View Full Version : C/K
- Air Filter housing for a 5.7 Vortec 96-98
- 92 K2500 -- Windsheild nozzles
- 1997 stuck in 2nd gear
- 97 C1500 Daytime Running Light problems
- 1998 chevy1/2 ton 4x4 missfire 5.7 po300
- windshield wiper circuit board
- Will 285/75/R16 fit under the bed as a spare on a 98 Z71?
- 350 to 454 engine swap
- 95 K 2500 454 intermittent ignition start problem
- 1994 Chevy Truck windshield wipers/dashlight/running lights not working
- 1997 Chev Silverado want start cold
- Temerature Gauge Not Working
- Death Wobble
- transmission question...
- 1985 silverado
- Switching 454 cab out for 350 cab
- 1993 K1500 Misfire?
- 1988 Chevy k1500 missing/sluggish
- distributer ??????
- 98 K1500 will not start(just Clicks and Clicks and Clicks!!
- 1994 v6 4.7L 4x2 conversion to 4x4
- Jetchip Air mass Sensor
- a/c - heat troubles
- Minor Electrical Quest.
- Heater Problems
- rough idle
- 95 K2500 blower motor resistor
- 96 fuel pressure specs?
- Please help, unusual no-start condition on '97 Vortec 5.7L
- Add Methanol To Fuel?
- 1991 Silverado y-pipe issue
- 1998 K1500 Starts and Dies- MAP Code
- 92 454 throttle position sensor
- Question about EVO Sensor on 1996-1999 C/K GM trucks
- heater stopped working
- code 32
- No Heat
- 97 Silverado won't start
- Running Board Advice..
- muffler location ?
- 92 Chevy Silverado 350 won't start after tuneup
- locks not cycling
- 1998 5.7L vortec ( no start, no fuel pump buzz)
- low rmp idle idles rough
- Bad upper intake manifold on 1998 305 vortec?
- 96 k1500 front brake pad wear question
- A/C Control panel buttons
- 1997 Vortec 5.7L fuel pressure regulator location??
- Replacing rear turn signal bulb...
- 1996 K1500 cargo light wiring
- 1985 K10 need new transmission
- Replacing th400 w/ th350
- 92 Noise in drivetrain
- oil in the intake
- Heater Core Question
- 1996 C/1500 Chevy temp guage doesn't work
- 95 Silverado Shifting? HELP
- 95 Z71 shifting?? HELP
- 1986 K5 Blazer having problems
- 93 Cheyenne heater issues...
- 1996 1500 ABS issue
- need some help please
- chevy wont start
- Fuel Mileage Improvement
- Engine needed
- 1992 Cheyenne. Defrost acuator wont direct air.
- should i buy
- Engine bogs down when I get on
- Tcase
- 99 K1500 rough idle
- HELP! I think new flowmasters are on wrong!
- 1997 c3500 7.4 3500 hard start
- 98 Chevy Z71 Brake Lights Dont Work
- SpeedOmeter gear
- Ball Joints
- Having trubble starting engine
- question
- how much is this truck worth?
- Passenger Air filter
- 4wd circuit
- Instrument cluster change
- 1992 C-1500 4x4 5.7L Tranny?
- 93' 1500 Turns over, won't start
- Front end shakes in 4x4
- How loud will the truck be?
- 4.3 vs 4.3 vortec
- 1992 C1500 350
- Headlight adjustment?
- 2001 454 crank sensor
- Need New Tie Rods
- 94 1500 Stalling
- Front End!
- Riding Rough
- 350 Tbi Egr?
- Too much fuel pressure
- Gear Ratio
- 1989 4.3 1500 transmission
- 98 chev died and wont start
- headlights dont work.
- fuel gauge flickers
- 1999 Chevy Z71 ExtCab SWB metallic noise when accelerating
- Shock Absorber
- 1997 C3500 7.4L P1345 code
- Clunk in Steering
- 87 k10 Hard start warm
- rear oxygen sensors
- 1998 V6 5-speed ext cab questions
- Rear window glass
- Transmission leaks BAD only in reverse??????
- 98 K2500 6.5L Turbo Diesel, Died
- hazard weirdies
- TBI 454 camshafts?
- 98 k1500 fuel pump problems
- Replacing front axle shaft seal
- 78 400 timing specs?
- Automatic Hubs for 84 K20
- heavy 2500 specs
- turning issue- (front end?)
- 1998 C1500 No Heat
- 98 Chevy 3500 1 ton dually diesel turbo dying
- slight rust on cab corner
- 1997 C1500 low fuel indicator light?
