gasket?
  210. Smokin Eclipse
  211. mechanic
  212. new squeak..
  213. spark plug gap
  214. Help with locks
  215. cam gears wont come off
  216. Finding boost leaks
  217. code 1390
  218. ECU codes?
  219. head gasket!!!!
  220. 94 eagle talon
  221. Car wont Start
  222. My second log on 20 Pounds of boost
  223. Talon Turbo putters when boost builds...
  224. What old TB shaft seals look like when bad..
  225. Check engine light
  226. possible crankwalk
  227. rps at idle
  228. exaust rumble and backfire?
  229. snap on modis as data logger on 1g?
  230. Little pop sound
  231. code p0141
  232. 91 Laser not won't run.
  233. Trouble code P0442
  234. Battery terminal
  235. My first log
  236. whatts wrong here
  237. random grinding sound
  238. 1996 Gst Problems
  239. cylinder misfire
  240. gs tranny
  241. white smoke coming out the exhaust and oil pressure reading low
  242. ***FAQ*** Read this BEFORE you ask a question.
  243. Boost leak check question
  244. Car Stalling ????
  245. Need MAJOR help. 92 Eagle Talon N/T wont start
  246. Help me out
  247. Bad Gas Milage on a 96 GSX
  248. Eclipse Question.
  249. Question on 95-99 warranties.
  250. Eclipse 4 cyl engine
