View Full Version : C/K
- Horn location 91 Cheyenne C1500
- 90 Chevy 2500 Pickup Will Not Idle Hot
- Cat off my Suburban
- '89 Suburban factory lug wrench
- 90 chevy 1500
- 95 k1500 4x4 wont engage
- 89 K1500 starts then stalls
- 86 c1500 fuel gauge
- 91 C1500 4.3L Possible Bad Fuel Pump?
- 88 k1500 350TBI I'm puzzled!!!
- '89 Suburban timing
- 88 chev 5 speed trans
- Coolant flush/replacement
- Reverse lamps inop
- Please Help!
- Pesky Oil Leak
- '89 C1500 front wheel bearings. Drift size?
- low voltage fuel pump relay
- 4L60E transmission slipping
- '98 K1500 Heater - All or Nothing
- 95 k1500 wheel driver side wheel
- lug pattern
- 97 K1500 Exhaust Options?
- 2nd battery in 1997 k1500
- 1997 chevy C1500 5.7L low humming/vibration
- 95 k1500 305 problems
- 93 c/k 1500 v6 heat not very hot
- u joints on drive shaft
- Light Bar???
- Temp At 240 Please Help....
- 96 K1500 wont start
- 1988 Chev PU Clutch problem
- 2000 K2500 Brake problem
- 4.3 Tbi oil pressure
- 5-Speed manual Transmission Fluid Type
- HELP! Bad transfer case???
- will the frame from a 1989 chev halfton fit a 1987 body
- new motor with timing problems
- synching crank sen.& cam sen.99 5.7 vortec
- Cigarette lighter fuse keeps blowing! Help please!
- Transmission
- loud clunking in the front end
- Smoking is worse after valve stem seal replacement on a 350 V8
- Does a GM oil pressure switch serve as a fuel cutoff ?
- Muffler suggestion 91 Silver k1500
- 1996 gmc 4.3 distributor phase issue need help
- Engine Help!!
- 94 need help
- Mode door will not work
- Extremely wierd hesitation at low rpm
- Surging while A/C is on
- Fuel Pressure Test 1998 5.7
- 6 lug rotor application?
- 1999 express van is back
- AC and Heater Control Problem
- 1982 C model pick-up diesel V8 6.2 L Transmission Reverse.
- 90 2500 Speedo Woes, Reads Nothing, low or Erratic.
- Brake Booster adjustment???
- Changiong the antenna on a 88 Chev PU
- strange vibration??
- timing/ backfire issue
- Just Can't Figure It Out?
- Manual trans fluid
- 1996 K1500 - 4.3L engine is missing - any thoughts?
- 1980 chev with no power
- 350 won't start...sometimes!
- Engine miss(stutter) in passing gear
- Tach
- Speedometer
- 1994 c1500 wont start
- New 98 5.7 stalls when stopping
- 98 Tahoe 5.7 - Compression Test
- Misfire has me puzzled?
- K1500 Maintainance and Efficiency Tuning Guide needed
- A/C problem
- Tail lights
- 94' k1500 starting/electrical problem
- 97 K1500 Z71 Head Gaskets
- 1998 1500 w/tilt ignition cylinder replacement
- '89 k2500 4x4 blowing 4wd fuse
- headlight switch diagram needed
- 96 c1500 4.3 vortec rotates but does not start
- 98 Z71 not shifting
- !!!!!!1997 c1500 5.7L making weird noise!!!!!
- 99 Suburban wont accelerate
- 1995 Chevy 2500 keyless entry
- A/C and Shifting
- '91 C2500 keeps blowing fuse
- Bad lifters,adjusting valves....
- 2001 Chevy 1500
- 88 chevy truck IAC valve replacement
- 97 chevy 1500 rear springs/lift kit
- Fan Connection behind Glove box
- 93 to 94 motor swap
- 350 carb/fuel problems.
- Hydraulic brake booster leak
- 93 1500 4x4 4.3
- 98 Z-71 Problem - Please Help!
- 5.7L misfires
- Distributor
- C1500 tire size?
- 90 454 TBI hesitation and boggs
- No driving rear tail lights?
- 91 GMC K1500 Won't Start
- 1996 K1500 abs problem
- Curios?????
- 4.3L 93 c1500 Misfires and backfires
- Valve issue?
- fan clutch
- 97 chevy p/u tranie problem
- 1983 Custom 10
- 98 z-71 5.7 won't crank with key in start
- 92 Cheyenne need to find tach wire
- parts:GM Performance, OEM, or what
- Brake electrical problem....
- 82 C30 350 vacuum line diagram
- 96 chevy k1500 tranny problem
- black rear bumper
- speed sensitive steering
- 97 k2500 manual tranny
- 1997 k2500 engine replace
- Stalling followed by not starting
- torque specs
- Check Engine Light Codes
- HELP! Knocking engine....!
