View Full Version : C/K
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. 95 chevy brake booster problem??
  2. 95 chevy brake booster problem??
  3. Oil Pump
  4. no backup lights on 4.3 manual
  5. 88 TBI tail lights and remote start don't work after new fuel pump
  6. temperature
  7. coolant in oil question
  8. hidden rust and lamp replacement question
  9. 1997 C1500 Power Steering question
  10. steering wheel locked
  11. engine surge
  12. 89 350
  13. 89 350
  14. transmission winding
  15. 2005 4door chey 1500 Z71 rear end hop
  16. Ford to Chevy.... "saw the light ! " -questions.
  17. wierd feeling in the front suspension
  18. Headers
  19. K2500 4L80E transmission whine
  20. having a problem between 50-65 miles per hr with a miss or trans trouble .
  21. Lift parts for 98 z71
  22. Fast Idle problem
  23. 98 k1500 starts and dies
  24. Dead Fuel Pump
  25. 1990 k 1500 nv 3500 4x4 5spd HELP PLEASE?
  26. 1989 350 Inj just sprays fuel
  27. starter bolts
  28. 1982 Chev Diesel 1/2 Ton Pick-Up with Cherry Bomb Mufflers
  29. Supercharger for my 95 5.7L Z71
  30. hypertech power programmer III
  31. W/T to Silverado Grille Conversion *PICS*
  32. interchangeabe dash ?
  33. 2000 gmc c3500 old body long cranking/starts hard
  34. motor swap question
  35. Ignition Problems...
  36. 95wt water pump hose?
  37. 6.5 trouble
  38. water heater pipe nipple thread count and size?
  39. rear wiring
  40. 5.7L vs 4.8L
  41. 98 Z71 5.7L losses power at 3000rpm
  42. 1990 Chev truck GM 5.7 EFI to a 383 EFI?
  43. 94 ac problem
  44. 1988 4.3 fuses
  45. Weird Timing problem
  46. 1997 Tahoe transission failure @ 135K
  47. What is proper fuel pressure for 1990 454 TBI?
  48. 93 4.3L V6 low/no oil pressure. already changed pump. Help please!
  49. 98 4.3l high idle
  50. replacement shocks for 1998 z71?
  51. '89 K stalling, not wanting to start after (LONG)
  52. headlight aiming and removal help
  53. Polishing/Cleaning scratched speedometer lens
  54. what to do about the oil cooler lines???
  55. 454ss
  56. heater vent no work?
  57. 7.4L ruff running (1997) Injectors?
  58. Pictures of my truck
  59. Looking for a 92 454ss
  60. Suggestions for 91 chevy 350
  61. Radio troubleshooting
  62. Max Tire Size
  63. 1988 1500 idles rough
  64. Speedo Problem
  65. belt shakes and makes noise when AC is on
  66. 4L60E Problems
  67. if i had a 383 stroker......
  68. finding an aftermarket elecrtical fan
  69. Fuel Pump/Relay- Help!!
  70. Low power when warm for 1 minute after starting
  71. (Heater/AC Fan) No Air
  72. OBDII code P1870?????
  73. 1990 C1500 2wd Steering Grease Boots/Fittings
  74. 88 K1500 Rear Driveshaft question
  75. Strange problems with door lock
  76. Wheel bearing for '97 Z71
  77. transmission problems????
  78. '79 chevy front end wiring problems
  79. Tranny-won't take off in drive/overdrive
  80. 1998 z71 wiper problems
  81. '96 K1500 - Rev's at Idle
  82. '96 K1500 - Hard to start after sitting - Fuel pump?
  83. Running water sound
  84. downshift???
  85. 1965 GMC pickup with 1988 chevy pickup parts
  86. Exterior Trim Removal - '88 - '98
  87. 99 c2500 hard start and rough idle ....HELP!
  88. engine missing
  89. Radio/speakers stopped working
  90. WAY OFF SUBJECT, but worth a look
  91. Need A/C Help
  92. Alternator upgrade wiring
  93. 1995 C1500 windsheild wiper/radio problem. Short?
  94. misfire
  95. Remote Starter for '96 K1500
  96. '96 K1500 "slips" or "jumps" in OD.
  97. White smoke only on startup with low coolant
  98. tranny trouble
  99. Idles rough, lose power when reaching operating temp
  100. Idle rough loses power when hot
  101. Rust
  102. How to replace rear speakers?
  103. still having a problem with plug wires fire running up and down them
  104. '97 C1500 Electrical Problems
  105. A/C Kaput on 97 c/k
  106. horsepower and torque specs
  107. '96 K1500 radio size
  108. Brake parts help?
  109. transmission slipping????
