View Full Version : C/K
- '98 K1500 Reverse light on in 'Park'
- Pwr window switch in '85 Chevy K10
- how do I do this?
- 92 c1500 4.3L: stalls - won't idle - no DTC codes
- Will a 2001 disc brake dif fit my 92 K2500?
- chevy SB turbo questions?
- Will all parts fit?
- to rebuild or just repair
- Oil for new engine...
- '98 K1500 overheat and power loss
- Torque Converter and flywheel problem.Help!
- system too lean fault...
- SES light won't go away
- a/c not very cold!!
- running rich
- Steering issues on 74 3+3
- 91 K1500 Interior noises?
- Both heads cracked on 97 Sierra
- m Air gap adjustment compressor clutch
- ticking/rattling sound
- 97 Z71 fuel pump intermittent
- 93 2500 propane converstion
- Tranny
- Wrong shocks on Z71 question???
- 4L60E problem?
- 98 Silverado Won't Start
- Shock ?
- Help! 97 won't start, pulling out hair
- Clutch doesnt release after a few mins
- 88 C10 350 - high pressure oil leak
- Brake light prob.
- AC compressor will not engage
- 94 4.3LV6 HVAC Blower tapping noise
- What should I expect?
- actuator
- From TBI to Carb. ?
- Temp needle pinned
- 88' K1500 loss of power at over half throttle
- 88 cheyenne...timing problems
- 96 5.7 Intermittent stalling-fuel pump?
- 1988 1500 Brake Lights/ Turn Signal Problem
- a/c compressor won't engage
- 89 C1500 A/C Question
- '93 1500 Runnin a little rough
- '93 1500 Clutch/Cruise issue
- headers or manifolds
- 98 7.4 timing and then some
- misfire at idle?
- Slight Electrical Problem
- power steering pump
- a/c compresser
- Spark Plug questions.....
- '98 AC Compressor Not Working
- Alternator/Electrical issues!
- I'm back
- Location and removal of EGR help
- Monroe Sport Edition
- replacing a starter on a 95 c1500 4.3 5 speed
- bolt pattern
- Rotor Button
- 1998 Chevy Tahoe Steering Sensor
- '93 C1500 4.3, 5 speed now has starter issue
- Code 1345 Need some help guys!
- 1989 c1500 brive shaft
- 1986 chevy 3/4 ton
- 1994 Gmc Sierra Suspenstion Question
- 1994 gmc sierra exhaust question
- Air Fuel Gauge on 95 5.7
- Has anyone ever had this problem?
- 89 k3500 454 timing issues
- 1996 5.7 Vortec starting problem
- 89 running badly
- 1999 454 high idle
- 93 2500 clutch ajustment ?
- How do I know what Tranny I have???
- 1996 5.7 fuel regulator
- 98 5.7 Timing all over and misfires
- Transmission swap
- 94 K1500, Erratic instrument cluster
- Bad Gas Mileage!
- Big Block Swap?
- 98 7.4 L spark knock and power loss problem
- Temp sensor
- 99 C1500 classic
- 96 K1500 AC Compressor Question
- 94 C1500 Whistling at Intake???
- Auto Enthusiast
- transmission
- MISFIRE - help, please!
- ecm fuse blowing
- '91 C2500 Silverado seatbelt?
- 350 starter wiring
- 305 & 350 Engine HP Ratings
- Erractic Idle
- 1996 Silverado Z71 4x4 Problems
- help!
- looking for headers
- Truck won't start
- Clunking Rear Axle
- 92 350 Engine Swap
- Soft Clutch on 93 C1500
- OBD-1 sensor readings
- 1992 c/k 1500 2wheel drive swap
- bogged down and sluggish like a wet sponge
- Drivings lights dont work on 99 tahoe
- Alot of Water through muffler and intake mani
- 97 1500, sometimes won't start with key..
- dual exhaust mileage
- Truck Won't Start!!!
- 97' accelation issue
- Instrument Cluster (Mileage)
- 98 silverado projector install help?
- Auto Transport Tips For Trucks And Truck Lovers :)
- 94 Tranny Slipping after Engine swap
- 2-Horsepower Starter (95 Chevy P/U)
- Fuel Gauge stuck past full
- rear end klunk
- Suburban shakes during acceleration
- 98 Power Windows
- Cylinder MIsfire - Experts help, please!
- Transmission Down! Need Help!