- Turn signal help
- Strange Problem Help Please
- radiator o'ring
- K2500 5.7L no codes misfire
- slows when driving uphill
- 98 k1500 knock
- Pivot Ball
- Rear axle/bearing clearance
- 97 4WD actuator upgrade
- How Much Glue?
- 1995 Z71 Skip
- 96 chevy wont start
- blower problem
- 1996 Chevy K1500 Key fob programming
- 1990 K1500 Electrical diagnosis
- 94/96 door interchange
- Driving me crazy
- PLEASE HELP!!! 1991 4.3tbi wont start
- Charging system
- can't balance mickey thompson 33" tires
- 94 K1500 Oil pan replacement
- 96 Fuel problem
- 1995 Chevy 1500 1/2 Ton Truck (350, 5.7L)
- problem with crank
- Went muddin in the 95 Cheyenne
- 78 chevy 350 build
- '95 5.7 auto - non working tach & speedo
- wont start
- Code P1870 again, new valve body already
- 1986-old low compression 305
- 1997 vortec 5.7L tranny oil change
- Exhaust on 1997 1500 5.7L V8
- no head, tail, insturment or inter. lights
- 96 Chevy cuts out under acceleration
- 350 vortec timing issues?
- Idle Surging. 1990 chevy 2500
- 93 1500, 4.3L just starting to run rough
- 97 1500 60/40 bench head rests. how do i removed them?
- 1998 chevy truck no sound
- Getting a few more horses out of my 4.3
- 1994 k1500 solid axle conversion
- 1989 Silverado 5.7 Auto, Code 43 Rough Idle
- a/c compressor rebuild
- 327 sbc swap
- O2 sensor locations
- Distributor, P1345 Cam retard offset
- Truck problem
- 94 Chevy 4L60E Transmission Problems
- IP Problems! Help!
- Bypass Knock sensor 89 chevy 350
- New Radiator
- can some one tell me
- Performance Chip installed, Service Engine light wont stop flashing
- rear end swap
- 98 2wd 4.3 dual exhaust
- hm rough cituations
- intake maifold or head gasket?
- Radio wont pick up distant stations
- front brake pads for a 93 dualie
- low coolant light and sensor
- 92 Chevrolet K 1500 battery issues
- Dually rotors
- o2 sensor simulators
- 85 C20 fuel tank replacement
- Question about timing chain and gears
- 92 pickup starting problems
- Electrical diagnosis please
- posi-track for 1991 C1500?
- 1985 k10 headunit wiring
- 93 4.3 with rattle in engine
- Removing armrest on a 97
- 1989 c/k 1500
- 99 suburban 454 p0123 code
- 1982 c-1500 diesel V8 pick-up won't start.
- repair bill question
- 92 starts then stalls when warm only
- '94 6.5 diesel fuel in oil
- very sick 95 5.7
- 98 k1500 5.7 manual gear shift knob
- Free Service Manuals??
- 68 and 88 tranny compatable
- Tranny ?
- 94 TD 4L80E stuck in 2nd
- How to replace 2wd front wheel bearing races
- ck recalls
- 4wd Question
- 96 1500 4.3 misfire
- Car is making a Grinding/whistling noise while driving
- 89 chevy truck power window and lock problems, (HELP)
- A/C issue on a '92 Silverado
- 1988 k1500 4wd acuator question
- Check Engine Light, How to CLEAR
- K1500 Wiring issues
- Hotter Plugs? Foulin' out - 91 K1500 plug help...
- 93 c/k cant get stoplight switch right
- frame width
- 95 Silverado 350 TBI running rich??
- more power
- Power Brake Booster Check Valve?
- 95 1500 4wd brake light switch?
- 94 c1500 silverado chevy truck, won't start
- 92 diesel information request
- looking for a good rebuilt engine dealer
- slow coolant loss
- 1990 K1500 Throttle Issues
- 98 K1500 Vortec 350 occasionally overheating
- 1997 C1500, 4.3L random misfire, at constant speed
- 1997 Z71 problem
- Now here is a tough one..... I am just stumped
- 1988 K1500 Wiper problem
- 93 1500 no cruise control
- Another TBI problem
- Having a very hard time replacing the EVO sensor - need suggestions!
- oil filter adaptor
- Help with 4.3 vortec
- 91 Chevy 5.7 Burnt Plug Wires? H E L P ! ! !
- 1991 Chevy 454 backfires, runs good, backfires, sometimes cycles
- 98 C1500 Possible EVO issue?
- 98 Z71 - Keyless remotes quit working
- TBI to carb
- A little help please!!! 93 k1500 4.3l
- Windshield Washer Problem
- 91 C1500 Starts & dies intermittedly
- 1991 chevy pu, 305
- 1993 k1500 4.3L spits & spudders during drive
