Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Chevrolet
Avalanche/C&K/Silverado/Suburban/Tahoe
> C/K |
View Full Version :
C/K
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
92 1500 A/C problem
TBI Swap
1988 shifter
95 chevy 1500 (Orifice Tube)
Squeaky Torque converter or transmission??
99 6.5 diesel inermittent problem
C1500 Lift
1992 and 1990 original service manuals repairs 15$ each
4WD compared to All wheel drive
Buzzing Noise From Engine Compartment
Can't figure out - alternator or fuel pump or something else?
silverado won't start....sometimes
belt/waterpump problem
89 c1500 brake problem
Water Pump????
95 ck 1500 stalling and wont start
Upper Control arm Mounting studs ?
Slight amount of oil atop 350 engine
95 Chevy 1500(4x2) Parking Brake
White smoke at start up
96 K1500 Fuel Pressure
96 K1500 4.3Vortec Won't stay running
93 6.5 turbo diesel hot start problem
one more question - ngk or ac delco plugs
does it hurt the spark plugs to gap a little bigger
1995 1500 couple problems
looking at a 88 CK2500
80 k-5 350 Starting schematic
82 K5 Emissions
82 K5 Emissions
1995 C1500 Wheels
'94 Chevy AC possible problem.
Strange Electrical Problem
Orfice Tube
A/C Wiring Harness
Motor mounts
Vacuum Source for MAP Sensor
94 5.7 found problem - how to fix . first time i ever seen this please help !
which multimeter to buy?
spark plug wires - 94 5.7
87 chevy questions several
Torsion bar cam lifts
Need Opinions
Trailer Brake Controller Problem
1994 silverado 5.7 - should i set time at 0 degrees or advance the time any
350 motor swap
Optimum RPMs
454 ss 90-93
94 silverado 5.7 - miss came back !!
Gear Ratio
hood release cable broke
1995 K1500 light throttle mis
Ignition Switch Replacement
81 Chevy only goes in 4 wheel low
has anyone ever replaced a fuel gauge?
1981 C10 dies when I let off the gas
94 miss at idle finally fixed !!!!!! found problem
1994 chevy c/k ac compressor replacement
Really Bad Shimmy
Leveling coil spring spacers for 2WD trucks
1990 Chev Sport 305CID Short Box Missing Too!
My 90 Silverado Stepside Body Lift Prob.
broken brake lines
1994 Intake Gasket Replacment
any opinions on this
Rear window in 95 C1500
Brake problem
1994 5.7 - bad miss at idle please help
95 6.5 diesel brake light problem
still a fuzzy fuel gauge
Changing instrument cluster need help
nv3500 help please 4x4
Need help troubleshooting AC
shift kit in a 93 1500 cheyenne truck????????
'98 5.7 Misfiring
Breaking in a new Headgasket
454
Passenger rattle at high speeds
Rattle in Drive
Street Truck
Pitmen Arm
U-Joints
EST location to set timing
transmission snapping end off
new tranny
ENG 1 Fuse Headach
Smashed Steering Column
My 95 Z71 has many problems HELP!
help 92 chevy 454 idle problem
92 Chev Rear ABS wiring
brake problem
Radiator 250 or 305/350
1989 Chevy C1500 Idle Problem
Door panel removal on a 97 Silverado pickup
Bad Coil again / 85 Chevy 4.3L
air bags for a 4wd?
1998 Chevy 1/2 ton pick up
90 5.7 wont hardly run, rich
Leaking Coolant
Help: Heat/AC Flow Problems!
92 K 1500 Vacuum Hoses
AM Radio hum...
headers
Rebuilt transmission still having problems
95 chevy 4.3 283 conversion tranny options any suggestions
94 K2500 6.5 Glow Plugs Inop
98 Chevy Alarm system problem
Shocking Problem!
Possible U Joint Problem & TPS Question
brake lights
glove box knob
Project K1500
Any other 6.5 L diesel people out there?
z71 tranny trouble
350 engine
95 throws error code 35
Oil Pressure Drop & Fluctuation???
Cars after 1987 Metric?
