Our Community is 662,000 Strong. Join Us.
View Full Version : Mustang Problem Diagnosis
Pages : 1 2 3 [4] 5 6
  1. 01 mustang egr insufficient flow
  2. Step by Step Process: Swapping out an old 87 4cyl for a new 93 4 cyl
  3. Oil blow out
  4. Check Engine light
  5. signal and brake lights
  6. Fuel guage diagram
  7. 86 gt tranny
  8. Clunking Noise on Tickover
  9. Self Adjust, Cluch Cable, Quadrent....
  10. 1969 Mustang when braking car pulls to left?
  11. 03 GT engine sucked water now knocking
  12. 2007 GT - manual trans - knocking noise ??
  13. overheating 66 straight 6
  14. Need help with block
  15. trans stuck in drive gear
  16. Speedometer off...
  17. 99 GT Fog Lights
  18. rear window problem
  19. 1995 Mustang - Violent Shaking into 1st
  20. seems like fuelloss
  21. schematic for light switch
  22. dash light
  23. 1984 5.0 stalled up
  24. dash light problems
  25. Front Window Stain
  26. 95 5.0 dies on cold throttle blip, throttle sticks at highway speed
  27. what part next?
  28. Tired of POS mustang. Just about all together
  29. Overheating PLEASE HELP!!!
  30. 1988 Mustang GT
  31. 95 6 cyl problem
  32. 94 mustang
  33. Vibration
  34. OBD 2 Codes
  35. hard to start, sometime
  36. fuel prob i think
  37. pcv valve
  38. 71 mustang throttle problem.
  39. 2.3L stalls from idle
  40. Odd starting problem
  41. 95 Mustang GT Running Oddly
  42. I have a million questions.....
  43. Found a full list of OBD II Trouble Codes
  44. New clutch new quadrent still wont disengauge
  45. Power locks on 89 lx
  46. Clutch, Throw out bearing... Help please
  47. Unknown sound problem
  48. 2001 mustang GT <motor pinging>
  49. wasting to much gas
  50. Relay swap???
  51. Throttle Body Spacer Problem.
  52. firing orders for mustangs from 65 to 75
  53. Rear brake pads 01 mustang
  54. 94 running hot?
  55. airbag light on 91 mustang
  56. airbag light on 91 mustang
  57. 90 gt wont start, very strange....
  58. 93 mustang rough acceleration, idle, and starting
  59. Problems with power locks-2000 V6
  60. Streaks on window from window seal- 2000 V6
  61. Door actuator frozen
  62. Alternator? 1997 Mustang V6
  63. 95 Mustang No Spark Help!!!!!!!
  64. 91 mustang Gt stalling problem
  65. ford taurus
  66. dim headlights
  67. fog lights aren't working in my 02 GT
  68. please help me
  69. wont start, help
  70. 95 5.0 mustang serious problems
  71. Help! 99 GT keeps killing batteries...???
  72. Anyone seen a harmonic balancer fail like this? '96 V6 3.8
  73. Sporadic Idle With A/c On
  74. Hard to start if its cold only
  75. Starter???
  76. Help A.s.a.p.!!!!
  77. Alt. help
  78. fuel pressure?
  79. Help
  80. 2003 GT A/C, moisture-condensation problem
  81. convertible top wont go down
  82. 2002 Mustang srs Stalling While Idling (It's an Automatic!)
  83. car running rich black smoke timing?
  84. Ball joint problem? PLEASE READ!!!!
  85. 1990 5.0 mustang clutch tranny problems???????
  86. 96 GT blue smoke
  87. 2003 v6 charging problems
  88. Not the smooth ride I would expect.
  89. 89 Mustang 2.3 Bogging Down
  90. 2000 V6 with an engine knock
  91. trouble starting
  92. 98 Mustang 3.8 check engine light?
  93. Steering Help Please
  94. Brake question
  95. 95 3.8L automatic - high idle when in park or neutral
  96. Vibrating Rear Window Defroster
  97. Clutch Replacement ?
  98. Bad vibrations
  99. need timing marks for 2.3
  100. 88 5.0 gt hard hard to put clutch and shift
  101. A/C problems
  102. 1969 mustang steering
  103. simple question
  104. 85 foxbody tranny issues
  105. check engine light on with mustang
  106. electronic ignition question
  107. A/C problem
  108. is this bad?
  109. 05 headlamp replacement
  110. 99 mustang wheel bearings repalcement
  111. Wandering Steering
  112. 94 heater core replaced, still has fogging
  113. 95 GT Convertable Top problem
  114. Idle problems
  115. Emergency brake
  116. Brake problems, and its getting dark
  117. help!
  118. help!
  119. 92 Mustang Covert. Questions..