- 4x4 fender flares
- Modulating Vlv Location
- ?'s about engine swap
- 93 cheyenne 4.3L bogging, backfiring
- 1989 V6 Running Lights
- What's the sound???
- Turning off ABS light?
- 1994 1500 Front End Alignment Question
- Replacing door window seals
- Valve Seal O-ring
- Location of BTSI
- 97 chevy wont start!!!
- 84 c-10 305 cranks, won't start
- 93' c1500 4.3L squeaks at low rpm
- replaced a 305 with a 350
- 1987 CHevy won't start unless primed
- Cylinder misfire and other probs
- ac and heater problem
- 350 very sluggish until engine warms up
- 1994 Chevy temp guage doesn't work
- 1990 runs 15 min then stops till cooled off
- a bit sluggish
- Which years...
- 2004 2500 noise under dash
- Interior Trim parts
- 92 454 ignition cuts out
- ac heat controls and display not working.
- 94 silverado heater core
- No start: Fuel pump runs but 50psi
- Idle miss
- 96 k1500 brake problem
- stoplight switch
- Fuel Mileage Increase?
- '95 C1500 a/c evaporator leak
- Engine Possesed
- 94 K2500,, 6.5 no running lights and trans in limp mode
- Trouble Starting
- wierd sensor setup
- 95 possible motor swap
- 1998 jeep grand cherokee laredo..300..strt line 6
- 99 1500 need help
- 88 Silverado dash lights going crazy
- I Need Heat
- Replacing brake rotors on a '00 K2500
- 83 6.2L diesel swap
- 2000 vortec 4.3 swap
- 350 new OE engine how much performance?
- blower motor 1985 silverado doesn't work all the time
- tranni no overdrive and starts in 2nd gear
- 4.3 low on power... ideas???
- T-Body!!!!! Help!!!!
- 93 2500 radio problum
- 1998 5.0 stalls out
- gas tank 72 chevy
- '93 C1500 350 TBI Specs
- problems with my 1971 chevy truck
- 98 5.7L Alternator whine and low voltage
- 93 4.3 extreme high idle rpm
- 1994 1500 Power Steering Issue
- 96 4.3 knocks
- Cranks More
- Transmission Fluid Level
- question 4u gear heads
- starter wont turn, fuel pump wont turn on, guages dont move
- 95 runs bad, no codes
- '98 Silverado Climate Control Parts?
- 96 k1500 o2 sensor codes
- 2003 blower motor quit. speed resistors?
- 1972 C10, engine/trans swap
- Ht383e
- 1994 C1500 Blower motor
- Temp sensor changed, new problem now
- Lift Gate
- 98 1 ton code p0175
- 1994 c/k Stop Light Switch Location
- Swapping 4.3's
- need dual battery setup help please
- Calling all tranny experts. 4l60e
- '98 K1500 - AC compressor stays on...
- Replacing Lower Ball Joints
- roof panel noise
- 95 Chevy PU (High Idle)
- 1994 C1500 4.3liter Injector Pulse
- 94 5.7L Idle Miss/Stall-for the experts
- tire size
- aux. tranny cooler
- Bewildered
- Leveling kit
- 1997 a/c question
- What Kind of Shocks?
- 98 work truck
- Won't run
- Power Steering went out!
- What is a 94, Heavy Duty 350 engine ?
- 1981 Chevy 1500 Doesn't Fire!!!
- 97 C/K No power to fuel pump...
- 1997 yukon light throttle hesitation
- Catalyst System Efficiency Below Threshold (Bank 1)
- AC/Heater control blackout, fuse blowing
- 92 350 Borderline Emissions
- Suggestions?
- 4x4 Not Dis-Engaging
- Ignition wires pop off
- 4L80 transmissiom
- Performance Chip- Power and Fuel Economy
- 1997 dash pad
- 1998 Silverado - white smoke from engine NOT tailpipe
- Spark Plugs
- 97 chevy truck evaporator core removeal
- Surging while braking
- 98 K1500 Front Susp. Question
- 1997 C2500 - little cooling from A/C
- 88 GMC 5.7l cuts out / diesels
- 77 c10 to a Pontiac Engine swap
- 1986 305 emission question - new thread
- 94 Chevy Silverdo stalling
- 94 Chevy Silverado stalling
- 4.3L Towing Question
- 97 5.7L wont start
- Fuel tank
- no fuel spray on start
- 87 1/2 ton 4x4 stalling
- 1992 Chevy C Pickup No Defrost
- sounds like starter dragging when warm
- ac vent controller on my 1984 Chevy Pickup
- Electrolysis Eating Heater Cores
- Thanks for the advice guys!!!!