93 runs rich, hesitates and keep getting codes
1990 C1500 No Power to Fuel Pump
moonvisor
moonvisor
Truck Wont Move !!!!!!
no spark
89 350 Valve Adjustment
Transmission Problem 1997 C2500 No Overdrive
94 Chevy Silverado Smokes when started
1989 1500 silverado window trouble
79 rear brake conversion
question about 1973 454
93 1500 half ton
Lucas Oil Stabilizer in my 95 Z71
Oil pressure
97 Silverado 1500 A/C Weak
98 Chevy Silverado Idle problem, Does Not Idle well, until warmered up
I have a 91 K 3500 with fuel pump run on
Tools - pt. 2
Question about timing
Speed-o-meter problems
tranny fluid change
horsepower/torque 1995 cheyenne
98 Chevy Silverado Fuel Pump goes in and out. Also won't idle(tries to die)
Colder plugs for 7.4?
Power Steerin Gets Real Hard To Steer !
Headlight Problem
89 k1500 Fuel Gauge Problems
1998 Silverado 5.7L Fuel Metering Body
305 Dipstick length 92
Heat Issue!
97 350 Surging
96 k1500 5.7 won't start
Cruise Control INOP - 03 Sierra
94 350ci 4x4 manual tranny swap
wiring diagram?????
what rims will fit?
98 Silverado Keyless remote problems
1988 K1500 5.7 won't start, again!
91 wiring
vibration -Harmonic Balancer?
'92 Temp Sensor
Trouble removing driveshaft on an 87 Silverado
235 c.i. and small block bellhousing bolt pattern? mounts?
A little shimmy
head gasket??
electrical or grounding problems?
Noise when stopped
94 K1500 Runs Rough When Cold
Replacing Rear Speakers in 95-98
Rust
96 vs 98 power steering changes?
82/86 Sierra C15 Carb trouble
Just turned 100k - should I change oils?
Noise from some a/c related part
wiring
86 GMC C1500 V-6 to V-8 Swap
86 Silverado won't turn over- please help!
4l60e Help
winshield wiper arms 98 silverado
Oil pressure
Rear End Locks Up When Turning (why)
Need a/c compresser 1995
oil pressure sending unit
1994 c/k 1500 4x4 front axle nut size
Need some information...
Sensor Question
instrument cluster wont light up. HELP!!!
91 1500 AC/Heater Floor To Face Problem
Which one should I do?
94 performance help
actual vehicle weight
Prndl Light
E-85 conversion question
"93" 4L80E home rebuild roadblock!!
4L60E shudders before downshift
1995 K3500 speed/cruise problem
Heater core removal 1995 K-3500 with Air
Help? Project Sierra Oil Spruing
Autotrac? Do I have this in my 95 K1500?
Silverado Passenger door problems!!!!
1988 K1500 4X4 Front Axle Won't Engage
Dealer can't even figure it out! What now?
The Float on my Carburetor Sticks
94 1500 4x4 wheel bearings
95 C1500 wont start
Headers
Brake Diagram
Trying something new and ned advice
Headers For My Trucks
FS: 1990 Silverado Shortbed 4x4 5.7L
Loose Steering Questions
Brakes? Ujoints?
Brakes? Ujoints?
HELP with my starter motor
oil pump
Oil Pressure
Missing
How do you know if a fuel pres reg is bad?
Heating issues
How Do I Retrieve Transmission Codes
few questions aboutm 1990 to 1993 engine swap
Timing, sensors, what the?? I'm stuck
fuel delivery problems
installing an alarm
82 to 89R Chevy truck cab Swap!!
93 Silverado Floor Vibration
Front Wheel Bearing Adjustment
teach me about (manual)FLYWHEEELS
Milky anti freeze in the overflow tank
Oil pan
Shifting Problems While Towing
changing air filter in 97 cheyenne
Looking For Wheels For your CHEVY???
Looking for some parts
EFI conversion
sputtering
Distributor pickup coil question
CD Player Removal 95 Tahoe
loading up
loading up
1989 Silverado 454 ECM Bad Ground?
8 foot box conversion to 6
Some d-bag sold me a piece of crap
Soft brake pedal
How do you?
1991 C1500 Steering Column
Electrical Problem
97 transmission noise
Web
AF