- TBI interchange
- 00 Z-71 air condition
- oil amount for 4.3
- 98 silverado 350 to 454 vortec swap
- Grille Makeover.....any Ideas
- Vats / Passlock Bypass Help '98 K2500
- bolt sizes
- Replacing Ball joints
- Front Frame Width
- '92 Silverado shifting issue
- 1992 chevy 1500 fuel vapor canister leaking
- turbo 350 no foward gear
- 94 4.3L Not getting fuel at injectors
- 1995 Chevy Cheyenne Dash Lights don't work
- 94 C1500 4.3 sensor wiring ?
- 1988 305 -350 major problems wont even start!!!!
- perfomance increase question
- Hydraulic winches, any thoughts?
- 95 Chevy 1500..350/5.7(Fire!! Fire!!!)
- Weird Miss??
- now i'm stumped
- '93 C1500 Brakes pulling to the right
- '93 C1500 Reverse Light Don't Work
- '93 C1500 W/T Turn signals flashing fast
- Power issues...
- Intake Gasket
- Eaton Clutch missing teeth
- Noisy Brakes!!!!?????
- 96 ac comp
- ’85 K10 Won’t Idle…
- Is there a sale forum here?
- 99 z71 water pump.... how bad to change?
- Help with Clutch on 95 cheyenne
- brakes
- Dash Vents
- Ignition switch???
- Cruise Control not in control.......
- fix code
- 3rd time water pump disc (where fan clutch bolts on) coming off
- 94 Pickup: Speedometer & Heater Controller Problems
- Stalling Problems
- Lights problem
- Another problem
- Timing a 1998 Chevy 5.7L K1500
- O2 sensor question.
- Brakes Dragging
- oil pressure for 5.7L
- 1997 Vortec 5.7 fuel pump prob!
- 5.7 or 5.0 L?
- ac/ heater problem
- Valve Job, stuck valve
- Speed Sensor (Geared Or Magnetic)
- Turn Signal Problem...Different Than Others
- Drivers Seat Repair - '97 C2500
- Throttle control valve sticking!!
- AC Compressor
- Door Lights
- mileage for a 4.3
- Help!
- still ticking at cold startup
- 1992 ck 1500 5.7 rough idle when warm
- closed loop idle questions
- 1995 454 No start
- 1998 chevy TRANSMISSION problem
- transmission problem
- Can a transfer case chain cause a driveline vibration?
- new truck and want to do hi4
- '92 Chevy Truck AC
- 1989 silverado power doors dont work sometimes
- Frame Parts
- turn/brake signal problems
- 90 k5100 code 44 lean fuel
- 92 K2500 has noisy O2 sensor
- TH 400 problem part name?
- 92 7.4L idle air control
- speedo accuracy
- 1994 6.5
- 94 C1500 Silverado Chevy Overheated
- Gauges
- Runs Great for 15-20 minutes then fuel dump ?
- code 43 est failure
- 454
- 94, surging, help
- '97 305 no start\timing issue when damp..
- new exhaust system 93 z71 ext cab?
- a miss
- 94 3500
- Help!!!
- Engine light code reader
- 97 Silverado knocking at start
- 1996 5.0 won't start cold
- 85 chevy silverado wont crank sometimes
- 98 Z71 4WD Problems - button lights
- 1991 vibration between 50-70mph
- 95 4X4 5.7l Ext cab truck hesitates on hwy
- Bad NEW Steering Gear?
- 94 Silverado Electrical Problem
- TBI Injectors
- Stereo question
- Interior of 85 needs replaced
- Help!!! 94 1500 Won't Start, Maybe Connection Problem
- Long blocks????
- 96 1500 dies when lights are on
- Troubleshooting 101
- brakes..hard brakes
- 88 pinging
- New Intake Gaskets
- Where's the drain plug on a 700r4?
- 1990 5.7L TBI flooding???
- Coolant leak
- exhaust
- valve issues 305
- Coolant leak 97 k1500 350
- Dumb question on Oil Pressure
- 89 C1500 5.0L Backfire
- 90 c1500 305 - failed emmisions High CO
- 97 wont start
- Shifting Head Scratcher.....
- Can you change O2 sensor ?
- '97 305 runs like out of gas
- 91 1500 Headlight/Ignition Warning Buzzer
- 1997 GMC Sierra 4X4 Speedo question?
- diesel motor oil
- Specs
- 1996 6.5 litre Turbe Diesel Intermittent Starting
- Temperature issue
- Problem With 97 Sierra