  120. staying started
  121. staying started
  122. temp gauge
  123. Oil level sensor 91 LX 5.0
  124. Need diagnosis for sudden 5 sp. man. trans. problem
  125. Air Pump
  126. No Spark Please help!
  127. Lots of problems + airbag code!!!
  128. No start!
  129. Vibration
  130. 95 5.0 problem keeping volts
  131. 95 Mustang 3.8 v6 starting problem
  132. Engine Fan on when car is off
  133. need help with new transmission
  134. 72' Mustang Raw exhaust fumes
  135. 93 GT running rough!
  136. Fault code 171 on 95 Mustang
  137. alternator problems
  138. 1995 mustang problem
  139. Door Hinges and Doors
  140. 65 Mustang C-4 Trans Problem
  141. backfire
  142. No spark 1994 mustang gt 5.0L
  143. speedometer adjustment
  144. Is replacing the clutch/flywheel/and transmission?
  145. V6 misfiring badly + lack power!!!
  146. air bag?
  147. water in oil
  148. So why is this happening...
  149. Straight and narrow
  150. Power Steering Problem
  151. How to adjust clutch cable 89 5.0
  152. Wiring Diagrams?
  153. Question about Interior Lights
  154. I didnt mark the Vibration Damper
  155. 1988 LX is running rich
  156. 2000 convertible rear glass replacement
  157. 89 mustang wont start
  158. keyless entry
  159. Blown Head Gasket
  160. 89 GT Convertible windshield wipers stop
  161. 95 mustang
  162. Quadrent stripped out twice whats up???
  163. 97 cobra problems...please help
  164. 95 Mustang 3.8, injector and transmission shift problem
  165. 89 stang;Tranny?Clutch/clutch cable????
  166. carb jet size
  167. 1992 mustang 2.3 ignition coil trouble!!!
  168. help
  169. Shakes it up
  170. Another 96 mustang braking/hub/wheel bearing question...
  171. misfire
  172. problem with my a/c on my 93 lx 5.o
  173. Alarm keeps sounding
  174. Location of Turn Signal Flasher
  175. Reprogram 96'keyless entry fob?
  176. steering vibration
  177. stalling/dis module
  178. 91 mustang lx 4 cyl shakes
  179. No Low Range Power in 3.8
  180. Electrical Problem
  181. 96 GT brakes
  182. 96 Mustang Brakes
  183. 93 Ford Mustang Lx 4-cyl ... no heat.
  184. Help....Transmission Problems 98 GT
  185. bad timing for bad timing
  186. 2001 GT Brakes Problem...
  187. 2003 transmission troubles?
  188. help pleeeeeeeeeeease
  189. radiator keeps losing water
  190. 99 GT post Vortech, cold start problems
  191. a/c - heater vent question.
  192. help it won't start
  193. 2000 v6 will crank, but wont start
  194. How do you remove a door panel to access the window mechanism?
  195. Adjusting tension on drivebelt '91 5.0 V8 Mustang
  196. 1987 Mustang Convertible Stalls
  197. Help with broken Pass power window 94musGT
  198. 92 mustang water pump bolt problem
  199. Breaks Dont Work Properly
  200. convert 1990/302 alternator wires with a 1985 bronco
  201. Trying to figure this out
  202. battery drain?
  203. We've got heat Captain!!!
  204. 1984 Mustang GT Turn Signals
  205. loss of power need help 89 lx 4cly
  206. Carb Problem
  207. help with starter install on 1990 mustang 5.0 lx
  208. PCV valve replacement
  209. Worn synchros?
  210. cold engine tap
  211. 4.6L Cracked Intake Manifold Repair
  212. 2003 Cobra high speed vibration
  213. 93 Mustang LX 4cycl, alot of hesitation
  214. engine seems to be bogging down
  215. ignition
  216. ABS light on and Pos. traction wont work now
  217. engine knock problem
  218. Looking for fuel pump relay
  219. Electrical Problem - Lights & Radio
  220. '95 5.0 Engine Problems - Please Help.
  221. heater problems: I'm stuck
  222. Interior Lights Not working
  223. Clutch replacement
  224. H-Pipe Experts, PLEASE HELP!!!
  225. Power Steering
  226. steering on 4runner
  227. Rack and Pinion
  228. 1986 3.8l v6 lx, spuratic idle/carbon ect.
  229. High Nox
  230. Strange noise: 86 Mustang.
  231. 88 Mustang 5.0 HO LX 5 speed tranny Question Please Help
  232. no signal lights
  233. 1996 gt mustang
  234. WOT A/C Cutout relay
  235. Starter Issue
  236. Fuel Tank Leak
  237. cricket in my truck, help me!
  238. Lights not working
  239. smog problems
  240. Car Stalls While at Idle
  241. Engine code problem
  242. speedometer
  243. rearend question
  244. Need Help-brights Are Stuck On-help
  245. 97 GT clutch squeaking
  246. 2005 Mustang GT
  247. dash and guages?
  248. 302 running prob
  249. will a 1994 V6 tranny work in a 95 gt
  250. A Series of Issues with my 95 GT Convertible
