Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Mitsubishi
Eclipse/Talon/Laser
> Engine, Transmission and Drivetrain |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
95 Eagle Talon MAP sensor
Auto to Manual - Reverse lights don't work!
Auto to 5-Spd swap, Speedometer no longer works? HELP!
shift knob
fuel pump not working...
can I use my same rings ?
Super-AFC II in 97 GSX
High Idle
Radiator hoses
turbo to non turbo
engine removal question
running hot
Rattling sound from drivetrain
it got a wobble!?! Help.
Timing belt walk HELP!
supercharger on gsx
420a Clutch how many splines? 17 or 20?
dsm problems
2g 5spd shift cable
1995 eclipse 420a turbo AEM F/IC
Spun bearing
Few questions - mainly references
1998 Eclipse 4cyl. Non-Turbo...Going Limp...Please Help! :(
Rebuild parts list?
Mitsubishi Eclipse 10 point bolt
Rebuild for mula
Eagle talon a/c adjustment bracket
1997 eclipse gs engine swap
Wrong diameter exhaust spacer
1g head gasket set
1991 eclipse in limp mode
can I run my tsi without a waste gate?
engine knocking, rebuild?
oil filter relocation
1990 gsx awd componets to a 1998 gst
vc gasket...felpro
1998 mitsubishi eclipse rs flywheel question
Engine burning oil
TRANSMISSION PROBS(contd)
420a arp Head stud torque
stock valve springs/retainers - 420a
starter grinding
Direct port nos injection
exhaust manifold studs
stuck in 2nd gear
replaced the alternator and battery still wont stay on
Turbo question.
Need help with 93 LSD
DIS BOX help
Hooking up tack in 95 rs.
looking to buy 95 GST ??? help
Ignition tune question
Is this the wrong clutch?
ready to pull the tranny
Please help me!
And another thing...
Kinda random...
driveaxles removial?
ordering parts in 2 days... need gear lube
boost problem
Lights flashing at idel and over 3000rpms
Clutch pedal issues and fuel question
5 speed transmission issue
question about replacing transmission
Oversized valves discussion
TDO5H Turbo
Engine swap 2.0 l DOHC
need help
Idle Surge on cold start
sparkplugs cover in oil
Parts Stores keep giving me wrong parts
???I have transmission issues on a 98 Mitsubishi Eclipse Spyder GS 2.4 non-turbo auto
Transmission Dilemma!!
1997 Tsi Clutch Problem!!
Quick water line question.. need it quick
car runs hot
99 gst turbo BOV
'97 eclipse sypder water pump
Clutch Master Cylinder Question
1998 Mitsubishi Eclipse GS-T Questions
RPMs ticking then car dies??
90 eclipse engine
clutch problem..i think
Valve cover gasket Replace
95 talon wont start - no fuel pressure
someone sell me! ...tax return = clutch time...
Car wont start, with clicking noise.
< 10k on new evoIII16g = Fail???
My car won't start -_-
any other known cause??
Clutch for gsx
pizza delivery guy in need of light to light speed.
Squeaky Belt
check enigine light after new intake
AWD to FWD
95 eclispe gsx: will a exedy FWD clutch work with AWD?
have spark but wont start
Self Proclaimed newbie: Quick question...
headwork
Main Bearings for my motor
non-turbo to turbo
Stevie K is addicted to meth...and doesn't need a intervention
Does the 1st gen DMS 4g63t line up with a 95 Mirage
question about engine swaps
starting problem
What Blow Off Valve is this
Engine Swap
1G and 2G knock sensor question???
Questions about where to buy 6bolt...
is there anyway to get better gas mileage?
Clutch and Flywheel... time to buy!
2.5L Avenger Engine into a 1990 Eclipse?
97 GSX Differential Problem
high hp
Wrist Pin Question
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd
2g mas idling
Trans only works in first gear and Speedo dosnt Work
Battery
1996 OBD location
Transmission buzzing. help!
Block Replacement Pdf's? 1999 Eclipse
low cylinder pressure cause failed emissions?
First start question.
stroker question.
Blown timing belt..., what to fix and estimate of how much?
do i need a new engine?
1995 Eagle Talon ESI Automatic Trans problem
Grounds?
question about the stock bov on a 90 ecipse
radiator hoses...
Leaking HG
intake mani and TB?
transmission!!
AWD or FWD with 4G63T
EVO motor in 93 Eclipse
500+ HorsePower
R these cars xspensive to maintain?
Cylinder 4 missfire along with burnt oil smoke
High Idle...still happening
2.0 non turbo timing belt question
4g63 engionge to different trans?
Time to re-introduce, and entertain ideas on this problem
low end (torque)
Maybe a stupid 2G maf to 1G car question??
Ground locations
2 step with DSMlink
Rods
Stock GSX
oil pan problems
ne1 have dyno sheet for gst/gsx with 16g
top speed
94 talon bad idle!!!
got a 92 eclipse and need some pointers
I need help
How to heat car up quicker
Disconnecting EVAP and EGR
help finding backup light switch wiring
450cc fuel injectors
Cast manifolds vs exhaust studs
best synthetic oil for the winter
Transmission problems pls help
Problem with 1991 Eagle
97 eclipse auto trans NOISE
MAF question
1995 Eagle Talon TSi Fuel Problems
Where to find intake manifold studs
flywheel
clutch engage problem
LUK clutch
Straight pipe exhaust
Gas mileage w/o loss of power
Timing belt tension
slipping clutch!!! >=(
Compressor Surge
motor makes weird sound when giving it gas
420a Nitrous
Malfunctioning fp gauge? or not
Wheelspin?
RS-t'd or GS-T
Help Speed Sensor
cop conversion
need for speed
injector id ?
turbo intercooler intake
94 Talon missing once warm
HELP!!!!! 1992 eagle talon non turbo
93 2.0 DOHC Non-Turbo Engine - Power Drop
car won't start
A/F ratio and ignition timing
bucking & mising in midrange rpms
aem fic location
IAC testing
5 bolt flange
Cooling And Knock
head gasket and stud question
extremely high idle speed
GSX conversion to RWD??
need help with tranny
flywheel problems
trans problems
Head Service
timing belt?
Will a 1g tranny fit in a 2g?
2g to 1g head swap
Newb needs help getting a base tune
90 gst idle off idle problem
my idle keeps stalling how do i adjust this to increase idle.
car won't stop being stupid.
New Turbo pre-install
95 Eclipse...p/s leak at rack pinion
Tuning with apexi 2
Tuning apex i afc for my talon
95 Eclipse...idles erratically
Play in front passenger side axle
Swapped tranny, now I don't have any fuel pressure.
Evo 3 16g Turbo
Boost controller
Confused about the fpr
95 talon smokes rings or valves how to tell
Grinding into first and fourth
Radiator cap difference
oil leak
01 Eclipse GT idling problem
Stumble problem, also what next?
talon radiator??
timing belt help
Can I flush my AT passages in my radiator?
Need Help
short shifter?
No Overdrive?!
Melting Wastegate boost hose
need advice
automatic tranny
420a is turbo. need help
automatic transmission oil
Starting Issues
94 Eclipse 1.8...idle issues = timing belt??
First Log!
weird spinning noise 95 gs
Engine Noise 95 Eclipse
I need help on arp studs/bolts
installing front mount intercooler??
95 tsi with crank walk... :(
CEL runs rich
Slave extension
Just got my Eclipse....where do I start?
Engine Rebuild Questions...
Few questions
Web
AF