  110. Multiple Battery Wiring
  111. 88 Chev Truck 2wd 4.3 no start
  112. emissions trouble
  113. Cowl Induction Hood
  114. wacky dashboard
  115. front shimmy when apply brakes
  116. '91 c2500 350 AC and Alternator questions
  117. national Auto service review website idea
  118. 92 1500 A/C problem
  119. TBI Swap
  120. 1988 shifter
  121. 95 chevy 1500 (Orifice Tube)
  122. Squeaky Torque converter or transmission??
  123. 99 6.5 diesel inermittent problem
  124. C1500 Lift
  125. 1992 and 1990 original service manuals repairs 15$ each
  126. 4WD compared to All wheel drive
  127. Buzzing Noise From Engine Compartment
  128. Can't figure out - alternator or fuel pump or something else?
  129. silverado won't start....sometimes
  130. belt/waterpump problem
  131. 89 c1500 brake problem
  132. Water Pump????
  133. 95 ck 1500 stalling and wont start
  134. Upper Control arm Mounting studs ?
  135. Slight amount of oil atop 350 engine
  136. 95 Chevy 1500(4x2) Parking Brake
  137. White smoke at start up
  138. 96 K1500 Fuel Pressure
  139. 96 K1500 4.3Vortec Won't stay running
  140. 93 6.5 turbo diesel hot start problem
  141. one more question - ngk or ac delco plugs
  142. does it hurt the spark plugs to gap a little bigger
  143. 1995 1500 couple problems
  144. looking at a 88 CK2500
  145. 80 k-5 350 Starting schematic
  146. 82 K5 Emissions
  147. 82 K5 Emissions
  148. 1995 C1500 Wheels
  149. '94 Chevy AC possible problem.
  150. Strange Electrical Problem
  151. Orfice Tube
  152. A/C Wiring Harness
  153. Motor mounts
  154. Vacuum Source for MAP Sensor
  155. 94 5.7 found problem - how to fix . first time i ever seen this please help !
  156. which multimeter to buy?
  157. spark plug wires - 94 5.7
  158. 87 chevy questions several
  159. Torsion bar cam lifts
  160. Need Opinions
  161. Trailer Brake Controller Problem
  162. 1994 silverado 5.7 - should i set time at 0 degrees or advance the time any
  163. 350 motor swap
  164. Optimum RPMs
  165. 454 ss 90-93
  166. 94 silverado 5.7 - miss came back !!
  167. Gear Ratio
  168. hood release cable broke
  169. 1995 K1500 light throttle mis
  170. Ignition Switch Replacement
  171. 81 Chevy only goes in 4 wheel low
  172. has anyone ever replaced a fuel gauge?
  173. 1981 C10 dies when I let off the gas
  174. 94 miss at idle finally fixed !!!!!! found problem
  175. 1994 chevy c/k ac compressor replacement
  176. Really Bad Shimmy
  177. Leveling coil spring spacers for 2WD trucks
  178. 1990 Chev Sport 305CID Short Box Missing Too!
  179. 1990 Chev Sport 305CID Short Box Missing Too!
  180. My 90 Silverado Stepside Body Lift Prob.
  181. broken brake lines
  182. 1994 Intake Gasket Replacment
  183. any opinions on this
  184. Rear window in 95 C1500
  185. Brake problem
  186. 1994 5.7 - bad miss at idle please help
  187. 95 6.5 diesel brake light problem
  188. still a fuzzy fuel gauge
  189. Changing instrument cluster need help
  190. nv3500 help please 4x4
  191. Need help troubleshooting AC
  192. shift kit in a 93 1500 cheyenne truck????????
  193. '98 5.7 Misfiring
  194. Breaking in a new Headgasket
  195. 454
  196. Passenger rattle at high speeds
  197. Rattle in Drive
  198. Street Truck
  199. Pitmen Arm
  200. U-Joints
  201. EST location to set timing
  202. transmission snapping end off
  203. new tranny
  204. ENG 1 Fuse Headach
  205. Smashed Steering Column
  206. My 95 Z71 has many problems HELP!
  207. help 92 chevy 454 idle problem
  208. 92 Chev Rear ABS wiring
  209. brake problem
  210. Radiator 250 or 305/350
  211. 1989 Chevy C1500 Idle Problem
  212. Door panel removal on a 97 Silverado pickup
  213. Bad Coil again / 85 Chevy 4.3L
  214. air bags for a 4wd?
  215. 1998 Chevy 1/2 ton pick up
  216. 90 5.7 wont hardly run, rich
  217. Leaking Coolant
  218. Help: Heat/AC Flow Problems!
  219. 92 K 1500 Vacuum Hoses
  220. AM Radio hum...
  221. headers
  222. Rebuilt transmission still having problems
  223. 95 chevy 4.3 283 conversion tranny options any suggestions
  224. 94 K2500 6.5 Glow Plugs Inop
  225. 98 Chevy Alarm system problem
  226. Shocking Problem!
  227. Possible U Joint Problem & TPS Question
  228. brake lights
  229. glove box knob
  230. Project K1500
  231. Any other 6.5 L diesel people out there?
  232. z71 tranny trouble
  233. 350 engine
  234. 95 throws error code 35
  235. Oil Pressure Drop & Fluctuation???
  236. Cars after 1987 Metric?
  237. 93 runs rich, hesitates and keep getting codes
  238. 1990 C1500 No Power to Fuel Pump
  239. moonvisor
  240. moonvisor
  241. Truck Wont Move !!!!!!
  242. no spark
  243. 89 350 Valve Adjustment
  244. Transmission Problem 1997 C2500 No Overdrive
  245. 94 Chevy Silverado Smokes when started
  246. 1989 1500 silverado window trouble
  247. 79 rear brake conversion
  248. 79 rear brake conversion
  249. question about 1973 454
  250. 93 1500 half ton
